Unable to access CUE
Amod Joshi
             We are having UC560 in our company. suddenly our cue has stopped working.
unable to reach cue..its giving fast busy tone but in CUE "service-module integrated-Service-Engine 0/0 status".. everything is up.
when i am trying access "service-module integrated-Service-Engine 0/0 session"..
its asking me to put username & password. but after that it gets stuck.
I reloaded, reset.. even i restarted the device.but still the same prob.
It is a issue of compact flash??
Rergards
AMOD
9 Replies 9
paolo bevilacqua
In one terminal, do service-module session.
In another, do service-module reset.
Observe if the CUE boots and any error message.
Here is what i m getting the error.. even m not eable to do factory reset.
Cisco Bootmon (Jun  2 2009 - 20:14:55)
Bootmon starts
Bootmon: cold reset.
User can press p/s to select a bootloader at this point
Getting default bootloader image from env...
Environment selected default bootloader image is: 0
Bootmon: reading primary bootloader image
Bootmon: calling bootloader at fff00100
CPU:   8572_E, Version: 2.1, (0x80e80021)
Core:  E500, Version: 3.0, (0x80210030)
Clock Configuration:
       CPU:1066 MHz, CCB: 533 MHz,
       DDR: 266 MHz (Synchronous), LBC:  33 MHz
L1:    D-cache 32 kB enabled
       I-cache 32 kB enabled
Board: Cisco uc560
I2C:   ready
DRAM:  Initializing....Non-interleaved    DDR: 1024 MB
FLASH:  8 MB
L2 cache 1MB: enabled
In:    serial
Out:   serial
Err:   serial
Net:   eTSEC1: PHY at 0x00 is Null-phy
eTSEC1
IDE:   Bus 0: OK
  Device 0: Model: UNIGEN FLASH Firm: 100511 Ser#: UNIGEN4     30030430
            Type: Hard Disk
            Capacity: 2000.2 MB = 1.9 GB (4096512 x 512)
Please enter '***' to change boot configuration:
ServicesEngine Bootloader Version : 1.0
bl_boot_cf_cmd reiserload ide 0:1 0x4000000 bzImage
** Bad Reisefs partition or disk - ide 0:1 **
boot loader >
Hello Amod,
Could be bad flash. It is good to open a case with SBSC about this issue.
Best regards,
Alex
Here are some more traces..
boot loader > boot diagscf
bl_boot_cf_diag_cmd fatload ide 0:1 0x1000000 cue-installer.uc560.8.6.5
reading cue-installer.uc560.8.6.5
10923860 bytes read
## Starting application at 0x01000000 ...
NIP: 01000000 XER: 20000000 LR: 0FFA0F70 REGS: 0ff6dca8 TRAP: 0700 DAR: 00000000
MSR: 00029200 EE: 1 PR: 0 FP: 0 ME: 1 IR/DR: 00
GPR00: 0FFA0F60 0FF6DD98 00000200 00000001 0FF6DDC4 00000010 FFFFFFFF 00000030
GPR08: 00000041 00000020 00000000 00000008 0FF6DB90 10026440 0FFC1600 0FFB76F4
GPR16: 0FFBAAEC 00000000 00000000 00000000 00000000 00000000 00000000 00000000
GPR24: 0FF70260 00000000 00000000 0FF6DDC4 01000000 0FF6DF7C 0FFC1CBC 00000002
** Illegal Instruction **
Call backtrace:
0FFA0F60 0FFAA20C 0FFAA2DC 0FFA8C20 0FFA8290 0FFA8440 0FFA0EF4
0FF990B4 0FF92628
Program Check Exception
### ERROR ### Please RESET the board ###
Try reinstalling CUE software, possibly in manual mode.
leidenkranz
Was this resolved?  I tried a new CF card and manually installing.  I get stuck here with no addtional output.  Maybe I'm not waiting long enough.
Please select from the following
1       Install software
2       Reload module
3       Disk cleanup
(Type '?' at any time for help)
Choice: 1
Package name: cue-main.uc560.8.6.5.pkg
Server url: ftp://x.x.x.x
Username: cue
Password:
Downloading ftp cue-main.uc560.8.6.5.pkg
Bytes downloaded :  3467
Validating package signature ... done
 - Parsing package manifest files... complete.
No installed manifests found.
 - Checking Package dependencies... complete.
