Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
                   On asterisk based IP PBX's I can set up a dial out rule to dial straight out instead of having to dial 1 or any other number specified before I dial the phone number, is it possible to do such a thing on the UC320 as it is a pain h...
We are on 7.5.1 firmware with a SPA504g and 500S attached. Normally when we are on a call, we can just hit the blf of the person we want to blind transfer to and this works great because we don't have to hit bxfer and then the person we want to trans...
Hi,I purchased a couple of SPA122 units yesterday, both with firmware version 1.0.2.I used the xml provisioning template that worked so well for SPA2102 (after changing the line indices to 0 and 1 from 1 and 2) and all seemed OK, except for the SIP p...
       Hi.I've enabled auto attendant on a uc540w and the 1 key allows dial by extension.The problem Is only one of around 8 extensions works when I dial It.All the extensions are valid and work correctly.The only thing I can think of Is that the ext...
Reprovoid by Level 1
  • 2698 Views
  • 11 replies
Hello People,I decided to change the topology to let a 3rd party DHCP server (SBS 2011) handle DHCP. After applying the changes, I plug the network cable between the UC320W and the Linksys/Cisco SRW2016 Gigabit switch. Soon after the whole network st...
lap by Level 1
  • 890 Views
  • 1 replies
