Voicemail to Email
pmoore
Guys, I had posted an issue in the beta test which I never got a response for, this included the trace and related to the smtp handling and smtp being rejected, can you put the details from that thread into this discussion , can you also advise if this is being looked at ?
supportforums.cisco.com/message/3267173#3267173
Phil Moore
16 Replies 16
Hi Phil,
I just checked the bug status and it is marked as Resolved in the 2.0.9(3) release.  The bug notes also indicate that additional logging has been added to the troubleshooting logs.  Can you please capture these logs and update your case with the support engineer with the logs and findings?
Chris
Hi Chris,
My mistake new code has fixed the issue, was failing due SSL not being ticked
Rgards
Phil Moore
