12-28-2010 12:59 PM - edited 03-21-2019 03:27 AM
I have a UC540 with FXS Small Business Pro router. I'm trying to configure BGP but i can't. The IOS doesn't support BGP,OSFP,ISIS or EIGRP protocols.
Here is the version of IOS i'm using:
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1).
Can somebody tell me if it is posible to install a IOS that let me configure BGP on this router?
Thanks a lot.
12-28-2010 08:35 PM
The UC500 series does not support any dynamic routing protocols. Site-to-site VPNs can be configured using crypto maps or IPsec static virtual tunnel interfaces with static routing on the UC500 series.
Example of site-to-site VPN configured with an IPsec static virtual tunnel interface on the UC500 series:
crypto keyring S2S-Keyring
pre-shared-key address 100.92.3.42 key s2sVPNkey1
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp profile S2S-KeyProfile
keyring S2S-Keyring
match identity address 100.92.3.42 255.255.255.255
crypto ipsec transform-set ESP_AES_SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP_3DES_SHA esp-3des esp-sha-hmac
crypto ipsec profile S2S-Tunnel
set transform-set ESP_AES_SHA ESP_3DES_SHA
set isakmp-profile S2S-KeyProfile
interface Tunnel0
ip unnumbered BVI1
! NOTE: For UC560 models, use tunnel source GigabitEthernet0/0 instead of
! tunnel source FastEthernet0/0 in the line below.
tunnel destination 100.92.3.42
tunnel mode ipsec ipv4
tunnel protection ipsec profile S2S-Tunnel
! Use ip route to route traffic over the IPSec static virtual tunnel interface.
ip route 10.1.20.0 255.255.255.0 Tunnel0
ip route 10.2.20.0 255.255.255.252 Tunnel0
ip route 192.168.20.0 255.255.255.0 Tunnel0
Site-to-site VPNs using IPsec static virtual tunnel interfaces is not a new feature on UC500 features. The CCA multisite manager can configure site-to-site VPNs, but it currently uses a crypto map instead of a IPsec static virtual tunnel interface to do so. It is possible to do multi-subnet site-to-site VPNs between IOS-based endpoints without having to use GRE or dynamic routing, as illustrated in my example above. There have been enhancements made to IPsec VPN support in IOS 15.1T, but these enhancements are not yet supported in CCA.
CCA already does support Easy VPN server using dynamic virtual tunnel interfaces since the CCA 1.9 release. Support for site-to-site VPNs using IPsec static virtual tunnel interfaces, along with enhancements made in IOS 15.1T available on UC500 IOS images, should be added to future CCA releases. The crypto map approach will still continue to be supported for site-to-site VPNs configured in the multisite manager for backwards compatibility.
