03-10-2011 06:12 PM - edited 03-21-2019 03:47 AM
supportforums.cisco.com/message/3267173#3267173
Solved! Go to Solution.
06-09-2011 12:55 PM
Hi Phil,
I just checked the bug status and it is marked as Resolved in the 2.0.9(3) release. The bug notes also indicate that additional logging has been added to the troubleshooting logs. Can you please capture these logs and update your case with the support engineer with the logs and findings?
Chris
06-09-2011 02:00 PM
Hi Chris,
My mistake new code has fixed the issue, was failing due SSL not being ticked
Rgards
Phil Moore
