VoiceView Express won't play messages
Mike Clements
Handsets are a mix of 7971GE, 7975G and 7937G, PBX is a UC520-32U-8FXO-K9, switch is a WS-C4506 with gig PoE blades.
I wiped our UC520 and installed software pack 8.6.2 fresh, then re-configured to meet our spec.  But I think I have broken VoiceView Express, audio based voicemail works properly.
I can login to VoiceView on the phones and see new messages and the details of the message left.  When I press the Listen button to play the message the phone shows the error message below.  Could it be that I set the wrong codec?
This is the message shown on the phone:
Playback Failed
Report this error to your system administrator.
SAXException: Content is not allowed in prolog.
This is the CUE trace on the PBX:
Press <CTRL-C> to exit...
2444 09/01 12:20:01.191 BUMS MIXR 32  audioMixer: Delayed wakeup, delta ms:12 us:12459 time_to_sleep ms:7 us:7227
3641 09/01 12:20:11.567 vovw cont 0 Enter Controller Requested URI: /voiceview/voicemail/playvm.do
3641 09/01 12:20:11.567 vovw sydb 0 /sw/apps/vui/vvconfig/enabled
3641 09/01 12:20:11.568 vovw sydb 0 1
3641 09/01 12:20:11.569 vovw cont 0 Submit Type 'LISTEN'
3641 09/01 12:20:11.569 vovw cont 0 Center Controller Requested URI: /voiceview/voicemail/playvm.do
3641 09/01 12:20:11.570 vovw sydb 0 /sw/apps/platformCapabilities/voiceview/faxpreview_enable
3641 09/01 12:20:11.570 vovw sydb 0 1
3641 09/01 12:20:11.571 vovw vcmt 0 Adding OID: 18078
3641 09/01 12:20:11.571 vovw vcmt 0 Total play time 6
3641 09/01 12:20:11.575 vovw vcmt 0 SoundTransmitter started
1390 09/01 12:20:11.583 ACCN COMG 0 ContactStubImpl is constructed, id=120,type=Cisco VoiceView Call,impl id=null
3641 09/01 12:20:11.594 vovw vcmt 0 New CRA callId: 120
1390 09/01 12:20:11.655 ACCN CHMG 0 ChMgrImpl:getGroup - got following group GroupStub[channelClass=com.cisco.wf.subsystems.cmt.CMTDialogChannelImpl,type=Cisco Media Channel,id=0,name=0,state=IN_SERVICE,channel=6]
1390 09/01 12:20:11.656 ACCN CHMG 0 GroupStubImpl::findAndLockIdleChannel() - inside method-GroupStub[channelClass=com.cisco.wf.subsystems.cmt.CMTDialogChannelImpl,type=Cisco Media Channel,id=0,name=0,state=IN_SERVICE,channel=6]
1390 09/01 12:20:11.656 ACCN CHMG 0 ChStubImpl:getChannelLock() -id=4 trying to get channel lock ...
1390 09/01 12:20:11.656 ACCN CHMG 0 ChStubImpl:getChannelLock() - channel locked successfully-ChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=4,state=IDLE,pendingState=null,groupId=0,locked=true]
1390 09/01 12:20:11.656 ACCN CHMG 0 GroupStubImpl::findAndLockIdleChannel() - channel successfully lockedChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=4,state=IDLE,pendingState=null,groupId=0,locked=true]
1390 09/01 12:20:11.656 ACCN CHMG 0 GrpStubImpl:getIdleChannel - attempt() successful resulting in 1 permits allocated
1390 09/01 12:20:11.656 ACCN CHMG 0 GrpStubImpl:getIdleChannel - permit allocated: 'Cisco Media Channel Group #0'.4(1)
1390 09/01 12:20:11.656 ACCN COMG 0 getApplicationPrivilege(): application is null for contact: 120
1390 09/01 12:20:11.656 ACCN COMG 0 ContactManager: Acquiring a port of type: AAWorkflowPrivilege
1390 09/01 12:20:11.656 LLMA LAPI 0 Llama: vmPortAllocate(): Allocating vm port for requestor "CRS"
1390 09/01 12:20:11.657 LLMA LSDB 0 Llama: vmPortAllocate(): LlamaSysdbUser(): setString(): Setting /sw/apps/limitsManager/vmPort/allocate/requestor to CRS
2339 09/01 12:20:11.658 LLMA LSDB 0 LlamaVmPortAllocate: check(): requestor, Value: CRS: returns true
2333 09/01 12:20:11.659 LLMA LVMP 0 LlamaVmPortAllocate: commit(): Attribute: requestor, Value: CRS
1390 09/01 12:20:11.659 LLMA LAPI 0 Llama: vmPortAllocate(): Allocate vm port for requestor "CRS" returns true
1390 09/01 12:20:11.659 ACCN COMG 0 ContactManager: Port of type AAWorkflowPrivilege acquired successfully
1390 09/01 12:20:11.659 ACCN COMG 0 Port of type AAWorkflowPrivilege acquired for contact #120
1390 09/01 12:20:11.660 ACCN CHMG 0 CHANNEL_STATE_CHANGE:Channel has changed state: Channel=null,Channel.cisco.dialog.DialogChannel,Channel Type=Cisco Media Channel,Channel id=4,Channel implementation id=4,Old state=IDLE,New state=IN_USE
1390 09/01 12:20:11.662 ACCN CMTS 0 MediaDialogChannel id=4,state=IN_USE MDC::init
1390 09/01 12:20:11.662 ACCN CMTS 0 MediaDialogChannel id=4,state=IN_USE ::init: create newMediaManagerImpl
1390 09/01 12:20:11.663 ACCN LMED 0 appId returned by RTPStreammanager = 1
1390 09/01 12:20:11.663 ACCN CHMG 0 GrpStubImpl:notifyChannelStateChange - state change recvd from: ChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=4,state=IN_USE,pendingState=null,groupId=0,locked=false]
1390 09/01 12:20:11.663 ACCN CHMG 0 GrpStubImpl:notifyChannelStateChange - channel changed from: IDLE ---> IN_USE for-GroupStub[channelClass=com.cisco.wf.subsystems.cmt.CMTDialogChannelImpl,type=Cisco Media Channel,id=0,name=0,state=IN_SERVICE,channel=6]
1390 09/01 12:20:11.663 ACCN CHMG 0 GrpStubImpl:notifyChannelInUse - No Group state change - channel state changed from Idle --> InUse
1390 09/01 12:20:11.663 ACCN CHMG 0 ChStubImpl:handleInUseTransition - notifying all waiting threads that channel is no longer idle-ChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=4,state=IN_USE,pendingState=null,groupId=0,locked=false]
1390 09/01 12:20:11.664 ACCN LMED 0 Sending media termination setup Command for call Id 67
3629 09/01 12:20:11.667 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.667 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.667 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.667 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 4 on Data fd : 13
3629 09/01 12:20:11.667 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 4
3629 09/01 12:20:11.667 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 28
3629 09/01 12:20:11.667 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.668 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 334
Msg Seq Num   : 1049
Src Component : 1
Dst Component : 2
Payload Size  : 4
Command Packet: IPPE_MEDIA_TERMINATION_SETUP
3629 09/01 12:20:11.668 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 28
3629 09/01 12:20:11.668 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 28
3629 09/01 12:20:11.668 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
version = 1, packet_type = 300, type_id = 334
seq_num = 1049, src_component =  1, dst_comp = 2, payload_size = 4
3629 09/01 12:20:11.668 BUMS CTRL 4 IppeMsgHandler.cpp.99:IppeMsgHandler.cpp 99 IPPE_MEDIA_TERMINATION_SETUP: callID is  67
3629 09/01 12:20:11.668 BUMS CTRL 2 ControlMsgParser.cpp.390:ControlMsgParser.cpp:390pPtr is
3629 09/01 12:20:11.668 BUMS CTRL 2 ControlMsgParser.cpp.421:ControlMsgParser.cpp:421
          Byte Read : 0
  High Nibble Codec : 0
   Low Nibble Codec : 0
3629 09/01 12:20:11.668 BUMS CTRL 2 ControlMsgParser.cpp.467:ControlMsgParser.cpp:467:: Decoding chan info :
           chan_id = 0
         ipaddress = 0.0.0.0
              port = 0
             flags = 0
       Codec Count = 0
3629 09/01 12:20:11.669 BUMS CTRL 2 ControlMsgParser.cpp.508:ControlMsgParser.cpp:508
         chan Name = (null)
     bytes skipped = 4
3629 09/01 12:20:11.669 BUMS CTRL 2 ControlMsgParser.cpp.578:ControlMsgParser.cpp:578:: pPtr is
3629 09/01 12:20:11.669 BUMS CTRL 4 IppeMsgHandler.cpp.126: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 126 IPPE_MEDIA_TERMINATION_SETUP: session object created for callID: 67 channelID is: 4294967295
3629 09/01 12:20:11.669 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  4294967295
3629 09/01 12:20:11.669 BUMS CTRL 2 apiController.cpp.135: IPPE01-0000000000067000000000000 apiController.cpp 135 IPPE_MEDIA_TERMINATION_SETUP
3629 09/01 12:20:11.669 BUMS CTRL 4 dmsApi.cpp.295:dmsApi.cpp 295 In function DmsApi::setupConnection
3629 09/01 12:20:11.669 BUMS CTRL 4 dmsApi.cpp.317:dmsApi.cpp 317 setupConnection params: callID: 67 ingressMute:
3629 09/01 12:20:11.669 BUMS CTRL 4 dmsApi.cpp.384:dmsApi.cpp 384 In function DmsApi::setupConnection Before Call to gy_CallMixer
3629 09/01 12:20:11.671 BUMS CTRL 4 dmsApi.cpp.414:dmsApi.cpp 414 DmsApi::setupConnection gy_callMixer successful callID=67 channelID=5 confId=65535 port=20670 rtcpPort=0
3629 09/01 12:20:11.671 BUMS CTRL 2 apiController.cpp.141: apiController.cpp 141 IPPE_MEDIA_TERMINATION_SETUP SUCCESS
3629 09/01 12:20:11.671 BUMS CTRL 2 apiController.cpp.152: apiController.cpp 152 Chan ID is 5
3629 09/01 12:20:11.672 BUMS CTRL 2 ../config/umsDataMgr.h.316:insertChanId IN
3629 09/01 12:20:11.672 BUMS CTRL 2 ../config/umsDataMgr.h.319:insertChanId pObj is not NULL
3629 09/01 12:20:11.672 BUMS CTRL 2 ../config/umsDataMgr.h.321:insertChanId ChanID inserted successfully
3629 09/01 12:20:11.672 BUMS CTRL 2 apiController.cpp.154: apiController.cpp 154 Before Build header for IPPE_MEDIA_TERMINATION_SETUP Response OK
3629 09/01 12:20:11.672 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 510, msg_seq_num = 1049, reserved1 = 0
3629 09/01 12:20:11.672 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
version = 1, packet_type = 500, type_id = 510
seq_num = 1049, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.672 BUMS CTRL 4 ControlMsgParser.cpp.698:ControlMsgParser.cpp:698:: pPtr =  ,Local IP Address = 10.90.3.1 , Local Port = 20670 ,codec = 1
3629 09/01 12:20:11.672 BUMS CTRL 2 apiController.cpp.173: IPPE01-0000000000067000000000000 apiController.cpp 173 IPPE_MEDIA_TERMINATION_SETUP response OK
3629 09/01 12:20:11.672 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.673 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 36
3629 09/01 12:20:11.673 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.673 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 510
Msg Seq Num   : 1049
Src Component : 2
Dst Component : 1
Payload Size  : 12
Response Packet: MEDIA_TERMINATION_SETUP_RESPONSE
3629 09/01 12:20:11.673 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 36
3629 09/01 12:20:11.673 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  36 bytes
1390 09/01 12:20:11.675 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.IppeMTSetupCommand type:334 completed
1390 09/01 12:20:11.675 ACCN LMED 0  Ippe media termination setup command  completed successfully.
