UC560 WAN PORT support for dot1q?
jlesa2457
should be a fairly simple question but does UC560 WAN port support dot1q trunking back to switch? Can't see any doc on this.
Aim is to run 3 VLAN's back to switch one for data,voice,SSL VPN for remote teleworker.
Joseph
17 Replies 17
I haven't worked on the 1921 but you may see if you can enable DTLS:
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect23/administration/23admin3.html
MTP can be configured on the remote ephone so you should still be able to use it.
-Trent Good ** Please rate useful posts! **
ah the fun and games start.
I'll check it out thanks Trent.
Your quite correct though it is L3 int.
