UC560 Licencing Issue
brendanmulcahy
  I am currently installing a UC560. I have successfully installed 3 licence packs for an additional 32 phones (License Manager tells me I have 56 available) I cant however install any more than 25 phones! In the topology the PBX sees both my SF300-24p switches, and I can mix and match the phones between either switch - but it simply wont let me install any more than 25 phones. I am using a mixture of SPA501G and SPA504G phones with the PC port active on them. Any suggestions?
I'm a newbie by the way so be gentle!! :-)
Many thanks in advance,
Brendan
Paul Dicine
Brendan, Can you attach the config and the output from your show license command you used? It would help us help you.
Thank you
Paul