1390 09/01 12:20:11.675 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> >>>>>setSockRTP: UMS port=20670
1390 09/01 12:20:11.675 ACCN LMED 0 RTP_PROPERTIES_REASSIGNED:RTP Properties Reassigned: Method Name=setInputProperties(),HOST NAME=127.0.0.1,PORT NUMBER=0,PACKET SIZE=20
1390 09/01 12:20:11.676 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> setInputProperties: payloadType-4
1390 09/01 12:20:11.676 ACCN LMED 0 Sending Mute Command for call Id 67 with INGRESS(Record): UNMUTE  EGRESS(Play): NO_CHANGE
3629 09/01 12:20:11.677 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.677 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.677 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.678 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 8 on Data fd : 13
3629 09/01 12:20:11.678 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 8
3629 09/01 12:20:11.678 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 32
3629 09/01 12:20:11.678 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.678 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 344
Msg Seq Num   : 1050
Src Component : 1
Dst Component : 2
Payload Size  : 8
Command Packet: MEDIA_TEMINATION_MUTE_UNMUTE
3629 09/01 12:20:11.678 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 32
3629 09/01 12:20:11.678 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 32
3629 09/01 12:20:11.679 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
version = 1, packet_type = 300, type_id = 344
seq_num = 1050, src_component =  1, dst_comp = 2, payload_size = 8
3629 09/01 12:20:11.679 BUMS CTRL 4 IppeMsgHandler.cpp.645:IppeMsgHandler.cpp 645 MEDIA_TEMINATION_MUTE_UNMUTE CallID : 67
3629 09/01 12:20:11.679 BUMS CTRL 4 IppeMsgHandler.cpp.664: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 664 MEDIA_TEMINATION_MUTE_UNMUTE: callID is  67 Channel Id is: 5
3629 09/01 12:20:11.679 BUMS CTRL 2 IppeMsgHandler.cpp.689: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 689 MEDIA_TEMINATION_MUTE_UNMUTE: setting Tx mute state to UNMUTE
3629 09/01 12:20:11.679 BUMS CTRL 2 IppeMsgHandler.cpp.704: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 704 MEDIA_TEMINATION_MUTE_UNMUTE: setting Rx mute state to unchanged
3629 09/01 12:20:11.679 BUMS CTRL 2 IppeMsgHandler.cpp.731: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 731 MEDIA_TEMINATION_MUTE_UNMUTE: Dispatching mute/unmute req to Api Controller
3629 09/01 12:20:11.679 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  5
3629 09/01 12:20:11.679 BUMS CTRL 2 apiController.cpp.407: IPPE01-0000000000067000000000000 apiController.cpp 407 MEDIA_TEMINATION_MUTE_UNMUTE  txmute (ingress)is: 2
3629 09/01 12:20:11.679 BUMS CTRL 2 apiController.cpp.409: IPPE01-0000000000067000000000000 apiController.cpp 409 MEDIA_TEMINATION_MUTE_UNMUTE  rxmute (egress)is: 0
3629 09/01 12:20:11.680 BUMS CTRL 4 dmsApi.cpp.248:dmsApi.cpp 248 Stream to be muted is INGRESS for chan id: 5
3629 09/01 12:20:11.680 BUMS CTRL 2 apiController.cpp.421: IPPE01-0000000000067000000000000 apiController.cpp 421 MEDIA_TEMINATION_MUTE_UNMUTE  unmute Tx (ingress)
3629 09/01 12:20:11.680 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 501, msg_seq_num = 1050, reserved1 = 0
3629 09/01 12:20:11.680 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
version = 1, packet_type = 500, type_id = 501
seq_num = 1050, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.680 BUMS CTRL 2 apiController.cpp.453: IPPE01-0000000000067000000000000 apiController.cpp 453 MEDIA_TEMINATION_MUTE_UNMUTE  unmute response OK
3629 09/01 12:20:11.680 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.680 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 24
3629 09/01 12:20:11.680 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.681 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 501
Msg Seq Num   : 1050
Src Component : 2
Dst Component : 1
Payload Size  : 0
Response Packet: RESPONSE_OK
3629 09/01 12:20:11.681 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 24
3629 09/01 12:20:11.681 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  24 bytes
1390 09/01 12:20:11.683 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.SetMuteCommand type:344 completed
1390 09/01 12:20:11.683 ACCN LMED 0  Ippe Mute command for call 67 completed successfully.
1390 09/01 12:20:11.798 ACCN CHMG 0 ChStubImpl:notifyIdle(true) - id=4, non-dynamic
1390 09/01 12:20:11.799 ACCN COMG 0 getApplicationPrivilege(): application is null for contact: 120
1390 09/01 12:20:11.799 ACCN COMG 0 ContactManager: Releasing a port of type: AAWorkflowPrivilege
1390 09/01 12:20:11.799 LLMA LAPI 0 Llama: vmPortDeallocate(): Deallocating vm port for requestor "CRS"
1390 09/01 12:20:11.799 LLMA LSDB 0 Llama: vmPortDeallocate(): LlamaSysdbUser(): setString(): Setting /sw/apps/limitsManager/vmPort/deallocate/requestor to CRS
2341 09/01 12:20:11.801 LLMA LSDB 0 LlamaVmPortDeallocate: check(): requestor, Value: CRS: returns true
2338 09/01 12:20:11.801 LLMA LVMP 0 LlamaVmPortDeallocate: commit(): Attribute: requestor, Value: CRS
1390 09/01 12:20:11.802 LLMA LAPI 0 Llama: vmPortDeallocate(): Deallocate vm port for requestor "CRS" returns true
1390 09/01 12:20:11.802 ACCN COMG 0 ContactManager: Port of type AAWorkflowPrivilege released successfully
1390 09/01 12:20:11.802 ACCN COMG 0 IVR port for privilege: AAWorkflowPrivilege released by contact #120
1380 09/01 12:20:11.803 ACCN CHMG 0 ChStubImpl:handleIdleTransition - channel currently InUse - removing channel from contact-ChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=4,state=IN_USE,pendingState=null,groupId=0,locked=false]
1380 09/01 12:20:11.804 ACCN CHMG 0 CHANNEL_STATE_CHANGE:Channel has changed state: Channel=null,Channel.cisco.dialog.DialogChannel,Channel Type=Cisco Media Channel,Channel id=4,Channel implementation id=4,Old state=IN_USE,New state=IDLE
1380 09/01 12:20:11.804 ACCN LMED 0 PrPl: appId=1, confId=67, parId=0, channelId=4, channelImplId=4, contactId=0 -> muteDestination()
1380 09/01 12:20:11.804 ACCN LMED 0 Sending Mute Command for call Id 67 with INGRESS(Record): NO_CHANGE  EGRESS(Play): MUTE
3641 09/01 12:20:11.806 vovw vcmt 0 SAXException: Content is not allowed in prolog.
3641 09/01 12:20:11.811 vovw cont 0 Exit Controller Requested URI: /voiceview/voicemail/playvm.do
3629 09/01 12:20:11.815 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.815 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.815 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.815 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 8 on Data fd : 13
3629 09/01 12:20:11.815 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 8
3629 09/01 12:20:11.815 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 32
3629 09/01 12:20:11.816 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.816 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 344
Msg Seq Num   : 1051
Src Component : 1
Dst Component : 2
Payload Size  : 8
3629 09/01 12:20:11.816 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 32
3629 09/01 12:20:11.816 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 32
3629 09/01 12:20:11.816 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1051, src_component =  1, dst_comp = 2, payload_size = 8
3629 09/01 12:20:11.816 BUMS CTRL 4 IppeMsgHandler.cpp.645:IppeMsgHandler.cpp 645 MEDIA_TEMINATION_MUTE_UNMUTE CallID : 67
3629 09/01 12:20:11.816 BUMS CTRL 4 IppeMsgHandler.cpp.664: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 664 MEDIA_TEMINATION_MUTE_UNMUTE: callID is  67 Channel Id is: 5
3629 09/01 12:20:11.816 BUMS CTRL 2 IppeMsgHandler.cpp.677: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 677 MEDIA_TEMINATION_MUTE_UNMUTE: setting Tx mute state to unchanged
3629 09/01 12:20:11.817 BUMS CTRL 2 IppeMsgHandler.cpp.710: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 710 MEDIA_TEMINATION_MUTE_UNMUTE: setting Rx mute state to MUTE
3629 09/01 12:20:11.817 BUMS CTRL 2 IppeMsgHandler.cpp.731: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 731 MEDIA_TEMINATION_MUTE_UNMUTE: Dispatching mute/unmute req to Api Controller
3629 09/01 12:20:11.817 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  5
3629 09/01 12:20:11.817 BUMS CTRL 2 apiController.cpp.407: IPPE01-0000000000067000000000000 apiController.cpp 407 MEDIA_TEMINATION_MUTE_UNMUTE  txmute (ingress)is: 0
3629 09/01 12:20:11.817 BUMS CTRL 2 apiController.cpp.409: IPPE01-0000000000067000000000000 apiController.cpp 409 MEDIA_TEMINATION_MUTE_UNMUTE  rxmute (egress)is: 1
3629 09/01 12:20:11.817 BUMS CTRL 4 dmsApi.cpp.186:dmsApi.cpp 186 Stream to be muted is EGRESS for chan id 5
3629 09/01 12:20:11.817 BUMS CTRL 2 apiController.cpp.431: IPPE01-0000000000067000000000000 apiController.cpp 431 MEDIA_TEMINATION_MUTE_UNMUTE  mute Rx (egress)
3629 09/01 12:20:11.817 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 501, msg_seq_num = 1051, reserved1 = 0
3629 09/01 12:20:11.818 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1051, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.818 BUMS CTRL 2 apiController.cpp.453: IPPE01-0000000000067000000000000 apiController.cpp 453 MEDIA_TEMINATION_MUTE_UNMUTE  unmute response OK
3629 09/01 12:20:11.818 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.818 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 24
3629 09/01 12:20:11.818 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.818 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 501
Msg Seq Num   : 1051
Src Component : 2
Dst Component : 1
Payload Size  : 0
3629 09/01 12:20:11.818 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 24
3629 09/01 12:20:11.819 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  24 bytes
1380 09/01 12:20:11.820 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.SetMuteCommand type:344 completed
1380 09/01 12:20:11.820 ACCN LMED 0  Ippe Mute command for call 67 completed successfully.
