UC520 Spontaneous Cold Boots
Hello, I am hearing from a client that their UC520 is spontaneously rebooting during the day.  They said it happened a couple times last week and just a few hours ago.
I went into the CCA and pulled the attached Log File, but am not sure what to look for in this instance.
I would appreciate if someone can look it over and let me know if they see a cause.
Thank you, Paul
19 Replies 19
Brandon Turpin
Hi Paul,
I looked at the logs you attached and it only has information showing the UC520 coming back online after the crash.  If the UC520 is crashing, there should be some crashinfo files on the flash.  You will want to gather those files and open a TAC case so they can be decoded.  The crashinfo files will have information leading up to the crashes.
Brandon
Brandon, thank you!
Is there a simple way to access the crash files using CCA?
If not let me know how in order to have TAC take a look.
Thank you, Paul
Hi Paul,
In CCA, go to Maintenance > File Management.  When the File Management window comes up, click on the Files tab and you should be able to see the files on the flash.  You can even upload them to your computer when you find them.
Hope that helps.
Brandon
David Trad
Hi Paul,
The alternative way to get them if everything else fails is to use a compact flash card reader and, take the flash card out and do a dump of the files onto the computer, the only side effect to the system is that MOH wont play until the card is reinserted back in
Just another way of doing it in case you have issues doing it another way
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
David/Brandon, I am attaching the "crash" files.  If you can read them let me know what you think.
Thank you and Happy Holidays, Paul
Writing crashinfo to flash:crashinfo_20111221-132445-EDTInterface Dot11Radio0/5/0, Deauthenticating Station 60c5.4767.35fb Reason: Sending station has left the BSS SSID[CVMS-Wireless]
Dec 21 18:16:56.263: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 2 packets
Dec 21 18:10:19.575: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.127(443) -> 192.168.1.65(54925), 1 packet
Dec 21 18:16:59.543: %FW-6-DROP_PKT: Dropping tcp session 192.168.1.65:56277 17.172.232.109:5223  due to  Stray Segment with ip ident 41678 tcpflags 0x5004 seq.no 2593812686 ack 0
Dec 21 18:10:23.579: %SEC-6-IPACCESSLOGP: list 105 denied tcp 199.16.83.72(80) -> 192.168.1.65(54965), 1 packet
Dec 21 18:17:16.075: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.232.109(5223) -> 192.168.1.65(56277), 1 packet
Dec 21 18:10:25.679: %SEC-6-IPACCESSLOGP: list 105 denied tcp 178.255.83.1(80) -> 192.168.1.65(54971), 1 packet
Dec 21 18:17:28.087: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51781), 1 packet
Dec 21 18:10:27.583: %SEC-6-IPACCESSLOGP: list 105 denied tcp 50.63.243.230(80) -> 192.168.1.65(54979), 1 packet
Dec 21 18:17:32.095: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51784), 1 packet
Dec 21 18:10:31.699: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.122(443) -> 192.168.1.65(54968), 1 packet
Dec 21 18:17:34.103: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51779), 1 packet
Dec 21 18:10:33.595: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.11(110) -> 192.168.1.65(51671), 1 packet
Dec 21 18:10:34.023: %FW-6-DROP_PKT: Dropping Other session 192.168.1.65:54938 23.1.17.134:443  due to  RST inside current window with ip ident 14612 tcpflags 0x5014 seq.no 2839766117 ack 297410558
Dec 21 18:17:48.695: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56284  due to  Stray Segment with ip ident 28649 tcpflags 0x5010 seq.no 636990538 ack 4031557464
Dec 21 18:10:35.691: %SEC-6-IPACCESSLOGP: list 105 denied tcp 208.71.125.129(443) -> 192.168.1.65(54957), 1 packet
Dec 21 18:17:52.119: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51782), 1 packet
Dec 21 18:10:39.607: %SEC-6-IPACCESSLOGP: list 105 denied tcp 199.7.48.72(80) -> 192.168.1.65(54981), 1 packet
Dec 21 18:17:56.199: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 8 packets
Dec 21 18:10:41.611: %SEC-6-IPACCESSLOGP: list 105 denied tcp 98.139.225.43(443) -> 192.168.1.65(54956), 1 packet
Dec 21 18:18:00.127: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.19(143) -> 192.168.1.65(54918), 1 packet
Dec 21 18:10:55.627: %SEC-6-IPACCESSLOGP: list 105 denied tcp 23.1.17.134(443) -> 192.168.1.65(54938), 1 packet
Dec 21 18:10:56.071: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 12 packets
Dec 21 18:18:06.243: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56282), 1 packet
Dec 21 18:11:11.643: %SEC-6-IPACCESSLOGP: list 105 denied tcp 67.214.159.90(443) -> 192.168.1.65(54969), 1 packet
Dec 21 18:18:12.139: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56290), 1 packet
Dec 21 18:11:39.671: %SEC-6-IPACCESSLOGP: list 105 denied tcp 68.67.159.186(443) -> 192.168.1.65(54974), 1 packet
Dec 21 18:18:16.155: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56306), 1 packet
Dec 21 18:11:56.199: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 2 packets
Dec 21 18:18:18.443: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56326  due to  Stray Segment with ip ident 40587 tcpflags 0x5010 seq.no 4163388234 ack 157520278
Dec 21 18:12:00.283: %FW-6-DROP_PKT: Dropping Other session 209.87.113.100:443 192.168.10.24:54982  due to  Stray Segment with ip ident 49681 tcpflags 0x5010 seq.no 1618168484 ack 918057987
Dec 21 18:18:22.255: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56314), 1 packet
Dec 21 18:12:13.691: %SEC-6-IPACCESSLOGP: list 105 denied tcp 131.103.137.80(80) -> 192.168.1.65(51672), 1 packet
Dec 21 18:18:24.179: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56311), 1 packet
Dec 21 18:12:15.719: %SEC-6-IPACCESSLOGP: list 105 denied tcp 209.87.113.100(443) -> 192.168.1.65(54982), 1 packet
Dec 21 18:18:28.183: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56319), 1 packet
Dec 21 18:12:25.775: %SEC-6-IPACCESSLOGP: list 105 denied tcp 209.87.113.100(443) -> 192.168.1.65(54984), 1 packet
Dec 21 18:18:34.191: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56325), 1 packet
Dec 21 18:12:31.827: %SEC-6-IPACCESSLOGP: list 105 denied tcp 209.87.113.100(443) -> 192.168.1.65(54983), 1 packet
Dec 21 18:18:42.203: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56337), 1 packet
Dec 21 18:12:47.727: %SEC-6-IPACCESSLOGP: list 105 denied tcp 209.87.113.100(443) -> 192.168.1.65(54987), 1 packet
Dec 21 18:18:46.215: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56352), 1 packet
Dec 21 18:12:56.199: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 3 packets
Dec 21 18:18:52.203: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56357), 1 packet
Dec 21 18:12:59.875: %SEC-6-IPACCESSLOGP: list 105 denied tcp 50.22.198.100(443) -> 192.168.1.65(54955), 1 packet
Dec 21 18:18:54.519: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56395  due to  Stray Segment with ip ident 41975 tcpflags 0x5010 seq.no 1825954686 ack 2460554365
Dec 21 18:13:21.787: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.19(143) -> 192.168.1.65(55008), 1 packet
Dec 21 18:18:56.199: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 67 packets
Dec 21 18:13:25.851: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.19(143) -> 192.168.1.65(55007), 1 packet
Dec 21 18:18:58.235: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56373), 1 packet
Dec 21 18:13:35.803: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.199(110) -> 192.168.1.65(51674), 1 packet
Dec 21 18:19:04.243: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56381), 1 packet
Dec 21 18:13:39.807: %SEC-6-IPACCESSLOGP: list 105 denied tcp 209.87.113.100(443) -> 192.168.1.65(54985), 1 packet
Dec 21 18:19:08.247: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51794), 1 packet
Dec 21 18:13:41.899: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.19(143) -> 192.168.1.65(55009), 1 packet
Dec 21 18:19:12.251: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51791), 1 packet
Dec 21 18:13:43.815: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.19(143) -> 192.168.1.65(55006), 1 packet
Dec 21 18:19:16.263: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56404), 1 packet
Dec 21 18:13:56.199: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 6 packets
Dec 21 18:19:22.251: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56416), 1 packet
Dec 21 18:14:10.107: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.84(443) -> 192.168.1.65(54923), 1 packet
Dec 21 18:19:25.575: %FW-6-DROP_PKT: Dropping Other session 192.168.1.65:56442 17.172.116.74:443  due to  Stray Segment with ip ident 36196 tcpflags 0x5010 seq.no 2399934676 ack 3774724163
Dec 21 18:14:13.939: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.113(443) -> 192.168.1.65(54926), 1 packet
Dec 21 18:19:30.295: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56421), 1 packet
Dec 21 18:14:19.855: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.127(443) -> 192.168.1.65(54928), 1 packet
Dec 21 18:19:34.295: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56432), 1 packet
Dec 21 18:14:21.859: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.59(443) -> 192.168.1.65(54945), 1 packet
Dec 21 18:19:36.303: %SEC-6-IPACCESSLOGP: list 105 denied tcp 131.103.137.97(80) -> 192.168.1.65(55023), 1 packet
Dec 21 18:14:23.859: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.84(80) -> 192.168.1.65(54921), 1 packet
Dec 21 18:19:42.307: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56437), 1 packet
Dec 21 18:14:35.871: %SEC-6-IPACCESSLOGP: list 105 denied tcp 131.103.137.80(80) -> 192.168.1.65(55014), 1 packet
Dec 21 18:19:46.311: %SEC-6-IPACCESSLOGP: list 105 denied tcp 97.74.135.111(110) -> 192.168.1.65(51680), 1 packet
Dec 21 18:15:01.899: %SEC-6-IPACCESSLOGP: list 105 denied tcp 64.4.11.160(80) -> 192.168.1.65(55016), 1 packet
Dec 21 18:19:52.315: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56455), 1 packet
Dec 21 18:15:03.915: %SEC-6-IPACCESSLOGP: list 105 denied tcp 131.103.137.88(80) -> 192.168.1.65(51775), 1 packet
Dec 21 18:19:55.591: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56488  due to  Stray Segment with ip ident 46649 tcpflags 0x5010 seq.no 3368255933 ack 2394204794
Dec 21 18:19:56.071: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 95 packets
Dec 21 18:15:12.019: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.51(443) -> 192.168.1.65(54950), 1 packet
Dec 21 18:19:58.331: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56471), 1 packet
Dec 21 18:15:14.139: %FW-6-DROP_PKT: Dropping Other session 23.0.220.74:443 192.168.10.24:54940  due to  Stray Segment with ip ident 10747 tcpflags 0x5011 seq.no 2281443 ack 1178903939
Dec 21 18:20:00.415: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56469), 1 packet
Dec 21 18:15:23.939: %SEC-6-IPACCESSLOGP: list 105 denied tcp 63.236.252.155(80) -> 192.168.1.65(54942), 1 packet
Dec 21 18:20:04.347: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56480), 1 packet
Dec 21 18:15:29.995: %SEC-6-IPACCESSLOGP: list 105 denied tcp 208.71.125.52(443) -> 192.168.1.65(54963), 1 packet
Dec 21 18:20:06.347: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.80(3535) -> 192.168.1.65(51795), 1 packet
Dec 21 18:15:32.515: %DOT11-6-ASSOC: Interface Dot11Radio0/5/0, Station   60c5.4767.35fb Associated SSID[CVMS-Wireless] AUTH_TYPE[OPEN] KEY_MGMT[WPAv2 PSK]
Dec 21 18:20:10.399: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56491), 1 packet
Dec 21 18:15:33.959: %SEC-6-IPACCESSLOGP: list 105 denied tcp 63.236.252.152(80) -> 192.168.1.65(54980), 1 packet
Dec 21 18:20:12.355: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56485), 1 packet
Dec 21 18:15:37.963: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51777), 1 packet
Dec 21 18:20:14.367: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51796), 1 packet
Dec 21 18:15:42.067: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51778), 1 packet
Dec 21 18:20:18.375: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56496), 1 packet
Dec 21 18:15:52.039: %SEC-6-IPACCESSLOGP: list 105 denied tcp 74.125.225.44(80) -> 192.168.1.65(55003), 1 packet
Dec 21 18:20:22.371: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56500), 1 packet
Dec 21 18:15:56.247: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 31 packets
Dec 21 18:20:25.691: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56518  due to  Stray Segment with ip ident 61129 tcpflags 0x5010 seq.no 2371193645 ack 1631918541
Dec 21 18:16:18.291: %FW-6-DROP_PKT: Dropping pop3 session 72.167.218.192:110 192.168.10.26:51677  due to  Invalid Ack (or no Ack) with ip ident 52191 tcpflags 0x6012 seq.no 1012630931 ack 1012630931
Dec 21 18:20:30.483: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56501), 1 packet
Dec 21 18:16:42.035: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51783), 1 packet
Dec 21 18:20:34.395: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56511), 1 packet
Dec 21 18:16:44.271: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.218.187(143) -> 192.168.1.65(51780), 1 packet
Dec 21 18:20:42.411: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56518), 1 packet
Dec 21 18:20:46.387: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56524), 1 packet
Dec 21 18:20:48.483: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56519), 1 packet
Dec 21 18:20:52.415: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56534), 1 packet
Dec 21 18:20:54.419: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56533), 1 packet
Dec 21 18:20:56.203: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 65 packets
Dec 21 18:20:58.423: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56544), 1 packet
Dec 21 18:21:00.495: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56568  due to  Stray Segment with ip ident 55497 tcpflags 0x5010 seq.no 1699325760 ack 4266981494
Dec 21 18:21:06.431: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56549), 1 packet
Dec 21 18:21:10.411: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56557), 1 packet
Dec 21 18:21:18.439: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56565), 1 packet
Dec 21 18:21:20.443: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.19(143) -> 192.168.1.65(55024), 1 packet
Dec 21 18:21:24.447: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56573), 1 packet
Dec 21 18:21:26.451: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51800), 1 packet
Dec 21 18:21:28.535: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51802), 1 packet
Dec 21 18:21:30.455: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.80(3535) -> 192.168.1.65(51803), 1 packet
Dec 21 18:21:30.651: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56608  due to  Stray Segment with ip ident 826 tcpflags 0x5010 seq.no 2914578016 ack 1581316368
Dec 21 18:21:34.463: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56600), 1 packet
Dec 21 18:21:38.467: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51798), 1 packet
Dec 21 18:21:42.471: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56604), 1 packet
Dec 21 18:21:48.479: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56608), 1 packet
Dec 21 18:21:52.487: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56609), 1 packet
Dec 21 18:21:56.199: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 67 packets
Dec 21 18:22:00.579: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56612), 1 packet
Dec 21 18:22:01.283: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56641  due to  Stray Segment with ip ident 34917 tcpflags 0x5011 seq.no 573515037 ack 2957342275
Dec 21 18:22:08.483: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56628), 1 packet
Dec 21 18:22:10.507: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56636), 1 packet
Dec 21 18:22:12.507: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56631), 1 packet
Dec 21 18:22:18.523: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56639), 1 packet
Dec 21 18:22:22.519: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56642), 1 packet
Dec 21 18:22:28.527: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56644), 1 packet
Dec 21 18:22:31.567: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56680  due to  Stray Segment with ip ident 27252 tcpflags 0x5010 seq.no 2237289620 ack 3823743146
Dec 21 18:22:34.615: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.232.64(5223) -> 192.168.1.65(56586), 1 packet
Dec 21 18:22:36.539: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56660), 1 packet
Dec 21 18:22:40.551: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56676), 1 packet
Dec 21 18:22:48.559: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56678), 1 packet
Dec 21 18:22:52.563: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51804), 1 packet
Dec 21 18:22:54.567: %SEC-6-IPACCESSLOGP: list 105 denied tcp 173.201.192.71(143) -> 192.168.1.65(51805), 1 packet
Dec 21 18:22:56.199: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 69 packets
Dec 21 18:22:58.767: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56692), 1 packet
Dec 21 18:23:04.579: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56704), 1 packet
Dec 21 18:23:06.579: %SEC-6-IPACCESSLOGP: list 105 denied tcp 72.167.82.80(3535) -> 192.168.1.65(51807), 1 packet
Dec 21 18:23:06.751: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56736  due to  Stray Segment with ip ident 55087 tcpflags 0x5010 seq.no 3257417589 ack 4135072037
Dec 21 18:23:10.587: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56708), 1 packet
Dec 21 18:23:12.599: %SEC-6-IPACCESSLOGP: list 105 denied tcp 65.55.200.155(443) -> 192.168.1.65(51686), 1 packet
Dec 21 18:23:16.603: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56724), 1 packet
Dec 21 18:23:24.623: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56736), 1 packet
Dec 21 18:23:28.639: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56740), 1 packet
Dec 21 18:23:34.635: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56753), 1 packet
Dec 21 18:23:36.635: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56752), 1 packet
Dec 21 18:23:36.919: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56780  due to  Stray Segment with ip ident 11326 tcpflags 0x5010 seq.no 309123130 ack 4093638645
Dec 21 18:23:40.731: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56756), 1 packet
Dec 21 18:23:46.659: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56772), 1 packet
Dec 21 18:23:52.667: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56775), 1 packet
Dec 21 18:23:56.203: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 80 packets
Dec 21 18:23:58.679: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56784), 1 packet
Dec 21 18:24:04.687: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56788), 1 packet
Dec 21 18:24:10.695: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56800), 1 packet
Dec 21 18:24:12.407: %FW-6-DROP_PKT: Dropping Other session 17.172.116.74:443 192.168.10.28:56828  due to  Stray Segment with ip ident 57502 tcpflags 0x5010 seq.no 3645266840 ack 2977114326
Dec 21 18:24:16.691: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56804), 1 packet
Dec 21 18:24:22.723: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56820), 1 packet
Dec 21 18:24:28.819: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56828), 1 packet
Dec 21 18:24:34.743: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56829), 1 packet
Dec 21 18:24:36.743: %SEC-6-IPACCESSLOGP: list 105 denied tcp 63.141.200.18(80) -> 192.168.1.65(55026), 1 packet
Dec 21 18:24:40.747: %SEC-6-IPACCESSLOGP: list 105 denied tcp 17.172.116.74(443) -> 192.168.1.65(56839), 1 packet
ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1817
ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 2581
ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1816
%Software-forced reload
13:24:45 EDT Wed Dec 21 2011: Unexpected exception to CPU: vector 700, PC = 0x802BC140, LR = 0x802BC104
-Traceback= 0x802BC140z 0x802BC104z 0x80C21F70z 0x80C16118z 0x802BE3B0z 0x802C1050z
CPU Register Context:
MSR = 0x00029032  CR  = 0x28222042  CTR = 0x800325FC  XER   = 0x00000000
R0  = 0x802BC104  R1  = 0x86470608  R2  = 0xFFF5FFF5  R3    = 0x85754060
R4  = 0x00000004  R5  = 0x84D80000  R6  = 0x00009032  R7    = 0xF0000000
R8  = 0x6DFFFFFF  R9  = 0x85630000  R10 = 0x6D000000  R11   = 0x00000000
R12 = 0x24222088  R13 = 0xFFF569B0  R14 = 0x00000000  R15   = 0x8647D0B6
R16 = 0x85630000  R17 = 0x8648A93C  R18 = 0x0F647606  R19   = 0x00000000
R20 = 0x86470690  R21 = 0x86491C44  R22 = 0x86491B00  R23   = 0x86470720
R24 = 0x86491C44  R25 = 0x86470690  R26 = 0x864731C8  R27   = 0x00000000
R28 = 0x00000000  R29 = 0x86473E64  R30 = 0x85010000  R31   = 0x00000000
=== Start of Crashinfo Collection (13:24:45 EDT Wed Dec 21 2011) ===
For image:
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.0(1)XA3a, SBTG Special
Small Business Support: http://www.cisco.com/go/smallbizhelp
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 08-Jun-10 13:40 by SBTG
========= Show Alignment =============================
Alignment data for:
Total Spurious Accesses 5, Recorded 5
Address  Count  Traceback
       0      1  0x80C86570z  0x80C21F70z  0x80C16118z  0x802BE3B0z  0x802C1050z
       0      1  0x80C86574z  0x80C21F70z  0x80C16118z  0x802BE3B0z  0x802C1050z
       0      1  0x80C86570z  0x80C21F70z  0x80C0B1D8z  0x80CDF3FCz  0x802BF7F8z  0x80027574z  0x80027574z  0x802BF8B8z
       0      1  0x80C86574z  0x80C21F70z  0x80C0B1D8z  0x80CDF3FCz  0x802BF7F8z  0x80027574z  0x80027574z  0x802BF8B8z
       0      1  0x80C9354Cz  0x80C865A8z  0x80C21F70z  0x80C0B1D8z  0x80CDF3FCz  0x802BF7F8z  0x80027574z  0x80027574z
========= Malloc and Free Traces=====================
MallocFree Trace: ixmallocfree=0x24  ptr=0x85BAA558
85BAA438: 8A5A8A9C 81DE4F38 85C15EA8 4000030A 85C15EA8 81E237F4 86AB2480 4000030A
85BAA458: 86AB2480 81E237F4 85DFF004 3000005E 85DFF004 81DE4F38 86AC2F78 30000062
85BAA478: 86AC2F78 81DE4128 85DFF004 81DE2780 8AA7439C 30000090 8AA7439C 80A90118
85BAA498: 8AA7439C 80A52FD8 8A778824 30000026 8A778824 807FB08C 86AB2480 81E29740
85BAA4B8: 86AB2AC4 600001BE 86AC2F78 81DE2780 8A778824 807FB9C8 85C15EA8 81E29740
85BAA4D8: 85C164EC 60000140 8A5A8A9C 81DE2780 8744B188 30000072 8744B188 82AA112C
85BAA4F8: 8744B188 82AA17C4 8A0ED198 82A47BE0 8A0EE41C 60000688 8A778824 30000026
85BAA518: 8A778824 807FB08C 8A778824 807FB9C8 85E29E20 4000092A 85E29E20 82A47AF4
85BAA538: 8A778824 30000026 8A778824 807FB08C 8A778824 807FB9C8 85E29E20 82A47BE0
85BAA558: 85E2B0A4 600003DA 86AC2F78 81DE4F38 85DFF004 3000005E 85DFF004 81DE4128
85BAA578: 86AC2F78 81DE2780 8AA7439C 30000090 8AA7439C 80A90118 8AA7439C 80A52FD8
85BAA598: 8A778824 30000026 8A778824 807FB08C 86AB2480 81E29740 86AB2AC4 600001BE
85BAA5B8: 85DFF004 81DE2780 8A778824 807FB9C8 8AA766E4 81E29740 8AA76D28 6000014C
85BAA5D8: 8A5A8A9C 81DE2780 86ABA41C 82A47BE0 86ABB6A0 600004B6 8AA7439C 30000090
85BAA5F8: 8AA7439C 82C5CDA4 8AA7439C 82C5431C 8A778824 30000026 8A778824 807FB08C
85BAA618: 8A778824 807FB9C8 8A0ED198 4000092A 8A0ED198 82A47AF4 8A5A8A9C 30000064
========= Chunk Malloc and Chunk Free Traces=====================
85BA9F0C: 86061980 81A501E0 81A4EAF0 863ED360 80443F5C 8044E938
85BA9EF4: 86AC263C 82AA0C40 82AA3C54 863E3AAC 82AA0C40 82AA3CF4
85BA9EDC: 863EEB6C 8043CF60 8044E988 863EF184 8043D12C 8044E9D4
85BA9EC4: 863EF1AC 8043D12C 8044E9D4 863EF1AC 8043D204 8044E9D4
85BA9EAC: 863EEB6C 8043D0B0 8044E988 863E3AAC 82AA8CC8 82AA3CF4
85BA9E94: 86AC263C 82AA2A5C 82AA3C54 86AC263C 82AA0C40 82AA3C54
85BA9E7C: 863E3AAC 82AA0C40 82AA3CF4 863EEB6C 8043CF60 8044E988
85BA9E64: 863EF1AC 8043D12C 8044E9D4 863EF1AC 8043D204 8044E9D4
