Hello Mike,
If you are using CCA, you can adjust this setting here:
Configure > Telephony > Dial Plan > Outgoing
Choose "PSTN Trunk Group" tab, then select the trunk group for "ALL_FXO", and click "modify" at the bottom of the screen. There you will be able to change the hunt scheme.
Thank you,
Darren
