UC540 - Disable the "0" prefix for outgoing calls
Patrick Werner
Hi Community.
Our customer doenst like to press first the "0" prefix for outgoing calls. How do i disable that, in CCA there isn't a option to disable that.
But i know its possible trough CLI.
Thanks and kind regards patrick
paolo bevilacqua
Sure is possible with CLI. That is advantageous for all countries which numbering plan do not require an access digit.
Hi Paolo.
Can you give me some tips, how i accomplish this?
Patrick
Just configure the necessary dial-peer with the appropriate destination-pattern and forward-digits all.