85BA9E4C: 863EEB6C 8043D0B0 8044E988 863E3AAC 82AA8CC8 82AA3CF4
85BA9E34: 86AC263C 82AA2A5C 82AA3C54 86AC263C 82AA0C40 82AA3C54
85BA9E1C: 863E3AAC 82AA0C40 82AA3CF4 863EEB6C 8043CF60 8044E988
85BA9E04: 863EF1AC 8043D12C 8044E9D4 863EF1AC 8043D204 8044E9D4
85BAA0EC: 863EEB6C 8043D0B0 8044E988 863E3AAC 82AA8CC8 82AA3CF4
85BAA0D4: 86AC263C 82AA2A5C 82AA3C54 86AC263C 82AA0C40 82AA3C54
85BAA0BC: 863E3AAC 82AA0C40 82AA3CF4 863EEB6C 8043CF60 8044E988
85BAA0A4: 863EF1AC 8043D12C 8044E9D4 863ECB8C 804483C8 8044E8E8
85BAA08C: 863ECBB0 804483C8 8044E8E8 863ECBD4 804483C8 8044E8E8
85BAA074: 863EF1AC 8043D204 8044E9D4 863EEB6C 8043D0B0 8044E988
85BAA05C: 863E3AAC 82AA8CC8 82AA3CF4 86AC263C 82AA2A5C 82AA3C54
85BAA044: 86AC263C 82AA0C40 82AA3C54 863E3AAC 82AA0C40 82AA3CF4
85BAA02C: 863EEB6C 8043CF60 8044E988 863EF1AC 8043D12C 8044E9D4
85BAA014: 863EF1AC 8043D204 8044E9D4 863EEB6C 8043D0B0 8044E988
85BA9FFC: 863E3AAC 82AA8CC8 82AA3CF4 86AC263C 82AA2A5C 82AA3C54
85BA9FE4: 86AC263C 82AA0C40 82AA3C54 863E3AAC 82AA0C40 82AA3CF4
85BA9FCC: 863EEB6C 8043CF60 8044E988 863EF1AC 8043D12C 8044E9D4
85BA9FB4: 863ECB8C 804482E0 8044E8E8 863ECBB0 804482E0 8044E8E8
85BA9F9C: 863ECBD4 804482E0 8044E8E8 863EF1AC 8043D204 8044E9D4
85BA9F84: 863EEB6C 8043D0B0 8044E988 863E3AAC 82AA8CC8 82AA3CF4
85BA9F6C: 86AC263C 82AA2A5C 82AA3C54 86AC263C 82AA0C40 82AA3C54
85BA9F54: 863E3AAC 82AA0C40 82AA3CF4 863EEB6C 8043CF60 8044E988
85BA9F3C: 863EF1AC 8043D12C 8044E9D4 86B3B394 81A48BAC 81A473EC
85BA9F24: 863EF1AC 8043D204 8044E9D4 863EEB6C 8043D0B0 8044E988
========== Stack Trace========
========= Context ======================
Signal = 23 Vector = 0x700
PC  = 0x802BC140  MSR = 0x00029032  CR  = 0x28222042  LR    = 0x802BC104
CTR = 0x800325FC  XER = 0x00000000  DAR = 0x00000000  DSISR = 0x04000000
DEC = 0xE8B3689D  TBU = 0x00002C5F  TBL = 0x174C64CF  IMMR  = 0x00000000
========= Stack Dump ==========================
Stack Frame Pointer in Context is 0x86470608, at process level
86470208: 86470238        8        8 86470300 86470230 8387CC90 864702A8 86470418
86470228: 84CF0000 86470300 86470250 8387CDA4        0      2A0 864702A8 86470300
86470248: 88217FCC 85C175F8 86470298 8387CFEC 86470280 82FB6B48 B57A6B95  A99F3A1
86470268: E8412EDD 84AC6983 EF0E6399 86AF36D6 86470290 86496E50 864702F0 86470438
86470288: 86470418 864702A8 86470298 8387CF70 864703C0 8387D068 86470310    D0009
864702A8:   2C2C00 864702CF    C0008    D0009 86470340 28284024        0        0
864702C8: 86470348        7 864702F0 864708B0 800325FC FFFFFFFF        0 860378DC
864702E8:        0 89F7D634 86470310 80313C50 28002082 86470370 8031393C 85630000
86470308: 89F7D634        0 86470368 80319B08 81371700 86470370 85630000 85630000
86470328:        1 85630000 80C87618        1        0        0 85630000 85630000
86470348:        0        0 85630000 86470370 85630000 85630000 89F7D634 86470628
86470368: 86470668 81371704 29D4E0FA  33F41B2 6618D51B 5C5C5C5C 5C5C5C5C 5C5C5C5C
86470388: 5C5C5C5C 5C5C5C5C 5C5C5C5C 5C5C5C5C    70700 1B10101B  F683740        0
864703A8:        0        0 864703C0 85C17604 88217FCC 28288028        0        0
864703C8: 8AA85378 8AA85618        0        1 8647AA2C 8647E0E0       48        0
864703E8: 8648E75C 864731C8 8647A93C 8648E75C 8648A93C 8AA85378 89CCCE70 8647AA2C
86470408: 86470448 80C1B238 81303B50 84393628 BEC98739 FE551848 28288022        0
86470428:        7 8648A93C 864731C8        0 8648E75C        0 86470458 89CCCE70
86470448: 86470538 8647046F      26A        1 86470508 81387250 864704D0 864707E0
86470468: 60C54767 35FB0000 36313831 85630000 60C54767 35FB1AA4 864704F0 85630000
86470488: 864704A0 EB001658 85630000 864704A0 8003355C F0004500 864704B8 80033514
864704A8: 8399B38A        0        0 FFFFFFFE 864704D0 813858C0        0 86473E64
864704C8: 7FFFFFFF FFFFFFFE 86470580 81387910 24222082        0 8031393C 857542BC
864704E8: 8A77F6E8        0 86470548 80315A58 8136E5FC 87924490        0 8647D0B6
86470508: 85630000 8648A93C  F647606        0        0 86491C44 83D1E664        0
86470528: 85630000        0        0 24222088        0 8647D0B6 85630000 8648A93C
86470548:  F647606        0 86470690 86491C44 86491B00 86470720 86491C44 86470690
86470568: 864731C8        0        0 86473E64        1 FFFFFFFE 86470608 81385B6C
86470588:      718     9032 864705F0        7        1 864705E8 85630000 864708B0
864705A8: 86470618        0 864705D0        4 86470628 24008084 864A354C 84008084
864705C8:  F680A00 86492198  3000608 864705F0 86470568 82A9A5AC 864C2F3C 85F98480
864705E8: 86470600 8139D2AC  2000043 86470610 86470608 86470608 85010000        0
86470608: 86470618 802BC104 864C2F3C 8647A93C 86470680 80C86588  F6475FC        0
86470628: 86470680 80319B08 80C22EA0 85A99238        0 8647D0B6 85630000 8648A93C
86470648:  F647606        0 86470690 86491C44 86491B00        E        0       80
86470668: 864731C8        0 8647A93C 86473E64  F6475FC 864A4290 86470790 80C21F70
86470688: 8A51F558 85640000 864706C0 8136E760  3000000        0        0   520457
864706A8:       91    B0000        8        0  F6475FC        7        1 86470730
864706C8:  3000000        3        3  3000000 F0000000 6DFFFFFF FFFFFFFF        0
864706E8:        0 2E865BC4        0 28004048        0        0 86470708        0
86470708: 86470740 82A9945C        0 2E865BEC  3000000 86470738        0 48008044
86470728:        0 85F98480 86470748 8139D2AC       43 864707A0 86470788 44008084
86470748: 80C15E74        0        0        0        0 864707E0 85A30000 850D0000
86470768: 84330000 85A30000 86491C44 864707A0 86073614 86491B00 864731C8        0
86470788: 8647A93C       80 86470868 80C16118 FFFFFFFF FFFFFFFF        0        0
864707A8:        0 864707C0        0 2E865BEC     4202        0 86470800 86470800
864707C8: 864707A0        0        0 2E865BEC    14244        0        0        0
864707E8: 864707A0        0        0        0     4240        0        0 864707C0
86470808: 864707A0        0        0 2E865BEC    24244        0        0 2E865BEC
86470828:        4        4        0        0        0        0        0        0
86470848:        0        0        0        0        0        0        0        0
86470868: 86470870 802BE3B0        0 802C1050 FFFFFFFF FD0110DF AB1234CD   430000
86470888:       43 83EABE48 82AA665C 86470B94 8646F0F0 80000172        1        0
864708A8:       4A 85FADD24 8646F10C 86016CD4        0 80C15E74        0        0
864708C8:        0        0 864707E0 85A30000 850D0000 84330000 85A30000 86491C44
864708E8: 864707A0        0 80C88680 85630000 86470BC4        0 85630000 48008088
86470908: 82AA03F0     9032        0        0        0 80C15E74        0    10000
86470928:        1    10000        0        0        0       43        0        0
86470948:        0   15AC34   13AB14    104E4        0        0        0       43
86470968:        0        0        0 2E865BC4        0        0        0 2E865BD8
86470988:        0 2E865BD8     3FE8      2E0      E25 8678AA34  134E38E        0
864709A8: 8432F184        4       60        0        0        1        0     1770
864709C8:     1770 85F98480        0        0        0        0        0 861580E0
864709E8:        0 864708B0 858C4A70        0        0        0 8569DC70        0
========= Process Level Info ==================
---- Current Process Block (at 0x864708B0) ----
86470880: AB1234CD   430000       43 83EABE48 82AA665C 86470B94 8646F0F0 80000172
864708A0:        1        0       4A 85FADD24 8646F10C 86016CD4        0 80C15E74
864708C0:        0        0        0        0 864707E0 85A30000 850D0000 84330000
864708E0: 85A30000 86491C44 864707A0        0 80C88680 85630000 86470BC4        0
86470900: 85630000 48008088 82AA03F0     9032        0        0        0 80C15E74
86470920:        0    10000        1    10000        0        0        0       43
86470940:        0        0        0   15AC34   13AB14    104E4        0        0
86470960:        0       43        0        0        0 2E865BC4        0        0
86470980:        0 2E865BD8        0 2E865BD8     3FE8      2E0      E25 8678AA34
864709A0:  134E38E        0 8432F184        4       60        0        0        1
864709C0:        0     1770     1770 85F98480        0        0        0        0
864709E0:        0 861580E0        0 864708B0 858C4A70        0        0        0
86470A00: 8569DC70        0        0        0     420E        0        0        0
86470A20: 864709F8        0        0        0     4294        0 864708B0        0
86470A40:        0        0 864709F8 864708B0        0        0    142D2        0
86470A60:        0        0 864709F8 864708B0        0        0    242D2        0
86470A80:        0        0        0        0        0 86470BC4        0        0
86470AA0:        0        0        0        0        0        0 8678F680 86470C54
86470AC0: 86470AA8 86470BCC        0 85BBEAA8        0        0        0        0
86470AE0:        0  FFFFFFF  FFFFFFF        0        0        0        0        0
86470B00:        0 2E863BC0        0 86470D94        0        0 FFFFFFAC        0
86470B20:        0        0        0        0        0     10B0 86118F8C 86118F8C
86470B40: 85FADD78 86470BD4 86470B38 857FCF0C      28C    D0000        1        0
86470B60: 849D57A0 82A9865C 8549413C        0 85FADD24        0        0        0
86470B80:        0        0        0 BEEFCAFE
---- Partial decode of process block ----
Pid 67: Process "Dot11 driver" stack 0x8646F10C savedsp 0x86016CD4
Flags: analyze prefers_new wakeup_posted
Status     0x00000000 Orig_ra   0x00000000 Routine    0x80C15E74 Signal 0
Caller_pc  0x00000000 Callee_pc 0x00000000 Dbg_events 0x00000000 State  0
Totmalloc  1420340    Totfree   1288980    Totgetbuf  0
Totretbuf  0          Edisms    0x0        Eparm 0x0
Elapsed    0x3FE8     Ncalls    0x134E38E  Ngiveups 0x0
Priority_q 4          Ticks_5s  96         Cpu_5sec   0        Cpu_1min 1
Cpu_5min   0          Stacksize 0x1770     Lowstack 0x1770
Ttyptr     0x85F98480 Mem_holding 0x104E4    Thrash_count 0
Wakeup_reasons      0x0FFFFFFF  Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000  Direct_wakeup_minor 0x00000000
Regs R14-R31, CR, PC, MSR at last suspend; R3 from proc creation, PC unused:
     R3 : 00000000  R14: 80C15E74  R15: 00000000  R16: 00000000  R17: 00000000
     R18: 00000000  R19: 864707E0  R20: 85A30000  R21: 850D0000  R22: 84330000
     R23: 85A30000  R24: 86491C44  R25: 864707A0  R26: 00000000  R27: 80C88680
     R28: 85630000  R29: 86470BC4  R30: 00000000  R31: 85630000  CR: 48008088
     PC : 82AA03F0  MSR: 00009032
---- Current Process Stack (0xC8C bytes used, out of 0x1770 available) ----
Current SP = 0x86470608, saved SP = 0x86016CD4
8647047C: 35FB1AA4 864704F0 85630000 864704A0 EB001658 85630000 864704A0 8003355C
8647049C: F0004500 864704B8 80033514 8399B38A        0        0 FFFFFFFE 864704D0
864704BC: 813858C0        0 86473E64 7FFFFFFF FFFFFFFE 86470580 81387910 24222082
864704DC:        0 8031393C 857542BC 8A77F6E8        0 86470548 80315A58 8136E5FC
864704FC: 87924490        0 8647D0B6 85630000 8648A93C  F647606        0        0
8647051C: 86491C44 83D1E664        0 85630000        0        0 24222088        0
8647053C: 8647D0B6 85630000 8648A93C  F647606        0 86470690 86491C44 86491B00
8647055C: 86470720 86491C44 86470690 864731C8        0        0 86473E64        1
8647057C: FFFFFFFE 86470608 81385B6C      718     9032 864705F0        7        1
8647059C: 864705E8 85630000 864708B0 86470618        0 864705D0        4 86470628
864705BC: 24008084 864A354C 84008084  F680A00 86492198  3000608 864705F0 86470568
864705DC: 82A9A5AC 864C2F3C 85F98480 86470600 8139D2AC  2000043 86470610 86470608
864705FC: 86470608 85010000        0 86470618 802BC104 864C2F3C 8647A93C 86470680
8647061C: 80C86588  F6475FC        0 86470680 80319B08 80C22EA0 85A99238        0
8647063C: 8647D0B6 85630000 8648A93C  F647606        0 86470690 86491C44 86491B00
8647065C:        E        0       80 864731C8        0 8647A93C 86473E64  F6475FC
8647067C: 864A4290 86470790 80C21F70 8A51F558 85640000 864706C0 8136E760  3000000
8647069C:        0        0   520457       91    B0000        8        0  F6475FC
864706BC:        7        1 86470730  3000000        3        3  3000000 F0000000
864706DC: 6DFFFFFF FFFFFFFF        0        0 2E865BC4        0 28004048        0
864706FC:        0 86470708        0 86470740 82A9945C        0 2E865BEC  3000000
8647071C: 86470738        0 48008044        0 85F98480 86470748 8139D2AC       43
8647073C: 864707A0 86470788 44008084 80C15E74        0        0        0        0
8647075C: 864707E0 85A30000 850D0000 84330000 85A30000 86491C44 864707A0 86073614
8647077C: 86491B00 864731C8        0 8647A93C       80 86470868 80C16118 FFFFFFFF
8647079C: FFFFFFFF        0        0        0 864707C0        0 2E865BEC     4202
864707BC:        0 86470800 86470800 864707A0        0        0 2E865BEC    14244
864707DC:        0        0        0 864707A0        0        0        0     4240
864707FC:        0        0 864707C0 864707A0        0        0 2E865BEC    24244
8647081C:        0        0 2E865BEC        4        4        0        0        0
8647083C:        0        0        0        0        0        0        0        0
8647085C:        0        0        0 86470870 802BE3B0        0 802C1050 FFFFFFFF
========= Interrupt Level Stack Dump ==========
---- Level 1 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 2 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 3 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 4 Interrupt stack (0x10D8 bytes used, out of 0x2328 available) ----
intstacks[4]: base 0x86385688 stack 0x863879A8 routine 0x0      count 0x4DBC938
              size 0x2328     low   0x2328     desc    0x83998518
863875B0: FFFF0000 FFFFFFFF        0        0 FFFF0000 FFFFFFFF        0        0
863875D0: 86AB98A0 82C65C90        0        0        0        0        0        0
863875F0:        0        0        0        0        0        0        0        0
86387610:        0       20        0        0        0        0 86387640        0
86387630:        0 86387657      26A        1 863876F0 81387250 863876B8        0
86387650:       77        0 36313831   1F012C        0       77 863876D8   770002
86387670:        0  11E7D00  1010000        0        0        0  FAC4C07 86387657
86387690: 8399B38A        0 863876B8        0        0 FFFFFFFF        0 860378DC
863876B0:        0 8A776FAC 863876D8 80313C50 24228084        0 8031393C 857542BC
863876D0: 8A776FAC        0 86387730 80315A58 8136E5FC 87924C24        0 8647D0B6
863876F0: 85630000 8648A93C 1740A646 84D80000 86387878 86491C44 86491B00        4
86387710: 85630000        0        0        0        0 857542BC 8A776FAC 85640000
86387730: 86387760 8136E600 86491B00 86387908 86491C44 86387878 863877D0 8647A93C
86387750:        0 85630000 863877D8        7        1 863877D0 800325FC        0
86387770:      718        9 78000000        1 864D4470        0 86387798 80F48CAC
86387790: 86310028        0 80122E6F   BCF5C0  74537AF 86445700        0  F5ED24E
863877B0: 86310028 858CFFE8  30078A8 863877D8 86387750     7064 864C2F3C 85F98480
863877D0: 863877E8 8139D2AC       43        0 86387800 85F98480 863877F8        0
863877F0:        0 86491B00 864C2F3C 8647A93C 86387868 80C865A8  F542FAA 85640000
86387810:        0 86387850 8630FBE0 8630FBBC  F542FB8        0     4000 8630FBBC
86387830: 86387840 82B88014 8563CBF5 8630FC04 863878A8        F 8500BE1C 85630000
86387850: 864731C8 8647A93C 8647A93C 86491B00 864731C8        1 86387978 80C21F70
86387870:        0 863FE56C 863878E8 863FC808 863878A8       20 863878A8        0
86387890: 85E1411C 8775ACA0        5        B 863878A8        0 863878C8 8232AE80
863878B0: 887A3350 FFFFFFFF 863878D8 860378DC 863878D8        0 864C33D0  F683E40
863878D0: 864C2F3C 864D4698 86387910 80C99030 AE5050AE 82AA06C0 86387910 48228082
863878F0: 86387910        0        0        0      200    20000        0  F6821C0
86387910:        0 80C99450 8647A93C 85630000 858A4744 8647A93C 86491C44 48228024
86387930:        0 8647D0B6 85630000 8648A93C 1740A646 84D80000 85630000 84D7B73C
86387950: 858A0000 85630000 8500BE1C 85630000 858A4744 8647A93C 86491C44 86491B00
86387970: 864731C8        1 86387998 80C0B1D8 F0100000 84D80000        0        4
86387990:     1030 858A5F5C 863879A0 80CDF3FC 858A5F5C 802BF7F8 FFFFFFFF FFFFFFFF
PC  = 0x863878D8  MSR = 0x00000000  CR  = 0x864C33D0  LR    = 0x0F683E40
CTR = 0x864C2F3C  XER = 0x864D4698  DAR = 0x86387910  DSISR = 0x48228082
DEC = 0x86387910  TBU = 0x80C99030  TBL = 0xAE5050AE  IMMR  = 0x86387910
R0  = 0x863878A8  R1  = 0x0000000F  R2  = 0x8500BE1C  R3    = 0x85630000
R4  = 0x864731C8  R5  = 0x8647A93C  R6  = 0x8647A93C  R7    = 0x86491B00
R8  = 0x864731C8  R9  = 0x00000001  R10 = 0x86387978  R11   = 0x80C21F70
R12 = 0x00000000  R13 = 0x863FE56C  R14 = 0x863878E8  R15   = 0x863FC808
R16 = 0x863878A8  R17 = 0x00000020  R18 = 0x863878A8  R19   = 0x00000000
R20 = 0x85E1411C  R21 = 0x8775ACA0  R22 = 0x00000005  R23   = 0x0000000B
R24 = 0x863878A8  R25 = 0x00000000  R26 = 0x863878C8  R27   = 0x8232AE80
R28 = 0x887A3350  R29 = 0xFFFFFFFF  R30 = 0x863878D8  R31   = 0x860378DC
---- Level 5 Interrupt stack (0x20 bytes used, out of 0x2328 available) ----
intstacks[5]: base 0x86383360 stack 0x86385680 routine 0x0      count 0x3E
              size 0x2328     low   0x2328     desc    0x83996C3C
86385668: 86385678 86385678 86385678 858A5F5C 858A5F5C 802BF7F8 FFFFFFFF FFFFFFFF
---- Level 6 Interrupt stack (0x54 bytes used, out of 0x2328 available) ----
intstacks[6]: base 0x86381038 stack 0x86383358 routine 0x0      count 0x5B38
              size 0x2328     low   0x2328     desc    0x83996B28
8638330C: 86383318 8139E174 86383320 80032A14 86383328 86383338 8641BDF8 86383348
8638332C: 85F98480 F0004500        2 86383350 80050474     1030        6     1030
8638334C: 858A5EB4 858A5EB4 802BF7F8 FFFFFFFF FFFFFFFF
---- Level 7 Interrupt stack (0x58 bytes used, out of 0x2328 available) ----
intstacks[7]: base 0x8637ED10 stack 0x86381030 routine 0x0      count 0xBA19759
              size 0x2328     low   0x2328     desc    0x83996BF0
86380FE0: 86380FF8 FFFFFFFF        0 2E865BD8        0 2E865D58 86381010 FFFFFFFF
86381000: 858A4744 84D80000     1030 858A5EB4 86381018 82A463C4 86381028 8002663C
86381020: FFFFFFFF 858A5EB4 858A5EB4 802BF7F8 FFFFFFFF FFFFFFFF
---- Level 8 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 9 Interrupt stack (base 0x0, size 0x0) is invalid ----
========= Register Memory Dump ================
Reg00(PC ): 802BC140
Reg01(MSR):    29032 [Not RAM Addr]
Reg02(CR ): 28222042 [Not RAM Addr]
Reg03(LR ): 802BC104
Reg04(CTR): 800325FC
Reg05(XER):        0 [Not RAM Addr]
Reg06(DAR):        0 [Not RAM Addr]
Reg07(DSISR):  4000000 [Not RAM Addr]
Reg08(DEC): E8B3689D [Not RAM Addr]
Reg09(TBU):     2C5F [Not RAM Addr]
Reg10(TBL): 174C64CF [Not RAM Addr]
Reg11(IMMR):     8083 [Not RAM Addr]
Reg12(R0 ): 802BC104
Reg13(R1 ): 86470608
Reg14(R2 ): FFF5FFF5 [Not RAM Addr]
Reg15(R3 ): 85754060
Reg16(R4 ):        4 [Not RAM Addr]
Reg17(R5 ): 84D80000
Reg18(R6 ):     9032 [Not RAM Addr]
Reg19(R7 ): F0000000 [Not RAM Addr]
Reg20(R8 ): 6DFFFFFF [Not RAM Addr]
Reg21(R9 ): 85630000
Reg22(R10): 6D000000 [Not RAM Addr]
Reg23(R11):        0 [Not RAM Addr]
Reg24(R12): 24222088 [Not RAM Addr]
Reg25(R13): FFF569B0 [Not RAM Addr]
Reg26(R14):        0 [Not RAM Addr]
Reg27(R15): 8647D0B6
Reg28(R16): 85630000
Reg29(R17): 8648A93C
Reg30(R18):  F647606 [In malloc Block 0xF647590]
Reg31(R19):        0 [Not RAM Addr]
Reg32(R20): 86470690
Reg33(R21): 86491C44 [In malloc Block 0x86491AD0]
Reg34(R22): 86491B00
Reg35(R23): 86470720
Reg36(R24): 86491C44
Reg37(R25): 86470690
Reg38(R26): 864731C8 [In malloc Block 0x86473198] [Last malloc Block 0x864730C4]
Reg39(R27):        0 [Not RAM Addr]
Reg40(R28):        0 [Not RAM Addr]
Reg41(R29): 86473E64 [In malloc Block 0x86473E34]
Reg42(R30): 85010000
Reg43(R31):        0 [Not RAM Addr]
buffer check=0 sched_hc=0x0
---- block0  ptr=86470568  is_malloc=0  length=0x2A0 ----
---- block1  ptr=802BC104  is_malloc=0  length=0x13C ----
802BC0C4: 3D208563 80092D94 2F800000 419E0010 3D208563 80692CB8 4800000C 3D2083D2
802BC0E4: 8069E588 4BD6ACF9 38000000 3D208563 3D608563 9009B70C 900B2DC0 4BFFFA81
802BC104: 2F9F0000 419E0038 3D208563 80092DE0 2F800000 40BE0028 3C8083D2 3860FFFE
802BC124: 3884E664 490C99B5 2F9F0003 409D0008 3BE00003 1C7F03E8 48016B05 7FE10808
802BC144: 38000000 901EBC90 80010014 83C10008 83E1000C 7C0803A6 38210010 4E800020
802BC164: 3D2084D0 39000000 38E92E8C 38C0002A 39200000 89430000 690B00FF 2F880003
802BC184: 7D400774 7C004A78 20A00000 7C050114 30ABFFFF 7D255910 7C0B4839 4182000C
802BC1A4: 39080001 48000034 5500E73E 550B073E 409D0024 7D2700AE 7C882050 7C0758AE
802BC1C4: 98C40000 9D240001 9C040001 89430000 38840001 39000000 99440000 38840001
802BC1E4: 88030000 38630001 7C090774 2F890000 409EFF84 4E800020 7C0802A6 9421FFE0
802BC204: 9361000C 7CBB2B78 93810010 3B800000 93C10018 7C9E2378 93E1001C 7C7F1B78
802BC224: 93A10014 90010024 881F0000 2F80002A 40BE004C 887F0001 48016A15
---- block2  ptr=800325FC  is_malloc=0  length=0x100 ----
800325BC: 4199FFDC 38600000 4E800020 80030004 3D2084D8 8169B628 39200001 2F800001
800325DC: 41BD0008 39200000 5529402E 7D295A14 88090001 60000003 98090001 4E800020
800325FC: 7C0802A6 9421FFF0 93E1000C 7C7F1B78 90010014 4936AC79 2F830000 39600001
8003261C: 409E003C 813F0728 71203000 40820030 801F0738 552BD7FE 2F8B0000 7FE3FB78
8003263C: 70093000 39600000 4182000C 7FE3FB78 41BE000C 4BFFFF79 39600001 80010014
8003265C: 7D635B78 83E1000C 38210010 7C0803A6 4E800020 7C0802A6 9421FFE0 93A10014
8003267C: 7C7D1B78 93E1001C 7C9F2378 93C10018 90010024 88030005 70090001 4182012C
8003269C: 813F1060 8BDD0000 2F890000 419E002C 801F1068 2F800000 41BE0020 9BC10008
800326BC: 7FE3FB78 38810008 38A00001 38C00001 7D2803A6 4E800021 813F0EF0 7FE3FB78
800326DC: 7FC4F378 39290001 913F0EF0 4936B9D9 2F830000 419C00CC 817F0E64 801F0E6C
---- block3  ptr=85754060  is_malloc=0  length=0x100 ----
85754020:        0        0        0        0        0        0        0        0
85754040:        0        0        0        0        0        0 867A952C        0
85754060:        0        0        0        0 86B27D20        0 8600C108        0
85754080:        0        0        0        0        0        0        0        0
857540A0:        0        0        0        0        0        0        0        0
857540C0:        0        0        0        0 82AA9130        0 82AA9134 82AA9134
857540E0: 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134
85754100: 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134 82AA9134
85754120: 82AA9134 82AA9134 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130
85754140: 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130
---- block4  ptr=84D80000  is_malloc=0  length=0x100 ----
84D7FFC0:        0        0        0        0        0        0        0        0
84D7FFE0:        0        0        0        0        0        0        0        0
84D80000:        0        0        0        0        0        0        0        0
84D80020:        0        0        0        0        0        0        0        0
84D80040:        0        0        0        0        0        0        0        0
84D80060:        0        0        0        0        0        0        0        0
84D80080:        0        0        0        0        0        0        0        0
84D800A0:        0        0        0        0        0        0        0        0
84D800C0:        0        0        0        0        0        0        0        0
84D800E0:        0        0        0        0        0        0        0        0
---- block5  ptr=85630000  is_malloc=0  length=0x100 ----
8562FFC0:        1        1        3        5        1     3A98      FA0        1
