12-07-2012 12:54 PM - edited 03-21-2019 06:42 AM
I have an AA set up to answer all incoming calls and transfer calls to 2 separate BACD group depending on what key is pressed. This seems to be causing CUE to hang and ring busy at times. Reloading CUE fixes the problem. STAC has told me that the customer can either have AA or BACD but not both. Just wondering if anyone else has had this issue and if so if they have found some kind of solution. Ie. having the AA transfer to an extension and then have that extension CFNA set to the BACD number. Any help would be appreciated.
Solved! Go to Solution.
12-07-2012 01:55 PM
All indications I gave above apply perfectly to UC500 systems.
Thank you for the nice rating and good luck!
12-07-2012 02:05 PM
Hi Shaun,
First of all there us no problems with running an AA along side of a B-ACD, I have deployed quite a few systems in the past that required both.
I am not sure why STAC said that to you, but then again I'm not sure why they say half the things they say half the time :-)
What will get you into a bind is of you try and do a multi-layered AA along side a B-ACD, this has caused significant grief in the past.
Can you provide some more information as to what is the current Software Pack being used and do you have any debug messages of when it freezes at all?
Cheers,
David Trad.
Sent from Cisco Technical Support Android App
12-07-2012 01:35 PM
First of all, you can have CUE AA and B-ACD work together, documented and supported:
Maybe if you update CUE, it will stop giving trouble..
Or, you can configure menu choices in B-ACD/AA directly, and eliminate CUE AA altogether.
12-07-2012 01:43 PM
I failed to mention that this problem is on a UC540 system
12-07-2012 01:55 PM
12-07-2012 02:03 PM
Thank you
12-07-2012 02:05 PM
Hi Shaun,
Cheers,
David Trad.
12-10-2012 08:53 AM
David
I am using a multi level AA so that may be what is causing the trouble. As far as software, I am running 8.6.1, and unfortunately I don't have any debug info. Everytime it hangs or crashes I am in such a rush to get the system back up and running I never bother to collect any of that info. I will try to rework the AA so that it can by a single menu and see if that helps.
Thanks for your assistance guys
05-18-2013 09:42 PM
Shaun, did changing the multi level AA to single resolve your issue? I was told the same thing by STAC. I have similar setup, but rather than multi level it's 3 separate AAs and at various points transfer to the same BACD hunt group