1380 09/01 12:20:11.820 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> UMSRTPRecorder.stopInput(): mute Reception
1380 09/01 12:20:11.820 ACCN LMED 0 Sending Mute Command for call Id 67 with INGRESS(Record): MUTE  EGRESS(Play): NO_CHANGE
3629 09/01 12:20:11.822 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.822 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.822 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.822 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 8 on Data fd : 13
3629 09/01 12:20:11.822 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 8
3629 09/01 12:20:11.822 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 32
3629 09/01 12:20:11.823 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.823 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 344
Msg Seq Num   : 1052
Src Component : 1
Dst Component : 2
Payload Size  : 8
3629 09/01 12:20:11.823 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 32
3629 09/01 12:20:11.823 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 32
3629 09/01 12:20:11.823 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1052, src_component =  1, dst_comp = 2, payload_size = 8
3629 09/01 12:20:11.823 BUMS CTRL 4 IppeMsgHandler.cpp.645:IppeMsgHandler.cpp 645 MEDIA_TEMINATION_MUTE_UNMUTE CallID : 67
3629 09/01 12:20:11.823 BUMS CTRL 4 IppeMsgHandler.cpp.664: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 664 MEDIA_TEMINATION_MUTE_UNMUTE: callID is  67 Channel Id is: 5
3629 09/01 12:20:11.823 BUMS CTRL 2 IppeMsgHandler.cpp.683: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 683 MEDIA_TEMINATION_MUTE_UNMUTE: setting Tx mute state to MUTE
3629 09/01 12:20:11.823 BUMS CTRL 2 IppeMsgHandler.cpp.704: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 704 MEDIA_TEMINATION_MUTE_UNMUTE: setting Rx mute state to unchanged
3629 09/01 12:20:11.824 BUMS CTRL 2 IppeMsgHandler.cpp.731: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 731 MEDIA_TEMINATION_MUTE_UNMUTE: Dispatching mute/unmute req to Api Controller
3629 09/01 12:20:11.824 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  5
3629 09/01 12:20:11.824 BUMS CTRL 2 apiController.cpp.407: IPPE01-0000000000067000000000000 apiController.cpp 407 MEDIA_TEMINATION_MUTE_UNMUTE  txmute (ingress)is: 1
3629 09/01 12:20:11.824 BUMS CTRL 2 apiController.cpp.409: IPPE01-0000000000067000000000000 apiController.cpp 409 MEDIA_TEMINATION_MUTE_UNMUTE  rxmute (egress)is: 0
3629 09/01 12:20:11.824 BUMS CTRL 4 dmsApi.cpp.180:dmsApi.cpp 180 Stream to be muted is INGRESS for chan id 5
3629 09/01 12:20:11.824 BUMS CTRL 2 apiController.cpp.416: IPPE01-0000000000067000000000000 apiController.cpp 416 MEDIA_TEMINATION_MUTE_UNMUTE  mute Tx (ingress)
3629 09/01 12:20:11.824 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 501, msg_seq_num = 1052, reserved1 = 0
3629 09/01 12:20:11.824 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1052, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.825 BUMS CTRL 2 apiController.cpp.453: IPPE01-0000000000067000000000000 apiController.cpp 453 MEDIA_TEMINATION_MUTE_UNMUTE  unmute response OK
3629 09/01 12:20:11.825 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.825 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 24
3629 09/01 12:20:11.825 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.825 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 501
Msg Seq Num   : 1052
Src Component : 2
Dst Component : 1
Payload Size  : 0
3629 09/01 12:20:11.825 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 24
3629 09/01 12:20:11.825 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  24 bytes
1380 09/01 12:20:11.828 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.SetMuteCommand type:344 completed
1380 09/01 12:20:11.828 ACCN LMED 0  Ippe Mute command for call 67 completed successfully.
1380 09/01 12:20:11.829 ACCN CMTS 0 MediaDialogChannel id=4,state=IDLE MDC::abort: return without waiting
1380 09/01 12:20:11.829 ACCN CMTS 0 MediaDialogChannel id=4,state=IDLE MediaManager resetted.
1380 09/01 12:20:11.829 ACCN LMED 0 PrPl: appId=1, confId=67, parId=0, channelId=4, channelImplId=4, contactId=0 -> stopPlay() called.
1380 09/01 12:20:11.829 ACCN LMED 0 CMTSimplePromptQueue.clear() called, started=false, size=0
1380 09/01 12:20:11.829 ACCN LMED 0 PrPl: appId=1, confId=67, parId=0, channelId=4, channelImplId=4, contactId=0 -> UmsPromptPlayer::closeStream
1380 09/01 12:20:11.829 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> stopInput(iscancelled:false)
1380 09/01 12:20:11.829 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> destroy()
1380 09/01 12:20:11.829 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> closeStream(), port=20670
1380 09/01 12:20:11.829 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> UMSRTPRecorder.stopInput(): mute Reception
1380 09/01 12:20:11.829 ACCN LMED 0 Sending Mute Command for call Id 67 with INGRESS(Record): MUTE  EGRESS(Play): NO_CHANGE
3629 09/01 12:20:11.831 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.831 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.831 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.831 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 8 on Data fd : 13
3629 09/01 12:20:11.831 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 8
3629 09/01 12:20:11.831 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 32
3629 09/01 12:20:11.831 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.832 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 344
Msg Seq Num   : 1053
Src Component : 1
Dst Component : 2
Payload Size  : 8
3629 09/01 12:20:11.832 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 32
3629 09/01 12:20:11.832 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 32
3629 09/01 12:20:11.832 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1053, src_component =  1, dst_comp = 2, payload_size = 8
3629 09/01 12:20:11.832 BUMS CTRL 4 IppeMsgHandler.cpp.645:IppeMsgHandler.cpp 645 MEDIA_TEMINATION_MUTE_UNMUTE CallID : 67
3629 09/01 12:20:11.832 BUMS CTRL 4 IppeMsgHandler.cpp.664: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 664 MEDIA_TEMINATION_MUTE_UNMUTE: callID is  67 Channel Id is: 5
3629 09/01 12:20:11.832 BUMS CTRL 2 IppeMsgHandler.cpp.683: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 683 MEDIA_TEMINATION_MUTE_UNMUTE: setting Tx mute state to MUTE
3629 09/01 12:20:11.832 BUMS CTRL 2 IppeMsgHandler.cpp.704: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 704 MEDIA_TEMINATION_MUTE_UNMUTE: setting Rx mute state to unchanged
3629 09/01 12:20:11.832 BUMS CTRL 2 IppeMsgHandler.cpp.731: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 731 MEDIA_TEMINATION_MUTE_UNMUTE: Dispatching mute/unmute req to Api Controller
3629 09/01 12:20:11.833 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  5
3629 09/01 12:20:11.833 BUMS CTRL 2 apiController.cpp.407: IPPE01-0000000000067000000000000 apiController.cpp 407 MEDIA_TEMINATION_MUTE_UNMUTE  txmute (ingress)is: 1
3629 09/01 12:20:11.833 BUMS CTRL 2 apiController.cpp.409: IPPE01-0000000000067000000000000 apiController.cpp 409 MEDIA_TEMINATION_MUTE_UNMUTE  rxmute (egress)is: 0
3629 09/01 12:20:11.833 BUMS CTRL 4 dmsApi.cpp.180:dmsApi.cpp 180 Stream to be muted is INGRESS for chan id 5
3629 09/01 12:20:11.833 BUMS CTRL 2 apiController.cpp.416: IPPE01-0000000000067000000000000 apiController.cpp 416 MEDIA_TEMINATION_MUTE_UNMUTE  mute Tx (ingress)
3629 09/01 12:20:11.833 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 501, msg_seq_num = 1053, reserved1 = 0
3629 09/01 12:20:11.833 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1053, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.833 BUMS CTRL 2 apiController.cpp.453: IPPE01-0000000000067000000000000 apiController.cpp 453 MEDIA_TEMINATION_MUTE_UNMUTE  unmute response OK
3629 09/01 12:20:11.834 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.834 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 24
3629 09/01 12:20:11.834 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.834 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 501
Msg Seq Num   : 1053
Src Component : 2
Dst Component : 1
Payload Size  : 0
3629 09/01 12:20:11.834 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 24
3629 09/01 12:20:11.834 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  24 bytes
1380 09/01 12:20:11.836 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.SetMuteCommand type:344 completed
1380 09/01 12:20:11.836 ACCN LMED 0  Ippe Mute command for call 67 completed successfully.