8562FFE0: 85803754 85803D54       19        1       3C        1        1        0
85630000:       20      200 FFFFFFFF 84A6DD48 20000000        0        0 40000000
85630020:        0  1020000 686F7374 3A000000 646F6D61 696E3A00 646E6973 3A000000
85630040:       8E 85805D14 873F8190 873F8298        0 85BC2F68 85807574     5E00
85630060:  1000000       22       1E       48 6D61696C 2E000000 22257322        0
85630080:        1      400 56584D4C        0 85BC2FD0 2D2F454E 44000000 2D2F4558
856300A0: 49540000 2F2D0000 2F435200 636F6D6D 616E6400 85BC33C0 85808428        9
856300C0:        0        0        0        0        0 848477A4 FFFFFFFF FFFFFFFF
856300E0: 8450406C 73657475 70000000 72656F72 64657200 68656C6C 6F000000 616C6C00
---- block6  ptr=8647D0B4  is_malloc=0  length=0x100 ----
8647D074:        0        0        0        0        0        0        0        0
8647D094:        0        0        0        0        0        0        0        0
8647D0B4:    20000        0        0        0        0 8647B060        0        0
8647D0D4:        0        0        0        0        0        0        0        0
8647D0F4:        0        0        0        0        0        0        0        0
8647D114:        0        0        0        0        0        0        0        0
8647D134:        0        0        0        0        0        0        0        0
8647D154:        0        0        0        0        0        0        0        0
8647D174:        0        0        0        0        0        0        0        0
8647D194:        0        0        0        0        0        0        0        0
---- block7  ptr=8648A93C  is_malloc=0  length=0x100 ----
8648A8FC:        0        0        0        0        0        0        0        0
8648A91C:        0        0        0        0        0        0        0        0
8648A93C:        0        0        0        0        0        0        0        0
8648A95C:        0        0        0        0        0        0        0        0
8648A97C:        0        0        0        0        0        0        0        0
8648A99C:        0        0        0        0        0        0        0        0
8648A9BC:        0        0        0        0        0        0        0        0
8648A9DC:        0        0        0        0        0        0        0        0
8648A9FC:        0        0        0        0        0        0        0        0
8648AA1C:        0        0        0        0        0        0        0        0
---- block8  ptr=F647590  is_malloc=1  length=0xA00 ----
F647550:        0        0        0        0        0        0        0        0
F647570:        0        0        0        0        0        0        0 FD0110DF
F647590: AB1234CD FFFE0000        0 83D97374 8031304C  F647FD0  F646B64 80000508
F6475B0:        1        0        1 85FB07EC AFACEFAD        0        0        0
F6475D0:        0        0        0        0        0     102C        0 56000057
F6475F0:  40B0000        0        0 80000000 FFFFFFFF FFFF001B 5B5637C9   1B5B56
F647610: 37C9E07C 81A1359E  C020000 64003104    8494A 6C656761 6C570108 82848B96
F647630:  C121824  3010B05  4000100    70655 5320010B 1B2A0100 32043048 606CBB74
F647650: BD111111 C1CA9E35 2E6CF54E 6DFC1B1D 79B37208 4C80443D F2315916 4B8FF211
F647670: 9997D0ED  AEA2924 2BAD5202 64C0CAA2 A1C84296 C96DD449 8C620758 D2E9B73D
F647690: 3F87019A 1E862F17 5F21BD0E 700194EF F144CA54 4FFDB7E5 3E421332 7DDF6FD9
F6476B0:  52E8584 48947D41 612EDEE6  513C5C9 BFD547F8 9041CEE7  AAB3C0D E4527743
F6476D0: 1E2783A6 E5446CA0 F62724DB D4A40344 B7E0F8D8 FBA6BDD4 AE86648A 5AAF2E56
F6476F0:  CB51CD2 96929CAA BA3A7F60 4B33A272 B8899AFE 5B50C86F 7408F580 19255BAD
F647710: 392C43B5 C333B64D AF87DE46 9AD63E1A BA717C7F  619B19A 834BBF09 2CDEBF33
F647730: B28D6354 B1F2F3BA E137AD81  A00FCB6 20422E4F 9A33ADA4 40BE0E0F BE6E9639
F647750: 84D0F11A 86F325EE CC494B38 58F62C10 470923F1 F2582941 186D5D86 9796C253
F647770: EBA66AB5 61308809 20737EA3 910515AA D8364201 4FFDB8ED 1E609176 FC3F2C8F
F647790: 2B7CC5B9 21ECD661 AA4BAEAA 924BF723 A1381185 CE0AA33B 4860E293 A83F96DA
F6477B0: A88BE8E0 CDCA0975  5AA8D8B AA353E53 190F6CAF 45DB10A4 6B3FBD80  B75BB1E
F6477D0: 87ABCE1E 9B1E2831 EC8BE6FE 7BF64506 4A2F83DF 90887919 16B113A0 53C4DABE
F6477F0: 5FA2DF12 F8F6A9C3 BAED409E 4180B248 DFEECB8D 44BB2580 3E76726B B7759C5F
F647810: 264BCBEE 88FF2000       1D 45B7EB00 60C54767 35FB0800 450001EE EB4E0000
F647830: 40063D01 C0A80A1C 11AC744A DBD701BB 7C0FE5F4 89990CF7 5018FFFF A8E10000
F647850: 17030101 C1CA9E35 2E6CF54E 6DFC1B1D 79B37208 4C80443D F2315916 4B8FF211
F647870: 9997D0ED  AEA2924 2BAD5202 64C0CAA2 A1C84296 C96DD449 8C620758 D2E9B73D
F647890: 3F87019A 1E862F17 5F21BD0E 700194EF F144CA54 4FFDB7E5 3E421332 7DDF6FD9
F6478B0:  52E8584 48947D41 612EDEE6  513C5C9 BFD547F8 9041CEE7  AAB3C0D E4527743
F6478D0: 1E2783A6 E5446CA0 F62724DB D4A40344 B7E0F8D8 FBA6BDD4 AE86648A 5AAF2E56
F6478F0:  CB51CD2 96929CAA BA3A7F60 4B33A272 B8899AFE 5B50C86F 7408F580 19255BAD
F647910: 392C43B5 C333B64D AF87DE46 9AD63E1A BA717C7F  619B19A 834BBF09 2CDEBF33
F647930: B28D6354 B1F2F3BA E137AD81  A00FCB6 20422E4F 9A33ADA4 40BE0E0F BE6E9639
F647950: 84D0F11A 86F325EE CC494B38 58F62C10 470923F1 F2582941 186D5D86 9796C253
F647970: EBA66AB5 61308809 20737EA3 910515AA D8364201 4FFDB8ED 1E609176 FC3F2C8F
F647990: 2B7CC5B9 21ECD661 AA4BAEAA 924BF723 A1381185 CE0AA33B 4860E293 A83F96DA
F6479B0: A88BE8E0 CDCA0975  5AA8D8B AA353E53 190F6CAF 45DB10A4 6B3FBD80  B75BB1E
F6479D0: 87ABCE1E 9B1E2831 EC8BE6FE 7BF64506 4A2F83DF 90887919 16B113A0 53C4DABE
F6479F0: 5FA2DF12 F8F6A9C3 BAED409E 4180B248 DFEECB8D 44BB2580 3E76726B B7759C5F
F647A10: 264BCBEE 88FF2000       1D 45B7EB00 60C54767 35FB0800 450001EE C8510000
F647A30: 40065FFE C0A80A1C 11AC744A DBD701BB 7C0FE5F4 89990CF7 5018FFFF A8E10000
F647A50: 17030101 C1CA9E35 2E6CF54E 6DFC1B1D 79B37208 4C80443D F2315916 4B8FF211
F647A70: 9997D0ED  AEA2924 2BAD5202 64C0CAA2 A1C84296 C96DD449 8C620758 D2E9B73D
F647A90: 3F87019A 1E862F17 5F21BD0E 700194EF F144CA54 4FFDB7E5 3E421332 7DDF6FD9
F647AB0:  52E8584 48947D41 612EDEE6  513C5C9 BFD547F8 9041CEE7  AAB3C0D E4527743
F647AD0: 1E2783A6 E5446CA0 F62724DB D4A40344 B7E0F8D8 FBA6BDD4 AE86648A 5AAF2E56
F647AF0:  CB51CD2 96929CAA BA3A7F60 4B33A272 B8899AFE 5B50C86F 7408F580 19255BAD
F647B10: 392C43B5 C333B64D AF87DE46 9AD63E1A BA717C7F  619B19A 834BBF09 2CDEBF33
F647B30: B28D6354 B1F2F3BA E137AD81  A00FCB6 20422E4F 9A33ADA4 40BE0E0F BE6E9639
F647B50: 84D0F11A 86F325EE CC494B38 58F62C10 470923F1 F2582941 186D5D86 9796C253
F647B70: EBA66AB5 61308809 20737EA3 910515AA D8364201 4FFDB8ED 1E609176 FC3F2C8F
F647B90: 2B7CC5B9 21ECD661 AA4BAEAA 924BF723 A1381185 CE0AA33B 4860E293 A83F96DA
F647BB0: A88BE8E0 CDCA0975  5AA8D8B AA353E53 190F6CAF 45DB10A4 6B3FBD80  B75BB1E
F647BD0: 87ABCE1E 9B1E2831 EC8BE6FE 7BF64506 4A2F83DF 90887919 16B113A0 53C4DABE
F647BF0: 5FA2DF12 F8F6A9C3 BAED409E 4180B248 DFEECB8D 44BB2580 3E76726B B7759C5F
F647C10: 264BCBEE 88FF2000       1D 45B7EB00 60C54767 35FB0800 450001EE 58060000
F647C30: 4006D049 C0A80A1C 11AC744A DBD701BB 7C0FE5F4 89990CF7 5018FFFF A8E10000
F647C50: 17030101 C1CA9E35 2E6CF54E 6DFC1B1D 79B37208 4C80443D F2315916 4B8FF211
F647C70: 9997D0ED  AEA2924 2BAD5202 64C0CAA2 A1C84296 C96DD449 8C620758 D2E9B73D
F647C90: 3F87019A 1E862F17 5F21BD0E 700194EF F144CA54 4FFDB7E5 3E421332 7DDF6FD9
F647CB0:  52E8584 48947D41 612EDEE6  513C5C9 BFD547F8 9041CEE7  AAB3C0D E4527743
F647CD0: 1E2783A6 E5446CA0 F62724DB D4A40344 B7E0F8D8 FBA6BDD4 AE86648A 5AAF2E56
F647CF0:  CB51CD2 96929CAA BA3A7F60 4B33A272 B8899AFE 5B50C86F 7408F580 19255BAD
F647D10: 392C43B5 C333B64D AF87DE46 9AD63E1A BA717C7F  619B19A 834BBF09 2CDEBF33
F647D30: B28D6354 B1F2F3BA E137AD81  A00FCB6 20422E4F 9A33ADA4 40BE0E0F BE6E9639
F647D50: 84D0F11A 86F325EE CC494B38 58F62C10 470923F1 F2582941 186D5D86 9796C253
F647D70: EBA66AB5 61308809 20737EA3 910515AA D8364201 4FFDB8ED 1E609176 FC3F2C8F
F647D90: 2B7CC5B9 21ECD661 AA4BAEAA 924BF723 A1381185 CE0AA33B 4860E293 A83F96DA
F647DB0: A88BE8E0 CDCA0975  5AA8D8B AA353E53 190F6CAF 45DB10A4 6B3FBD80  B75BB1E
F647DD0: 87ABCE1E 9B1E2831 EC8BE6FE 7BF64506 4A2F83DF 90887919 16B113A0 53C4DABE
F647DF0: 5FA2DF12 F8F6A9C3 BAED409E 4180B248 DFEECB8D 44BB2580 3E76726B B7759C5F
F647E10: 264BCBEE 88FF2000       1D 45B7EB00 60C54767 35FB0800 450001EE 6F520000
F647E30: 4006B8FD C0A80A1C 11AC744A DBD701BB 7C0FE5F4 89990CF7 5018FFFF A8E10000
F647E50: 17030101 C1CA9E35 2E6CF54E 6DFC1B1D 79B37208 4C80443D F2315916 4B8FF211
F647E70: 9997D0ED  AEA2924 2BAD5202 64C0CAA2 A1C84296 C96DD449 8C620758 D2E9B73D
F647E90: 3F87019A 1E862F17 5F21BD0E 700194EF F144CA54 4FFDB7E5 3E421332 7DDF6FD9
F647EB0:  52E8584 48947D41 612EDEE6  513C5C9 BFD547F8 9041CEE7  AAB3C0D E4527743
F647ED0: 1E2783A6 E5446CA0 F62724DB D4A40344 B7E0F8D8 FBA6BDD4 AE86648A 5AAF2E56
F647EF0:  CB51CD2 96929CAA BA3A7F60 4B33A272 B8899AFE 5B50C86F 7408F580 19255BAD
F647F10: 392C43B5 C333B64D AF87DE46 9AD63E1A BA717C7F  619B19A 834BBF09 7F56F8D5
F647F30: CDC365C6 A9EA0BC2 C0B67EDC 431DE40C  D28B762 EB455E19 3A90996A 9DDCF88B
F647F50: BAF902DF FBB03C7E 76DA68BE        0        0        0        0        0
F647F70:        0        0        0        0        0        0        0        0
---- block9  ptr=86491AD0  is_malloc=1  length=0x698 ----
86491A90:        0        0        0        0        0        0        0        0
86491AB0:        1        1        0        1        0        0        0 FD0110DF
86491AD0: AB1234CD FFFE0000        0 8432F31C 80C17BA8 86492168 8647A920 80000334
86491AF0:        1        0        1 85FB07EC    3300A        0    33008        0
86491B10: 80C84F30 80C859A8 80C87CEC 80C864D0 80C8768C 80C89084 80C8918C 80C892D4
86491B30: 80C89184 80C89EE0 80C89EE8        0 80C89354 80C89538 80C89540 80C88008
86491B50: 80C884AC 80C887A4 80C89380 80C8879C 80C88AC0 80C88F4C 80C8956C 80C895F4
86491B70: 80C87C20 80C89628 80C8965C 80C87CE8 80C88680 80C88594 80C89E5C 80C89E60
86491B90: 80C846C4 80C84828 80C84EE4 80C87E7C 80C89450 80C885C8 80C885CC 80C885E4
86491BB0: 80C89544 80C89548 80C84F0C 80C89384 80C886C8 80C89DE0 80C89454 80C89468
86491BD0: 80C89534 80C87ECC 80C8954C 80C8955C 80C89554 80C89564 80C896B8 80C89660
86491BF0: 80C89B98 80C89880 80C89888        0        0 80C8908C 80C89E3C 80C89E44
86491C10: 80C89E4C 80C89E54 80C89F08 80C89F10 80C89F18 80C89F94 80C884A4        0
86491C30:        0        0 80C89F9C        0 80C8A01C 8647A800 864731C8 84347A64
86491C50:    33009        0 864731C8 8647A93C 864C2F3C        0        0        0
86491C70:        0        0        0        0        0        0        0        0
86491C90:        0        0        0        0        0        0        0        0
86491CB0:        0        0        0        0        0        0        0        0
86491CD0:        0        0        0        0        0        0        0        0
86491CF0:        0     AE05        0        0        0        0        0        0
86491D10:        0 41544845 524F5320 41523532 31320000        0        0        0
86491D30:        0 43697363 6F205379 7374656D 73000000        0        0        0
86491D50:        0        0        0        0        0        0        0        0
86491D70:        0        0        0        0        0        0        0        5
86491D90:        9        0        0        0        0        0        0        0
86491DB0:        0        0        0        0        0        0        0        0
86491DD0:        0        0        0        0        0        0        0        0
86491DF0:        0        0        0        0        0        0        0        0
86491E10:        3        0        0        0        0        0        0        0
86491E30:        0        0        0        0        0        0        0        0
86491E50:        0        0        0        0        0        0        0        0
86491E70:        0        0        0        0        0        0        0        0
86491E90:        0        0        1        0        0        0        0        0
86491EB0:        0        0        0        0        0        0        0        0
86491ED0:        0        0        0        0        0        0        0        0
86491EF0:        0        0        0        0        0        0        0        0
86491F10:        0        0        0        0        0        0        0        0
86491F30:        0        0        0        0        0        0        0        0
86491F50:        0        0        0        0        0        0        0        0
86491F70:        0        0        0        0        0        0        0        0
86491F90:        0       1E  2040B0C 12161824 3048606C      96C        1      971
86491FB0:        2      976        3      97B        4      980        5      985
86491FD0:        6      98A        7      98F        8      994        9      999
86491FF0:        A      99E        B        0        0        0        0        0
86492010:        0        0        0        0        0        0        0        0
86492030:        0        0        0        0        0        0        0        0
86492050:        0        0        0        0        0        0        0        0
86492070:        0        0        0        0        0        0        0        0
86492090:        0        0        0        0        0        0        0        0
864920B0:        0        0        0    30004    50006    7000A    D000F   110000
864920D0:        0        0        0        0        0        3    40005    60007
864920F0:    A000D    F0011        0        0        0        0        0        0
86492110:        0        0 464F4331 31333532 48583200       40 96000000        1
86492130:        1        0        1        6   1D45B7 EB000000        0        0
86492150:        0        0        0        0        0 FD0110DF
---- block10  ptr=864730C4  is_malloc=1  length=0xA00 ----
86473084: 839C1F98 82AB41A0 864730C4 86473040 8000000E        1        0        1
864730A4: 85FB07EC        0        0        0        0        0        0 FD0110DF
864730C4: AB1234CD FFFE0000        0 839C1F98 83989988 86473198 8647308C 80000052
864730E4:        1        0        1 85FB07EC 86470D94        0        0        0
86473104:        0        0        0        0        0        0        0        0
86473124:        0        0        0        0        0        0        0        0
86473144:        0        0        0        0        0        0        0        0
86473164:        0        0        0        0        0        0        0        0
86473184:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
864731A4: 83D97C78 813696CC 86473E34 864730D8 80000636        1        0        1
864731C4: 85FB07EC 878573E0      101        0        0        0        0 86473E64
864731E4:       EA        2 80C1DD28        0        0        0  1000000        0
86473204:        0        0        0 818422A4       14        0        0        0
86473224:        1      5EE        E        0        0      5EA        0        0
86473244:        0        0        F        C        C        0 FFFFFFFF FFFFFFFF
86473264: FFFFFFFF        0        0        0        0        0        0        0
86473284:        0        0        0 83DA1774 8432F3A0 86474340 8647438C        0
864732A4:        0        0        0        0        0        0        0  5DC05DC
864732C4:        1      5F8      8FC        6 86492198 8631427C   210040   200010
864732E4:     4000        0 10002200        4        2        0        5        2
86473304:        0        0 2E8641CC        0 2E864EAC        0        0        0
86473324:     BDE8        0        0 858CF038 864731C8        0        0    14246
86473344:        0        0        0        0 84309E38 8647A93C        0        1
86473364:        1        1        0        0        0 80C17108  1010001 FD000009
86473384:        0        0        0        0       10        0        0        0
864733A4:        0        0        0        0        0        0        0        0
864733C4:        0        0        0        0        0        0        0        0
864733E4:        0        0        0        0        0        0        0       1E
86473404:       1E       1E       1E       1E       1E       1E       1E       1E
86473424:       1E       1E       1E       1E       1E       1E       1E       1E
86473444:        0        0        0       1E        0        0        0       1E
86473464:        0        0        0       1E        0        0        0       1E
86473484:        0        0        0       1E        0        0        0       1E
864734A4:        0        0        0       1E        0        0        0       1E
864734C4:        0        0        0       1E        0        0        0       1E
864734E4:        0        0        0       1E        0        0        0       1E
86473504:        0        0        0       1E        0        0        0       1E
86473524:        0        0        0       1E        0        0        0       1E
86473544:        0        0        0       1E        0 864731C8        0        0
86473564:        0       4B        0       4B        0        0        0 8031EE14
86473584: 8031EE78        0        0 815E7F34 815E7628        0 813A522C        0
864735A4:        0        0 80C1DF3C        0        0 80341D0C 8031DEA8 8031E5DC
864735C4:        0        0 815E6780 80C0E230 80C0E278 815EAE80 803393B8 815E6270
864735E4:        0 815E66B8        0        0        0        0 80C0E5B0        0
86473604:        0 80C0E274 80C0E5C0 80C0E5C0 80C0E5C0        0        0 80C194B0
86473624:        0        0        0        0        0        0        0        0
86473644:        0        0        0        0        0        0    6B672        0
86473664:        0 1F18E6AA       16        0        0 10D2DCCA       27        0
86473684:        0      311        0     9022        0    10CA8   F617C5     8D30
864736A4:    599E0        0        0        4        0        0     177E        0
864736C4:        0        0        0        0    467EE      7D3        0        0
864736E4:        0        0     1370        0        0        0        0        0
86473704:        0        0        0        0        0        0        0        0
86473724:        0        0        0        0        0        0    1B991        0
86473744:        0        0        0        0        0        0        0        0
86473764:        0        0        0        0        0        0        1        0
86473784:        0        0        0        0  442D097    BE878       13    90A88
864737A4:       18     9503       F1        0        0    2EB9E        0        0
864737C4:        0        0        0        0 2E865124 86473898 864738E4        0
864737E4:        0        0        0        0        0        0        0 86144F58
86473804:        0        0        0        0        0        0 86144B30        0
86473824:        0 861450D4        0        0        0        0        0        0
86473844:        0        0        0        0        0        0        0        0
86473864:        0        0        0        0        0        0        0        0
86473884:        0 86144AE4        0        0        0        0        0        0
864738A4:        0        0        0        0        0        0        0        0
864738C4:        0      242        0    13F63        0        0        0        0
864738E4:        0        0        0        0        0        0        0        0
86473904:        0        0     6F36   3AE064        0        0        0        0
86473924:        0        0        0        0        0        0        0        0
86473944: 2E865124        0        0        0        0        0        0        0
86473964:        0        0 8647A800 864D4A54 86491C44 8647AFF4 8691A198 8691ED00
86473984:        0        0        0 888A8478 8A03781C        0        0        0
864739A4:        0        0        0        0        0        0        0        0
864739C4:        0        0        0        0        0        0        0        0
864739E4:        0        0        0        0        0        0        0        0
86473A04:        0 8A03781C        0        0 FFFFFFFF        0        0        0
86473A24:        0        0        0        0        0        0        0        0
86473A44:        0        0        0        0        0        0        0        0
86473A64:        0        0        0        0        0        0        0        0
86473A84: 80C085FC 80C090D8        0        0        0 858C7320 864731C8        0
86473AA4:        0    44246        0        0        0        0        0        0
---- block11  ptr=86473E34  is_malloc=1  length=0x4DC ----
86473DF4:        0        0        0        0        8        0 88257C2C        0
86473E14:        0        0        0        0        0        0        0 FD0110DF
86473E34: AB1234CD FFFE0000        0 83D97C68 813696EC 86474310 864731AC 80000256
86473E54:        1        0        1 85FB07EC 88257C2C 864538FC      5DC        0
86473E74:  5DC0000        0        0        0 887BB46C        1        0        0
86473E94:        0        0        1        0        0        0        0        0
86473EB4:        0        0        0        0        0 864731C8 88849DDC 888AD728
86473ED4:        F        0        0        1        2        1 86474340 8647438C
86473EF4:        0        0        C 86473E64        0        0       80    10000
86473F14:        0        0        0        0        0        0        0       64
86473F34:       64     D2F0     D2F0        0        0        0        0 863FE1D4
86473F54:        0 8735C050 87106AE8        0        0        0        0        0
86473F74:        0        0        0        0        0        0        0        0
86473F94:        0        0        0        0        0        0        0 877E55EC
86473FB4:        0        0        0        0        0        0 877E55EC        0
86473FD4:        0        0        0        0        0        6        0        0
86473FF4:        0        0   DBBA00        0  1000000    10000        0        0
86474014:        0        0        0        0        0        0 FFFFFFFF        0
86474034:        0        0        0        0        0        0        0        0
86474054:        0        0        0    10100        0        0 86471D19        0
86474074:        0        0        0        0        0        0        0        0
86474094:        0        0        0        0        0     3774        0        0
864740B4:        0        0        0        0        0        0        0        0
864740D4:        0      100  1000000        0      202  2808080        0        0
864740F4:        0        0        0        0        0        0        0        1
86474114:        0        0        0        0        0        0        0        0
86474134:        0        0        0        0 86BA4B14     FFFF 42000000        0
86474154:        0        0        0        0        0        0        0        0
86474174:        0        0        0        0        0        0        0        0
86474194:        0        0        0        0        0        0        0        0
864741B4:        0        0        0        0        0        0        0        0
864741D4:        0        0        0        0        0        0        0        0
864741F4:        0        0        0        0        0  2000000        0        0
86474214:        0        0        0        0        0 85B0EFB0 85B0E460 89F8B9C0
86474234: 89F8B9C0        1        0        0        0        0        0        0
86474254:        0        0 89F644BC 86AD7E20        0        0        0        0
86474274:        0        0        0        0        0        0        0        0
86474294:        0        0        0        0        0        0        0        0