Downloading ftp cue-apps.uc560.8.6.5.pkg
Bytes downloaded :  21713
Found Add-On Subsystem SID: 8191416e-d347-4ba7-8eb2-747138fd87de Name: PhoneConnect Version: 7.0.0
Found Add-On Subsystem SID: 1493990e-ec6f-4281-bfb7-1dc859153d37 Name: Monitor Agent Version: 7.0.0
Found Add-On Subsystem SID: 12161eb0-e646-4d3e-b174-d2fcac54d3b0 Name: Madrox refer install scripts Version: 8.6.5
Found Add-On Subsystem SID: 49bc5843-5c46-4bfe-83fa-e3634565b03d Name: Madrox Multi-app Support Version: 8.6.5
Found Add-On Subsystem SID: e2497725-368d-48b5-a7d5-7f87d889a608 Name: TimeCardView Version: 8.6.5
Downloading ftp cue-vm-k9.uc560.8.6.5.pkg
Bytes downloaded :  262257
Downloading ftp cue-vm-langpack.uc560.8.6.5.pkg
Bytes downloaded :  1386807
Found Add-On Subsystem SID: e2e81cc6-39b5-47e1-9f83-b83c897fc50c Name: CUE Voicemail Language Support Version: 8.6.5
Found Add-On Subsystem SID: c28339fa-f7ae-4732-85ab-fa6c68b5de0c Name: CUE Voicemail Italian Version: 8.6.5
Found Add-On Subsystem SID: 49f09114-e0b0-4721-8b85-04be2064920c Name: CUE Voicemail European Spanish Version: 8.6.5
Found Add-On Subsystem SID: 27e5e2ab-1622-4c02-8a0a-cfad0d932148 Name: CUE Voicemail US English Version: 8.6.5
Found Add-On Subsystem SID: cf860289-67ac-4886-9295-a41e4c7a8487 Name: CUE Voicemail European French Version: 8.6.5
Found Add-On Subsystem SID: f0a41398-3917-4d49-b5ab-c2b39a80c121 Name: CUE Voicemail Latin American Spanish Version: 8.6.5
Found Add-On Subsystem SID: c4ca62e2-daff-40dc-b94e-bf20094bd700 Name: CUE Voicemail Mexican Spanish Version: 8.6.5
Found Add-On Subsystem SID: 88a84158-c090-4203-bde8-0d62eda200c7 Name: CUE Voicemail Arabic Version: 8.6.5
Found Add-On Subsystem SID: ab049397-cfad-4952-852a-8dfa69780cb8 Name: CUE Voicemail Dutch Version: 8.6.5
Found Add-On Subsystem SID: d60c3add-0c6b-4a99-8e5c-31019fe7939e Name: CUE Voicemail Swedish Version: 8.6.5
Found Add-On Subsystem SID: e1ed9919-31da-4c38-b029-9bbd8231d523 Name: CUE Voicemail Norwegian Version: 8.6.5
Found Add-On Subsystem SID: 683674a5-e6ef-4c97-8e05-efbba1e6fe47 Name: CUE Voicemail Canadian French Version: 8.6.5
Found Add-On Subsystem SID: c3d2409a-ae9a-47d3-baf0-3c1a3ff85d82 Name: CUE Voicemail Portuguese Version: 8.6.5
Found Add-On Subsystem SID: b18bcd35-5a37-46af-b230-0d9c27713dec Name: CUE Voicemail Turkish Version: 8.6.5
Found Add-On Subsystem SID: 3e72a8ae-45d2-4790-b0b5-9301600e886e Name: CUE Voicemail Hungarian Version: 8.6.5
Found Add-On Subsystem SID: fa803d25-9c89-4171-a14c-ec12d6ed6b8c Name: CUE Voicemail UK English Version: 8.6.5
Found Add-On Subsystem SID: 09aa3e26-6efc-4bc4-a821-60d0fb238c74 Name: CUE Voicemail Hebrew Version: 8.6.5
Found Add-On Subsystem SID: 88f73a6c-884d-4838-b162-1b544dd6583f Name: CUE Voicemail Danish Version: 8.6.5
Found Add-On Subsystem SID: a2ba4f96-3452-40c3-83ad-c442cb6bf42f Name: CUE Voicemail Brazilian Portuguese Version: 8.6.5
Found Add-On Subsystem SID: 3f968fd0-6598-48e2-be1c-4af6c2e02e02 Name: CUE Voicemail German Version: 8.6.5
Found Add-On Subsystem SID: e67d778d-53bd-4a2e-8dec-2c640f00bec0 Name: CUE Voicemail Traditional Chinese (Taiwan) Version: 8.6.5
Found Add-On Subsystem SID: ea206a88-e44f-488b-a660-114a3b179065 Name: CUE Voicemail Korean Version: 8.6.5
Found Add-On Subsystem SID: 372fa3fd-1efb-4353-9005-45876646a351 Name: CUE Voicemail Simplified Chinese (PRC) Version: 8.6.5
Found Add-On Subsystem SID: 6cdfed34-6d45-48fd-afe0-717e589c9aa9 Name: CUE Voicemail Japanese Version: 8.6.5
Found Add-On Subsystem SID: fa2e95d4-6be5-422d-a934-89a8e6d33e95 Name: CUE Voicemail Hong Kong Chinese Version: 8.6.5
Found Add-On Subsystem SID: 24cb0b00-ed1c-4463-bf6f-261b15dfb3e7 Name: CUE Voicemail Russian Version: 8.6.5
 - Checking Manifest dependencies for subsystems in the install candidate list...
complete
WARNING:: Software installation will clear disk contents
Continue [n]? y
cleaning fs
prepfs.sh: uc560 reiser /mnt clean
umount: /dev/hda1: not mounted
Hello leidenkranz,
You have to wait longer at this point of the process.
HTH,
Alex
*Please rate helpful posts
 Hello Alexander Maroukian,
Actually the problem was with the flash.
I tried my best to resolved the issue. But at last cisco replaced our UC560 box​, as it was under warranty.
AMOD
**UPDATE**
Turned out not to be a bad flash but a bad CF slot or onboard hardware module.  I was able to mount the CF reiser partition in linux and do a reiserfsck on it.  Also tried cloning to a different CF and tried that CF in the UC560 with no change in outcome.  I ultimately took the lid off a UC540 and put the UC560's CF in that one.  I could see it read the partition and boot up as best it could under different hardware.  There were various mountpoint errors but it did "boot".  This told me the CF was still good.
This customer will need to replace the UC560 chassis.  If they do, I should be able to pop their old CF card in and not lose any AA or VM recordings.