1380 09/01 12:20:11.836 ACCN CMTS 0 Sending IppeEndCallCommand to UMS
1380 09/01 12:20:11.836 ACCN LMED 0 forceStopPlayAndRecord before ending call
1380 09/01 12:20:11.836 ACCN LMED 0 stopPlay: callId=67, confId=-1
1380 09/01 12:20:11.837 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.IppeStopPlayPromptCommand type:356 completed
1380 09/01 12:20:11.839 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.IppeStopRecordPromptCommand type:357 completed
1380 09/01 12:20:11.839 ACCN LMED 0 Trying to send EndCall command for callId: 67
3629 09/01 12:20:11.840 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.841 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.841 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.841 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 8 on Data fd : 13
3629 09/01 12:20:11.841 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 8
3629 09/01 12:20:11.841 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 32
3629 09/01 12:20:11.841 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.841 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 356
Msg Seq Num   : 1054
Src Component : 1
Dst Component : 2
Payload Size  : 8
Command Packet: MEDIA_TERMINATION_STOP_PLAY_FILE
3629 09/01 12:20:11.841 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 32
3629 09/01 12:20:11.842 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 32
3629 09/01 12:20:11.842 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
version = 1, packet_type = 300, type_id = 356
seq_num = 1054, src_component =  1, dst_comp = 2, payload_size = 8
3629 09/01 12:20:11.842 BUMS CTRL 4 IppeMsgHandler.cpp.1068:IppeMsgHandler.cpp 1068 MEDIA_TERMINATION_STOP_PLAY_FILE CallID : 67, confID=4294967295
3629 09/01 12:20:11.842 BUMS CTRL 4 IppeMsgHandler.cpp.1086: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 1086 MEDIA_TERMINATION_STOP_PLAY_FILE: callID is  67 Channel Id is: 5
3629 09/01 12:20:11.842 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  5
3629 09/01 12:20:11.842 BUMS CTRL 2 apiController.cpp.770: IPPE01-0000000000067000000000000 apiController.cpp 770 MEDIA_TERMINATION_STOP_PLAY_FILE
3629 09/01 12:20:11.842 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 501, msg_seq_num = 1054, reserved1 = 0
3629 09/01 12:20:11.843 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1054, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.843 BUMS CTRL 2 apiController.cpp.788: IPPE01-0000000000067000000000000 apiController.cpp 788 MEDIA_TERMINATION_STOP_PLAY_FILE
3629 09/01 12:20:11.843 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.843 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 24
3629 09/01 12:20:11.843 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.843 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 501
Msg Seq Num   : 1054
Src Component : 2
Dst Component : 1
Payload Size  : 0
3629 09/01 12:20:11.843 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 24
3629 09/01 12:20:11.843 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  24 bytes
3629 09/01 12:20:11.845 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.845 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.845 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.845 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 6 on Data fd : 13
3629 09/01 12:20:11.845 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 6
3629 09/01 12:20:11.845 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 30
3629 09/01 12:20:11.845 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.846 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 357
Msg Seq Num   : 1055
Src Component : 1
Dst Component : 2
Payload Size  : 6
Command Packet: MEDIA_TERMINATION_STOP_RECORD_FILE
3629 09/01 12:20:11.846 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 30
3629 09/01 12:20:11.846 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 30
3629 09/01 12:20:11.846 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
version = 1, packet_type = 300, type_id = 357
seq_num = 1055, src_component =  1, dst_comp = 2, payload_size = 6
3629 09/01 12:20:11.846 BUMS CTRL 4 IppeMsgHandler.cpp.1164:IppeMsgHandler.cpp 1164 MEDIA_TERMINATION_STOP_RECORD_FILE CallID : 67
3629 09/01 12:20:11.846 BUMS CTRL 2 IppeMsgHandler.cpp.1186: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 1186 MEDIA_TERMINATION_STOP_RECORD_FILE: callID is  67 Channel Id is: 5 isCancel:0
3629 09/01 12:20:11.846 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  5
3629 09/01 12:20:11.846 BUMS CTRL 2 apiController.cpp.810: IPPE01-0000000000067000000000000 apiController.cpp 810 MEDIA_TERMINATION_STOP_RECORD_FILE
3629 09/01 12:20:11.847 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 501, msg_seq_num = 1055, reserved1 = 0
3629 09/01 12:20:11.847 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1055, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.847 BUMS CTRL 2 apiController.cpp.832: IPPE01-0000000000067000000000000 apiController.cpp 832 MEDIA_TERMINATION_STOP_RECORD_FILE
3629 09/01 12:20:11.847 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.847 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 24
3629 09/01 12:20:11.847 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.847 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 501
Msg Seq Num   : 1055
Src Component : 2
Dst Component : 1
Payload Size  : 0
3629 09/01 12:20:11.847 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 24
3629 09/01 12:20:11.848 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  24 bytes
3629 09/01 12:20:11.848 BUMS CTRL 2 MsgHandler.cpp.234:MsgHandler.cpp:234:: Got some stuff..from select: Total num Fds: 1
3629 09/01 12:20:11.848 BUMS CTRL 2 MsgHandler.cpp.259:MsgHandler.cpp:259:: FD marked for read: 13
3629 09/01 12:20:11.848 BUMS CTRL 2 MsgHandler.cpp.350:MsgHandler.cpp:350:: Total bytes read for header is 24
3629 09/01 12:20:11.848 BUMS CTRL 2 MsgHandler.cpp.359:MsgHandler.cpp:359:: Payload Size 4 on Data fd : 13
3629 09/01 12:20:11.848 BUMS CTRL 2 MsgHandler.cpp.378:MsgHandler.cpp:378:: Total bytes read for payload is 4
3629 09/01 12:20:11.848 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 28
3629 09/01 12:20:11.849 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.849 BUMS CTRL 2 controlProtocol.cpp.291:
Version       : 1
Packet Type   : 300
Type Id       : 338
Msg Seq Num   : 1056
Src Component : 1
Dst Component : 2
Payload Size  : 4
Command Packet: MEDIA_TERMINATION_TEARDOWN
3629 09/01 12:20:11.849 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 28
3629 09/01 12:20:11.849 BUMS CTRL 2 IppeMsgHandler.cpp.71:IppeMsgHandler.cpp 71 Process Packet in IPPE Msg Handler of len 28
3629 09/01 12:20:11.849 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
version = 1, packet_type = 300, type_id = 338
seq_num = 1056, src_component =  1, dst_comp = 2, payload_size = 4
3629 09/01 12:20:11.849 BUMS CTRL 4 IppeMsgHandler.cpp.229:IppeMsgHandler.cpp 229 MEDIA_TERMINATION_TEARDOWN CallID : 67
3629 09/01 12:20:11.849 BUMS CTRL 4 IppeMsgHandler.cpp.249: IPPE01-0000000000067000000000000 IppeMsgHandler.cpp 249 MEDIA_TERMINATION_TEARDOWN: callID is  67 Channel Id is: 5
3629 09/01 12:20:11.849 BUMS CTRL 2 apiController.cpp.121: IPPE01-0000000000067000000000000 apiController.cpp 121 performApiOperation called for chanID  5
3629 09/01 12:20:11.850 BUMS CTRL 2 apiController.cpp.480: IPPE01-0000000000067000000000000 apiController.cpp 480 MEDIA_TERMINATION_TEARDOWN/DEL_UNICAST_CHANNEL
3629 09/01 12:20:11.850 BUMS CTRL 2 apiController.cpp.497: IPPE01-0000000000067000000000000 apiController.cpp 497 MEDIA_TERMINATION_TEARDOWN/DEL_UNICAST_CHANNEL: endpoint is not in  TG: 0 send out close connect command
3629 09/01 12:20:11.850 BUMS CTRL 4 dmsApi.cpp.1100:dmsApi.cpp 1100 callid: 67 channelID: 5 closing the connection for channel
3629 09/01 12:20:11.851 BUMS CTRL 2 ControlMsgParser.cpp.650:ControlMsgParser.cpp:650:: pPtr = , pktType = 500, subType = 501, msg_seq_num = 1056, reserved1 = 0
3629 09/01 12:20:11.852 BUMS CTRL 2 ControlMsgParser.cpp.148:ControlMsgParser.cpp:148Decoding Header info :
seq_num = 1056, src_component =  2, dst_comp = 1, payload_size = 0
3629 09/01 12:20:11.852 BUMS CTRL 2 apiController.cpp.511: IPPE01-00000000000670000000000001 apiController.cpp 511 MEDIA_TERMINATION_TEARDOWN/DEL_UNICAST_CHANNEL -leaveVTG/closeConnection OK
3629 09/01 12:20:11.852 BUMS CTRL 2 apiController.cpp.1107: apiController.cpp 1107 sendResponse for fd: 13
3629 09/01 12:20:11.852 BUMS CTRL 2 controlProtocol.cpp.599:controlProtocol.cpp:599:: Buffer length: 24
3629 09/01 12:20:11.852 BUMS CTRL 2 controlProtocol.cpp.39:controlProtocol.cpp 39 dumping header started.
3629 09/01 12:20:11.852 BUMS CTRL 2 controlProtocol.cpp.405:
Version       : 1
Packet Type   : 500
Type Id       : 501
Msg Seq Num   : 1056
Src Component : 2
Dst Component : 1
Payload Size  : 0
3629 09/01 12:20:11.852 BUMS CTRL 2 controlProtocol.cpp.606:controlProtocol.cpp:606:: Dump Packet done: 24
3629 09/01 12:20:11.852 BUMS CTRL 2 apiController.cpp.1131: apiController.cpp 1131 Successfully sent the response for  24 bytes
3629 09/01 12:20:11.852 BUMS CTRL 2 apiController.cpp.1155: apiController.cpp cleanupSessionMaps callId=67 chanId=5 confId=65535
3629 09/01 12:20:11.853 BUMS CTRL 2 apiController.cpp.1158: apiController.cpp cleanupSessionMaps deleting call session
1380 09/01 12:20:11.887 ACCN LMED 0 Command class:com.cisco.ipics.ums.client.command.IppeEndCallCommand type:338 completed
1380 09/01 12:20:11.887 ACCN LMED 0  Ippe End Call command  completed successfully.
1380 09/01 12:20:11.888 ACCN CHMG 0 GrpStubImpl:notifyChannelStateChange - state change recvd from: ChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=4,state=IDLE,pendingState=null,groupId=0,locked=true]
1380 09/01 12:20:11.888 ACCN CHMG 0 GrpStubImpl:notifyChannelStateChange - channel changed from: IN_USE ---> IDLE for-GroupStub[channelClass=com.cisco.wf.subsystems.cmt.CMTDialogChannelImpl,type=Cisco Media Channel,id=0,name=0,state=IN_SERVICE,channel=6]
1380 09/01 12:20:11.888 ACCN CHMG 0 GrpStubImpl:notifyChannelIdle - No Group state change - channel state changed from InUse --> Idle
1380 09/01 12:20:11.888 ACCN CHMG 0 GrpStubImpl:notifyChannelIdle - calling async.release() to make channel available
1380 09/01 12:20:11.888 ACCN CHMG 0 ChStubImpl:releaseChannelLock() - channel lock releasedChannelStub[channelClass=com.cisco.dialog.DialogChannel,type=Cisco Media Channel,id=4,state=IDLE,pendingState=null,groupId=0,locked=false]
2206 09/01 12:20:51.986 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 ->  finalize rtprecorder
2206 09/01 12:20:51.986 ACCN LMED 0 Rec: appId=1 confId=67 parId=1 -> closeStream(), port=20670
2206 09/01 12:20:51.986 ACCN LMED 0 PrPl: appId=1, confId=67, parId=0, channelId=4, channelImplId=4, contactId=0 -> UmsPromptPlayer::closeStream
Thanks for any help
MC
13 Replies 13
paolo bevilacqua
Check/post relevant config on both CME and CUE.
Config's below, I've sanitised them a little so anything inside if <> brackets has been replaced and usernames are now User A to L
To jump to the CUE config search for "CUE Config:"
IOS/CME config:
Building configuration...
