525 Intercom/Paging (as compared to 504)
dieswaytoofast
What is the appropriate header to send to a 525 to get it to 'auto-answer'?
Assuming that the config settings are correct (Auto_Answer_Page = Yes, etc.), we have the following -
   * On the 504, if the incoming INVITE contains the header   "Alert-Info: <info=alert-autoanswer>", then the phone will automatically pick up the call
   * On the 525, this header doesnt seem to do anything.
So
   a) Should we be using a different header? A different payload? "answer-after" or some such?
   b) Is there some additional setting that needs to be tweaked on the 525?
dieswaytoofast
More information:
   There are actually *two* headers on the incoming INVITE
Alert-Info: .
Call-Info: ;answer-after=0.
My Cisco525G2 running firmware 7.4.8 auto answers with only the following field in the Invite:
The configuration has the following set:
Yes
Yes
Are you running firmware version 7.4.8?  If not try upgrading to that version.  If you'd like you can attach a full config file and wireshark to this ticket and I will take a look.
-Adam
FYI - I also verified this with a 525G (not a G2) and tested both devices with 7-4-6 as well.  Both devices work with those two firmware versions and with that call-info field.
Hope that helps.
-Adam
Thanks Adam, that pretty much took care of the problem.  Somewhere along the way, Auto_Answer_Page got set to Yes in the config file.  I wasn't looking for it, as the default (Yes) is pretty much what I wanted.
I finally did the paranoid thing, and actually checked the settings on the fone (hmmm.  should have done that first thing, yes?), and was not-so-pleasantly surprised to find it set to No.
Thanx again.
