07-21-2009 02:47 PM - edited 03-21-2019 01:21 AM
Hello again,
Is it possible to set up the UC520 such that a user can login to any phone and get a specific extension?
Thank you.
07-21-2009 02:49 PM
We have a feature called extension mobility that does just that.
https://supportforums.cisco.com/docs/DOC-9684
Also, check the out of band guide to make sure your changes won't cause any other problems.
07-21-2009 03:14 PM
Steven.... thanks!! I thought extension mobility was only for remote users.
CCA caused a lot of issues with my SIP trunk. I was advised by the Cisco TAC support to use only CLI and CUE. I made the changes in CUE but can't get to use the dummy MAC. Will this work without the dummy MAC? Thanks.
07-21-2009 03:37 PM
07-21-2009 03:40 PM
Marcos.... Sorry... I don´t have a case opened for this issue. I was referring to other issues that TAC support has helped me with.
