06-22-2009 04:11 PM - last edited on 03-25-2019 10:38 PM by ciscomoderator
Customer has several WIP310 connected wirelessly to an accesspoint and then to a internal PBX Tribox V2.6.22. Using Teliax ITSP.
01-15-2010 10:03 AM
The WIP310 don't loose the connection since one week. Just adjusting the config files like i described in my last posting. Also the "Peer '7227-wlan-cisco1' is now Lagged" is never coming up again. I never update the firmware in the phone (5.0.11(10301355)) and for me, it's not the problem from the phone, it's a problem between trixbox or asterisk and the phone.
Please check the config on the trixbox or asterisk (on the cli: "sip show settings" then it is under "Reg. max duration") and adjust the settings in the sip config or on the phone.
cu ivo
01-18-2010 02:46 PM
Thank you, I understand that you are suggesting
"Change the value in the sip.conf to 4800 (and the phone 3600)"
Got it!
Problem is, on my version of Trixbox (2.6.2.3) I cannot change the sip.conf.
The file says:
; Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
; this file must be done via the web gui. There are alternative files to make ;
; custom modifications, details at: http://freepbx.org/configuration_files ;
01-18-2010 03:21 PM
Hi Mark
That's interesting, can you post the output from the cli command "sip show settings"?
cu ivo
01-19-2010 08:18 AM
Hey Guys,
Environment at my office:
1xWIP 310
Asterisk
WRT54G
Environment at my customer:
3x WIP 310
Asterisk
4xCisco 1250 AP's managed by a Cisco 2106 Controller
I've been having some issues with the WIP 310, too. It happens pretty much the same thing as in another post.. Conversations occur normally (or don't), wireless signal is entirely lost, and the phone shows "Acquiring Network" shortly afterwards.
This issue with the "Acquiring Network" happens in sync with the "registry timeout setting". If it's three minutes, it'll "Acquiring Network" in three minutes and so on.
The longer I put this timeout to happen, the more it takes for the problem to get back. But if it'll have to re-register let's say, in two minutes and my call will take five minutes, the call will drop.
My WIP 310 can always register after the call drops.
Should I update it to the alpha version?
01-21-2010 10:48 AM
Thand you.
From the Trixbox Menu I went to
Pbx -> PBX Settings -> Tools - Asterisk CLI and type Sip Show Setting. I got the information below.
Is this what I need to Change?
Reg. min duration 60 secs
Reg. max duration: 3600 secs
Reg. default duration: 120 secs
If so, I can look in the Trixbox forum to find out how.
Note that, on my SNOM phones, I was told to change the Sip Session Timer from the Default of 3600 to 60 -- which solved a similar problem of remote SNOM phones disconnecting frequently. This setting, from the SNOM website is described as:
"If SIP Session Timer Support is enabled, this option specifies the SIP session timer in seconds. For instance, a Re-INVITE will be sent after 50% of its value has elapsed."
Help would be appreciated!
Global Settings:
SIP Port: 5060
Bindaddress: 0.0.0.0
Videosupport: Yes
AutoCreatePeer: No
Allow unknown access: Yes
Allow subscriptions: Yes
Allow overlap dialing: Yes
Promsic. redir: No
SIP domain support: No
Call to non-local dom.: Yes
URI user is phone no: No
Our auth realm asterisk
Realm. auth: No
Always auth rejects: No
Call limit peers only: Yes
Direct RTP setup: No
User Agent: Asterisk PBX
MWI checking interval: 10 secs
Reg. context: (not set)
Caller ID: Unknown
Record SIP history: Off
Call Events: Off
IP ToS SIP: CS3
IP ToS RTP audio: EF
IP ToS RTP video: AF41
T38 fax pt UDPTL: No
RFC2833 Compensation: No
SIP realtime: Disabled
Global Signalling Settings:
Codecs: 0x28000c (ulaw|alaw|h263|h264)
Codec Order: ulaw:20,alaw:20
T1 minimum: 100
Relax DTMF: No
Compact SIP headers: No
RTP Keepalive: 0 (Disabled)
RTP Timeout: 0 (Disabled)
RTP Hold Timeout: 0 (Disabled)
MWI NOTIFY mime type: application/simple-message-summary
DNS SRV lookup: Yes
Pedantic SIP support: No
Outbound reg. timeout: 20 secs
Outbound reg. attempts: 0
Notify ringing state: Yes
Notify hold state: Yes
SIP Transfer mode: open
Max Call Bitrate: 384 kbps
Auto-Framing: No
Default Settings:
Context: from-sip-external
Nat: Always
DTMF: rfc2833
Qualify: 0
Use ClientCode: No
Progress inband: Never
Language: (Defaults to English)
MOH Interpret: default
MOH Suggest:
Voice Mail Extension: *97
01-25-2010 04:13 PM
Hi ivo,
Great input. Thanks so much for sharing your findings.