864742B4:        0        0        0        0        0        0        0        0
864742D4: 86473E64        0        0        0        0        0        0       4B
864742F4:     9E34        0        0        0        0        0 FD0110DF
---- block12  ptr=85010000  is_malloc=0  length=0x100 ----
8500FFC0:        1        1        0        0  FFFFFFF        0        1        0
8500FFE0:        0        0        0     1000        0        0 856336E0        0
85010000: 83DA1914        0        0       4C 83DA15E8 83DA1934        0        0
85010020:        0        0 FFFFFFFF FFFFFFFF        0        1        1        1
85010040:        0        0  FFFFFFF        0        1        0        0        0
85010060:        0      800        0        0 85633550        0 83DA195C        0
85010080:        0       4B 83DA1600 83DA197C        0        0        0        0
850100A0: FFFFFFFF FFFFFFFF        0        1        1        1        0        0
850100C0:  FFFFFFF        0        1        0        0        0        0      400
850100E0:        0        0 85633340        0 83DA199C        0        0       4A
---- block13  ptr=864A351C  is_malloc=1  length=0x46C ----
864A34DC:        0        0        0        0        0        0        0        0
864A34FC:        0        0        0 85FB0630        4 864A354C 864A2C74 FD0110DF
864A351C: AB1234CD FFFE0000        0 83D97384 80312FF8 864A3988 864A30C4 8000021E
864A353C:        1        0        1 85FB07EC        0        0        0 BEADEA5E
864A355C: AEADEA5E        0 FFFF0000    10000  F645704  F64573C  F64573C  F64575A
864A357C:        0  F645758        0        0  F645726        0  9600001        E
864A359C:        0       17        0        0        0 FF000000        0        0
864A35BC:        0        0        0        0        0        0        0        0
864A35DC:        0        0        0        0        0        1        0 86492198
864A35FC:        0 80C86454        0        0        0        0        0        0
864A361C:        0        0        0        0        0        0        0        0
864A363C:        0        0        0        0        0        0        0        0
864A365C:        0        0        0        0        0        0        0        0
864A367C:        0 2E864ACC        0 2E865D34        0        0        0        0
864A369C:        0        0        0        0        0        0        0        0
864A36BC:        0        0 88257C2C        0        0        0        0        0
864A36DC:        0        0        0        0        0        0        0        0
864A36FC:        0        0        0        0        0        0        0        0
864A371C:        0        0        0        0        0        0        0        0
864A373C:        0        0        0        0        0        0        0        0
864A375C:        0        0        0        0        0        0        0        0
864A377C:        0        0        0        0        0        0        0        0
864A379C:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A37BC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A37DC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A37FC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A381C: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
864A383C:        0        0        0        0        0        0        0        0
864A385C:        0        0        0        0 C0A80A1C 11AC744A DE1C01BB        0
864A387C:        0        0        0        0        0        0        0        0
864A389C:        0        0        0        0        0        0        0        0
864A38BC:        0        0        0        0        0        0        0        0
864A38DC:        0        0        0        0        0        0        0        0
864A38FC:        0        0        0        0        0        0        0        0
864A391C:        0        0        0        0        0        0        0        0
864A393C:        0        0        0        0        0        0        0        0
864A395C:        0        0        0        0        0        0 85FADD24       4A
864A397C: 864A39B8 864A30E0 FD0110DF
---- block14  ptr=84008084  is_malloc=0  length=0x100 ----
84008044:        0 50617261 6D657465 72206865 7820776F 72642073 7472696E 672E2054
84008064: 6F206265 20656E74 65726564 3A203030 3030202D 20464646 46000000 73692D72
84008084: 65672D77 72697465        0 57726974 65207265 67697374 6572206F 6E205369
840080A4: 6C616273 20646576 69636520 61747461 63686564 20746F20 74686973 20706F72
840080C4: 74000000 73692D72 65672D72 65616400 52656164 20726567 69737465 72732066
840080E4: 726F6D20 53696C61 62732064 65766963 65206174 74616368 65642074 6F207468
84008104: 69732070 6F727400 2869735F 706F7274 5F757369 6E675F53 694C6162 735F6368
84008124: 69705F77 6974685F 52414D28 63736229 29000000 73692D72 616D2D77 72697465
84008144:        0 57726974 65205241 4D206C6F 63617469 6F6E206F 6E205369 6C616273
84008164: 20646576 69636520 61747461 63686564 20746F20 74686973 20706F72 74000000
---- block15  ptr=86492168  is_malloc=1  length=0x18C ----
86492128: 96000000        1        1        0        1        6   1D45B7 EB000000
86492148:        0        0        0        0        0        0        0 FD0110DF
86492168: AB1234CD FFFE0000        0 849CFDF8 82A87970 864922F4 86491AE4 800000AE
86492188:        1        0        1 85FB07EC        0 DEADB10B 80312F84 803135A8
864921A8: 80313708 8031393C 80313CB0 80313CC0 80313CD0 80313EC4 80314534 864AA844
864921C8: 864A4290       20        0        0        0        0        0        0
864921E8:        0        0        0        0        0        0        0 86074F20
86492208: 864799C8 86492198 858C7A18        6      960       54        0       44
86492228:       60       20       60        0        0     10B4        0     10B0
86492248:        0  101BDCA        0        0        0        0        0        0
86492268:        0       60       60       60       60       60        0        0
86492288:        0        2        0        0 8564865C        0        0 86474340
864922A8: 86492324 864AC738        0        0 86037BF4        0        0        0
864922C8:        0        0        0        0        0        0        0        0
864922E8:        0        0 FD0110DF
---- block16  ptr=864C2F0C  is_malloc=1  length=0xA00 ----
864C2ECC:        0        0        0        0        0        0        0        0
864C2EEC:        0        0        0 85FB0630        4        0 864C2664 FD0110DF
864C2F0C: AB1234CD FFFE0000        0 8434A888 80C8A0DC 864D4210 864C2AB4 8000896A
864C2F2C:        1        0        1 85FB07EC 86491C44 78000000        7        0
864C2F4C:        0        0        0        9        0        0        0        0
864C2F6C:        0        0        0        0        0        0        0        0
864C2F8C:        0        0 864D4698        0        0        0        0        0
864C2FAC:        0        0        0        0        0        0        0        0
864C2FCC:        0        0 864D773C        D 43564D53 2D576972 656C6573 73000000
864C2FEC:        0        0        0        0        7 860435E4        0        0
864C300C:        0        0        0        0        0        0        0        0
864C302C: 86043A50        0        0        0        0        0        0        0
864C304C:        0        0        0 864D8480        0        0        0        0
864C306C:        0        0        0        0        0        0 86043EBC        0
864C308C:        0        0        0        0        0        0        0        0
864C30AC:        0        0        0        0        0        0        0        0
864C30CC:        0        0        0        0        0        0        0        0
864C30EC:        0        0        0        0        0        0        0        0
864C310C:        0        0        0        0        0        0        0        0
864C312C:        0        0        0        0        0        0        0        0
864C314C:        0        0        0        0        0        0        0        0
864C316C:        0        0        0        0        0        0        0        0
864C318C:        0        0        0        0        0        0        0        0
864C31AC:        0        0        0        0        0        0        0        0
864C31CC:        0        0        0        0        0        0        0        0
864C31EC:        0        0        0        0        0        0        0        0
864C320C:        0        0        0        0        0        0        0        0
864C322C:        0        0        0        0        0        0        0        0
864C324C:        0        0        0        0        0        0        0        0
864C326C:        0        0        0        0        0        0        0        0
864C328C:        0        0        0        0        0        0        0        0
864C32AC:        0        0        0        0        0        0        0        0
864C32CC:        0        0        0        0        0        0        0        0
864C32EC:  F682240        0        0        0        0        8        0        0
864C330C:        0        0        0        0        0        0        0        0
864C332C:        0        0        0        0        0        0        1    A5212
864C334C:        0 864D4470        0        0        0  F6835C0  F6835C0        0
864C336C:        0        0        0  F682A40  F682A40        0  F6837C0  F6837C0
864C338C:        1        0        0        0        0        0        0        0
864C33AC:        0        0  F683E40  F683E40 FFFF19E3  F6821C0  F6821C0        0
864C33CC: 864D44BC        0        0        0        0        0        0        0
864C33EC:        0        0        0        0        0        0        0        0
864C340C:        0        0        0        0        0        0        0        0
864C342C:        0        0        0        0        0        0        0        0
864C344C:        0        0        0        0        0        0        0        0
864C346C:        0        0        0        0        0        0        0        0
864C348C:        0 864D4508 864D4808   1D45B7 EB000000   1D45B7 EB000000        3
864C34AC:        0        0        0        1        0        0        0        0
864C34CC:        0        0        0 864D49F0 864D49F0        0  92A092A      92B
864C34EC:        0      200    80000        0        0        0        0        0
864C350C:        0        0        0        0        0        0        0        0
864C352C:        0   1E0000        0        0        0        0        0        0
864C354C:        0        0        0    30000        0       40        4       40
864C356C:       32        0        1        0       3C   3C0000        0    80000
864C358C:        0        0        0        1        0        0        0        0
864C35AC:        0        0        0        0        0        0        0        0
864C35CC:        0        0        0        0        0        0        0        0
864C35EC:        0        0        0        0        0        0        0        0
864C360C:        0        0        0        0        0        0        0        0
864C362C:        0        0        0        0        0        0        0        0
864C364C:        0        0        0        0        0        0        0        0
864C366C:        0        0        0        0        0        0        0        0
864C368C:        0        0        0        0        0        0        0        0
864C36AC:        0        0        0        0        0        0        0        0
864C36CC:        0        0        0        0        0        0        0        0
864C36EC:        0        0        0        0        0        0        0        0
864C370C:        0        0        0        0        0        0        0        0
864C372C:        0        0        0        0        0        0        0        0
864C374C:        1        2        F 864D4240 84347B18 850DD0D8 850DCE2C 850DCB80
864C376C: 850DC8D4 850DCE2C 850DC628    30000        0  F647606 D0A80000  A530024
864C378C: 94E27F8B  F680A00        0        0        0        0        0        0
864C37AC:        0        0        0        0        0        0        0        0
864C37CC:        0        0        0        0        0        0        0        0
864C37EC:        0        0        0        0        0        0        0        0
864C380C:        0        0        0        0        0        0        0        0
864C382C:        0        0        0        0        0        0        0        0
864C384C:        0        0        0        0        0        0        0        0
864C386C:        0        0        0        0        0        0        0        0
864C388C:        0        0        0        0        0        0        0        0
864C38AC:        0        0        0        0        0        0        0        0
864C38CC:        0        0        0        0        0        0        0        0
864C38EC:        0        0        0        0        0        0        0        0
---- block17  ptr=85F9836C  is_malloc=1  length=0xA00 ----
85F9832C: 82A9865C 8549413C        0        0        0        0        0        0
85F9834C:        0        0        0        0        0        0        0 FD0110DF
85F9836C: AB1234CD FFFE0000        0 84524B38 83989988 85F98440 85F96FC4 80000052
85F9838C:        1        0        1 85FB07EC        0        0        0        0
85F983AC:        0        0        0        0        0        0        0        0
85F983CC:        0        0        0        0        0        0        0        0
85F983EC:        0        0        0        0        0        0        0        0
85F9840C:        0        0        0        0        0        0        0        0
85F9842C:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
85F9844C: 845045F8 813A1F6C 85F99594 85F98380 80000892        1        0        1
85F9846C: 85FB07EC 43534364 72303139 32390000        0        1        0        0
85F9848C:        0        0        0        0        0        0        0        0
85F984AC:        0        0 858A4698 858A4698 858A4698        0        0 85A44F48
85F984CC:        0        0        0     4200        0        0        0        0
85F984EC:        0        0        0        0        0        0        0        0
85F9850C:        0        0        0        0        0        0        0        0
85F9852C:        0        0        0        0        0        0        0        4
85F9854C:     1388        0 FFFFFFFF FFFFFFFF        0        0        0        0
85F9856C:        0        0        0        0        0        0        0        0
85F9858C:        0        0        0        0        0        0 86036BB8 86034378
85F985AC:       31       32        0        0        0        0       32        0
85F985CC:        0        0        0        0        0        0        0        0
85F985EC:        0        0        0        0        0        0        0        0
85F9860C:        0        0        0        0        0        0        0        0
85F9862C:        0        0        0        0        0        0        0        0
85F9864C:        0        0        0        0        0        0        0        0
85F9866C:        0        0        0        0        0        0        0        0
85F9868C:        0        0        0        0        0        0        0        0
85F986AC:        0        0        0        0        0        0        0        0
85F986CC:        0        0        0        0        0        0        0        0
85F986EC:        0        0        0        0        0        0        0        0
85F9870C:        0        0        0        0        0        0        0        0
85F9872C:        0        0        0        0        0        0        0        0
85F9874C:        0        0        0        0        0        0        0        0
85F9876C:        0        0        0        0        0        0        0        0
85F9878C:        0        0        0        0        0        0        0        0
85F987AC:        0        0        0        0        0        0        0        0
85F987CC:        0        0        0        0        0        0        0        0
85F987EC:        0        0        0        0        0        0        0        0
85F9880C:        0        0        0        0        0        0        0        0
85F9882C:        0        0        0        0        0        0        0        0
85F9884C:        0        0        0        0        0        0        0        0
85F9886C:        0        0        0        0        0        0        0        0
85F9888C:        0        0        0        0        0        0        0        0
85F988AC:        0        0        0        0        0        0        0        0
85F988CC:        0        0        0        0        0        0        0        0
85F988EC:        0        0        0        0        0        0        0        0
85F9890C:        0        0        0        0        0        0        0        0
85F9892C:        0        0        0        0        0        0        0        0
85F9894C:        0        0        0        0        0        0        0        0
85F9896C:        0        0        0        0        0        0        0        0
85F9898C:        0        0        0        0        0        0        0        0
85F989AC:        0        0        0        0        0        0        0        0
85F989CC:        0        0        0        0        0        0        0        0
85F989EC:        0        0        0        0        0        0        0        0
85F98A0C:        0        0        0        0        0        0        0        0
85F98A2C:        0        0        0        0        0        0        0        0
85F98A4C:        0        0        0        0        0        0        0        0
85F98A6C:        0        0        0        0        0        0        0        0
85F98A8C:        0        0        0        0        0        0        0        0
85F98AAC:        0        0        0        0        0        0        0        0
85F98ACC:        0        0        0        0        0        0        0        0
85F98AEC:        0        0        0        0        0        0        0        0
85F98B0C:        0        0        0        0        0        0        0        0
85F98B2C:        0        0        0        0        0        0        0        0
85F98B4C:        0        0        0        0        0        0    F0005     4E20
85F98B6C:        0        0 FFFFFFFF        D        0        0 89EBD248        0
85F98B8C:        0        0        0        0        0 7FFFFFFF        0       40
85F98BAC:        0        0        0        0        0        0        0        0
85F98BCC:        0        0        0     2580     2580        0        8        2
85F98BEC:       13       11       50       18       1E FFFFFFFF        0        0
85F98C0C:        0 FFFFFFFF        0        0        0        0        8 FFFFFFFF
85F98C2C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        4 FFFFFFFF FFFFFFFF
85F98C4C:       7F       15       17       12 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
85F98C6C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF       18        0
85F98C8C:  1000000  1000000        0      100    10001  1000000        0        0
85F98CAC:        0        0        0        0        0        0        0        0
85F98CCC:        0        0        0        0        0        0        0        0
85F98CEC:        0        0        0        0        0        0        1        0
85F98D0C: 7FFFFFFF  1010000        0        0        0        0        0        0
85F98D2C:        0   FF7F7F        1        1       14        1        0        0
85F98D4C:        0        0       14        0        0        0        0        0
---- block18  ptr=83C10008  is_malloc=0  length=0x100 ----
83C0FFC8:    4A001 400C8003     8201 B600C101   109DE5 B200D4E1 BA05C1E1  610D4E5
83C0FFE8:     51E3 1600000A     55E3 B401D601 B601D611  130A0E1   10D4E5 931027E0
83C10008: B210D4E1     A0E3  10051E3  778A0E1 2778A0E1  1000712  1002012  73080E0
83C10028:  338A0E1 2338A0E1  10053E3  3C08102  2208112 93020C10 910009E0  8008DE5
83C10048: 1C0000EA B811D6E1     D4E5  1A080E0  AA8A0E1 BA11D6E1 2AA8A0E1  1E080E0
83C10068:  EE8A0E1 B200D4E1 2EE8A0E1  10050E3   10A003  120A001  700000A  1300AE2
83C10088:  11023E2  1001EE3  120A003  200000A   20A0E3     53E3  220A003  A3081E0
83C100A8:  4C080E2 930C0CE0  338A0E1 2338A0E1 900109E0  8208DE5  5B1A0E1 E8859FE5
83C100C8: BB9088E1  59188E0  8809DE5 B2B0D4E1     55E3 980B0BE0 108086E2  C6086E2
83C100E8: B2B0C9E1 85B0A0E1  3904CE0 BB9088E1   809DE5 BB3086E1 B8C5C8E1  CC8A0E1
---- block19  ptr=83E1000C  is_malloc=0  length=0x100 ----
83E0FFCC: 6365726F 75746520 7465726D 696E6174 65642E00  A43616E 206E6F74 2066696E
83E0FFEC: 64206D61 74636865 64206163 74697665 204C6F63 616C204D 45502077 69746820
83E1000C: 736F7572 6365204D 50494420 25642E20 54726163 65726F75 74652074 65726D69
83E1002C: 6E617465 642E0000  A4E6F20 61637469 7665204D 45502063 6F6E6669 67757265
83E1004C: 64206174 206C6576 656C2025 752C2064 6F6D6169 6E202573 2C202573 2E204361
83E1006C: 6E6E6F74 20696E69 74696174 65207472 61636572 6F757465 206D6573 73616765
83E1008C: 20776974 686F7574 20616E20 61637469 7665204D 45502063 6F6E6669 67757265
83E100AC: 642E2054 72616365 726F7574 65207465 726D696E 61746564 2E000000  A546865
83E100CC: 72652061 7265206D 756C7469 706C6520 6C6F6361 6C204D45 50732063 6F6E6669
83E100EC: 67757265 64206174 20646F6D 61696E20 25732C20 25732E20 506C6561 73652073
---- block20  ptr=89430000  is_malloc=0  length=0x100 ----
8942FFC0:        0        0        0        0        0        0        0        0
8942FFE0:        0        0        0        0        0        0        0        0
89430000:        0        0        0        0        0        0        0        0
89430020:        0        0        0        0        0        0        0        0
89430040:        0        0        0        0        0        0        0        0
89430060:        0        0        0        0        0        0        0        0
89430080:        0        0        0        0        0        0        0        0
894300A0:        0        0        0        0        0        0        0        0
894300C0:        0        0        0        0        0        0        0        0
894300E0:        0        0        0        0        0        0        0        0
---- block21  ptr=88030000  is_malloc=0  length=0x100 ----
8802FFC0: 2E33362E 34302834 34332920 2D3E2031 39322E31 36382E31 2E363528 34393138
8802FFE0: 38292C20 31207061 636B6574 20200A44 65632031 39203138 3A32363A 31322E39
88030000: 39393A20 25534543 2D362D49 50414343 4553534C 4F47503A 206C6973 74203130
88030020: 35206465 6E696564 20746370 2036362E 3136332E 33362E34 30283434 3329202D
88030040: 3E203139 322E3136 382E312E 36352834 39313936 292C2031 20706163 6B657420
88030060: 200A4465 63203139 2031383A 32363A31 342E3938 333A2025 5345432D 362D4950
88030080: 41434345 53534C4F 47503A20 6C697374 20313035 2064656E 69656420 74637020
880300A0: 36362E31 36332E33 362E3430 28343433 29202D3E 20313932 2E313638 2E312E36
880300C0: 35283130 3838292C 20312070 61636B65 7420200A 44656320 31392031 383A3236
880300E0: 3A32312E 3031313A 20255345 432D362D 49504143 43455353 4C4F4750 3A206C69
---- block22  ptr=881EFA0C  is_malloc=1  length=0x83C ----
881EF9CC:        0        0        0        0        0        0        0        0
881EF9EC:        0        0        0        0        0        0        0 FD0110DF
881EFA0C: AB1234CD FFFE0000        0 839C1F98 807F84DC 881F0248 881EF1E4 80000406
881EFA2C:        1        0        1 85FB07EC        0        0        0        0
