UC540 software upgrade
RexPr
Using CCA and  I’m trying to upgrade US540’s software. After the first stage, I’ve this message:
Ping researchable test failed from CUE to CCA embedded TFTP server 192.168.0.78 please check ….
The message say  that the TFTP server is on IP 192.168.0.78, but this IP is not  on my network, it seem an old default configuration. Where is it? How to change?
Fabrizio
www.rfc.it
Fabrizio www.rfc.it
chrcoope
Hello Fabrizio,
This problem happens ussually when the workstation running CCA does not point to the UC500 as its default gateway.  We often just add a route ("c:\>route add 192.168.0.78 mask 255.255.255.0 192.168.10.1" for instance) on the workstation to correct the problem.  A UC540 ussually has this line in its running configuration file, "ip tftp source-interface Loopback0".  So another method that we do try is removing that command.  In a CCA compliant configuration the Loopback0 IP address is 10.1.10.2.
Hope this helps,
Christopher
Thank you for your suggestion. I’ll try, even if don’t know why the software upgrade say me 192.168.0.78.  On my UC540 I don’t have such address.
Fabrizio
www.rfc.it
Fabrizio www.rfc.it
Found. It's one of my stupid mistakes. Sometime happen. Too much. The problem is firewall enabled on PC. A classic warning on manuals . Only one mitigation factor: normally I work with workstation with firewall disabled.
Fabrizio
www.rfc.it
Fabrizio www.rfc.it