Current configuration : 82434 bytes
! Last configuration change at 09:39:41 NZST Mon Sep 2 2013 by admin
! NVRAM config last updated at 09:39:43 NZST Mon Sep 2 2013 by admin
version 15.1
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 4
logging buffered 51200
logging console critical
enable secret 4
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone NZST 12 0
clock summer-time NZDT recurring last Sun Sep 2:00 1 Sun Apr 3:00
crypto pki trustpoint TP-self-signed-991870720
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-991870720
revocation-check none
rsakeypair TP-self-signed-991870720
crypto pki certificate chain TP-self-signed-991870720
certificate self-signed 01
  quit
dot11 syslog
no ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.90.1.1 10.90.1.20
ip dhcp excluded-address 10.90.1.201 10.90.1.220
ip dhcp excluded-address 10.90.1.221 10.90.1.240
ip dhcp excluded-address 10.90.1.241 10.90.1.254
ip dhcp pool phone
network 10.90.1.0 255.255.255.0
default-router 10.90.1.254
option 150 ip 10.90.1.254
domain-name int.mydomain.com
dns-server 10.90.0.1 10.90.0.2 10.90.0.3
netbios-name-server 10.90.0.3
ip domain name int.mydomain.com
ip name-server 10.90.0.1
ip name-server 10.90.0.2
ip name-server 10.90.0.3
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic timeout 300
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
password encryption aes
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
  registrar server expires max 3600 min 3600
  localhost dns:int.mydomain.com
  no update-callerid
voice class codec 1
codec preference 1 g722-64
codec preference 2 g722-56
codec preference 3 g722-48
codec preference 4 g711alaw
codec preference 5 g711ulaw
video codec h261
video codec h263
video codec h263+
video codec h264
video codec mpeg4
voice class custom-cptone CCAleavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone CCAjointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone customNZ
dualtone disconnect
  frequency 400
  cadence 250 250
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.90.1.254 port 5060
max-dn 160
max-pool 40
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
timezone 53
time-format 24
date-format D/M/Y
create profile sync 0000338104589209
voice hunt-group 1 parallel
final 4112
list 4601,4607
timeout 22
pilot 4111
voice hunt-group 2 sequential
final 4101
list 4605,4604,4613
timeout 10
pilot 4112
voice logout-profile 1
pin 4699
user em-logged_out password 4699
number 4699 type normal
speed-dial 1 1111 label "Emergency Services"
speed-dial 2 4111 label "Reception"
speed-dial 3 4611 label "ICT Assist"
voice user-profile 101
pin 4601
number 4601 type normal
voice user-profile 102
pin 4602
number 4602 type normal
voice user-profile 103
pin 4603
number 4603 type normal
voice user-profile 104
pin 4604
number 4604 type normal
voice user-profile 105
pin 4605
number 4605 type normal
voice user-profile 106
pin 4606
number 4606 type normal
voice user-profile 107
pin 4607
number 4607 type normal
voice user-profile 108
pin 4608
number 4608 type normal
voice user-profile 109
pin 4609
number 4609 type normal
voice user-profile 110
pin 4610
number 4610 type normal
voice user-profile 111
pin 4611
number 4611 type normal
voice user-profile 112
pin 4612
number 4612 type normal
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
voice translation-rule 410
rule 1 /^1\(.*\)/ /\1/
rule 15 /^....$/ /028123456/
voice translation-rule 411
rule 1 /^1\(.*\)/ /ABCD1\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^1/ //
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^9/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server 10.90.3.1 port 25
mta send with-subject both
mta send mail-from hostname 10.90.3.2
mta send mail-from username $s$
mta receive aliases 10.90.3.2
mta receive maximum-recipients 7
application
service cca_fax_detection flash:/applications/faxmail/app_fax_detect.2.1.2.2.tcl
  param fax-dtmf 2
  param mode listen-first
  param voice-dtmf 1
  param prompt flash:/applications/faxmail/en_listen_first.au
service cca_offramp flash:/applications/faxmail/app_faxmail_offramp.2.0.1.1.tcl
service cca_onramp flash:/applications/faxmail/app_faxmail_onramp.2.0.1.3.tcl
license udi pid UC520-32U-8FXO-K9 sn FHK1219F11B
archive
log config
  logging enable
  logging size 600
  hidekeys
username admin privilege 15 secret 4
ip tftp source-interface Loopback0
gw-accounting aaa
gw-accounting file
primary ftp ftp://10.90.0.1/cdr username password 7
secondary ifs flash:/cdr/call-data
maximum buffer-size  15
maximum retry-count 3
maximum cdrflush-timer 50
interface Loopback0
description $FW_INSIDE$
ip address 10.90.3.2 255.255.255.252
ip access-group 102 in
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address 172.16.90.4 255.255.255.0
ip access-group 106 in
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group$FW_INSIDE$
ip unnumbered Loopback0
ip access-group 101 in
service-module ip address 10.90.3.1 255.255.255.252
service-module ip default-gateway 10.90.3.2
interface FastEthernet0/1/0
description ip-phone
switchport voice vlan 100
no ip address
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
description Uplink
switchport mode trunk
no ip address
macro description cisco-switch
interface Vlan1
ip address 10.90.0.4 255.255.255.0
ip access-group 104 in
interface Vlan100
ip address 10.90.1.254 255.255.255.0
ip access-group 105 in
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip route 0.0.0.0 0.0.0.0 172.16.90.254
ip route 10.0.0.0 255.0.0.0 10.90.0.254
ip route 10.90.3.1 255.255.255.255 Integrated-Service-Engine0/0
ip route 172.16.0.0 255.240.0.0 10.90.0.254
ip route 192.168.0.0 255.255.0.0 10.90.0.254
access-list 2 remark SIP requestors
access-list 2 permit any
access-list 3 remark SIP peering
access-list 3 permit 27.111.14.66
access-list 3 deny   any
access-list 101 remark Interface Integrated-Service-Engine0/0
access-list 101 permit icmp any any
access-list 101 permit igmp any any
access-list 101 permit ip any any
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 102 remark Interface Loopback0
access-list 102 permit icmp any any
access-list 102 permit igmp any any
access-list 102 permit ip any any
access-list 102 permit tcp any any
access-list 102 permit udp any any
access-list 104 remark Interface Vlan1
access-list 104 permit icmp any any
access-list 104 permit igmp any any
access-list 104 permit ip any any
access-list 104 permit tcp any any
access-list 104 permit udp any any
access-list 105 remark Interface Vlan100
access-list 105 permit icmp any any
access-list 105 permit igmp any any
access-list 105 permit ip any any
access-list 105 permit tcp any any
access-list 105 permit udp any any
access-list 106 remark Interface FastEthernet0/0
access-list 106 permit icmp any any
access-list 106 permit udp host 27.111.14.66 eq 5060 any
access-list 106 permit udp host 27.111.14.66 any eq 5060
access-list 106 permit udp any any range 16384 32767
access-list 106 deny   ip any any log
ixi transport http
response size 64
no shutdown
request outstanding 1
ixi application cme
no shutdown
snmp-server community public RO
snmp-server location -41.285623,174.777543
snmp-server contact Systems Management
snmp-server host 1.1.1.1 cms
tftp-server flash:/phones/6901_6911/SCCP6911.9-1-1-0.loads alias SCCP6911.9-1-1-0.loads
tftp-server flash:/phones/6901_6911/SCCP6901.9-1-1-0.loads alias SCCP6901.9-1-1-0.loads
tftp-server flash:/phones/6901_6911/KNL6911SCCP.9-1-1-0.zz.sgn alias KNL6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/KNL6901SCCP.9-1-1-0.zz.sgn alias KNL6901SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/BFS6911SCCP.9-1-1-0.zz.sgn alias BFS6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/APP6911SCCP.9-1-1-0.zz.sgn alias APP6911SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/6901_6911/APP6901SCCP.9-1-1-0.zz.sgn alias APP6901SCCP.9-1-1-0.zz.sgn
tftp-server flash:/phones/69xx/SCCP69xx.9-1-1-2-sr.loads alias SCCP69xx.9-1-1-2-sr.loads
tftp-server flash:/phones/69xx/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:/phones/69xx/DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:/phones/69xx/SCCP69xx.9-1-1-2-sr.zz.sgn alias SCCP69xx.9-1-1-2-sr.zz.sgn
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-5-2c.bin alias spa525g-7-5-2c.bin
tftp-server flash:/phones/51x/spa51x-7-5-2d.bin alias spa51x-7-5-2d.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-5-2c.bin alias spa50x-30x-7-5-2c.bin
tftp-server flash:/phones/7906_7911/apps11.9-2-1TH1-13.sbn alias apps11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/cnu11.9-2-1TH1-13.sbn alias cnu11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.9-2-1TH1-13.sbn alias cvm11sccp.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/dsp11.9-2-1TH1-13.sbn alias dsp11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.9-2-1TH1-13.sbn alias jar11sccp.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/SCCP11.9-2-1S.loads alias SCCP11.9-2-1S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7914/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:/phones/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:/phones/7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:/phones/7921/APPS-1.4.1SR1.SBN alias APPS-1.4.1SR1.SBN
tftp-server flash:/phones/7921/CP7921G-1.4.1SR1.LOADS alias CP7921G-1.4.1SR1.LOADS
tftp-server flash:/phones/7921/GUI-1.4.1SR1.SBN alias GUI-1.4.1SR1.SBN
tftp-server flash:/phones/7921/TNUXR-1.4.1SR1.SBN alias TNUXR-1.4.1SR1.SBN
tftp-server flash:/phones/7921/SYS-1.4.1SR1.SBN alias SYS-1.4.1SR1.SBN
tftp-server flash:/phones/7921/TNUX-1.4.1SR1.SBN alias TNUX-1.4.1SR1.SBN
tftp-server flash:/phones/7921/WLAN-1.4.1SR1.SBN alias WLAN-1.4.1SR1.SBN
tftp-server flash:/phones/7925/APPSH-1.4.1SR1.SBN alias APPSH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/CP7925G-1.4.1SR1.LOADS alias CP7925G-1.4.1SR1.LOADS
tftp-server flash:/phones/7925/GUIH-1.4.1SR1.SBN alias GUIH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/JSYSH-1.4.1SR1.SBN alias JSYSH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/JUIH-1.4.1SR1.SBN alias JUIH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/SYSH-1.4.1SR1.SBN alias SYSH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/TNUXH-1.4.1SR1.SBN alias TNUXH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/TNUXRH-1.4.1SR1.SBN alias TNUXRH-1.4.1SR1.SBN
tftp-server flash:/phones/7925/WLANH-1.4.1SR1.SBN alias WLANH-1.4.1SR1.SBN
tftp-server flash:/phones/7931/apps31.9-1-1TH1-16.sbn alias apps31.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/cnu31.9-1-1TH1-16.sbn alias cnu31.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/cvm31sccp.9-1-1TH1-16.sbn alias cvm31sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/dsp31.9-1-1TH1-16.sbn alias dsp31.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/jar31sccp.9-1-1TH1-16.sbn alias jar31sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7931/SCCP31.9-1-1SR1S.loads alias SCCP31.9-1-1SR1S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-21-0.bin alias cmterm_7936.3-3-21-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-4-4-0.bin alias apps37sccp.1-4-4-0.bin
