02-29-2012 06:22 AM - edited 03-21-2019 05:26 AM
Hello all this is my first post in cisco support community and ofc always there is a problem that needs fixing!
The problem is with the ISM inside the UC520.
Suddenly unity express stopped working.
From what i found the problem is with the installation on the flash of ISM.
For an unknown reason the file system is corrupted.
I suspect a failed flash.
IUC520#service-module integrated-Service-Engine 0/0 status
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is failed
Service Module heartbeat-reset is enabled
Service Module status is not available
I tried to make a new install utilizing the boot-helper using a tftp and ftp server like it is described at cisco's site.
I didn't have any problems with the procedure but the installation stops at some point and a lot of gibberish msgs pop up at the command line.
Yes i used the correct files of unity express for uc520 and i tried different versions.
Every time i have the same problem
So, i need info about where to get a new flash for ISM (what type of CF exactly), if there is such thing and how to properly format it so i can make the clean installation.
Every information will be very much appriciated !!
D.V.
Here is what it spams at my CLI and then the installation is freezed
add_file /mnt/dwnld/pkgdata/cue-vm-full-k9.uc500.8.0.6.prt1 6 /mnt tgz
------------[ cut here ]------------
Oops: Exception in kernel mode, sig: 5 [#1]
NIP: c0096a68 LR: c0096b60 CTR: 00000000
REGS: de115c40 TRAP: 0700 Not tainted (2.6.22.10-vs2.2.0.5-cisco-freddo)
MSR: 00029032 <EE,ME,IR,DR> CR: 20000448 XER: 00000000
TASK = d1f53790[2454] 'sutar' THREAD: de114000
GPR00: 00000001 de115cf0 d1f53790 c3b0e200 c982c170 e1011014 0b2c4840 00000000
GPR08: c9862ffc c9863000 24000082 00000000 0000acfe 1003b3b4 1001ee00 10030000
GPR16: 10030000 10030000 1001e30c de115dbc 1003c95a 00000000 c980c258 000041fd
GPR24: 10030000 de115e58 c3b0e200 e1011000 00000005 00028000 c982c170 c3b0e200
NIP [c0096a68] reiserfs_cache_bitmap_metadata+0x70/0xc8
LR [c0096b60] reiserfs_read_bitmap_block+0xa0/0x118
Call Trace:
[de115cf0] [c0096b0c] reiserfs_read_bitmap_block+0x4c/0x118 (unreliable)
[de115d10] [c0097558] reiserfs_choose_packing+0xe8/0xf8
[de115d30] [c00a4864] reiserfs_new_inode+0xe0/0x6f4
[de115e50] [c009ef68] reiserfs_mkdir+0xcc/0x20c
[de115eb0] [c005f8b4] vfs_mkdir+0x9c/0xc0
[de115ed0] [c0062384] sys_mkdirat+0xbc/0xf4
[de115f40] [c0003dfc] ret_from_syscall+0x0/0x38
Instruction dump:
409e0038 a1250002 3908fffc b0e50000 39290020 b1250002 81240014 7f884840
409cffd0 a0050000 7c000034 5400d97e <0f000000> 4e800020 2f8bffff 41beffa8
Badness at c0016aec [verbose debug info unavailable]
Call Trace:
[de115a10] [c000a1e4] show_stack+0x44/0x1ac (unreliable)
[de115a50] [c00e3d2c] report_bug+0xa0/0xa8
[de115a60] [c0004c3c] program_check_exception+0x8c/0x494
[de115a80] [c0004444] ret_from_except_full+0x0/0x4c
[de115b40] [00000001] 0x1
[de115b80] [c00048e0] nonrecoverable_exception+0x0/0x4c
[de115b90] [c00049d8] _exception+0xac/0xc8
[de115c30] [c0004444] ret_from_except_full+0x0/0x4c
/bin/extract_pkg_file.sh: line 133: 2611 Broken pipe dd ibs=1M bs=1M cbs=1M count=$npasses 2>/dev/null
/bin/extract_pkg_file.sh: line 133: 2613 Broken pipe dd ibs=$lastblock bs=$lastblock cbs=$lastblock count=1 2>/dev/null
/bin/install_files.sh: line 860: 2452 Done extract_pkg_file.sh $pld $idx
2454 Trace/breakpoint trap | ${SUTAR} -C $dst -xoz $file
Solved! Go to Solution.
03-01-2012 07:17 PM
Hi Dimitrios,
This almost looks like a kernel panic
Here is my suggestion, power the entire unit down wait about half hour to left the compact flash card cool down (Yes it does get hot ) and then power it back up, if you can leave it for an hour even better.
Then attempt to do a OS upgrade to it, and hopefully before it gets too hot again.
This may bring it back to life, but I warn you that it will be a temporary thing before it fails again.
If the system is not under any support contract and there is no interest in getting one, you can get a high quality Transcend CFC and use that for the CUE, the tricky part is getting the CUE image onto it
Cheers,
David.
02-29-2012 09:22 AM
Something similar happened to me a few months back. I had the same messages that you received. Unfortunately, your CUE module is beyond repair. If you have SMARTnet on the device, get this unit replaced. I don't think there are replacement internal flash cards for these devices.....
03-01-2012 07:17 PM
Hi Dimitrios,
Cheers,
David.
03-06-2012 11:40 PM
thank you both for your replies.
Kernel panic was the problem due to faulty cf card.
The cooling off method didnt work.
I change it with a new one and the clean install worked .
After that, restoring the backup was very easy and the system is now up and running like before.
It helps also if you have the wav files and the AA scripts backed up.
All these years playing with cisco equipment first time i had problem with a flash card.
There is a first time for everything.
06-21-2012 05:12 AM
Hi Dimitrios,
I have exactly the same problem with my UC520. Would you share what kind of flash card do I need? From where can I buy it?
Thanks!
06-21-2012 06:48 AM
Hello dizma
You can use any brand of CF card. Better to use Cisco.
I used a transcend 1GB that i had spare and since it worked i didnt change it to a cisco one.
The cost is about 15-20$ and you can buy it from any online shop that sells CF cards.
The CF type is a standard so you will not have i think any compatibility issues.
06-22-2012 02:01 AM
Thanks a lot!