881EFA4C:        0        0        0        0        0        0        0        0
881EFA6C:        0        0        0        0        0        0        0        0
881EFA8C:        0        0        0        0        0        0        0        0
881EFAAC:        0        0        0        0        0        0        0        0
881EFACC:        0        0        0        0        0        0        0        0
881EFAEC:        0        0        0        0        0        0        0        0
881EFB0C:        0        0        0        0        0        0        0        0
881EFB2C:        0        0        0        0        0        0        0        0
881EFB4C:        0        0        0        0        0        0        0        0
881EFB6C:        0        0        0        0        0        0        0        0
881EFB8C:        0        0        0        0        0        0        0        0
881EFBAC:        0        0        0        0        0        0        0        0
881EFBCC:        0        0        0        0        0        0        0        0
881EFBEC:        0        0        0        0        0        0        0        0
881EFC0C:        0        0        0        0        0        0        0        0
881EFC2C:        0        0        0        0        0        0        0        0
881EFC4C:        0        0        0        0        0        0        0        0
881EFC6C:        0        0        0        0        0        0        0        0
881EFC8C:        0        0        0        0        0        0        0        0
881EFCAC:        0        0        0        0        0        0        0        0
881EFCCC:        0        0        0        0        0        0        0        0
881EFCEC:        0        0        0        0        0        0        0        0
881EFD0C:        0        0        0        0        0        0        0        0
881EFD2C:        0        0        0        0        0        0        0        0
881EFD4C:        0        0        0        0        0        0        0        0
881EFD6C:        0        0        0        0        0        0        0        0
881EFD8C:        0        0        0        0        0        0        0        0
881EFDAC:        0        0        0        0        0        0        0        0
881EFDCC:        0        0        0        0        0        0        0        0
881EFDEC:        0        0        0        0        0        0        0        0
881EFE0C:        0        0        0        0        0        0        0        0
881EFE2C:        0        0        0        0        0        0        0        0
881EFE4C:        0        0        0        0        0        0        0        0
881EFE6C:        0        0        0        0        0        0        0        0
881EFE8C:        0        0        0        0        0        0        0        0
881EFEAC:        0        0        0        0        0        0        0        0
881EFECC:        0        0        0        0        0        0        0        0
881EFEEC:        0        0        0        0        0        0        0        0
881EFF0C:        0        0        0        0        0        0        0        0
881EFF2C:        0        0        0        0        0        0        0        0
881EFF4C:        0        0        0        0        0        0        0        0
881EFF6C:        0        0        0        0        0        0        0        0
881EFF8C:        0        0        0        0        0        0        0        0
881EFFAC:        0        0        0        0        0        0        0        0
881EFFCC:        0        0        0        0        0        0        0        0
881EFFEC:        0        0        0        0        0        0        0        0
881F000C:        0        0        0        0        0        0        0        0
881F002C:        0        0        0        0        0        0        0        0
881F004C:        0        0        0        0        0        0        0        0
881F006C:        0        0        0        0        0        0        0        0
881F008C:        0        0        0        0        0        0        0        0
881F00AC:        0        0        0        0        0        0        0        0
881F00CC:        0        0        0        0        0        0        0        0
881F00EC:        0        0        0        0        0        0        0        0
881F010C:        0        0        0        0        0        0        0        0
881F012C:        0        0        0        0        0        0        0        0
881F014C:        0        0        0        0        0        0        0        0
881F016C:        0        0        0        0        0        0        0        0
881F018C:        0        0        0        0        0        0        0        0
881F01AC:        0        0        0        0        0        0        0        0
881F01CC:        0        0        0        0        0        0        0        0
881F01EC:        0        0        0        0        0        0        0        0
881F020C:        0        0        0        0        0        0        0        0
881F022C:        0        0        0        0        0        0 FD0110DF
---- block23  ptr=8BDD0000  is_malloc=0  length=0x100 ----
8BDCFFC0: 20010601  1004480       40   8300CA  2070010   400A21  4485400 4000C091
8BDCFFE0: 80600098   808450 10000005       80  1324108   404000    15010 8434C080
8BDD0000: EF7FDB7F FFEF7EFF FF7BFDBF FFFB7FF7 673FFEFF FFFFFFDC FEFB9FFF FFFFFFDC
8BDD0020: FFBFFFFF FFFFB3A7 CBDDFFFF FF8FF8C7 FFFFBFFA FFFF5EB7 AFEBFF97 BDE5DFED
8BDD0040: FFFEFEEF FE7ED7DF FFBFFEEF FF7FFFFF F7EF6FFF FFFF8EFD F3FDEF7F DDF37FE7
8BDD0060: BBFFFEBF 757EFFFD BFFFFFE6 FFFFBE3F FFDDFFBF DFDDDDAF FBF6FFDF FFF3DDE5
8BDD0080: FBFFFFEF FEFFFFDD FFFBEFFF FAFF3DFD FFBFFFFF FFFDDDF7 EFEAFBFF FFFFEFEC
8BDD00A0: FFF3FEFD FEFFFEEF FDFFFFDF FFDFFF9F DFF9CFF7 FBFFEBDF F797F3D7 EFED9FFC
8BDD00C0: E9FFFEFF FDF3FBDF FF3FFE7F FEBFFDD7 97DEF7FA 7F7EFB77 FFB7EFFF BF7FFFBA
8BDD00E0: DBFFFFBD EFBFEFFF FBF7FFFE FEFFFDDE FFDFBEFF FFF7B7FD FE3FFFFD CDF7BFFB
---- block24  ptr=86B276F0  is_malloc=1  length=0x860 ----
86B276B0: 80000016        1        0        1 85FB07EC        0        0        0
86B276D0:        0        0        0        0 84403F14    90202        0 FD0110DF
86B276F0: AB1234CD FFFE0000        0 8480C750 8225CEC8 86B2774C 86B276A8 80000016
86B27710:        1        0        1 85FB07EC        0        0        0        0
86B27730:        0        0        0 84403F20    A0202        0 FD0110DF AB1234CD
86B27750: FFFE0000        0 8600ACE8 82AA9390 86B27F50 86B27704 800003EA        1
86B27770: 82A47550        1 85FB07EC        0 86A5966C 8735DDA4        0 8600ACAC
86B27790:       64       77    C000C        0        0        0        0        4
86B277B0:    30000 85647630 52656720 46756E63 74696F6E 204C0000 86B279B4 86B27F48
86B277D0:        0        0 86B279B4 86B279C0 86B279CC 86B279D8 86B279E4 86B279F0
86B277F0: 86B279FC 86B27A08 86B27A14 86B27A20 86B27A2C 86B27A38 86B27A44 86B27A50
86B27810: 86B27A5C 86B27A68 86B27A74 86B27A80 86B27A8C 86B27A98 86B27AA4 86B27AB0
86B27830: 86B27ABC 86B27AC8 86B27AD4 86B27AE0 86B27AEC 86B27AF8 86B27B04 86B27B10
86B27850: 86B27B1C 86B27B28 86B27B34 86B27B40 86B27B4C 86B27B58 86B27B64 86B27B70
86B27870: 86B27B7C 86B27B88 86B27B94 86B27BA0 86B27BAC 86B27BB8 86B27BC4 86B27BD0
86B27890: 86B27BDC 86B27BE8 86B27BF4 86B27C00 86B27C0C 86B27C18 86B27C24 86B27C30
86B278B0: 86B27C3C 86B27C48 86B27C54 86B27C60 86B27C6C 86B27C78 86B27C84 86B27C90
86B278D0: 86B27C9C 86B27CA8 86B27CB4 86B27CC0 86B27CCC 86B27CD8 86B27CE4 86B27CF0
86B278F0: 86B27CFC 86B27D08 86B27D14 86B27D20 86B27D2C 86B27D38 86B27D44 86B27D50
86B27910: 86B27D5C 86B27D68 86B27D74 86B27D80 86B27D8C 86B27D98 86B27DA4 86B27DB0
86B27930: 86B27DBC 86B27DC8 86B27DD4 86B27DE0 86B27DEC 86B27DF8 86B27E04 86B27E10
86B27950: 86B27E1C 86B27E28 86B27E34 86B27E40 86B27E4C 86B27E58 86B27E64 86B27E70
86B27970: 86B27E7C 86B27E88 86B27E94 86B27EA0 86B27EAC 86B27EB8 86B27EC4 86B27ED0
86B27990: 86B27EDC 86B27EE8 86B27EF4 86B27F00 86B27F0C 86B27F18 86B27F24 86B27F30
86B279B0: 86B27F3C 873C4170        0        0 873C417C        0        0 873C4188
86B279D0:        0        0 873C41C4        0        0 873C41D0        0        0
86B279F0: 873C41F4        0        0 873C4200        0        0 873C4218        0
86B27A10:        0 873C423C        0        0 873C4248        0        0 873C4254
86B27A30:        0        0 873C4260        0        0 873C426C        0        0
86B27A50: 873C42A8        0        0 873C42B4        0        0 873C42C0        0
86B27A70:        0 873C42F0        0        0 873C42FC        0        0 873C438C
86B27A90:        0        0 873C43D4        0        0 873C43E0        0        0
86B27AB0: 873F8FD0        0        0 873F903C        0        0 873F9048        0
86B27AD0:        0 873F90A8        0        0 873F912C        0        0 873F9204
86B27AF0:        0        0 873F9264        0        0 873F9270        0        0
86B27B10: 873F927C        0        0 873F92DC        0        0 873F92F4        0
86B27B30:        0 873F9300        0        0 873F930C        0        0 873F9318
86B27B50:        0        0 873F9324        0        0 873F9330        0        0
86B27B70: 873F933C        0        0 873F9360        0        0 873F93F0        0
86B27B90:        0 873F9420        0        0 873F942C        0        0 873F9444
86B27BB0:        0        0 873F945C        0        0 873F9480        0        0
86B27BD0: 873F948C        0        0 873F9498        0        0 873F94A4        0
86B27BF0:        0 873F94B0        0        0 873F94BC        0        0 873F94C8
86B27C10:        0        0 873F94EC        0        0 873F94F8        0        0
86B27C30: 873F9504        0        0 873F9510        0        0 873F951C        0
86B27C50:        0 86EFBCC0        0        0 86EFBCD8        0        0 86EFBD08
86B27C70:        0        0 86EFBD74        0        0 86EFBD80        0        0
86B27C90: 86EFBE94        0        0 86EFBF0C        0        0 86EFBF18        0
86B27CB0:        0 86EFBF24        0        0 86EFBF30        0        0 86EFBF84
86B27CD0:        0        0 86EFBFC0        0        0 86EFBFCC        0        0
86B27CF0: 86EFBFFC        0        0 86EFC008        0        0 86EFC014        0
86B27D10:        0 86EFC038        0        0 86EFC050        0        0 86EFC074
86B27D30:        0        0 86EFC08C        0        0 86EFC098        0        0
86B27D50: 86EFC0BC        0        0 86EFC0C8        0        0 86EFC0D4        0
86B27D70:        0 86EFC0E0        0        0 86EFC0EC        0        0 86EFC104
86B27D90:        0        0 86EFC128        0        0 86EFC14C        0        0
86B27DB0: 86EFC158        0        0 86EFC164        0        0 86EFC194        0
86B27DD0:        0 86EFC1AC        0        0 86EFC1B8        0        0 86EFC1D0
86B27DF0:        0        0 86EFC200        0        0 86EFC2D8        0        0
86B27E10: 86EFC2FC        0        0 86EFC314        0        0 86B26910        0
86B27E30:        0 86B2691C        0        0 86B26934        0        0 86B26940
86B27E50:        0        0 86B2694C        0        0 86B26A30        0        0
86B27E70: 86B26A54        0        0 86B26A60        0        0 86B26A6C        0
86B27E90:        0 86B26A78        0        0 86B26A84        0        0 86B26B50
86B27EB0:        0        0 86B26B68        0        0 86B26BBC        0        0
86B27ED0: 86B26BC8        0        0 86B26BD4        0        0 86B26BE0        0
86B27EF0:        0 86B26C04        0        0 86B26C10        0        0 86B26C1C
86B27F10:        0        0 86B26C28        0        0 86B26C34        0        0
86B27F30: 86B26C88        0        0 86B26D00        0        0        0 FD0110DF
---- block25  ptr=8600BC90  is_malloc=1  length=0x804 ----
8600BC50:        2        1        0        0 823D3534        0        0 823D352C
8600BC70:        0        0 823D3524        0        0 823D3520        0 FD0110DF
8600BC90: AB1234CD FFFE0000        0 8600ACE8 82AA9390 8600C494 8600B4A0 800003EA
8600BCB0:        1 82A47550        1 85FB07EC        0        0 861274B8        0
8600BCD0: 8600ACAC       64       77    C000C        0        0        0        0
8600BCF0:        4    30000 85647630 52656720 46756E63 74696F6E 204C0000 8600BEF8
8600BD10: 8600C48C        0        0 8600BEF8 8600BF04 8600BF10 8600BF1C 8600BF28
8600BD30: 8600BF34 8600BF40 8600BF4C 8600BF58 8600BF64 8600BF70 8600BF7C 8600BF88
8600BD50: 8600BF94 8600BFA0 8600BFAC 8600BFB8 8600BFC4 8600BFD0 8600BFDC 8600BFE8
8600BD70: 8600BFF4 8600C000 8600C00C 8600C018 8600C024 8600C030 8600C03C 8600C048
8600BD90: 8600C054 8600C060 8600C06C 8600C078 8600C084 8600C090 8600C09C 8600C0A8
8600BDB0: 8600C0B4 8600C0C0 8600C0CC 8600C0D8 8600C0E4 8600C0F0 8600C0FC 8600C108
8600BDD0: 8600C114 8600C120 8600C12C 8600C138 8600C144 8600C150 8600C15C 8600C168
8600BDF0: 8600C174 8600C180 8600C18C 8600C198 8600C1A4 8600C1B0 8600C1BC 8600C1C8
8600BE10: 8600C1D4 8600C1E0 8600C1EC 8600C1F8 8600C204 8600C210 8600C21C 8600C228
8600BE30: 8600C234 8600C240 8600C24C 8600C258 8600C264 8600C270 8600C27C 8600C288
8600BE50: 8600C294 8600C2A0 8600C2AC 8600C2B8 8600C2C4 8600C2D0 8600C2DC 8600C2E8
8600BE70: 8600C2F4 8600C300 8600C30C 8600C318 8600C324 8600C330 8600C33C 8600C348
8600BE90: 8600C354 8600C360 8600C36C 8600C378 8600C384 8600C390 8600C39C 8600C3A8
8600BEB0: 8600C3B4 8600C3C0 8600C3CC 8600C3D8 8600C3E4 8600C3F0 8600C3FC 8600C408
8600BED0: 8600C414 8600C420 8600C42C 8600C438 8600C444 8600C450 8600C45C 8600C468
8600BEF0: 8600C474 8600C480 86126BFC        0        0 86126C44        0        0
8600BF10: 86126C5C        0        0 86126C68        0        0 86126C74        0
8600BF30:        0 86126C80        0        0 86126C8C        0        0 860646CC
8600BF50:        0        0 860646D8        0        0 860646E4        0        0
8600BF70: 860646F0        0        0 860646FC        0        0 86064708        0
8600BF90:        0 8606472C        0        0 86064738        0        0 86064744
8600BFB0:        0        0 86064750        0        0 8606475C        0        0
8600BFD0: 86064768        0        0 86064774        0        0 86064780        0
8600BFF0:        0 8606478C        0        0 860647B0        0        0 860647BC
8600C010:        0        0 860647C8        0        0 860647E0        0        0
8600C030: 860647EC        0        0 860647F8        0        0 8606481C        0
8600C050:        0 86064930        0        0 860649B4        0        0 860649C0
8600C070:        0        0 860649CC        0        0 860649D8        0        0
8600C090: 86064A20        0        0 86064A44        0        0 86064A50        0
8600C0B0:        0 86064AA4        0        0 86064AB0        0        0 86064ABC
8600C0D0:        0        0 86064AC8        0        0 86064AE0        0        0
8600C0F0: 86064AEC        0        0 86064AF8        0        0 86064B28        0
8600C110:        0 86064B34        0        0 86064B58        0        0 86064B64
8600C130:        0        0 86064B70        0        0 86064B7C        0        0
8600C150: 86064B88        0        0 86064B94        0        0 86064BA0        0
8600C170:        0 86064BAC        0        0 86064BB8        0        0 86064BC4
8600C190:        0        0 86064BD0        0        0 86064BDC        0        0
8600C1B0: 86064C0C        0        0 86064C18        0        0 86064C24        0
8600C1D0:        0 8600B7D8        0        0 8600B7F0        0        0 8600B7FC
8600C1F0:        0        0 8600B808        0        0 8600B820        0        0
8600C210: 8600B82C        0        0 8600B838        0        0 8600B844        0
8600C230:        0 8600B850        0        0 8600B868        0        0 8600B874
8600C250:        0        0 8600B880        0        0 8600B88C        0        0
8600C270: 8600B8A4        0        0 8600B8C8        0        0 8600B8E0        0
8600C290:        0 8600B958        0        0 8600B9AC        0        0 8600B9B8
8600C2B0:        0        0 8600B9DC        0        0 8600BA00        0        0
8600C2D0: 8600BA0C        0        0 8600BA6C        0        0 8600BA90        0
8600C2F0:        0 8600BA9C        0        0 8600BAA8        0        0 8600BAB4
8600C310:        0        0 8600BAC0        0        0 8600BACC        0        0
8600C330: 8600BAF0        0        0 8600BAFC        0        0 8600BB08        0
8600C350:        0 8600BB14        0        0 8600BB20        0        0 8600BB2C
8600C370:        0        0 8600BB38        0        0 8600BB44        0        0
8600C390: 8600BB5C        0        0 8600BB68        0        0 8600BB74        0
8600C3B0:        0 8600BB80        0        0 8600BB8C        0        0 8600BB98
8600C3D0:        0        0 8600BBA4        0        0 8600BBB0        0        0
8600C3F0: 8600BBBC        0        0 8600BBC8        0        0 8600BBD4        0
8600C410:        0 8600BBE0        0        0 8600BBEC        0        0 8600BBF8
8600C430:        0        0 8600BC04        0        0 8600BC10        0        0
8600C450: 8600BC1C        0        0 8600BC28        0        0 8600BC34        0
8600C470:        0 8600BC58        0        0 8600BC70        0        0        0
8600C490: FD0110DF
---- block26  ptr=84A6DD48  is_malloc=0  length=0x100 ----
84A6DD08: 20726564 69726563 74206964        0 5650444E 206D6772 2063616C 6C206368
84A6DD28: 756E6B00 5650444E 206D6772 206D6764 2074696D 65722063 68756E6B        0
84A6DD48: 5650444E 20000000 7569643A 25752000 546E6C2F 536E0000 5650444E 20535720
84A6DD68: 53420000 556E6578 70656374 65642065 76656E74 21212120 5650444E 20537562
84A6DD88: 626C6F63 6B206465 7374726F 79206361 6C6C6564        0 5650444E 5F494442
84A6DDA8:        0 5650444E 5F4C4143 5F444941 4C4F5554        0 5650444E 20737562
84A6DDC8: 626C6F63 6B206368 756E6B73        0  A257320 5650444E 3A205265 73657474
84A6DDE8: 696E6720 696E7465 72666163 65000000 4C32583A 204E756C 6C207072 6F746F63
84A6DE08: 6F6C2066 756E6374 696F6E20 7461626C 65000000 41414120 756E6971 75652049
84A6DE28: 4420616C 6C6F6320 6572726F 72000000 50505020 73796E63 68726F6E 6F757320
---- block27  ptr=85805D14  is_malloc=0  length=0x100 ----
85805CD4:        0        0        0        0        0        0        0        0
85805CF4:        0        0        0        0        0        0        0        0
85805D14: 8589D1C0 84A779D4        0        2        0 82AA9130 877D74F8 82CC884C
85805D34:        1   100080        0        0        0        1 87107038 86F6DCC4
85805D54: 86F6E40C 82CCA6F4        1 82A4A408 83989430 82A4A7FC        0        0
85805D74:        0        0        0        0        0        0        0        0
85805D94:        0        0        0        0        0        0        0        0
85805DB4:        0        0        0        0        0        0        0        0
85805DD4:        0        0        0        0        0        0        0        0
85805DF4:        0        0        0        0        0        0        0        0
---- block28  ptr=873F8114  is_malloc=1  length=0x14C ----
873F80D4: 8450EAF8 813CC38C 873F8114 873F8090 8000000E        1        0        1
873F80F4: 85FB07EC 873F80AC 85638AFC 854EC090        1        1        0 FD0110DF
873F8114: AB1234CD FFFE0000        0 8450EAF8 813CC38C 873F8160 873F80DC 8000000E
873F8134:        1        0        1 85FB07EC 873F80F8 85637E84 854EC024        1
873F8154:        0        0 FD0110DF AB1234CD FFFE0000        0 8451675C 813E4150
873F8174: 873F81D0 873F8128 80000020        1        0        1 85FB07EC 873F8298
873F8194: 868F9DC4 847E1544 84A7F438 84A7F444 84C50310 82CDBED8 82CDBEEC        0
873F81B4:        7 854EBD24 873F8200 873F824C        0        0 FD0110DF AB1234CD
873F81D4: FFFE0000        0 84516768 813E41BC 873F821C 873F8174 8000000E        1
873F81F4:        0        1 85FB07EC        0        0        0        0        0
873F8214:        0 FD0110DF AB1234CD FFFE0000        0 84516778 813E41E0 873F8268
873F8234: 873F81E4 8000000E        1        0        1 85FB07EC        0        0
873F8254:        0        0        0
---- block29  ptr=873F8268  is_malloc=1  length=0x100 ----
873F8228: 84516778 813E41E0 873F8268 873F81E4 8000000E        1        0        1
873F8248: 85FB07EC        0        0        0        0        0        0 FD0110DF
873F8268: AB1234CD FFFE0000        0 8451675C 813E4150 873F82D8 873F8230 80000020
873F8288:        1        0        1 85FB07EC 873F96CC 8614F368 843985F4 84A7F460
873F82A8: 84A7F470 847E1544 82CDBF10 82CDBF28        0        7 854EB804 873F8308
873F82C8: 873F8354        0        0 FD0110DF AB1234CD FFFE0000        0 84516768
873F82E8: 813E41BC 873F8324 873F827C 8000000E        1        0        1 85FB07EC
873F8308:        0        0        0        0        0        0 FD0110DF AB1234CD
873F8328: FFFE0000        0 84516778 813E41E0 873F8370 873F82EC 8000000E        1
873F8348:        0        1 85FB07EC        0        0        0        0        0
---- block30  ptr=85BC2F68  is_malloc=0  length=0x100 ----
85BC2F28:        0        0        0        0        0        0        0        0
85BC2F48:        0        0        0        0        0        0        0        0
85BC2F68:        0        0        0        0        0        0        0        0
85BC2F88:        0        0        0        0        0        0        0        0
85BC2FA8:        0        0        0        0        0        0        0        0
85BC2FC8:        0        0 84A9EF30 85B22820 86C6979C        1       16      500
85BC2FE8:        1        0        0        0        0 81E76A10 81E76A44 81E76B0C
85BC3008: 81E7906C 82D7E598 81E7A064 81E79E88 82D7E924 81E76994 82D7E264 82D7E31C
85BC3028: 81E79828 81E79238 81E77BFC 81E79330 81E791E4 81E792BC 81E799EC 82D7E468
85BC3048: 82D7E3A0 81E7A1F4 81E7A330        0        0        0        0        0
---- block31  ptr=8647A90C  is_malloc=1  length=0xA00 ----
8647A8CC:        0        0        0        0        0        0        0        0
8647A8EC:        0        1        0        0        0        0        0 FD0110DF
8647A90C: AB1234CD FFFE0000        0 8432F304 80C17B68 86491AD0 8647A7E4 8000B8CA
8647A92C:        1        0        1 85FB07EC D15CD15C      10D        0        0
8647A94C:        0        0        0        0        1        0        0        0
8647A96C:        0        0        0        0        0        0 8647CCD8        0
8647A98C:        0        0        0 8647AAC4        0        0        1        2
8647A9AC:        F        0        0        F        E       46        0        F
8647A9CC:        4 8647CCEC        0        0        0        0 8647A994        0
8647A9EC:        0        2        3        0        0        0        0        0
8647AA0C:        0        0        0        0 8647CD00        0        0        0
8647AA2C: 8647A994 8647A9E0        0        0        3        4        0        0
8647AA4C:        0        0        0        0        0        0        0 8647CD14
8647AA6C:        0        0        0        0 8647AA2C        0        0        4
8647AA8C:        0        0        0        0        0        0        0        0
8647AAAC:        0        0 8647CE68        0        0        0        0 8647A948
8647AACC:        0        0        5        0        0        0        0        0
8647AAEC:        0        0        0        0        0 8647CCD8        0        0
8647AB0C:   300500        0 8647AB5C        0        0        6        0        0
8647AB2C:        0        0        0        0        0        0        0        0
8647AB4C: 8647CD3C        0        0        0        0 8647ABA8        0        0
8647AB6C:        7        0        0        0        0        0        0        0
