07-27-2010 08:53 PM - edited 03-21-2019 02:48 AM
I have been told that the UC500 platform supports extension mobilty, yet no where can I find documentation nor does SMP Pro Support have anything either, Can someone please produce a step by step guide to configure this? I could really market this in my territory as most of my clients are in the healthcare verticle. Hoteling is a concept many of my customers have never thought of and this could be a great discussion starter.
07-28-2010 03:09 AM
EM will be CCA configurable in The fall release, or let me carefully
say that is the current plan. We have received this feedback frommany
Partners like you. So for uc540 and uc560, that would be the way to
have it supported.
Between CCA 2.2.5 (next 2-3 weeks look for it) and The next (fall
release) we really closed the GAP between what you need and what CCA
can deliver,
On uc520, you can consider out of band cli, which I believe you can
find in this community if you search for extension mobility?
On Jul 27, 2010, at 11:54 PM, "Bill.Lopez@Strategic-VA.com"
12-23-2010 05:56 PM
Hi Steve,
Have there been any status updates on when EM will be available on the 540/60?
12-23-2010 06:36 PM
Extension mobility is now supported using CCA 3.0 on the UC540/560
You will need to update to the latest software pack for it to work
Have a great night
Key features and enhancements:
*- Extension Mobility
- Floating Extensions
- Floating Voicemail
- Voicemail Notifications sent to phone or email
- T.37 Fax to Email
- Single Number Reach (SNR) timeout settings
- Call Park timeout and recall settings
- Call Hold audible alert settings
- Detailed FXO (analog) trunk settings
- Live Record Beep Tone settings
- Improved Bulk User and Phone Data Import
- Static NAT Mapping
- Simplified UC500 Localization, Software Installation, and Upgrade
- Upload and Download files to UC500 Flash
- Drag-and-Drop Phone Upgrades
- Enable or Disable Network Polling
- Telephony Configuration Menu Changes
12-23-2010 07:18 PM
THANKS!
