After Upgrade to 8.1 Only 1 AA works
jcarter
Level 4
Level 4
I upgraded a UC520 using the 8.1 pack.  It failed when trying to reload the CUE data.  Everything looks like it upgraded.  The version numbers are the new versions.  The problem is only 1 of my 3 auto attendants are working.  I tried deleting and readding the other 2 but they still don't work.  When you call the pilot number, it give a busy signal.
Anyone have an idea?
5 Replies 5
jcarter
Level 4
Level 4
I figured it out.  I created the scripts with a version 7 CUE script editor.  They do not work with the new version 8.x of CUE.  The one that worked was configured using one of the standard CUE scripts.
Jason,
     You should be able to open the scripts in the new version of CUE Editor, save them, upload them to CUE and they should work.
Hope this helps.
Brandon
Thanks for the response.  By any chance do you have a link to the new CUE editor?
Thanks for the link.  I was not able to bring the existing script into the program.  I had to recreate a new one.  It is not a complicated script so it wasn't a big deal.