8647AB8C:        0        0        0 8647CD50        0        0        0        0
8647ABAC: 8647ABF4        0        0        8        0        0        0        0
8647ABCC:        0        0        0        0        0        0 8647CD64        0
8647ABEC:        0        0        0 8647AC40        0        0        9        0
8647AC0C:        0        0        0        0        0        0        0        0
8647AC2C:        0 8647CD78        0        0        0        0 8647AC8C        0
8647AC4C:        0        A        0        0        0        0        0        0
8647AC6C:        0        0        0        0 8647CD8C        0        0        0
8647AC8C:        0 8647ACD8        0        0        B        0        0        0
8647ACAC:        0        0        0        0        0        0        0 8647CDA0
8647ACCC:        0        0        0        0 8647AD24        0        0        C
8647ACEC:        0        0        0        0        0        0        0        0
8647AD0C:        0        0 8647CDB4        0        0        0        0 8647AD70
8647AD2C:        0        0        D        0        0        0        0        0
8647AD4C:        0        0        0        0        0 8647CDC8        0        0
8647AD6C:        0        0 8647ADBC        0        0        E        0        0
8647AD8C:        0        0        0        0        0        0        0        0
8647ADAC: 8647CDDC        0        0        0        0 8647AE08        0        0
8647ADCC:        F        0        0        0        0        0        0        0
8647ADEC:        0        0        0 8647CDF0        0        0        0        0
8647AE0C: 8647AE54        0        0       10        0        0        0        0
8647AE2C:        0        0        0        0        0        0 8647CE04        0
8647AE4C:        0        0        0 8647AEA0        0        0       11        0
8647AE6C:        0        0        0        0        0        0        0        0
8647AE8C:        0 8647CE18        0        0        0        0 8647AEEC        0
8647AEAC:        0       12        0        0        0        0        0        0
8647AECC:        0        0        0        0 8647CE2C        0        0        0
8647AEEC:        0 8647AF38        0        0       13        0        0        0
8647AF0C:        0        0        0        0        0        0        0 8647CE40
8647AF2C:        0        0        0        0 8647AF84        0        0       14
8647AF4C:        0        0        0        0        0        0        0        0
8647AF6C:        0        0 8647CE54        0        0        0 8647A994        0
8647AF8C:       14        0        0        1        0        0        0        0
8647AFAC:        0        0        0        0        0        0        0        0
8647AFCC:        0        0        0        0       50        0        0       80
8647AFEC: 85FF8EA8 863E48B8 86491C44 864731C8 8432B480        0        0 4C000000
8647B00C:    A5212 82AA0009        0 82848B0C 12961824 3048606C 82848B0C 12961824
8647B02C: 3048606C  1000000        1 40400000        0  202092A  92B7FFF 7FFF7FFF
8647B04C:  3030000        0 864D8E94 864D917C        3        0        0        0
8647B06C:        0        0        0        0        0        0        0        0
8647B08C:        0        0        0        0        0        0        0        0
8647B0AC:        0        0        0        0        0        0        0        0
8647B0CC:        0    10214    10000        0        0        0        0        0
8647B0EC:        0        0 10297A67 EF759EA0 32672634 C5FC4BC5 71000000        0
8647B10C:        0        0        0        0        0        0        0        0
8647B12C:        0        0        0    3DCE0        3        0        0        0
8647B14C:        0        0        0        0        0        0        0        0
8647B16C:        0        0        0        0        0        0        0        0
8647B18C:        0        0        0        0        0        0        0        0
8647B1AC:        0        0        0        0        0        0        0        0
8647B1CC:        0        0        0        0        0        0        0        0
8647B1EC:        0        0        0        0        0        0        0        0
8647B20C:        0        0        0        0        0        0        0        0
8647B22C:        0        0        0        0        0        0        0        0
8647B24C:        0        0        0        0        0        0        0        0
8647B26C:        0        0        0        0        0        0        0        0
8647B28C:        0        0        0        0        0        0        0        0
8647B2AC:        0        0        0        0        0        0        0        0
8647B2CC:        0        0        0        0        0        0        0        0
8647B2EC:        0        0        0        0        0        0        0        0
---- block32  ptr=83D97374  is_malloc=0  length=0x100 ----
83D97334: 70726573 73696F6E 206E6F74 20737570 706F7274 65642077 69746820 5243502E
83D97354: 20436F6D 70726573 73696F6E 20646973 61626C65 642E0000 7365713A 20636100
83D97374: 2A506163 6B657420 44617461 2A000000 2A506163 6B657420 48656164 65722A00
83D97394: 5075626C 69632050 6F6F6C73        0 50726976 61746520 506F6F6C 73000000
83D973B4: 48656164 65722050 6F6F6C73        0 706F6F6C 5F676574 62756666 65720000
83D973D4:  A0A2041 75746F6D 61746963 2074756E 696E6720 696E666F 726D6174 696F6E20
83D973F4: 636F756C 64206E6F 74206265 20736176 65640000 42756666 65722065 6C656D65
83D97414: 6E747300  A252525 73206973 20612073 74617469 6320706F 6F6C2061 6E642063
83D97434: 616E6E6F 74206265 2074756E 65640000  A0A3D3D 3D3D3D3D 3D3D3D20 7061636B
83D97454: 65747320 756E7765 64676564 20616E64 20646561 6C6C6F63 61746564 203D3D3D
---- block33  ptr=85FB0794  is_malloc=0  length=0x158 ----
85FB0754: 85FABAF0        0  1000002        0 85FAAD28        0        0        0
85FB0774:       FF 85F9DB98        0        0        0        0        0        0
85FB0794: 85FB0700 85FB0828 85FB0758 85FAAD70 85FB67E0 85FB66D0 85FB67A0 85FB6828
85FB07B4: 85FB07A4 857FCF0C       39    90000        3        0 849D6A34 82A9865C
85FB07D4: 8549413C        0        0        0        0 85FABAF0        0  1000001
85FB07F4:        0 85FAAD28        0        0        0       FF 85F9DBAC        0
85FB0814:        0        0        0        0        0 85FB0794        0 85FB07EC
85FB0834: 85FAAD70 85FB6978 85FB6868 85FB6938 85FAADB0 85FB0838 857FCF0C       35
85FB0854:    90000        3        0 849D6A34 82A9865C 8549413C        0        0
85FB0874:        0        0        0        0        0        0        0        0
85FB0894:        0        0        0        0        0        0        0        0
85FB08B4:        0        0        0        0        0        0        0        0
85FB08D4:        0        0        0        0        0        0
---- block34  ptr=8C620758  is_malloc=0  length=0x100 ----
8C620718: 7FFEEFFF FFFBCDEE 37DFF7FF FFDDFE5F EFFFFDFD E7FFFF7E 7FFFFF7F D7FFBFFD
8C620738: 8EFE7F9F EBF96BF4 FFEEFFFF BFDF6EEF F8F7FBFF FFFBDEEC EFBDEF7F FFFFEFBF
8C620758: 7FF6F7F6 FDFDFFFD FEAFFBFD FFF7D7DF D5C7FFFF EEFFEFFE FFEDFFFF FBFDFC7D
8C620778: 3FFEFBDD EFBEFEDC FFFF7D2F 9F6FFFF5 EBBFFFFF FFFEEF7F 77FDFFDF FFF7FFF9
8C620798: FFF67FFD FFFF5CF6 FDCCFDF7 FFEFF7FD FE3FFFFF FFFFFDBF F7FBDF7F AFFAFFFD
8C6207B8: 7EDDFEBF FEDFD7EA BFFFFFFF F7DFF7FF FDFFF5FF FFFDB7FF 77EFF7FF BBDF7FF4
8C6207D8: BFDFFFC7 FBF6DFFF FFFF7BFF EEB7754F DFFBFFFF FFBFB796 FBFFC7FD FFFF7DFF
8C6207F8: 6FFFFFBF FFB7B3FD FF7FBFAF FFFFBB9A FEEFFFFF 7FF6FF7B BFFFFEFF DFF9F8FF
8C620818: FFBFBFFD F7FD87FF 75EFFFAE FFFF7F2E F6B7FEFD E7EFFFDD EFD2FF7E FFFDEFFF
8C620838: FFFBEFFF FFBFF7B1 BF7FFFDF FFFEF7F5 EFF7FFFF FF6FFFFC EFF5EFFB FFFF5FDF
---- block35  ptr=84D0F118  is_malloc=0  length=0x100 ----
84D0F0D8: 332E342E 352D7035 29000047 43433A20 28474E55 2920332E 342E3520 70352028
84D0F0F8: 43697363 6F206333 2E342E35 2D703529     4743 433A2028 474E5529 20332E34
84D0F118: 2E352070 35202843 6973636F 2063332E 342E352D 70352900   474343 3A202847
84D0F138: 4E552920 332E342E 35207035 20284369 73636F20 63332E34 2E352D70 35290000
84D0F158: 4743433A 2028474E 55292033 2E342E35 20703520 28436973 636F2063 332E342E
84D0F178: 352D7035 29000047 43433A20 28474E55 2920332E 342E3520 70352028 43697363
84D0F198: 6F206333 2E342E35 2D703529     4743 433A2028 474E5529 20332E34 2E352070
84D0F1B8: 35202843 6973636F 2063332E 342E352D 70352900   474343 3A202847 4E552920
84D0F1D8: 332E342E 35207035 20284369 73636F20 63332E34 2E352D70 35290000 4743433A
84D0F1F8: 2028474E 55292033 2E342E35 20703520 28436973 636F2063 332E342E 352D7035
---- block36  ptr=86F325EC  is_malloc=0  length=0x100 ----
86F325AC:        0        0        0        0        0        0        0        0
86F325CC:        0        0        0        0        0        0        0        0
86F325EC:        0        0        0        0        0        0        0        0
86F3260C:        0        0        0        0        0        0        0        0
86F3262C:        0        0        0        0        0        0        0        0
86F3264C:        0        0        0        0        0        0        0        0
86F3266C:        0        0        0        0        0        0        0        0
86F3268C:        0        0        0        0        0        0        0        0
86F326AC:        0        0        0        0        0        0        0        0
86F326CC:        0        0        0        0        0        0        0        0
---- block37  ptr=8432F304  is_malloc=0  length=0x118 ----
8432F2C4: 61647920 73656D61 70686F72 65000000 436F756C 64206E6F 74206164 64207468
8432F2E4: 65207261 64696F20 49444220 746F2074 6865206D 61696E20 6C697374        0
8432F304: 3830322E 31312064 72697665 7220496E 7374616E 63650000 646F7431 31204841
8432F324: 4C000000  A496E63 6F6D7061 7469626C 65204841 4C207665 7273696F 6E20666F
8432F344: 72207468 69732073 6F667477 61726520 72656C65 61736500 696E7466 5F656E61
8432F364: 626C6564        0 696E7466 5F726561 64790000 646F7431 31207261 64696F20
8432F384: 696E7465 72727570 74000000 3830322E 31314120 52616469 6F000000 3830322E
8432F3A4: 31314720 52616469 6F000000 3830322E 31314220 52616469 6F000000 25735073
8432F3C4: 70000000 636F7272 75707465 64206472 69766572 20747820 626C6F63 6B000000
8432F3E4: 7061636B 65742073 74696C6C 20696E20 4C6F7765 72204D41 43000000 696E7661
8432F404: 6C696420 71756575 6520636F 756E7400 6E6F7478 61637469
---- block38  ptr=8647A75C  is_malloc=1  length=0x1B0 ----
8647A71C:        0        0        0        0        0 8652B4F8 8647A704 8647A720
8647A73C: 8647A6A8        0 85BAE9C8        0  FFFFFFF  FFFFFFF        0 FD0110DF
8647A75C: AB1234CD FFFE0000        0 839C1F98 82AB41A0 8647A7D0 8647A684 80000022
8647A77C:        1        0        1 85FB07EC        0        0        0        0
8647A79C:        0        0        0        0        0        0        0        0
8647A7BC:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
8647A7DC: 839C1F98 815E73E0 8647A90C 8647A770 80000086        1        0        1
8647A7FC: 85FB07EC        0 864731C8 84587D58 8787860C 8645406C        0        0
8647A81C:        0        0        0        0        0        0        0        0
8647A83C:        0        0        0        0        0        0        0        0
8647A85C:        0        0        0        0        0        0        0        0
8647A87C:        0        0        0        0        0        0        0        0
8647A89C:        0        0        0        0        0        0        0        0
8647A8BC:        0        0        0        0        0        0        0        0
8647A8DC:        0        0        0        0        0        1        0        0
8647A8FC:        0        0        0 FD0110DF
---- block39  ptr=84347A64  is_malloc=0  length=0x100 ----
84347A24:        0        0        1 8562F874        1 8562F82C 745F6966 5F646F74
84347A44: 31315F68 616C5F72 65676973 74727900 49465F44 4F543131 5F48414C        0
84347A64: 856350C8        0 813A524C 80C83F20 8434A5B0        0  2000200  4000400
84347A84:  B000800 16001000  C000001 12000002 18000004 24000008 30000010 48000020
84347AA4: 60000040 6C000080  2000200  4000400  B000800  C000001 12000002 16001000
84347AC4: 18000004 24000008 30000010 48000020 60000040 6C000080    30004    50006
84347AE4:    7000A    D000F   110012   140003    40005    60007    A000D    F0011
84347B04:    30004    50006    7000A    D0010   409600 80CA1928 80C9B9E4 80C9B98C
84347B24: 80CA1018 80C9F5B4 80C940AC 80C94184 80C94224 80C942CC 80C943E4 80C944E8
84347B44: 80C94598 80C948E8 80C9521C 80C95594 80C951BC 80C92678 80C9273C 80C92860
---- block40  ptr=839C1F98  is_malloc=0  length=0x100 ----
839C1F58: 616C2056 4C414E0A        0  A564C41 4E205573 6167650A 2D2D2D2D 202D2D2D
839C1F78: 2D2D2D2D 2D2D2D2D 2D2D2D2D 2D2D2D2D 2D0A0000 45787420 566C616E 20444220
839C1F98: 496E6974        0  A4E6F20 6D656D6F 72792074 6F206372 65617465 20657874
839C1FB8: 20766C61 6E206461 74616261 73650A00  A496E76 616C6964 20657874 20766C61
839C1FD8: 6E206964 2025640A        0  A416C6C 6F636174 696E6720 65787420 766C616E
839C1FF8: 20256400 45787420 566C616E 20656E74 72790000  A466169 6C656420 746F2061
839C2018: 64642061 206E6577 20657874 20564C41 4E20656E 7472790A        0  A566C61
839C2038: 6E202564 20737461 7475733D 4558545F 4E45575F 564C414E        0 45787420
839C2058: 566C616E 20444220 6261636B 75700000 45787420 566C616E 20626163 6B757020
839C2078: 656E7472 79000000  A446561 6C6C6F63 61746520 65787420 766C616E 20256400
---- block41  ptr=8647302C  is_malloc=1  length=0x14C ----
86472FEC: 845052B4 81392DB0 8647302C 86472F08 8000000E        1        0        1
8647300C: 85FB07EC 446F7431 31206472 69766572 206C6F67        0        0 FD0110DF
8647302C: AB1234CD FFFE0000        0 839C1F98 82AB41A0 86473078 86472FF4 8000000E
8647304C:        1        0        1 85FB07EC        0        0        0        0
8647306C:        0        0 FD0110DF AB1234CD FFFE0000        0 839C1F98 82AB41A0
8647308C: 864730C4 86473040 8000000E        1        0        1 85FB07EC        0
864730AC:        0        0        0        0        0 FD0110DF AB1234CD FFFE0000
864730CC:        0 839C1F98 83989988 86473198 8647308C 80000052        1        0
864730EC:        1 85FB07EC 86470D94        0        0        0        0        0
8647310C:        0        0        0        0        0        0        0        0
8647312C:        0        0        0        0        0        0        0        0
8647314C:        0        0        0        0        0        0        0        0
8647316C:        0        0        0
---- block42  ptr=86470D18  is_malloc=1  length=0x14C ----
86470CD8: 839C1F98 82AB41A0 86470D18 86470C94 8000000E        1        0        1
86470CF8: 85FB07EC        0        0        0        0        0        0 FD0110DF
86470D18: AB1234CD FFFE0000        0 839C1F98 82AB41A0 86470D64 86470CE0 8000000E
86470D38:        1        0        1 85FB07EC        0        0        0        0
86470D58:        0        0 FD0110DF AB1234CD FFFE0000        0 839C1F98 83989988
86470D78: 86470E38 86470D2C 80000052        1        0        1 85FB07EC 8646B078
86470D98:        0        0        0        0        0        0        0        0
86470DB8:        0        0        0        0        0        0        0        0
86470DD8:        0        0        0        0        0        0        0        0
86470DF8:        0        0        0        0        0        0        0        0
86470E18:        0        0        0        0        0        0        0 FD0110DF
86470E38: AB1234CD FFFE0000        0 839C1F98 82AA9A90 8647128C 86470D78 80000212
86470E58:        1        0        1
---- block43  ptr=83D97C68  is_malloc=0  length=0x110 ----
83D97C28: 63652573  A000000 25752053 6174656C 6C697465 20696E74 65726661 63652573
83D97C48:  A000000 25752043 656C6C75 6C617220 696E7465 72666163 6525730A        0
83D97C68: 2A536F66 74776172 65204944 422A0000 2A486172 64776172 65204944 422A0000
83D97C88: 456C656D 656E7420 496E7365 7274696F 6E000000 44454332 31313430 41000000
83D97CA8: 44454332 31313430        0 416D6446 45000000 4952422F 43524220 72787479
83D97CC8: 70657300  A696462 5F696E69 745F636F 6D6D6F6E 3A20546F 6F206D61 6E792049
83D97CE8: 4442732E 2069665F 6E756D62 6572203D 2025640A        0 25732E25 75000000
83D97D08: 456C656D 656E7420 44656C65 74696F6E        0 25632563 25642573 25640000
83D97D28: 436F6D70 75746520 4C6F6164 73204164 64697469 6F6E616C 20494442 73000000
83D97D48: 5461626C 6520496E 69746961 6C697A61 74696F6E        0 444F4449 50000000
83D97D68: 584E5300 4150504C 45000000 4E4F5645
---- block44  ptr=87857364  is_malloc=1  length=0xA00 ----
87857324:        1        0        1 85FB07EC        0 84B06EC4 84B070EC      16A
87857344:  4000000        0      710 FFFFFFFF FFFFFFFF FFFFFFFF        0 FD0110DF
87857364: AB1234CD FFFE0000        0 839C1F98 80218370 878573B0 87857318 8000000E
87857384:        1        0        1 85FB07EC        0        0        0        0
878573A4:        0        0 FD0110DF AB1234CD FFFE0000        0 83D97C78 813696CC
878573C4: 8785804C 87857378 80000636        1        0        1 85FB07EC 8889A24C
878573E4:      101        0        0        0        0 8787AD30       93        2
87857404: 8010E980        0        0        0  1000000        0        0        0
87857424: 81AAA3D8 818422A4       11        0        0        0        1      5EA
87857444:        E        0        0      5EA        0        0        0        1
87857464:       11        F        D        0 FFFFFFFF FFFFFFFF FFFFFFFF        0
87857484:        0        0        0        0        0        9        0        0
878574A4:        0 83E07538 839C71BC 87878748 8787B678        0        0        0
878574C4:        0        0        0        0        0  5DC05DC        1      5F4
878574E4:      5F0 FFFFFFFF        0        0   210048   200011        0        0
87857504: 10000200        4        5        0        5        0        0        0
87857524: 2E85FD34        0        0        0        0        0     BDA4        0
87857544:        0 858CF038 878573E0        0        0    14242        0      7D0
87857564:      7D0        0 84309E38 86454210        0        1        1        1
87857584:        0        0        0 81368440  1010101 FF000009        0        0
878575A4:        0        0       10        0        0        0        0        0
878575C4:        0        0        0        0        0        0        0        0
878575E4:        0        0        0        0        0        0        0        0
87857604:        0        0        0        0        0       28       28       28
87857624:       28       28       28       28       28       28       28       28
87857644:       28       28       28       28       28       28        0        0
87857664:        0       28        0        0        0       28        0        0
87857684:        0       28        0        0        0       28        0        0
878576A4:        0       28        0        0        0       28        0        0
878576C4:        0       28        0        0        0       28        0        0
878576E4:        0       28        0        0        0       28        0        0
87857704:        0       28        0        0        0       28        0        0
87857724:        0       28        0        0        0       28        0        0
87857744:        0       28        0        0        0       28        0        0
87857764:        0       28        0 878573E0        0        0        0       4B
87857784:        0       4B        0        0        0 8010EB0C 8010EC54        0
878577A4:        0 815E7F34 815E7628        0 813A522C        0        0        0
878577C4: 8010EA14        0        0 80341D0C 8031DEA8 8031E5DC        0        0
878577E4: 815E6780 8010E724 8010E8FC 815EAE80 803393B8 815E6270        0 815E66B8
87857804:        0        0        0        0 8010E978        0        0 8010ED38
87857824: 813A524C        0        0        0 801E9F10        0        0 815E656C
87857844:        0        0        0        0        0        0        0        0
87857864:        0        0        0        0        0        0        0 5ACBC8EA
87857884:       20        0        0 2142E91D        0        0        0     8691
878578A4:        0     22F3        0   1F89FC    2DA7F        0        0        0
878578C4:        0        0        0        0        0        0        0        0
878578E4:        0        0    167ED        0        0        0        0        0
87857904:        0        0        0        0        0        0        0        0
87857924:        0        0        0        0        0        0        0        0
87857944:        0        0        0        0    167ED        0        0        0
87857964:        0        0        0        0        0        0        0        0
87857984:        0        0        0        0        1        0        0        0
878579A4:        2        0   9DED72   185AA7        2   169C53        1        0
878579C4:        0        0        0        0        0        0        0        0
878579E4:        0        0 2E865124 87857AB0 87857AFC        0        0        0
87857A04:        0        0        0        0        0 8614529C        0        0
87857A24:        0        0        0        0 88B7EB08        0        0        0
87857A44:        0        0        0        0        0        0        0        0
87857A64:        0        0        0        0        0        0        0        0
87857A84:        0        0        0        0        0        0        0        0
87857AA4:        0        0        0        0        0        0        0        0
87857AC4:        0        0        0        0        0        0        0        0
87857AE4:        0        0        0        0        0        0        0        0
87857B04:        0        0        0        0        0        0        0        0
87857B24:     91B7   64E966        0        0        0        0        0        0
87857B44:        0        0        0        0        0        0 2E865124        0
87857B64:        0        0        0        0        0        0        0        0
87857B84: 8787860C 8787B6C4        0        0        0        0        0        0
87857BA4:        0        0        0        0        0        0        0        0
87857BC4:        0        0        0        0        0        0        0        0
87857BE4:        0        0        0        0        0        0        0        0
87857C04:        0        0        0        0        0        0        0 8787B6C4
87857C24:        0        0 FFFFFFFF        0        0        0        0        0
87857C44:        0        0        0        0        0        0        0        0
87857C64:        0        0        0        0        0        0        0        0
87857C84:        0        0        0        0        0        0        0        0
87857CA4:        0        0        0 858C7320 878573E0        0        0    44246
87857CC4:        0        0        0        0        0        0        0        0
87857CE4:        0        0        0        0        0        0        0        0
87857D04:        0        0        0        0        0        0        0        0
87857D24:        0        0        0        0        0        0        0        0
87857D44:        0        0        0        0        0        0        0        0
---- block45  ptr=86474310  is_malloc=1  length=0x100 ----
864742D0:        0 86473E64        0        0        0        0        0        0
864742F0:       4B     9E34        0        0        0        0        0 FD0110DF
86474310: AB1234CD FFFE0000        0 839C1F98 8004C5B4 8647435C 86473E48 8000000E