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.9-1-1TH1-16.sbn alias apps41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cnu41.9-1-1TH1-16.sbn alias cnu41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.9-1-1TH1-16.sbn alias cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/dsp41.9-1-1TH1-16.sbn alias dsp41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.9-1-1TH1-16.sbn alias jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/SCCP41.9-1-1SR1S.loads alias SCCP41.9-1-1SR1S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/apps42.9-1-1TH1-16.sbn alias apps42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cnu42.9-1-1TH1-16.sbn alias cnu42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.9-1-1TH1-16.sbn alias cvm42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/dsp42.9-1-1TH1-16.sbn alias dsp42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.9-1-1TH1-16.sbn alias jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/SCCP42.9-1-1SR1S.loads alias SCCP42.9-1-1SR1S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.9-1-1TH1-16.sbn alias apps45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cnu45.9-1-1TH1-16.sbn alias cnu45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.9-1-1TH1-16.sbn alias cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/dsp45.9-1-1TH1-16.sbn alias dsp45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.9-1-1TH1-16.sbn alias jar45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/SCCP45.9-1-1SR1S.loads alias SCCP45.9-1-1SR1S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.9-1-1TH1-16.sbn alias apps70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/cnu70.9-1-1TH1-16.sbn alias cnu70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.9-1-1TH1-16.sbn alias cvm70sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/dsp70.9-1-1TH1-16.sbn alias dsp70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.9-1-1TH1-16.sbn alias jar70sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/SCCP70.9-1-1SR1S.loads alias SCCP70.9-1-1SR1S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/apps75.9-1-1TH1-16.sbn alias apps75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/cnu75.9-1-1TH1-16.sbn alias cnu75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/cvm75sccp.9-1-1TH1-16.sbn alias cvm75sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/dsp75.9-1-1TH1-16.sbn alias dsp75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/jar75sccp.9-1-1TH1-16.sbn alias jar75sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/SCCP75.9-1-1SR1S.loads alias SCCP75.9-1-1SR1S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/English_United_States/501-dictionary.xml alias English_United_States/501-dictionary.xml
tftp-server flash:/English_United_States/502-dictionary.xml alias English_United_States/502-dictionary.xml
tftp-server flash:/English_United_States/504-dictionary.xml alias English_United_States/504-dictionary.xml
tftp-server flash:/English_United_States/508-dictionary.xml alias English_United_States/508-dictionary.xml
tftp-server flash:/English_United_States/509-dictionary.xml alias English_United_States/509-dictionary.xml
tftp-server flash:/English_United_States/512-dictionary.xml alias English_United_States/512-dictionary.xml
tftp-server flash:/English_United_States/514-dictionary.xml alias English_United_States/514-dictionary.xml
tftp-server flash:/English_United_States/521-dictionary.xml alias English_United_States/521-dictionary.xml
tftp-server flash:/English_United_States/524-dictionary.xml alias English_United_States/524-dictionary.xml
tftp-server flash:/English_United_States/525G-dictionary.xml alias English_United_States/525G-dictionary.xml
tftp-server flash:/English_United_States/525G-kate.xml alias English_United_States/525G-kate.xml
tftp-server flash:/English_United_States/525G-tones.xml alias English_United_States/525G-tones.xml
tftp-server flash:/English_United_States/525G2-dictionary.xml alias English_United_States/525G2-dictionary.xml
tftp-server flash:/English_United_States/525G2-kate.xml alias English_United_States/525G2-kate.xml
tftp-server flash:/English_United_States/525G2-tones.xml alias English_United_States/525G2-tones.xml
tftp-server flash:/English_United_States/7921-dictionary.xml alias English_United_States/7921-dictionary.xml
tftp-server flash:/English_United_States/7921-font.dat alias English_United_States/7921-font.dat
tftp-server flash:/English_United_States/7921-kate.utf-8.xml alias English_United_States/7921-kate.utf-8.xml
tftp-server flash:/English_United_States/7921-kate.xml alias English_United_States/7921-kate.xml
tftp-server flash:/English_United_States/7960-tones.xml alias English_United_States/7960-tones.xml
tftp-server flash:/English_United_States/be-sccp.jar alias English_United_States/be-sccp.jar
tftp-server flash:/English_United_States/CME-locale-en_US-English-8.6.2.4.tar.cfg alias English_United_States/CME-locale-en_US-English-8.6.2.4.tar.cfg
tftp-server flash:/English_United_States/g3-tones.xml alias English_United_States/g3-tones.xml
tftp-server flash:/English_United_States/gp-sccp.jar alias English_United_States/gp-sccp.jar
tftp-server flash:/English_United_States/ipc-sccp.jar alias English_United_States/ipc-sccp.jar
tftp-server flash:/English_United_States/mk-sccp.jar alias English_United_States/mk-sccp.jar
tftp-server flash:/English_United_States/rp-sccp.jar alias English_United_States/rp-sccp.jar
tftp-server flash:/English_United_States/rtl-sccp.jar alias English_United_States/rtl-sccp.jar
tftp-server flash:/English_United_States/tags_file alias English_United_States/tags_file
tftp-server flash:/English_United_States/tc-sccp.jar alias English_United_States/tc-sccp.jar
tftp-server flash:/English_United_States/td-sccp.jar alias English_United_States/td-sccp.jar
tftp-server flash:/English_United_States/utf8_tags_file alias English_United_States/utf8_tags_file
radius-server attribute 31 send nas-port-detail
control-plane
call threshold interface FastEthernet0/0 int-calls low 40 high 40
voice-port 0/0/0
cptone NZ
description fxs-0/0/0_extn-4614
station-id name fxs-0/0/0
station-id number 4614
caller-id enable
voice-port 0/0/1
cptone NZ
description fxs-0/0/1_extn-4615
station-id name fxs-0/0/1
station-id number 4615
caller-id enable
voice-port 0/0/2
cptone NZ
description fxs-0/0/2_extn-4616
station-id name fxs-0/0/2
station-id number 4616
caller-id enable
voice-port 0/0/3
cptone NZ
description fxs-0/0/3_extn-4617
station-id name fxs-0/0/3
station-id number 4617
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
supervisory custom-cptone customNZ
compand-type a-law
cptone NZ
timeouts call-disconnect 3
timeouts wait-release 3
connection plar opx 4111
impedance complex3
description fxo-0/1/0_v.t.1_POTS-644-xxxxxxx
caller-id enable
voice-port 0/1/1
compand-type a-law
cptone NZ
impedance complex3
description fxo-0/1/1_v.t.2_POTS-644-xxxxxxx
caller-id enable
voice-port 0/1/2
compand-type a-law
cptone NZ
shutdown
impedance complex3
description Configured by CCA 4 FXO-0/1/2-Custom-HG
caller-id enable
voice-port 0/1/3
compand-type a-law
cptone NZ
shutdown
impedance complex3
description Configured by CCA 4 FXO-0/1/3-HG
caller-id enable
voice-port 0/3/0
compand-type a-law
cptone NZ
shutdown
impedance complex3
description Configured by CCA 4 FXO-0/3/0-HG
caller-id enable
voice-port 0/3/1
compand-type a-law
cptone NZ
shutdown
impedance complex3
description Configured by CCA 4 FXO-0/3/1-HG
caller-id enable
voice-port 0/3/2
compand-type a-law
cptone NZ
shutdown
impedance complex3
description Configured by CCA 4 FXO-0/3/2-HG
caller-id enable
voice-port 0/3/3
compand-type a-law
cptone NZ
shutdown
impedance complex3
description Configured by CCA 4 FXO-0/3/3-HG
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.90.1.254 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
associate profile 2 register mtp001e7a42dc60
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk 2talk New Zealand
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum conference-participants 32
maximum sessions 2
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
description ** CCA Analog Fax **
destination-pattern 4614
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 4615
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 4616
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 4617
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 150 pots
port 0/3/0
dial-peer voice 151 pots
port 0/3/1
dial-peer voice 152 pots
port 0/3/2
dial-peer voice 153 pots
port 0/3/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 154 pots
destination-pattern A4
port 0/3/0
no sip-register
dial-peer voice 155 pots
destination-pattern A5
port 0/3/1
no sip-register
dial-peer voice 156 pots
destination-pattern A6
port 0/3/2
no sip-register
dial-peer voice 157 pots
destination-pattern A7
port 0/3/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 4101
b2bua
session protocol sipv2
session target ipv4:10.90.3.1
voice-class sip outbound-proxy ipv4:10.90.3.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 4102
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 4103
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*New Zealand*International Access Code**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 100T
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*New Zealand*Operator Service**
preference 5
destination-pattern 1010
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
description **CCA*New Zealand*IAC for US 800 Numbers**
preference 5
destination-pattern 101681T
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*New Zealand*Service Numbers**
preference 5
destination-pattern 1017.
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 117.
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1018
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-local-plus
description **CCA*New Zealand*Mobile Service**
preference 5
destination-pattern 1020[023456789]T
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 10201......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 10210[013456789].....
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 102102......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1021[12]......
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1021[3456789].....
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1022T
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1024.......
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1025[01345789].....
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1025[26]......
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_FXO
description **CCA*New Zealand*Paging Service**
preference 5
destination-pattern 1026[023456789]......
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 10261.....
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 102[79].......
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 10280......
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 102885......
forward-digits all
no sip-register
dial-peer voice 79 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*New Zealand*Domestic Long Distance**
preference 5
destination-pattern 10[34679].......
forward-digits all
no sip-register
dial-peer voice 80 pots
trunkgroup ALL_FXO
description **CCA*New Zealand*Carrier Preselection Override**
preference 5
destination-pattern 10505T
forward-digits all
no sip-register
dial-peer voice 81 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*New Zealand*Freephone Numbers**
preference 5
destination-pattern 10508......
forward-digits all
no sip-register
dial-peer voice 82 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 105T
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 10800......
forward-digits all
no sip-register
dial-peer voice 84 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1083T
forward-digits all
no sip-register
dial-peer voice 85 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1086[0123469]......
forward-digits all
no sip-register
dial-peer voice 86 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1086[578].....
forward-digits all
no sip-register
dial-peer voice 87 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1087[012]......
forward-digits all
no sip-register
dial-peer voice 88 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1087[3456789]T
forward-digits all
no sip-register
dial-peer voice 89 pots
trunkgroup ALL_FXO
description **CCA*New Zealand*Premium Services**
preference 5
destination-pattern 10900.....
forward-digits all
no sip-register
dial-peer voice 90 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 11[012345689].
forward-digits all
no sip-register
dial-peer voice 91 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*New Zealand*Emergency Services**
preference 5
destination-pattern 1111
forward-digits all
no sip-register
dial-peer voice 92 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 93 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 11[346]
forward-digits all
no sip-register
dial-peer voice 94 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 119[67]
forward-digits all
no sip-register
dial-peer voice 95 pots
trunkgroup ALL_FXO
description **CCA*New Zealand*Domestic Local Calls**
preference 5
destination-pattern 1[23456789]......
forward-digits all
no sip-register
dial-peer voice 96 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 1502...
