10-02-2013 01:35 AM - edited 03-21-2019 07:49 AM
Hi Community.
Our customer doenst like to press first the "0" prefix for outgoing calls. How do i disable that, in CCA there isn't a option to disable that.
But i know its possible trough CLI.
Thanks and kind regards patrick
10-02-2013 02:47 AM
Sure is possible with CLI. That is advantageous for all countries which numbering plan do not require an access digit.
10-02-2013 07:07 AM
Hi Paolo.
Can you give me some tips, how i accomplish this?
Patrick
10-02-2013 01:17 PM
Just configure the necessary dial-peer with the appropriate destination-pattern and forward-digits all.
