UC560 software download
alex-mendes
Hi Guy's
Could some one point me in the correct direction to download the software package and GB language files for the UC560 and CUE
Many thanks
6 Replies 6
Here is the correct link: https://supportforums.cisco.com/docs/DOC-9829
Also, link on the lower right corner of the landing page for this Community.
Marcos
alex-mendes
Hi Marcos,
Thanks for the fast reply, I have looked on this site a number of time's and can not find anything for the UC560, there is 520 and 540. Am I looking in the right place or should I be using the same software packages as the uc540 for the 560 unit
Many thanks
vcappucc
Hello Alex,
please find the Voice and Unified Communication Software in the following linksUC560; UC540; and for the UC520
also in this link you can find all the localization files for the UC´s and in this link for CCA Upgrade, UK Specific.
Hope this helps
Victor.-
Hi Victor,
Do you know if there are some newest UC OS version?.
I need to support remote wifi Iphone and I read CME 8.6 or above is required? (CME 8.6 is the OS rruning on UC5XX I guess)
https://supportforums.cisco.com/message/3366023#3366023
Thanks.
Eduardo.
Give a reading into Documents, "UC500 software packs".
alex-mendes
Thanks Victor,
That's what I was after...
Kindest regards