forward-digits all
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (2talk New Zealand) **
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
fax rate 14400
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (2talk New Zealand) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^....$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1021 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1022 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1023 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1024 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1025 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1026 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1027 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1028 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1029 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1030 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1031 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1032 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1033 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1034 voip
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1035 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1036 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1037 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1038 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1039 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1040 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1041 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1042 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1043 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1044 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1045 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1046 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1047 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1048 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1049 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1050 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1051 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1052 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1053 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1054 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1055 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1056 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1057 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1058 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1800 mmoip
description ** fax onramp for outbound faxmail to CUE **
service fax_on_vfc_onramp_app out-bound
destination-pattern ^....$
information-type fax
session target mailto:$d$@10.90.3.1
dial-peer voice 1801 mmoip
description ** fax offramp for inbound faxmail from CUE **
service cca_offramp
incoming called-number 4614
dsn delayed
dsn success
dsn failure
no dial-peer outbound status-check pots
presence
sip-ua
credentials username password 7 realm peering.2talk.co.nz
keepalive target dns:peering.2talk.co.nz
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
sip-server dns:peering.2talk.co.nz
host-registrar
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 1 confprof1
sdspfarm tag 2 mtp001e7a42dc60
conference hardware
video
authentication credential admin admin
xml user weex password weex-pw 15
fxo hook-flash
max-ephones 40
max-dn 160
ip source-address 10.90.1.254 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message
url services http://10.90.3.1/voiceview/common/login.do
url authentication http://10.90.3.2/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale U4 load CME-locale-en_GB-English-8.6.2.4.tar
network-locale U4
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.9-2-1S
load 7911 SCCP11.9-2-1S
load 7921 CP7921G-1.4.1SR1
load 7925 CP7925G-1.4.1SR1
load 7931 SCCP31.9-1-1SR1S
load 7936 cmterm_7936.3-3-21-0
load 7937 apps37sccp.1-4-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.9-1-1SR1S
load 7941GE SCCP41.9-1-1SR1S
load 7942 SCCP42.9-1-1SR1S
load 7945 SCCP45.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
load 7961GE SCCP41.9-1-1SR1S
load 7962 SCCP42.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 7970 SCCP70.9-1-1SR1S
load 7971 SCCP70.9-1-1SR1S
load 7975 SCCP75.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-5-2c
load 501G spa50x-30x-7-5-2c
load 502G spa50x-30x-7-5-2c
load 504G spa50x-30x-7-5-2c
load 508G spa50x-30x-7-5-2c
load 509G spa50x-30x-7-5-2c
load 525G2 spa525g-7-5-2c
load 301 spa50x-30x-7-5-2c
load 303 spa50x-30x-7-5-2c
load 512G spa51x-7-5-2d
load 514G spa51x-7-5-2d
load 6921 SCCP69xx.9-1-1-2-sr
load 6941 SCCP69xx.9-1-1-2-sr
load 6961 SCCP69xx.9-1-1-2-sr
load 6901 SCCP6901.9-1-1-0
load 6911 SCCP6911.9-1-1-0
time-zone 53
time-format 24
date-format dd-mm-yy
keepalive 30 auxiliary 4
live-record 4104
voicemail 4101
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/-mono-8khz-float32-ulaw.au
multicast moh 239.10.16.16 port 2000
web admin system name admin secret 5
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
transfer-pattern 1.T
transfer-pattern 9.... blind
secondary-dialtone 1
night-service weekday 17:30 08:00
night-service weekend 00:01 23:59
night-service date Jan 1 00:00 23:59
night-service date Dec 25 00:00 23:59
directory entry 1 021548141 name User F
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn-template  1
call-forward busy 4101
call-forward noan 4101 timeout 22
hold-alert 40 originator
mwi-type visual
pickup-group 1
ephone-template  1
url services 1 http://10.90.3.1/voiceview/common/login.do VoiceviewExpress
url services 2 http://10.90.3.1/timecardview/common/login.do TimeCardView
service phone webAccess 0
softkeys remote-in-use  Newcall CBarge
softkeys hold  Resume Newcall Join Select
softkeys idle  Redial Dnd Cfwdall Gpickup ConfList Login Pickup Join RmLstC Newcall HLog Mobility
softkeys seized  Endcall Callback Gpickup Redial Pickup Meetme Cfwdall HLog
softkeys alerting  Endcall Callback Acct
softkeys connected  Trnsfer Hold LiveRcd Confrn ConfList Join Park Endcall Flash Acct Select TrnsfVM RmLstC HLog Mobility
softkeys ringing  Answer Dnd HLog
button-layout 7931 2
ephone-template  15
softkeys idle  Redial Newcall Mobility Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected  Hold Endcall Mobility Trnsfer TrnsfVM LiveRcd Confrn ConfList RmLstC Acct Park Select Join
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  101  dual-line
number 4601 no-reg both
label 4601: User B
description User B
name User B
ephone-dn  102  dual-line
number 4602 no-reg both
label 4602: User H
description User H
name User H
ephone-dn  103  dual-line
number 4603 no-reg both
label 4603: User G
description User G
name User G
ephone-dn  104  dual-line
number 4604 no-reg both
label 4604: User I
description User I
name User I
ephone-dn  105  dual-line
number 4605 no-reg both
label 4605: User A
description User A
name User A
ephone-dn  106  dual-line
number 4606 no-reg both
label 4606: User D
description User D
name User D
ephone-dn  107  dual-line
number 4607 no-reg both
label 4607: User K
description User K
name User K
ephone-dn  108  dual-line
number 4608 no-reg both
label 4608: User L
description User L
name User L
ephone-dn  109  dual-line
number 4609 no-reg both
label 4609: Board Room
description Board Room
name Board Room
ephone-dn  110  dual-line
number 4610 no-reg both
label 4610: Conference Room
description Conference Phone
name Conference Phone
ephone-dn  111  dual-line
number 4611 no-reg both
label 4611: User F
description User F
name User F
mobility
snr delay 6 timeout 30 cfwd-noan 4101
ephone-hunt login
ephone-dn  112  dual-line
number 4612 no-reg both
label 4612: User J
description User J
name User J
ephone-dn  113  dual-line
number 4613 no-reg both
label 4613: User E
description User E
name User E
ephone-dn  114
ephone-dn  115
ephone-dn  116
ephone-dn  117
ephone-dn  118  dual-line
number 4618 no-reg both
label 4618: Emma
description User C (extn:4618 dn:118 ep:118)
name User C
ephone-dn  147  octo-line
number 7070 no-reg primary
conference meetme unlocked
preference 3
ephone-dn  148  octo-line
preference 2
no huntstop
ephone-dn  149  octo-line
preference 1
no huntstop
ephone-dn  150  octo-line
no huntstop
ephone-dn  151  octo-line
number C001 no-reg primary
conference ad-hoc
preference 3
ephone-dn  152  octo-line
conference ad-hoc
preference 2
no huntstop
ephone-dn  153  octo-line
conference ad-hoc
preference 1
no huntstop
ephone-dn  154  octo-line
conference ad-hoc
no huntstop
ephone-dn  156
number 028123456
description SIP Main Number registration
preference 10
ephone-dn  157
number 4104 no-reg primary
name LiveRecord
call-forward all 4101
ephone-dn  158
number 9.... no-reg primary
description ***CCA XFER TO VM EXTENSION***
ephone-dn  159
number A801.... no-reg primary
mwi off
ephone-dn  160
number A800.... no-reg primary
mwi on
ephone  101
device-security-mode none
video
mac-address 0021.5554.9EF7
ephone-template 1
username "user.b" password 4601
paging-dn 1
type 7971
button  1:101 2m103 3m106 4m107
button  5m102 6m112 7m104 8m105
ephone  102
video
mac-address 001E.13E5.D8D6
ephone-template 1
username "user.h" password 4602
paging-dn 1
type 7971
button  1:102 2m103 3m106 4m107
button  5m112 6m105 7m109 8m101
ephone  103
video
mac-address 0021.5554.9E9F
ephone-template 1
username "user.g" password 4603
paging-dn 1
type 7971
button  1:103 2m106 3m102 4m107
button  5m112 6m104 7m105 8m101
ephone  104
video
mac-address 0021.5554.A036
ephone-template 1
username "user.i" password 4604
paging-dn 1
type 7971
button  1:104 2m105 3m101 4m106
button  5m103 6m102 7m112 8m107
ephone  105
video
mac-address 0021.5554.A030
ephone-template 1
username "user.a" password 4605
paging-dn 1
type 7971
button  1:105 2m101 3m106 4m103
button  5m102 6m104 7m112 8m107
ephone  106
video
mac-address 0021.5554.9E69
ephone-template 1
username "user.d" password 4606
fastdial 1 name
paging-dn 1
type 7971
button  1:106 2m103 3m101 4m102
button  5m107 6m112 7m105 8m104
ephone  107
video
mac-address 0021.5554.9F3A
ephone-template 1
username "user.k" password 4607
fastdial 1 name
paging-dn 1
type 7971
button  1:107 2m103 3m101 4m104
button  5m102 6m106 7m105 8m112
ephone  108
video
mac-address 0021.5554.9F5F
ephone-template 1
username "user.l" password 4608
paging-dn 1
type 7971
button  1:108 2m113 3m101 4m102
button  5m103 6m104 7m105 8m106
ephone  109
video
mac-address 001E.13E5.D643
ephone-template 1
username "board.room" password 4609
type 7971
button  1:109 2m103 3m108 4m106
button  5m105 6m104 7m102 8m113
ephone  110
video
mac-address 0004.F2E1.1666
ephone-template 1
username "conference.phone" password 4610
type 7937
button  1:110
ephone  111
video
mac-address 58BC.2775.FD19
ephone-template 1
username "user.f" password 4611
paging-dn 1
type 7971
button  1:111 2m103 3m106 4m101
button  5m107 6m105 7m104 8m112
ephone  112
video
mac-address 0021.5554.9E84
ephone-template 1
username "user.j" password 4612
paging-dn 1
type 7971
button  1:112 2m103 3m101 4m102
button  5m107 6m105 7m104 8m106
ephone  113
video
mac-address 0001.0002.0003
ephone-template 1
username "user.e" password 4613
fastdial 1 name
paging-dn 1
type 7975
button  1:113 2m103 3m111 4m104
button  5m101 6m106 7m105 8m107
alias exec cca_voice_mode KEYSYSTEM
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Sun Sep 01 02:22:07 NZST 2013^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport preferred ssh
transport input all
transport output all
line vty 5 100
transport input all
ntp master
ntp server 10.90.0.2 prefer
end
CUE Config:
Generating configuration:
clock timezone Pacific/Auckland
hostname
ip domain-name int.mydomain.com
line console
  length 0
system language preferred "en_GB"
ip name-server 10.90.0.1 10.90.0.2 10.90.0.3
ntp server 10.90.3.2
software download server url "ftp://127.0.0.1/ftp" credentials hidden ""
site name local
phone-authentication credentials hidden ""
site-hostname 10.90.3.2
web credentials hidden ""
xml credentials hidden ""
end site
fax gateway inbound address 10.90.3.2
fax gateway outbound address 10.90.3.2
fax print 4614
privilege ViewHistoricalReports create
privilege manage-users create
privilege vm-imap create
privilege ViewPrivateList create
privilege broadcast create
privilege ManagePrompts create
privilege ViewRealTimeReports create
privilege ManagePublicList create
privilege manage-passwords create
privilege local-broadcast create
privilege tcv-payroll create
groupname PromptAdministrators create
groupname hunt1 create
groupname Broadcasters create
groupname IMAPgrp create
groupname tcv-payroll-specialists create
username user.e create
username user.l create
username user.f create
username user.d create
username user.j create
username user.b create
username user.g create
username user.a create
username board.room create
username user.k create
username conference.phone create
username user.h create
username admin create
username user.c create
username user.i create
privilege ViewHistoricalReports description "Privilege to view historical reports"
privilege manage-users description "Privilege to create, modify, and delete users and groups"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP client"
privilege ViewPrivateList description "Privilege to view private list"