86474330:        1        0        1 85FB07EC 446F7431 31526164 696F302F 352F3000
86474350:        0        0 FD0110DF AB1234CD FFFE0000        0 839C1F98 8004C968
86474370: 864743A8 86474324 8000000E        1        0        1 85FB07EC 446F302F
86474390: 352F3000        0        0        0        0 FD0110DF AB1234CD FFFE0000
864743B0:        0 839C1F98 81A459B0 86474404 86474370 80000016        1        0
864743D0:        1 85FB07EC 86474434 8527DAF4       22    80000        0        0
864743F0:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
---- block46  ptr=88257BB0  is_malloc=1  length=0x528 ----
88257B70: 839C1F98 8007B11C 88257BB0 88257B04 8000000E        1        0        1
88257B90: 85FB07EC 63697363 6F2D7068 6F6E6500        0        0        0 FD0110DF
88257BB0: AB1234CD FFFE0000        0 839C1F98 8007B11C 88257BFC 88257B78 8000000E
88257BD0:        1        0        1 85FB07EC 63697363 6F2D7068 6F6E6500        0
88257BF0:        0        0 FD0110DF AB1234CD FFFE0000       9D 83D97C68 813696EC
88257C10: 882580D8 88257BC4 80000256        1        0        1 85FB07EC 882DF644
88257C30: 86473E64      5DC        0  5DC0000        0        1 882317D4 88849BD0
88257C50: 40000018        0        0 888A8654        0        1        0        0
88257C70:        0        0        0        0        0        0        0        0
88257C90: 864731C8 882DF6AC        0       14        1        0        1        2
88257CB0:        1 88258154 88258108        0        0       1C 88257C2C        0
88257CD0:        0       10    20000        0        0        0        0        0
88257CF0:        0        0       64       64     D2F0     D2F0        0        0
88257D10:        0        0        0        0 88849D90 8A1C16D8        0        0
88257D30:        0        0        0        0        0        0        0        0
88257D50:        0 888ADB60 88231788 882DF398        0        0        0        0
88257D70:        0        0 874891F4        0        0        0        0        0
88257D90:        0 8A1C16D8        0        0        0        0        0        0
88257DB0:        0        0        0        0        0   DBBA00        0  1000000
88257DD0:    10000        0        0        0        0        0        0        0
88257DF0:        0 FFFFFFFF        0        0        0        0        0        0
88257E10:        0        0        0        0        0        0    10100        0
88257E30:        0 88256219        0        0        0        0        0        0
88257E50:        0        0        0        0        0        0        0        0
88257E70:     94B8        0        0        0        0        0        0        0
88257E90:        0        0        0        0      100  1000000        0      202
88257EB0:  2808080        0        0        0        0        0        0        0
88257ED0:        0        0        1        0        0        0        0        0
88257EF0:        0        0        0        0        0        1        0 88849D10
88257F10:     FFFF 42000000        0        0        0        0        0        0
88257F30:        0        0        0        0        0        0        0        0
88257F50:        0        0        0        0        0        0        0        0
88257F70:        0        0        0        0        0        0        0        0
88257F90:        0        0        0        0        0        0        0        0
88257FB0:        0        0        0        0        0        0        0        0
88257FD0:  2000000        0        0        0        0        0        0        0
88257FF0: 85B0EFB0 85B0E460 89F8CB90 89F8CB90        1        0        0        4
88258010:        0        0        0        0        0 89F64508 882581A0        0
88258030:        0        0        0        0        0        0        0        0
88258050:        0        0        0        0        0        0        0        0
88258070:        0        0        0        0        0        0        0        0
88258090:        0        0        0 88257C2C        0        0        0        0
882580B0:        0        0        0        0        0        0        0        0
882580D0:        0 FD0110DF
---- block47  ptr=864538CC  is_malloc=1  length=0x4DC ----
8645388C:        0        0        0        0        0 81000000 864538FC        0
864538AC:        0        0        0        0       58        0        0 FD0110DF
864538CC: AB1234CD FFFE0000        0 83D97C68 813696EC 86453DA8 86452C44 80000256
864538EC:        1        0        1 85FB07EC 86473E64 8645234C      5DC        0
8645390C:  5DC0000        0        0        0 887BB378        0        0        0
8645392C:        0        0        1        0        0        0        0        0
8645394C:        0        0        0        0        0 86452C60        0        0
8645396C:        E        0        0        1        2        1 86791780 867917CC
8645398C:        0        0        B 864538FC        0        0       40    10000
864539AC:        0        0        0        0        0        0        0        A
864539CC:        A    186A0    186A0        0        0        0        0 863FE20C
864539EC:        0 8735BAD0 8723DD1C 86D6C474        0        0        0        0
86453A0C:        0        0        0        0        0 88849824        0        0
86453A2C:        0        0        0        0        0        0        0 881C0B98
86453A4C:        0        0        0        0        0        0 881C0B98        0
86453A6C:        0        0        0        0        0        0        0        0
86453A8C:        0        0   DBBA00        0  1000000    10000        0        0
86453AAC:        0        0        0        0        0        0 FFFFFFFF        0
86453ACC:        0        0        0        0        0        0        0        0
86453AEC:        0        0        0    10100        0        0 86453E0A        0
86453B0C:        0        0        0        0        0        0        0        0
86453B2C:        0        0        0        0        0     3774        0        0
86453B4C:        0        0        0        0        0        0        0        0
86453B6C:        0      100  1000000        0      202  2808080        0        0
86453B8C:        0        0        0        0        0        0        0        1
86453BAC:        0        0        0        0        0        0        0        0
86453BCC:        0        0        0        0 871000F8     FFFF 42000000        0
86453BEC:        0        0        0        0        0        0        0        0
86453C0C:        0        0        0        0        0        0        0        0
86453C2C:        0        0        0        0        0        0        0        0
86453C4C:        0        0        0        0        0        0        0        0
86453C6C:        0        0        0        0        0        0        0        0
86453C8C:        0        0        0        0        0  2000000        0        0
86453CAC:        0        0        0        0        0 85B0EFB0 85B0E460        0
86453CCC:        0        0        0        0        0        0        0        0
86453CEC:        0        0 89F64470 86AD7DB4        0        0        0        0
86453D0C:        0        0        0        0        0        0        0        0
86453D2C:        0        0        0        0        0        0        0        0
86453D4C:        0        0        0        0        0        0        0        0
86453D6C: 864538FC        0        0        0 87877298        0        0       4B
86453D8C:    124F8        0        0        0 88257BE0        0 FD0110DF
---- block48  ptr=887BB43C  is_malloc=1  length=0x100 ----
887BB3FC:        0        0        0        0        0        0        0        0
887BB41C:        0        0        0        0        0        0        0 FD0110DF
887BB43C: AB1234CD FFFE0000        0 84409638 80F410F0 887BB530 887BB35C 80000062
887BB45C:        1        0        1 85FB07EC        2        0        0        0
887BB47C:    20000        0        0        0        2        0        0        0
887BB49C:        0        0        0        2        0    20000        0        0
887BB4BC:        0        0        0        0        0        0        0        0
887BB4DC:        0        0        0        0        0        0        0        0
887BB4FC:        0        0        0        0        0        0        0        0
887BB51C:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
---- block49  ptr=88849DAC  is_malloc=1  length=0x100 ----
88849D6C: 84717278 81DBA3E4 88849DAC 88849CF4 8000000E        1        0        1
88849D8C: 85FB07EC        0 88257C2C 85334484        0     FFFF        0 FD0110DF
88849DAC: AB1234CD FFFE0000        0 84500ED0 81369740 88849E04 88849D74 80000014
88849DCC:        1        0        1 85FB07EC        2 88257C94 882DF6AC        0
88849DEC:        0        0        0        0        0 FD0110DF AB1234CD FFFE0000
88849E0C:        0 839C1F98 829321D0 88849E50 88849DC0 8000000E        1        0
88849E2C:        1 85FB07EC        0        0        0        0        0        0
88849E4C: FD0110DF AB1234CD FFFE0000        0 846F9EF8 81D3099C 88849EA4 88849E18
88849E6C: 80000012        1        0        1 85FB07EC 8855C028 888B2CE8 888ACD4C
88849E8C: 86AF4A08 852F0520        0 10000001  1000000 FD0110DF AB1234CD FFFE0000
---- block50  ptr=83DA1914  is_malloc=0  length=0x100 ----
83DA18D4: 496E7465 726E616C 20536572 76696365 73204D6F 64756C65 20284953 4D292077
83DA18F4: 69746820 53657276 69636573 20526561 64792045 6E67696E 65202853 52452900
83DA1914: 49465459 50455F49 4E544552 4E414C5F 53455256 49434553 5F4D4F44 554C4500
83DA1934: 63697363 6F20656D 62656464 65642073 65727669 63652065 6E67696E 65206D6F
83DA1954: 64756C65        0 49465459 50455F45 4D424544 4445445F 53455256 4943455F
83DA1974: 454E4749 4E450000 63697363 6F20496E 7465726E 616C2053 65727669 6365204D
83DA1994: 6F64756C 65000000 49465459 50455F49 4E544552 4E414C5F 53455256 4943455F
83DA19B4: 4D4F4455 4C450000 4C6F6E67 2D526561 63682045 74686572 6E657420 696E7465
83DA19D4: 72666163 65000000 49465459 50455F4C 52450000 63697363 6F205370 65636961
83DA19F4: 6C205365 72766963 65732045 6E67696E 65206D6F 64756C65        0 49465459
---- block51  ptr=83DA15E8  is_malloc=0  length=0x100 ----
83DA15A8: 74206D69 736D6174 63682069 6E206361 6C6C5F61 6374696F 6E000000  A756E61
83DA15C8: 626C6520 746F2063 6F6D7069 6C652072 65676578 70202225 73220000 49534D00
83DA15E8: 456D6265 64646564 2D536572 76696365 2D456E67 696E6500 496E7465 726E616C
83DA1608: 2D536572 76696365 2D4D6F64 756C6500 4C6F6E67 52656163 68457468 65726E65
83DA1628: 74000000 53706563 69616C2D 53657276 69636573 2D456E67 696E6500 56696465
83DA1648: 6F2D5365 72766963 652D456E 67696E65        0 766D6900 576C616E 2D476967
83DA1668: 61626974 45746865 726E6574        0 776C616E 2D617000 776C616E 2D636F6E
83DA1688: 74726F6C 6C657200 77616E61 70702D65 6E67696E 65000000 53617465 6C6C6974
83DA16A8: 65000000 46637061        0 43444D41 2D497800 56697274 75616C2D 50505000
83DA16C8: 44636861 6E6E656C        0 414F4E2D 456E6769 6E650000 4944532D 53656E73
---- block52  ptr=85633550  is_malloc=0  length=0x100 ----
85633510:        0        0        1        0        0       59        0        0
85633530:       1D 85F9E760        0       49        0       3F        0        0
85633550:        0       4C        7        0        4        0        0        3
85633570:        0       45        0        0        0        0        0        0
85633590:        0       25        0        0        0        2 86054834        0
856335B0:        0       11        0        0       1A        0        0        0
856335D0:        0       20        0        0        0        0        0       3D
856335F0:        0        0        0        0        0       47        0       2C
85633610:        0        0        0        0        0       10        0       34
85633630:        0       2E        0        0        6        0        0  2000000
---- block53  ptr=85633340  is_malloc=0  length=0x100 ----
85633300:        0       2B        0        0        0       35        0        0
85633320:        A        0        0        1        0        0        0        E
85633340:        0       4B        0        0        0        0        0       2F
85633360:        0        0        0       21        0        0        0        0
85633380:        0       31        0        0        0        0        0        0
856333A0:        0       2D        0       26        0        0        0       13
856333C0:        0        0        0       1E        D        0        0        0
856333E0:        0        A        0        0        0        0        0        0
85633400:        0       39 85FF6910        0        0 85FF92F4        0        0
85633420:        0        0        0       24        0        0        0        B
---- block54  ptr=864A3988  is_malloc=1  length=0x46C ----
864A3948:        0        0        0        0        0        0        0        0
864A3968:        0        0        0 85FADD24       4A 864A39B8 864A30E0 FD0110DF
864A3988: AB1234CD FFFE0000        0 83D97384 80312FF8 864A3DF4 864A3530 8000021E
864A39A8:        1        0        1 85FB07EC        0        0        0 BEADEA5E
864A39C8: AEADEA5E        0 FFFF0000    10000  F646144  F64617C  F64617C  F64619A
864A39E8:        0  F646198        0        0  F646166        0  9600001        E
864A3A08:        0       17        0        0        0 FF000000        0        0
864A3A28:        0        0        0        0        0        0        0        0
864A3A48:        0        0        0        0        0        1        0 86492198
864A3A68:        0 80C86454        0        0        0        0        0        0
864A3A88:        0        0        0        0        0        0        0        0
864A3AA8:        0        0        0        0        0        0        0        0
864A3AC8:        0        0        0        0        0        0        0        0
864A3AE8:        0 2E864400        0 2E864CD0        0        0        0        0
864A3B08:        0        0        0        0        0        0        0        0
864A3B28:        0        0 88257C2C        0        0        0        0        0
864A3B48:        0        0        0        0        0        0        0        0
864A3B68:        0        0        0        0        0        0        0        0
864A3B88:        0        0        0        0        0        0        0        0
864A3BA8:        0        0        0        0        0        0        0        0
864A3BC8:        0        0        0        0        0        0        0        0
864A3BE8:        0        0        0        0        0        0        0        0
864A3C08:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A3C28: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A3C48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A3C68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A3C88: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
864A3CA8:        0        0        0        0        0        0        0        0
864A3CC8:        0        0        0        0 C0A80A1C 11AC744A DE1201BB        0
864A3CE8:        0        0        0        0        0        0        0        0
864A3D08:        0        0        0        0        0        0        0        0
864A3D28:        0        0        0        0        0        0        0        0
864A3D48:        0        0        0        0        0        0        0        0
864A3D68:        0        0        0        0        0        0        0        0
864A3D88:        0        0        0        0        0        0        0        0
864A3DA8:        0        0        0        0        0        0        0        0
864A3DC8:        0        0        0        0        0        0 85FB0630        4
864A3DE8: 864A3E24 864A354C FD0110DF
---- block55  ptr=864A30B0  is_malloc=1  length=0x46C ----
864A3070:        0        0        0        0        0        0        0        0
864A3090:        0        0        0 85FB0630        4 864A30E0 864A2808 FD0110DF
864A30B0: AB1234CD FFFE0000        0 83D97384 80312FF8 864A351C 864A2C58 8000021E
864A30D0:        1        0        1 85FB07EC        0        0        0 BEADEA5E
864A30F0: AEADEA5E        0 FFFF0000    10000  F644CC4  F644CFC  F644CFC  F644D1A
864A3110:        0  F644D18        0        0  F644CE6        0  9600001        E
864A3130:        0       17        0        0        0 FF000000        0        0
864A3150:        0        0        0        0        0        0        0        0
864A3170:        0        0        0        0        0        1        0 86492198
864A3190:        0 80C86454        0        0        0        0        0        0
864A31B0:        0        0        0        0        0        0        0        0
864A31D0:        0        0        0        0        0        0        0        0
864A31F0:        0        0        0        0        0        0        0        0
864A3210:        0 2E86459C        0 2E864D9C        0        0        0        0
864A3230:        0        0        0        0        0        0        0        0
864A3250:        0        0 88257C2C        0        0        0        0        0
864A3270:        0        0        0        0        0        0        0        0
864A3290:        0        0        0        0        0        0        0        0
864A32B0:        0        0        0        0        0        0        0        0
864A32D0:        0        0        0        0        0        0        0        0
864A32F0:        0        0        0        0        0        0        0        0
864A3310:        0        0        0        0        0        0        0        0
864A3330:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A3350: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A3370: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A3390: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A33B0: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
864A33D0:        0        0        0        0        0        0        0        0
864A33F0:        0        0        0        0 C0A80A1C 11AC744A DE1E01BB        0
864A3410:        0        0        0        0        0        0        0        0
864A3430:        0        0        0        0        0        0        0        0
864A3450:        0        0        0        0        0        0        0        0
864A3470:        0        0        0        0        0        0        0        0
864A3490:        0        0        0        0        0        0        0        0
864A34B0:        0        0        0        0        0        0        0        0
864A34D0:        0        0        0        0        0        0        0        0
864A34F0:        0        0        0        0        0        0 85FB0630        4
864A3510: 864A354C 864A2C74 FD0110DF
---- block56  ptr=85FADD24  is_malloc=0  length=0x100 ----
85FADCE4: 862F5924 86472EA0 85FADCDC 857FCF0C      294    90000        3        0
85FADD04: 849D6A34 82A9865C 8549413C        0        0        0        0 85FABAF0
85FADD24:        0  100004A    40000 85FAAD28        0        0        0       FF
85FADD44: 863F053C        0        0        0        0        0        0 85FADCCC
85FADD64: 85FADDF4 85FADD24 85FAAD70 862F5AFC 862F59EC 862F5ABC 86470B40 85FADD70
85FADD84: 857FCF0C      28D    90000        3        0 849D6A34 82A9865C 8549413C
85FADDA4:        0        0        0        0 85FABAF0        0  1000049    40000
85FADDC4: 85FAAD28        0        0        0       FF 863F0550        0        0
85FADDE4:        0        0        0        0 85FADD60 85FADF1C 85FADDB8 85FAAD70
85FADE04: 862F5C94 862F5B84 862F5C54 8646AE5C 85FADE04 857FCF0C      285    90000
---- block57  ptr=849CFDF8  is_malloc=0  length=0x100 ----
849CFDB8: 2047726F 77730000 64697363 61726451 5F657665 6E740000 506F6F6C 204D616E
849CFDD8: 61676572        0 44697363 61726451 20426163 6B67726F 756E6420 4D677200
849CFDF8: 506F6F6C 20496E66 6F000000 6D6F6475 6C655F72 65676973 74727900 436F7272
849CFE18: 75707465 64207265 647A6F6E 65200000 436F7272 75707465 64206D61 67696320
849CFE38: 76616C75 6520696E 20696E2D 75736520 626C6F63 6B200000 436F7272 75707465
849CFE58: 64207072 6576696F 75732070 6F696E74 65722000 53697A65 20616E64 20707265
849CFE78: 76696F75 7320646F 206E6F74 20636F72 72657370 6F6E6420 746F2062 6C6F636B
849CFE98: 20616464 72657373 20000000 436F7272 75707465 64206E65 78742070 6F696E74
849CFEB8: 65722000 426C6F63 6B206164 64726573 7320616E 64207369 7A652064 6F206E6F
849CFED8: 7420636F 72726573 706F6E64 20746F20 6E657874 20000000 46726565 73706163
---- block58  ptr=864922F4  is_malloc=1  length=0x46C ----
864922B4:        0 86037BF4        0        0        0        0        0        0
864922D4:        0        0        0        0        0        0        0 FD0110DF
864922F4: AB1234CD FFFE0000        0 83D97384 80312FF8 86492760 8649217C 8000021E
86492314:        1        0        1 85FB07EC 8649E5B4        0        0 BEADEA5E
86492334: AEADEA5E        0 FFFF0000        0  F61DB84  F61DBBC  F61DBBC  F61DBDA
86492354:        0  F61DBD8        0        0 86387878        0   B80001        E
86492374:        0       17        0        0        0 FF000000        0        0
86492394:        0        0        0        0        0        0        0        0
864923B4:        0        0        0        0        0        1        0 86492198
864923D4:        0 80C86454        0        0        0        0        0        0
864923F4:        0        0        0        0        0        0        0        0
86492414:        0        0        0        0        0        0        0        0
86492434:        0        0        0        0        0        0        0        0
86492454:        0 2E864C68        0 2E863FE0        0        0        0        0
86492474:        0        0        0        0        0        0        0        0
86492494:        0        0 88257C2C        0        0        0        0        0
864924B4:        0        0        0        0        0        0        0        0
864924D4:        0        0        0        0        0        0        0        0
864924F4:        0        0        0        0        0        0        0        0
86492514:        0        0        0        0        0        0        0        0
86492534:        0        0        0        0        0        0        0        0
86492554:        0        0        0        0        0        0        0        0
86492574:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
86492594: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864925B4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864925D4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864925F4: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
86492614:        0        0        0        0        0        0        0        0
86492634:        0        0        0        0 C0A80A1C 11AC744A DE1501BB        0
86492654:        0        0        0        0        0        0        0        0
86492674:        0        0        0        0        0        0        0        0
86492694:        0        0        0        0        0        0        0        0
864926B4:        0        0        0        0        0        0        0        0
864926D4:        0        0        0        0        0        0        0        0
864926F4:        0        0        0        0        0        0        0        0
86492714:        0        0        0        0        0        0        0        0
86492734:        0        0        0        0        0        0 85FB0630        4
86492754: 86492790        0 FD0110DF
---- block59  ptr=864AA814  is_malloc=1  length=0x46C ----
