10-26-2010 07:25 AM - edited 03-21-2019 03:11 AM
Hi Guys,
I'm connecting IP Phones CP-524 to a UC520 with software pack 8.0.4. and the phones can not register, the phones shows in the screen the following information:
Downloding XMLDefault
Any of you had expirience this problem?
10-26-2010 07:31 AM
I have seen this before but not on the CP-524. If I recall, the phone was having trouble finding it's phone load.
I believe i just reset the phone to factory defaults (manually) and off she went and started to grab the right phone load.
10-26-2010 07:33 AM
I already did that but doenst work.
10-26-2010 11:41 AM
Here are some displays that may help you. I have CP521 and CP524 on a UC560 and running SWP 8.0.4.
I manage this system only with CCA 2.2.5.
I can do some CLI displays for you to confirm...
UC_560#dir flash:/phones/521_524
Directory of flash:/phones/521_524/
5 -rw- 892511 Aug 23 2010 18:30:56 -04:00 cp524g-8-1-17.bin
UC_560#sh telephony-service
CONFIG (Version=8.0)
Version 8.0
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.1.1.1 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
service dnis overlay
service dnis dir-lookup
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.4SR1
load 7925 CP7925G-1.3.4SR1
load 7931 SCCP31.8-5-3S
load 7936 cmterm_7936.3-3-20-0
load 7937 apps37sccp.1-3-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-3S
load 7941GE SCCP41.8-5-3S
load 7942 SCCP42.8-5-3S
load 7945 SCCP45.8-5-3S
load 7961 SCCP41.8-5-3S
load 7961GE SCCP41.8-5-3S
load 7962 SCCP42.8-5-3S
load 7965 SCCP45.8-5-3S
load 7970 SCCP70.8-5-3S
load 7971 SCCP70.8-5-3S
load 7975 SCCP75.8-5-3S
load 521G-524G cp524g-8-1-17
UC_560#more system:its/XMLDefault521G.cnf.xml
UC_560#
UC_560#more system:its/XMLDefault524G.cnf.xml
UC_560#sh run | inc tftp-server
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
10-27-2010 07:43 AM
Hi Steven,
I was using SWP 8.0.4 with the default config, I will do your recomendation in my lab with the SWP 8.04 , but the thing that I did in the customer was to put the software pack 7.0.4 and the phones comes up without problem.
Thanks for your help.
10-26-2010 02:14 PM
One more thing I would check before worrying about having the correct load statement, tftp-server statement, and xml file.
What is the IP address you are receiving on the phone? If the IP address is on the data Vlan, the DHCP server for the data side will most likely not have the option configured to give you the TFTP server address. Make sure that you are getting an IP address on the Voice Vlan.
10-27-2010 07:38 AM
Hi Darren,
The IP address that the phone is receiving is correct, from voice vlan (10.1.1.x) and everithing looks.
10-27-2010 07:48 AM
Do you have the latest firmware ? if not try it. If you don't know how to do that, you have a lab in the document section.
BR,
Romain
10-27-2010 08:26 AM
The phones has the 8.1.17 firmware version.
10-29-2010 11:02 PM
You can also run the debug tftp commands to see what is happening with the TFTP server of the UC560.
Enter the following commands to enable TFTP packets or events:
debug tftp packets
or
debug tftp events
term mon
To disable:
undebug all
term no mon
The debug commands will give you visability into when the phone tries to register and upload the image. The EVENTS command will give you the summary of each event the phone is requesting where the PACKETS give you the details of the TFTP requests and the associated responses.
Hope this helps.
Bert Wilhelm
APW Solutions