privilege broadcast description "Privilege to send local or remote broadcast messages"
privilege ManagePrompts description "Privilege to create, modify, or delete system prompts"
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege ManagePublicList description "Privilege to manage public lists"
privilege manage-passwords description "Privilege to reset user passwords"
privilege local-broadcast description "Privilege to send local broadcast messages"
privilege tcv-payroll description "privilege of a TimeCardView payroll specialist"
privilege ViewHistoricalReports operation report.historical.view
privilege manage-users operation user.mailbox
privilege manage-users operation user.remote
privilege manage-users operation user.password
privilege manage-users operation system.debug
privilege manage-users operation user.notification
privilege manage-users operation group.configuration
privilege manage-users operation user.configuration
privilege manage-users operation user.pin
privilege vm-imap operation voicemail.imap.user
privilege ViewPrivateList operation voicemail.lists.private.view
privilege broadcast operation broadcast.local
privilege broadcast operation system.debug
privilege broadcast operation broadcast.remote
privilege ManagePrompts operation system.debug
privilege ManagePrompts operation prompt.modify
privilege ViewRealTimeReports operation report.realtime
privilege ManagePublicList operation voicemail.lists.public
privilege ManagePublicList operation system.debug
privilege manage-passwords operation user.password
privilege manage-passwords operation system.debug
privilege manage-passwords operation user.pin
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege tcv-payroll operation timecardview.config
privilege tcv-payroll operation timecardview.payroll
privilege tcv-payroll operation timecardview.database
groupname PromptAdministrators member user.b
groupname PromptAdministrators member user.g
groupname PromptAdministrators member user.a
groupname PromptAdministrators member user.e
groupname PromptAdministrators member user.l
groupname PromptAdministrators member user.f
groupname PromptAdministrators member user.k
groupname PromptAdministrators member user.d
groupname PromptAdministrators member user.c
groupname hunt1 member user.b
groupname hunt1 member user.j
groupname hunt1 member user.a
groupname hunt1 member user.g
groupname hunt1 member user.e
groupname hunt1 member user.f
groupname hunt1 member user.l
groupname hunt1 member user.k
groupname hunt1 member user.h
groupname hunt1 member user.d
groupname hunt1 member user.c
groupname hunt1 member user.i
groupname Broadcasters member user.f
groupname Broadcasters member admin
groupname Administrators member user.f
groupname Administrators member user.d
groupname Administrators member admin
groupname IMAPgrp member user.f
groupname tcv-payroll-specialists member user.f
groupname PromptAdministrators privilege ManagePrompts
groupname Broadcasters privilege broadcast
groupname IMAPgrp privilege vm-imap
groupname tcv-payroll-specialists privilege tcv-payroll
groupname hunt1 phonenumber "4112"
username user.e phonenumber "4613"
username user.l phonenumber "4608"
username user.f phonenumber "4611"
username user.d phonenumber "4606"
username user.j phonenumber "4612"
username user.b phonenumber "4601"
username user.g phonenumber "4603"
username user.a phonenumber "4605"
username board.room phonenumber "4609"
username user.k phonenumber "4607"
username conference.phone phonenumber "4610"
username user.h phonenumber "4602"
username user.i phonenumber "4604"
username user.f email user.f@mydomain.com
web session security keyLabel weex-https
username user.d supervisor designate
username user.f supervisor designate
username user.g supervisor designate
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
smtp server address smtp.mydomain.com port 25 authentication none
backup server url "ftp://192.168.10.22/cue/" credentials hidden ""
calendar biz-schedule systemschedule
closed day 1 from 00:00 to 24:00
open day 2 from 08:00 to 18:00
open day 3 from 08:00 to 18:00
open day 4 from 08:00 to 18:00
open day 5 from 08:00 to 18:00
open day 6 from 08:00 to 18:00
closed day 7 from 00:00 to 24:00
end schedule
calendar holiday date 2013 01 21 description "Wellington Anniversary"
calendar holiday date 2013 03 29 description "Good Friday"
calendar holiday date 2013 03 31 description "Easter Sunday"
calendar holiday date 2013 04 01 description "Easter Monday"
calendar holiday date 2013 06 03 description "Queen's Birthday"
calendar holiday date 2013 10 28 description "Labour Day"
calendar holiday date 2014 01 20 description "Wellington Anniversary"
calendar holiday date 2014 04 18 description "Good Friday"
calendar holiday date 2014 04 20 description "Easter Sunday"
calendar holiday date 2014 04 21 description "Easter Monday"
calendar holiday date 2014 06 02 description "Queen's Birthday"
calendar holiday date 2014 10 27 description "Labour Day"
calendar holiday fixed 01 01 description "Happy New Year!"
calendar holiday fixed 01 02 description "Happy New Year!"
calendar holiday fixed 02 06 description "Waitangi Day"
calendar holiday fixed 04 25 description "ANZAC Day"
calendar holiday fixed 12 24 description "Christmas Eve"
calendar holiday fixed 12 25 description "Merry Christmas!"
calendar holiday fixed 12 26 description "Boxing Day"
calendar holiday fixed 12 31 description "New Years Eve"
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 6
script "aa_sbcs_v03.aef"
parameter "BusinessHoursOption0" "none"
parameter "BusinessHoursOption6" "none"
parameter "BusinessHoursOptionPound" "none"
parameter "directXferMailboxNumber" "none"
parameter "AfterHoursOption1" "none"
parameter "BusinessHoursOption5" "none"
parameter "BusinessHoursOption1" "none"
parameter "AfterHoursOptionStar" "none"
parameter "AfterHoursOption6" "none"
parameter "allowExternalTransfers" "false"
parameter "AfterHoursOption0" "none"
parameter "AfterHoursOption7" "none"
parameter "BusinessHoursOption2" "none"
parameter "AfterHoursMenuPrompt" "P3_CompanyGreetingAfterHo.wav"
parameter "maxRetry" "3"
parameter "AfterHoursOption8" "none"
parameter "BusinessHoursOption7" "none"
parameter "BusinessHoursOption4" "none"
parameter "AfterHoursOption5" "none"
parameter "extensionLength" "4"
parameter "Schedule" "systemschedule"
parameter "BusinessHoursOption9" "none"
parameter "operator" "4111"
parameter "transferMaskEnabled" "false"
parameter "AfterHoursOption2" "none"
parameter "BusinessHourMenuPrompt" "P1_CompanyGreetingBusines.wav"
parameter "transferMaskPrefixDigits" "2"
parameter "BusinessHoursOption8" "none"
parameter "DialByNameDigit" "none"
parameter "AfterHoursOption3" "none"
parameter "AfterHoursOptionPound" "none"
parameter "BusinessHoursOptionStar" "none"
parameter "BusinessHoursOption3" "none"
parameter "AfterHoursOption4" "none"
parameter "AfterHoursOption9" "none"
parameter "DialByExtensionAnytime" "false"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 6
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "A801"
parameter "strMWI_ON_DN" "A800"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 6
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
parameter "appManagementScript" ""
end application
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 6
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
description "se-10-90-3-1"
end reporting
ccn subsystem sip
gateway address "10.90.3.2"
dtmf-relay rtp-nte
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 2
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 4101
application "voicemail"
enabled
maxsessions 6
end trigger
ccn trigger sip phonenumber 4102
application "autoattendant"
enabled
maxsessions 6
end trigger
ccn trigger sip phonenumber 4103
application "promptmgmt"
enabled
maxsessions 1
end trigger
security password lockout enable
security password temp-lock duration 3
security password temp-lock max-attempts 9
security password length min 4
security pin lockout enable
security pin temp-lock duration 3
security pin temp-lock max-attempts 9
security pin length min 4
service imap
maxsessions 20
end imap
service monitor-agent
end monitor-agent
service phone-authentication
end phone-authentication
service phoneconnect
end phoneconnect
service timecardview
payroll server quickbooks address null
enable
end timecardview
service voiceview
enable
session idletimeout 15
end voiceview
voicemail notification enable
voicemail notification preference all
voicemail notification allow-login
voicemail notification email attach
voicemail callerid
voicemail configuration outgoing-email from-address phone.system@mydomain.com
voicemail default mailboxsize 1800
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail operator telephone 4111
voicemail live-record beep duration 0
voicemail live-record pilot-number 4104
voicemail live-reply enable
voicemail mailbox owner "user.l" size 1800
description "User L"
login pinless subscriber-phone-numbers
end mailbox
voicemail mailbox owner "user.a" size 1800
description "User A"
end mailbox
voicemail mailbox owner "user.b" size 1800
description "User B"
end mailbox
voicemail mailbox owner "user.c" size 1800
description "User C"
end mailbox
voicemail mailbox owner "user.d" size 1800
description "User D"
end mailbox
voicemail mailbox owner "hunt1" size 5400
description "GDM +"
messagesize 90
end mailbox
voicemail mailbox owner "user.e" size 1800
description "User E"
end mailbox
voicemail mailbox owner "user.f" size 1800
description "User F"
end mailbox
voicemail mailbox owner "user.g" size 1800
description "User G"
end mailbox
voicemail mailbox owner "user.h" size 1800
description "User H"
end mailbox
voicemail mailbox owner "user.i" size 1800
description "User I"
end mailbox
voicemail mailbox owner "user.j" size 1800
description "User J"
end mailbox
voicemail mailbox owner "user.k" size 1800
description "User K"
end mailbox
voicemail notification cascading enable
voicemail notification liverecord enable
voicemail notification text prefix append "Please find your voicemail attached"
voicemail notification text suffix append "Cisco Unity Express Voicemail"
voicemail notification owner user.b enable
voicemail notification owner user.d enable
voicemail notification owner user.e enable
voicemail notification owner user.g enable
voicemail notification owner hunt1 enable
voicemail notification owner user.h enable
voicemail notification owner user.j enable
voicemail notification owner user.i enable
voicemail notification owner user.k enable
voicemail notification owner user.l enable
voicemail notification owner user.a enable
voicemail notification owner user.c enable
voicemail notification owner user.f enable
banner login append "Use of this system is monitored and logged, unauthorised access is prohibited and is subject to criminal and civil penalties."
banner login append "By proceeding you consent to interception, auditing, and the interrogation of your devices, traffic and information for evidence of mis-use."
end
Note I am also trying to configure a number of other things like extn mobility and moving from POTS to SIP, so the config is half baked in parts.
Cheers,
MC
Hello Mike,
Please try to enable web access on the phones.
Under telephony service add the following (case sensitive):
Create cnf-files
After this please restart the phones.
HTH,
Alex
*Please rate hepful posts
Hi Alexander
That setting is already applied via "ephone-template  1" but I added the setting to the telephony-service, re-created the CNF, and restarted my test phone and I still have the same issue.
MC
Bump
Hello Mike,
Looking at your configuration you are using ephone temaplte 1 on phones which are different than the 7931 type of phone.
Please change the template you are using to another which is not using specific 7931 layout, you may change to e.g. ephone template 16 or 17.
HTH,
Alex
Yeah all the phones are 7971G-GE, 7975G or 7937G.  I'm happy to change the template 1 but what button-layout should it be instead of 7931?
7931 is the default configured by CCA, thats the only reason its there.
MC
Hello Mike,
Just use template 16 or 17.
HTH,
Alex
*Please rate helpful posts
So you want to test with no button-layout?
I have just tested that and there is no change in the issue, VoiceView still has the same issue trying to play a voicemail.
MC
Hello Mike,
Please try ephone template 16 then recreate cnf and restart the phone.
Best regards,
Alex
templates 15-18 no longer exist as they were not being used by anything, CCA kept making unused templates.
The test I did before (at my previous post with no button-layout) was to alter template 1 to match 16, re-created the cnf and restarted the phone.  VoiceView doesn't play messages
I don't see how the button-layout would affect VoiceView's ability to play voicemail?
MC
I got the same problem ...
I use CME ver 8.6   CUE ver 8.6.1
Cisco 7942 phone  cmterm-7942_7962-sccp.9-3-1SR4-1
Cisco IP Communicator 8.6.2.0
my 7942 and CIPC have the same ephone-DN ....  the problem is present on the 7942 phone but not on the CIPC phone (I m able to listen messages).....
Did you find an solution ?
Just for your information ...
I downgrade my firmware for the 7942  at  ver  cmterm-7942_7962-sccp.9-3-1-1
and it's working now !
