Corlist on UC500
wbourguibartic
Hi all,
I have question regarding steup corlist on Cisco UC500 with CLI.
Outgoing calls are routed via a SIP trunk from a generic SIP provider.
There is my config :
dial-peer cor custom
name national
name gsm
name international
name urgence
dial-peer cor list droits-limites
member national
member urgence
dial-peer voice 1015 voip
corlist outgoing droits-limites
description Appels Locaux
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 1
destination-pattern 0[1-59]........
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
ephone-dn  4  dual-line
number 847
label 847
description TOTO
name TOTO
allow watch
corlist incoming droits-limites
transfer-mode consult
I have another dial-peer with no corlist configured.
When i make an outgoing call, It match with dial-peer wich have no corlist configured.
have you any idea ?
Thanks all.
Steven Smith
Level 7
Level 7
Does the other dial peer have a perference of 0 (which would mean no preference)?
If you do not have a cor list configure on the ephone-dn or the dial-peer, they are available to anyone.
Here is all the information you need to know about the subject.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Joseph Chambers
You will need to apply to all dial peers if you want to restrict access.
I've attached something - its for US but you should be able to see correlation.
Thanx for response guys, I had no time to configure it.
I will test it and give response asap.
Best regards.
