UC560 calling number (ANI) in transfered call
jfrodriguez23
My name is Julián.
We have a customer with a UC560 Pbx. We have a problem with transfered calls. One call is received in UC560, and this call is trasfered to other system by one voip dial-peer.
Calling Number A (external  number - PRI E1 port)
Called Number B (ip phone registered in UC560)
Transfered number (external device)
This option works fine, the ip phone (B) can to transfer the call from A to C, but:
This other system needs to get several fields from the call, for example who is the originating calling number (number A). I have added the comand clid network-provided in dial peer but this option does not works for me.
Is it posible  to show in number C, the original calling number (number A)?
Could you help me?
Kind Regards,
12 Replies 12
Can you post the configuration of the UC?
Do you have the option 'call-forward system redirecting-expanded' under telephony-service menu?
Regards.
Hello Daniele,
i have attached sh_run.
I do not have call-forward system redirecting-expanded' under telephony-service menu.
In SIP debug, this is my first invite to trasnsfered extension:
Sent:
INVITE sip:600@192.168.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK5D1C1E
Remote-Party-ID: "Ingrid/Eva" <sip:200@192.168.0.1>;party=calling;screen=no;privacy=off
From: "Ingrid/Eva" <sip:200@192.168.0.1>;tag=261690-90F
To: <sip:600@192.168.0.2>
Date: Wed, 13 Jun 2018 13:22:16 GMT
Call-ID: A077BFA8-6E4311E8-81CCEA7B-A85B6B69@192.168.0.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2683842855-1849889256-2177297019-2824563561
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1528896136
Contact: <sip:200@192.168.0.1:5060>
Call-Info: <sip:192.168.0.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 267
v=0
o=CiscoSystemsSIP-GW-UserAgent 124 4656 IN IP4 192.168.0.1
s=SIP Call
c=IN IP4 192.168.0.1
t=0 0
m=audio 19530 RTP/AVP 8 101 19
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
screen=no, ¿could be do this the problem?
Hi, try to remove the command
calling-number local
from your telephony-service
This command is used to replace the original calling-party with the forwarding-party number.
Regards.
Hello Daniele, I was some testa yesterday, and this removed command does not work. We have the same problem ....
add a new debug ccsip, please
regards
Calling number 911939521
Called number 932128108 (internal extension 200)
The called number is an AA
Hour of call: 10:54
The call was attended and transfered at 11:00
Transfered extension: 600
I hace attached ccsip all and q931 debugs.
In the trace I cannot see calls to extension 600.
I see a call to extension 299:
INVITE sip:299@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;x-route-tag="tgrp:ALL_T1E1";branch=z9hG4bK11F7548
Remote-Party-ID: <sip:911939521@10.1.10.2>;party=calling;screen=yes;privacy=off
To: <sip:299@10.1.10.1>
It is this (appear in logs file),
112887: //12521/72E4AE5A8C43/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK12641875
From: "Ingrid/Eva" <sip:200@192.168.0.1>;tag=9838048-2463
Date: Fri, 15 Jun 2018 09:00:57 GMT
Call-ID: 73A7FEEE-6FB111E8-8C49EA7B-A85B6B69@192.168.0.1
Min-SE: 1800
Cisco-Guid: 1927589466-1873875432-2353261179-2824563561
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1529053257
Expires: 180
Content-Length: 268
I've better checked the logs.
I see that new call to extension 600 uses dial-peer [4000]:
dial-peer voice 4000 voip
destination-pattern 6..
b2bua
session protocol sipv2
session target ipv4:192.168.0.2
dtmf-relay sip-notify rtp-nte
codec g711alaw
Can you try to rmeove from this dp the command 'clid network-provided'?
What is the result?
And what happens if you use the command 'clid override rdnis'?
Regards.
Hello Daniele, I removed clid network-provided, and now i see an update of connected number. The provider is checking if this solutin is valid. I will update as soon as posible,
ok glad to hear it, let me know the feedback of the provider
regards
Hello Danielle,
I am sorry by delay.
With removed command clid network-provided:
Calling number: 913346155
Called number: 932128108
This call is attended by ip phone (ext. 200)
Ext. 200 transfer to 600 by dial peer 4000. In 600, the calling number is 200.
I have checked what the clid override rdnis command it is not available in voice dial peer. It is supported in pots dial peer only.