Patrick
01-25-2010 01:57 PM
I changed my SIP T1 to 2 and Reg Max Expires to 3600.
This is with asterisk 1.4 and FreePBX 2.6
My WIP310 used to lock up and never reregister until I made these changes now I have not had any problems with it. I made the changes 3 days ago.
01-25-2010 04:21 PM
Hi cspiess24,
Thanks for sharing.
Can you confirm please:
1. what your *CLI> sip show conf reports
2. that you made the the SIP T1: 2 and the Reg Max Expires: 3600 changes on the the WIP310, not on your Asterisk server
Patrick
01-25-2010 05:40 PM
I made the changes to the WIP310 and not the asterisk server.
freepbx*CLI> sip show settings
freepbx*CLI>
Global Settings:
SIP Port: 5060
Videosupport: No
AutoCreatePeer: No
Promsic. redir: No
Realm. auth: No
Always auth rejects: Yes
Caller ID: Unknown
Call Events: Off
IP ToS SIP: CS3
Codecs: 0xe (gsm|ulaw|alaw)
Codec Order: ulaw:20,alaw:20,gsm:20
T1 minimum: 100
No premature media: No
Relax DTMF: No
DNS SRV lookup: Yes
Auto-Framing: No
Default Settings:
Nat: RFC3581
DTMF: rfc2833
Qualify: 0
Use ClientCode: No
MOH Suggest:
01-26-2010 03:40 AM
cspless24,
Which firmware version are you running? The alpha one or 5.0.11?
Thanks!
01-26-2010 07:46 AM
I am running the 5.0.11 firmware.
02-21-2011 12:39 PM
Patrick,
any news on the new FW 5.0.13? thanks
01-28-2010 12:32 AM
It seems that I am not alone... I have installed several WIP310 for SPA9000 on customer sites and faced the same problem - WIP310 was running unstable; sometimes shown as "Acquring Network", sometimes seems running normal but no response actually (i.e. no incoming/outgoing call could be made).
I tried to assign fixed ip to WIP310 but no improvement, it seems to be lost network connection after 20-30 seconds in idle state; even ping test was no response!!
I have upgrade firmware to 5.0.11 and change wifi router but the problem still could not be fixed :(
01-28-2010 01:30 AM
In response to Nelson-Wong's post - we were experience very similar issues with the handsets showing "aquiring network" or locking up, which we have seem to have got rid of by upgrading the firmware to the beta release posted earlier in this thread. It puts the firmware to version 5.0.12.
To everyone else - However we are still getting issues with the handsets dropping calls. We have traced this issue to the fact that when we roam with the handset between WiFi cells the call gets dropped as the WIP310 re-associates to the nearer Access Point. First there is a drop in the Voice stream (RTP) and then the call gets dropped. We have carried out the same test and walked the same route with a Cisco 7921G WiFi handset and it 'hands-off' seamlessly between WiFi cells. We have even walked the entire building (which has 9 access points) with the 7921, and the 'hand-offs' were seamless, with the call staying active.
We are now contemplating replacing all the WIP310s at the customers premise at a big cost to our company :(
01-28-2010 03:02 AM
Ok, se we now have 6 months or so of debate and 140 odd emails all confirming that the device in question is defective. Can someone from CISCO advise when we are all going to get a replacement device that works so I supply my postal address for shipment please? I hope CISCO is not waiting for the warranty period to expire.
Thank you
Dimitrios:(
