Cisco SPA525 XML resync issue with $PSN macro
adam.baird
I have a problem using the XML resync method with the Cisco 525G.  The issue is that when the  phone executes my resync xml file it expands $PSN to 'SPA525G' and not '525G'.
Even stranger, when I issue the same resync command via URL (or add it to the profile rule manually)  it expands $PSN correctly to '525G'.
For example:
The phone calls the my XML app:
<CiscoIPPhoneExecute>
        <ExecuteItem URL="Resync:tftp://<ip_removed>/spa$PSN.cfg"/>
</CiscoIPPhoneExecute>
and the result is (syslog message from phone):
Message: SPA525G 00:24:97:f0:5d:9e -- Requesting resync tftp://  <ip_removed>:69/spaSPA525G.cfg\n
Notice the extra capital 'SPA'.
If I resync via url:
http://192.168.1.5/admin/resync?tftp://<ip_removed>/spa$PSN.cfg
the result is correct:
Message: SPA525G 00:24:97:f0:5d:9e -- Requesting resync tftp://  <ip_removed>:69/spa525G.cfg\n
I have my SPA504Gs calling the same XML application and they work correctly.
Am I missing something?
-Adam
Alberto Montilla
Dear Adam;
Sorry for the delay replying. I'll get this escalated as it looks like a defect (you are using the right macros). Meanwhile, can you please let us know the firmware version you are using? If not the latest I suggest you upgrade and try again.
Stay tuned.
Alberto
nseto
Level 6
Level 6
Please let me know the version number and this will get looked at.  Thanks.
My 525 is running v7.4.6.
-Adam
Entered as a bug and should be fixed in the 7.4.7 release.
Bug # CSCtj80506
