SIP trunk not registered
nicanor00
I have the uc-560 and a GSM gateway
The outgoing call on GSM gateway  are working fine, but incoming call are rejected
I have created a SIP trunk account for the GSM gateway, but he stil not registered
How can I solve it ?
Thanks in advance
You can see that the provider is failing on the registration attempt:
Sent:
REGISTER sip:172.25.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.0.1:5060;branch=z9hG4bK1992269
To: <79526723>
Date: Fri, 08 Oct 2010 16:25:06 GMT
Call-ID: 66AA8803-D21911DF-881DEFB4-7D00ADBA
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1286555106CSeq: 54 REGISTER
Contact: <79526723>
Expires:  3600
Supported: path
Content-Length: 0
000910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 501 Not Implemented
To: <79526723>
Max-Forwards: 70
CSeq: 54 REGISTER
Contact: <79526723>
Expires:  3600
Supported: path
Content-Length: 0
Is '79526723' a fully qualified number for where you are located?  Is this the number the provider wants you to register with?  Can you find out why they are throwing the 501 for registration request?  Have you confirmed that the provider does require registration of the number?
9 Replies 9
Steven Holl
What number are you supposed to register to the provider with?  Is that number configured on the system?  Typically you add it as a secondary number to your operator extension.  Something like:
ephone-dn  5  dual-line
number 301 secondary 5551234567 no-reg primary
That will get the router to try to register that number to the registrar.  You can see the status of that with:
sh sip-ua reg stat
If you still have issues, get 'debug ccsip mess' during while the timer for the above command rolls over.
Also, you don't need a username/password for authentication on this trunk?
I made the modification as you ask
But the problem remain the same
ephone-dn  29  dual-line
 number 220 secondary 99257890
 no-reg primary
C_560_EBACCION#show sip-ua register status
Line          peer           expires(sec)  registered   P-Associated-URI
99257890          20110            16            no
UC_560_EBACCION#
Sould I create a dial peer 20110 ?
please help
Registration on that number is failing.  Run 'debug ccsip mess' and observe the output of the register message for that number and what the provider's response is.
see below
000906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:226@172.25.0.1:5060 SIP/2.0Max-Forwards: 70Via: SIP/2.0/UDP 172.25.0.3:5060;branch=z9hG4bK-158028959-CX00From: <78273829>;tag=7C1EB3001750-46016091To: <226>Call-ID: 7C1EB3001750-110012660@172.25.0.3CSeq: 7 INVITEContact: <78273829>User-Agent: 2N VoiceBlue V-02.07.35i30Allow: INVITE, BYE, ACK, CANCEL, OPTIONS, REFER, NOTIFYContent-Type: application/sdpContent-Length: 260v=0o=VoiceBlue 51132 9441 IN IP4 172.25.0.3s=GSM callc=IN IP4 172.25.0.3t=0 0m=audio 8050 RTP/AVP 18 8 0 101a=rtpmap:18 G729/8000a=fmtp:18 annexb=noa=rtpmap:8 PCMA/8000a=rtpmap:0 PCMU/8000a=rtpmap:101 telephone-event/8000a=fmtp:101 0-11
000907: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server ErrorVia: SIP/2.0/UDP 172.25.0.3:5060;branch=z9hG4bK-158028959-CX00From: <78273829>;tag=7C1EB3001750-46016091To: <226>;tag=4BC71F0-1D4Date: Fri, 08 Oct 2010 16:25:01 GMTCall-ID: 7C1EB3001750-110012660@172.25.0.3CSeq: 7 INVITEAllow-Events: telephone-eventServer: Cisco-SIPGateway/IOS-12.xContent-Length: 0
000908: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:226@172.25.0.1:5060 SIP/2.0Max-Forwards: 70Via: SIP/2.0/UDP 172.25.0.3:5060;branch=z9hG4bK-158028959-CX00From: <78273829>;tag=7C1EB3001750-46016091To: <226>;tag=4BC71F0-1D4Call-ID: 7C1EB3001750-110012660@172.25.0.3CSeq: 7 ACKContact: <78273829>User-Agent: 2N VoiceBlue V-02.07.35i30Allow: INVITE, BYE, ACK, CANCEL, OPTIONS, REFER, NOTIFYContent-Length: 0
000909: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:172.25.0.3:5060 SIP/2.0Via: SIP/2.0/UDP 172.25.0.1:5060;branch=z9hG4bK1992269From: <79526723>;tag=4BC84EC-16C9To: <79526723>Date: Fri, 08 Oct 2010 16:25:06 GMTCall-ID: 66AA8803-D21911DF-881DEFB4-7D00ADBAUser-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70Timestamp: 1286555106CSeq: 54 REGISTERContact: <79526723>Expires:  3600Supported: pathContent-Length: 0
Received:
SIP/2.0 501 Not ImplementedVia: SIP/2.0/UDP 172.25.0.1:5060;branch=z9hG4bK1992269From: <79526723>;tag=4BC84EC-16C9To: <79526723>Date: Fri, 08 Oct 2010 16:25:06 GMTCall-ID: 66AA8803-D21911DF-881DEFB4-7D00ADBAUser-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70Timestamp: 1286555106CSeq: 54 REGISTERContact: <79526723>Expires:  3600Supported: pathContent-Length: 0
see the uc-560 sip trunk printsreen attached
Please help
see again the debug output
I am using a gsm gateway with 2 SIM card from 2 different operator
The uc ask a company main number to be used as outgoing caller ID
wich number should i use
May be  the problem come from there
Please help
debug ccsip messages
004438: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:201@0.0.0.0:5060 SIP/2.0
Max-Forwards: 70
Via: SIP/2.0/UDP 192.168.1.3:5060;branch=z9hG4bK-152027812-CX00
To: <201>
Call-ID: 7C1EB3001750-81015425@192.168.1.3
CSeq: 17 INVITE
Contact: <67893567>
User-Agent: 2N VoiceBlue V-02.07.35i39
Content-Length: 261
v=0
o=VoiceBlue 23785 14378 IN IP4 192.168.1.3
s=GSM call
c=IN IP4 192.168.1.3
t=0 0
m=audio 8048 RTP/AVP 18 8 0 101
a=fmtp:18 annexb=no
a=fmtp:101 0-11
004439: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
004440: //-1/0B5ABB929762/SIP/Error/sact_idle_new_message_invite: Invalid URL in incoming INVITE
004441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
To: <201>;tag=291E5698-1A4B
Date: Fri, 15 Oct 2010 16:56:52 GMT
CSeq: 17 INVITE
Reason: Q.850;cause=100
Content-Length: 0
004442: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:201@0.0.0.0:5060 SIP/2.0
Max-Forwards: 70
CSeq: 17 ACK
Contact: <67893567>
Content-Length: 0
004443: //-1/0B5ABB929762/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x87EB3A08
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           :
Called Number            : 201
Source IP Address (Sig  ): 192.168.1.1
Destn SIP Req Addr:Port  : 192.168.1.3:0
Destn SIP Resp Addr:Port : 192.168.1.3:5060
Destination Name         : 192.168.1.3
004444: //-1/0B5ABB929762/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 100
Disconnect Cause (SIP)   : 400
Sent:
To: <79526723>
Max-Forwards: 70
Contact: <79526723>
Expires:  3600
Supported: path
Content-Length: 0
Received:
To: <79526723>
Max-Forwards: 70
CSeq: 54 REGISTER
Contact: <79526723>
Expires:  3600
Supported: path
Content-Length: 0
For this, you can see that the INVITE coming in has a TO header with an invalid IP:
Received:
Max-Forwards: 70
To: <201>
CSeq: 17 INVITE
Contact: <67893567>
Content-Length: 261
That invite should have a valid IP in there.  Something is stripping that to 0's, perhaps?  Or maybe that's behavior of the sending SIP proxy as a result of you not being registered?
See below another debig output
I am using a GSM gateway with 2 SIM card from 2 different operator, so there is no trunk ISP main number
I used one number of the 2 sim card as trunk ISP number
Please help
004781: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.1.1:5060 SIP/2.0
Max-Forwards: 70
Via: SIP/2.0/UDP 192.168.1.3:5060;branch=z9hG4bK-242011176-CX04
To: <67893567>
Call-ID: 7C1EB3001750-10022159@192.168.1.3
CSeq: 27 REGISTER
Contact: <67893567>
Expires: 600
Content-Length: 0
004782: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <67893567>
Date: Sat, 16 Oct 2010 10:24:57 GMT
CSeq: 27 REGISTER
Content-Length: 0
004783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 423 Interval Too Brief
To: <67893567>;tag=2CDDE31C-20B
CSeq: 27 REGISTER
Min-Expires:  3600
Content-Length: 0
004784: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:192.168.1.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK10E91964
To: <67893567>
Date: Sat, 16 Oct 2010 10:25:22 GMT
Call-ID: 96046F4C-D7B711DF-977CEFB4-7D00ADBA
Max-Forwards: 70
Timestamp: 1287224722
CSeq: 343 REGISTER
Contact: <67893567>
Expires:  3600
Supported: path
Content-Length: 0
004785: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: via branch list is:
004786: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList:     end of list
004787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <67893567>
CSeq: 343 REGISTER
Either way, you need to reach out to the device responding to the REGISTER message to find out what they don't like about the formatting, and why they respond with a 5xx.
