UC540 CCA cant display PSTN Trunk details.
rajesh.kumar
Level 4
Level 4
We have UC540 FXO
Installed PACKAGE IS : spa50x-30x-7-4-6.bin
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.0(1)XA3a, SBTG Special
PSTN FXO port configuration as below,
voice-port 0/1/0
supervisory disconnect anytone
cptone GB
connection plar opx 209
impedance complex2
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
voice-port 0/1/1
cptone GB
impedance complex2
description Configured by CCA 4 FXO-0/1/1-OP
caller-id enable
Problem is :
(1) When I click on PSTN, I an getting the screen(attached JPG screenshot) "Operation in Progress, Reading PSTN trunk Configuration" and goes like that for 10 minutes. What could be the issue ? We have 8 FXO ports and configuration is as shown above.
(2) When I click on some configuration (ex. VLAN) we get "Java.lang.NullPointerException", what could be issue ? CCA version is 3.0(1)
Rgds
Rajesh
paolo bevilacqua
Wrong forum, try "small business - UC500" . You can move the post using the panel on the right.
However, you should update software on the UC500.
paolo bevilacqua
Thank you for the nice rating and good luck!
