uc540 and spa232d
albenora72
                Are the spa232d usable with UC540? Not only throuth the analog interface but throuth voip interface?
naarjuna
Hi albenora72,
Yes the spa232d can be used through the analog interface and also the voip interface. But it is not supported by the CCA.
Naresh Arjunan
thanks for the answer.
it should be possible to have an example of the configuration throuth the voip interface?
because i jast have configured the SPA232D throuth the analog interface but i would like to use or better to see the two possible configurations.
i think i should create a sip trunk between the UC540 and the SPA232d or i have to do something else?
could you help me?
tnx
