uc560 and pap2t configuration
dchiarion
Hi all,
we have a UC560 with t1 and we would like to connect some analog dect to it (we already haveSPA504 connected and working fine).
for the analog dect we would like to use linksys pap2t
do someone know how to configure it?
Diego
danplacek
Level 4
Level 4
Why not use the FXS ports on the UC560?
This will be much easier to configure and it is supported by Cisco. (PAP2T is not)
-Dan
Please rate useful posts.
Hello Diego,
Just to add to what Dan said - you may also use ata186 or spa8800 or 8000 for additional FXS these are also supported in CCA if you are using CCA.
HTH,
Alex
*Please rate helpful posts
Tony Bagalini
Did you ever figure this out, I am trying to do the same thing... thanks!
Mike Clements
Just so I'm clear, you want the PAP2T to use the UC520 as a SIP provider e.g. Analog phone hard wired to PAP2T, SIP to UC520, Unknown to PSTN.
Can you post your PAP2T config?  It should be a simple SIP registration from the PAP2T to the UC520, much like any SIP phone.
Tip easy way to manage your PAP2T config is SPA Conf, I can't find it online anymore so here is a direct link to my copy
For Mac/Linux
https://www.dropbox.com/s/qh8sy3utvyvy9iv/spaconf-0.3.tar.gz
For Windows
https://www.dropbox.com/s/q0mekobskrntjnt/spaconf-0.3.zip
MC