864AA7D4:        0        0        0        0        0        0        0        0
864AA7F4:        0        0        0 85FB0630        4 864AA844 864A9F6C FD0110DF
864AA814: AB1234CD FFFE0000        0 83D97384 80312FF8 864AAC80 864AA3BC 8000021E
864AA834:        1        0        1 85FB07EC 864A77A0        0        0 BEADEA5E
864AA854: AEADEA5E        0 FFFF0000        0  F656184  F6561BC  F6561BC  F6561DA
864AA874:        0  F6561D8        0        0 86387878        0   520001        E
864AA894:        0       17        0        0        0 FF000000        0        0
864AA8B4:        0        0        0        0        0        0        0        0
864AA8D4:        0        0        0        0        0        1        0 86492198
864AA8F4:        0 80C86454        0        0        0        0        0        0
864AA914:        0        0        0        0        0        0        0        0
864AA934:        0        0        0        0        0        0        0        0
864AA954:        0        0        0        0        0        0        0        0
864AA974:        0 2E864AD0        0 2E863F30        0        0        0        0
864AA994:        0        0        0        0        0        0        0        0
864AA9B4:        0        0 88257C2C        0        0        0        0        0
864AA9D4:        0        0        0        0        0        0        0        0
864AA9F4:        0        0        0        0        0        0        0        0
864AAA14:        0        0        0        0        0        0        0        0
864AAA34:        0        0        0        0        0        0        0        0
864AAA54:        0        0        0        0        0        0        0        0
864AAA74:        0        0        0        0        0        0        0        0
864AAA94:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864AAAB4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864AAAD4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864AAAF4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864AAB14: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
864AAB34:        0        0        0        0        0        0        0        0
864AAB54:        0        0        0        0 C0A80A1C 11AC744A DE1801BB        0
864AAB74:        0        0        0        0        0        0        0        0
864AAB94:        0        0        0        0        0        0        0        0
864AABB4:        0        0        0        0        0        0        0        0
864AABD4:        0        0        0        0        0        0        0        0
864AABF4:        0        0        0        0        0        0        0        0
864AAC14:        0        0        0        0        0        0        0        0
864AAC34:        0        0        0        0        0        0        0        0
864AAC54:        0        0        0        0        0        0 85FB0630        4
864AAC74: 864AACB0 864AA3D8 FD0110DF
---- block60  ptr=864A4260  is_malloc=1  length=0x46C ----
864A4220:        0        0        0        0        0        0        0        0
864A4240:        0        0        0 85FB0630        4 864A4290 864A39B8 FD0110DF
864A4260: AB1234CD FFFE0000        0 83D97384 80312FF8 864A46CC 864A3E08 8000021E
864A4280:        1        0        1 85FB07EC        0        0        0 BEADEA5E
864A42A0: AEADEA5E        0 FFFF0000        0  F6475C4  F6475FC  F6475FC  F64761A
864A42C0:        0  F647618        0        0 86470690        0   520001        E
864A42E0:        0       17        0        0        0 FF000000        0        0
864A4300:        0        0        0        0        0        0        0        0
864A4320:        0        0        0        0        0        1        0 86492198
864A4340:        0 80C86454        0        0        0        0        0        0
864A4360:        0        0        0        0        0        0        0        0
864A4380:        0        0        0        0        0        0        0        0
864A43A0:        0        0        0        0        0        0        0        0
864A43C0:        0 2E865D34        0 2E864268        0        0        0        0
864A43E0:        0        0        0        0        0        0        0        0
864A4400:        0        0 88257C2C        0        0        0        0        0
864A4420:        0        0        0        0        0        0        0        0
864A4440:        0        0        0        0        0        0        0        0
864A4460:        0        0        0        0        0        0        0        0
864A4480:        0        0        0        0        0        0        0        0
864A44A0:        0        0        0        0        0        0        0        0
864A44C0:        0        0        0        0        0        0        0        0
864A44E0:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A4500: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A4520: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A4540: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864A4560: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
864A4580:        0        0        0        0        0        0        0        0
864A45A0:        0        0        0        0 C0A80A1C 11AC744A DE2101BB        0
864A45C0:        0        0        0        0        0        0        0        0
864A45E0:        0        0        0        0        0        0        0        0
864A4600:        0        0        0        0        0        0        0        0
864A4620:        0        0        0        0        0        0        0        0
864A4640:        0        0        0        0        0        0        0        0
864A4660:        0        0        0        0        0        0        0        0
864A4680:        0        0        0        0        0        0        0        0
864A46A0:        0        0        0        0        0        0 85FB0630        4
864A46C0: 864A46FC 864A3E24 FD0110DF
---- block61  ptr=86074E84  is_malloc=1  length=0x18C ----
86074E44:        0        0        0        0        0        0        0        0
86074E64:        0        0        0        0        0        0        0 FD0110DF
86074E84: AB1234CD FFFE0000        0 849CFDF8 82A87970 86075010 86074CBC 800000AE
86074EA4:        1        0        1 85FB07EC        0 DEADB10B 80312F84 803135A8
86074EC4: 80313708 8031393C 80313CB0 80313CC0 80313CD0 80313EC4 80314534 860754AC
86074EE4: 860754AC        1        0        0        0        0        0        0
86074F04:        0        0        0        0        0        0        0        0
86074F24: 86492204 86074EB4 858C7A18        1     1000       54        0       44
86074F44:        2        1        2        0        0      77C        0 2E551798
86074F64:        0        1        0        0        0        0        0        0
86074F84:        0        2        2        2        8        8        1        1
86074FA4:        0        3        0        0 8564865C        0        0 84C22B6C
86074FC4: 86075040 860754AC        0        0 86037BF4        0        0        0
86074FE4:        0        0        0        0        0        0        0        0
86075004:        0        0 FD0110DF
---- block62  ptr=8434A888  is_malloc=0  length=0x100 ----
8434A848: 73686F6C 64206C6F 770A0000 41746820 72782069 6E666F20 73747275 63740000
8434A868: 41544845 524F5320 41523532 31320000 43697363 6F205379 7374656D 73000000
8434A888: 44495343 20737065 63696669 63207374 72756374 75726520 6D656D62 65727300
8434A8A8:  A0A4446 53205374 61746973 74696373 3A0A0000 20284D6F 6E69746F 72204D6F
8434A8C8: 64652045 6E61626C 6564290A        0 20285465 7374204D 6F646520 456E6162
8434A8E8: 6C656429  A000000 496E7661 6C696420 6368616E 6E656C2E  A000000  A2A2A2A
8434A908: 20444653 2073696D 756C6174 6564206F 6E206672 65717565 6E637920 2564204D
8434A928: 487A202A 2A2A0A00 44465320 6E6F7420 656E6162 6C656420 666F7220 63757272
8434A948: 656E7420 66726571 75656E63 790A0000 646F7431 315F6469 61670000 2E2E2F64
8434A968: 6F743131 742F745F 6174685F 61747461 63682E63        0 2E2E2F64 6F743131
---- block63  ptr=864D4210  is_malloc=1  length=0x230 ----
864D41D0:        0        0        0        0        0        0        0        2
864D41F0:       19      A0F      1B3  AE60008    60020        1        0 FD0110DF
864D4210: AB1234CD FFFE0000        0 839C1F98 80C880CC 864D4440 864C2F20 80000100
864D4230:        1        0        1 85FB07EC 864D4B24 864D5C7C        0        1
864D4250:        0        0  58A0510        0        0        5        0        0
864D4270:        1        1        0  58A0510        0        0        1        0
864D4290: FFFFFFFC        1        2        0  58A0510      BC0        0 FFFFFFFF
864D42B0: FFFFFFFF FFFFFFFA        1        3        0  58A0510      5E0        0
864D42D0: FFFFFFFF FFFFFFFE FFFFFFF9        1        4        0        0      5E0
864D42F0:        0 FFFFFFFF FFFFFFFE FFFFFFF9        0        0        0        0
864D4310:        0        0        0        0        0        0        0        0
864D4330:        0        0        0        0        0        0        0        0
864D4350:        0        0        0        0        0        0        0        3
864D4370:        8        0        0      5E0       56 FFFFFFFF FFFFFFFE FFFFFFF9
864D4390:        2        9        0        0      5E0        0 FFFFFFFF FFFFFFFE
864D43B0: FFFFFFF9      11F 84348068        0 864D5CD0       14       22        2
864D43D0:        1        0     8186        C        1        1        1        1
864D43F0:        1        1        1        1        3        1        0 133817D4
864D4410:  90809C4        1        0        1        1        0        1 464F4331
864D4430: 31333532 48583200        0 FD0110DF
---- block64  ptr=864C2AA0  is_malloc=1  length=0x46C ----
864C2A60:        0        0        0        0        0        0        0        0
864C2A80:        0        0        0 85FB0630        4 864C2AD0 864C21F8 FD0110DF
864C2AA0: AB1234CD FFFE0000        0 83D97384 80312FF8 864C2F0C 864C2648 8000021E
864C2AC0:        1        0        1 85FB07EC 864ACD7C        0        0 BEADEA5E
864C2AE0: AEADEA5E        0 FFFF0000        0  F67FA24  F67FA4E CEADEA5E        0
864C2B00:        0  F67FA4E        0        0  F53FA4A        0   A70000        0
864C2B20:        0        0        0        0        0 FF000000        0        0
864C2B40:        0        0        0        0        0        0        0        0
864C2B60:        0        0        0        0        0        1        0 864ACBF0
864C2B80:        0 80C1C930        0        0        0        0        0        0
864C2BA0:        0        0        0        0        0        0        0        0
864C2BC0:        0        0        0        0        0        0        0        0
864C2BE0:        0        0        0        0        0        0        0        0
864C2C00:        0 2E841844        0 2E8417D4        0        0        0        0
864C2C20:        0        0        0        0        0        0        0        0
864C2C40:        0        0        0        0        0        0        0        0
864C2C60:        0        0        0        0        0        0        0        0
864C2C80:        0        0        0        0        0        0        0        0
864C2CA0:        0        0        0        0        0        0        0        0
864C2CC0:        0        0        0        0        0        0        0        0
864C2CE0:        0        0        0        0        0        0        0        0
864C2D00:        0        0        0        0        0        0        0        0
864C2D20:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864C2D40: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864C2D60: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864C2D80: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864C2DA0: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
864C2DC0:        0        0        0        0        0        0        0        0
864C2DE0:        0        0        0        0        0        0        0        0
864C2E00:        0        0        0        0        0        0        0        0
864C2E20:        0        0        0        0        0        0        0        0
864C2E40:        0        0        0        0        0        0        0        0
864C2E60:        0        0        0        0        0        0        0        0
864C2E80:        0        0        0        0        0        0        0        0
864C2EA0:        0        0        0        0        0        0        0        0
864C2EC0:        0        0        0        0        0        0        0        0
864C2EE0:        0        0        0        0        0        0 85FB0630        4
864C2F00:        0 864C2664 FD0110DF
---- block65  ptr=864D4668  is_malloc=1  length=0x170 ----
864D4628: 864D6A70 864D6AB0 864D6AF0 864D6B30 864D6B70 864D6BB0 864D6BF0 864D6C30
864D4648: 864D6C70 864D6CB0 864D6CF0 864D6D30 864D6D70 864D6DB0 864D6DF0 FD0110DF
864D4668: AB1234CD FFFE0000        0 839C1F98 80C88160 864D47D8 864D44EC 800000A0
864D4688:        1        0        1 85FB07EC        1  F406B38        0        0
864D46A8:   A00060    600A6        0 CABD0000        0        1        0        0
864D46C8:        0        0        0        0        0        0        0        0
864D46E8:        0        0        0        0        0        0        0        0
864D4708:        0        0        0        0        0        0        0        0
864D4728:        0        0        0        0        0        0        0        0
864D4748:        0        0        0        0        0        0        0        0
864D4768:        0        0        0        0        0        0        0        0
864D4788:        0        0        0        0        0        0        0        0
864D47A8:        0        0        0        0        0        0        0        0
864D47C8:  F406E1C 86043178  F6821C0 FD0110DF
---- block66  ptr=864D770C  is_malloc=1  length=0x46C ----
864D76CC:        0        0        0        0        0        0        0        0
864D76EC:        0        0        0 877FF534      160 85DFEB98 89F7C170 FD0110DF
864D770C: AB1234CD FFFE0000        0 83D97384 80312FF8 864D7B78 864D72B4 8000021E
864D772C:        1        0        1 85FB07EC        0        0        0        0
864D774C:        0        0 FFFF0000    10000  F6850C4  F685118        0        0
864D776C:        0  F685118        0        0        0        0   A00000        0
864D778C:        0        0        0        0        0 FF000000        0        0
864D77AC:        0        0        0        0        0        0        0        0
864D77CC:        0        0        0        0        0        0        0 86037A68
864D77EC:        0 80C881B8        0        0        0        0        0        0
864D780C:        0        0        0        0        0        0        0        0
864D782C:        0        0        0        0        0        0        0        0
864D784C:        0        0        0        0        0        0        0        0
864D786C:        0     1214        0     1214        0        0        0        0
864D788C:        0        0        0        0        0        0        0        0
864D78AC:        0        0        0        0        0        0        0        0
864D78CC:        0        0        0        0        0        0        0        0
864D78EC:        0        0        0        0        0        0        0        0
864D790C:        0        0        0        0        0        0        0        0
864D792C:        0        0        0        0        0        0        0        0
864D794C:        0        0        0        0        0        0        0        0
864D796C:        0        0        0        0        0        0        0        0
864D798C:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864D79AC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864D79CC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864D79EC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
864D7A0C: FFFFFFFF FFFFFFFF        0        0        0        0        0        0
864D7A2C:        0        0        0        0        0        0        0        0
864D7A4C:        0        0        0        0        0        0        0        0
864D7A6C:        0        0        0        0        0        0        0        0
864D7A8C:        0        0        0        0        0        0        0        0
864D7AAC:        0        0        0        0        0        0        0        0
864D7ACC:        0        0        0        0        0        0        0        0
864D7AEC:        0        0        0        0        0        0        0        0
864D7B0C:        0        0        0        0        0        0        0        0
864D7B2C:        0        0        0        0        0        0        0        0
864D7B4C:        0        0        0        0        0        0 85FB07EC        1
864D7B6C: 864D8480 86044328 FD0110DF
---- block67  ptr=845045F8  is_malloc=0  length=0x100 ----
845045B8:        0 206E6F2D 6C696D69 74000000 20757074 696D6500 20646174 6574696D
845045D8: 65000000 206C6F63 616C7469 6D650000 2073686F 772D7469 6D657A6F 6E650000
845045F8: 54545920 64617461        0  A202020 20202020 20202020 20202020 20202020
84504618: 20202020 20202020 20202020 20202020 20202020 20202020 20202020        0
84504638:  A64656C 6574655F 6E616D65 74797065 5F66726F 6D5F696E 6465783A 20736561
84504658: 72636869 6E672025 7320746F 2064656C 65746500  A64656C 6574655F 6E616D65
84504678: 74797065 5F66726F 6D5F696E 6465783A 20257320 666F756E 64202620 64656C65
84504698: 74656400  A64656C 6574655F 6E616D65 74797065 5F66726F 6D5F696E 6465783A
845046B8: 206E616D 65202573 206E6F74 20666F75 6E642074 6F206465 6C000000  A64656C
845046D8: 6574655F 6E616D65 74797065 5F66726F 6D5F696E 6465783A 20616C73 6F20666F
---- block68  ptr=85F99594  is_malloc=1  length=0x804 ----
85F99554:        0        0        0        0        0        0        0        0
85F99574:        0        0        0        0        0        0        0 FD0110DF
85F99594: AB1234CD FFFE0000        0 84505940 8139CDA4 85F99D98 85F98454 800003EA
85F995B4:        1        0        1 85FB07EC        0        0        0        0
85F995D4:        0        0        0        0        0        0        0        0
85F995F4:        0        0        0        0        0        0        0        0
85F99614:        0        0        0        0        0        0        0        0
85F99634:        0        0        0        0        0        0        0        0
85F99654:        0        0        0        0        0        0        0        0
85F99674:        0        0        0        0        0        0        0        0
85F99694:        0        0        0        0        0        0        0        0
85F996B4:        0        0        0        0        0        0        0        0
85F996D4:        0        0        0        0        0        0        0        0
85F996F4:        0        0        0        0        0        0        0        0
85F99714:        0        0        0        0        0        0        0        0
85F99734:        0        0        0        0        0        0        0        0
85F99754:        0        0        0        0        0        0        0        0
85F99774:        0        0        0        0        0        0        0        0
85F99794:        0        0        0        0        0        0        0        0
85F997B4:        0        0        0        0        0        0        0        0
85F997D4:        0        0        0        0        0        0        0        0
85F997F4:        0        0        0        0        0        0        0        0
85F99814:        0        0        0        0        0        0        0        0
85F99834:        0        0        0        0        0        0        0        0
85F99854:        0        0        0        0        0        0        0        0
85F99874:        0        0        0        0        0        0        0        0
85F99894:        0        0        0        0        0        0        0        0
85F998B4:        0        0        0        0        0        0        0        0
85F998D4:        0        0        0        0        0        0        0        0
85F998F4:        0        0        0        0        0        0        0        0
85F99914:        0        0        0        0        0        0        0        0
85F99934:        0        0        0        0        0        0        0        0
85F99954:        0        0        0        0        0        0        0        0
85F99974:        0        0        0        0        0        0        0        0
85F99994:        0        0        0        0        0        0        0        0
85F999B4:        0        0        0        0        0        0        0        0
85F999D4:        0        0        0        0        0        0        0        0
85F999F4:        0        0        0        0        0        0        0        0
85F99A14:        0        0        0        0        0        0        0        0
85F99A34:        0        0        0        0        0        0        0        0
85F99A54:        0        0        0        0        0        0        0        0
85F99A74:        0        0        0        0        0        0        0        0
85F99A94:        0        0        0        0        0        0        0        0
85F99AB4:        0        0        0        0        0        0        0        0
85F99AD4:        0        0        0        0        0        0        0        0
85F99AF4:        0        0        0        0        0        0        0        0
85F99B14:        0        0        0        0        0        0        0        0
85F99B34:        0        0        0        0        0        0        0        0
85F99B54:        0        0        0        0        0        0        0        0
85F99B74:        0        0        0        0        0        0        0        0
85F99B94:        0        0        0        0        0        0        0        0
85F99BB4:        0        0        0        0        0        0        0        0
85F99BD4:        0        0        0        0        0        0        0        0
85F99BF4:        0        0        0        0        0        0        0        0
85F99C14:        0        0        0        0        0        0        0        0
85F99C34:        0        0        0        0        0        0        0        0
85F99C54:        0        0        0        0        0        0        0        0
85F99C74:        0        0        0        0        0        0        0        0
85F99C94:        0        0        0        0        0        0        0        0
85F99CB4:        0        0        0        0        0        0        0        0
85F99CD4:        0        0        0        0        0        0        0        0
85F99CF4:        0        0        0        0        0        0        0        0
85F99D14:        0        0        0        0        0        0        0        0
85F99D34:        0        0        0        0        0        0        0        0
85F99D54:        0        0        0        0        0        0        0        0
85F99D74:        0        0        0        0        0        0        0        0
85F99D94: FD0110DF
---- block69  ptr=858A4698  is_malloc=0  length=0x100 ----
858A4658:        0        0        0        0        0        0        0        0
858A4678:        0        0        0        0        0        0        0        0
858A4698: 8139B864 8139BAA4 80033320 80025AF4 8139B914 8139B8D0 8135DA2C 8139B864
858A46B8: 800325FC 8135C498 8135C538 8135C2F0 8135C364 8135C370 8005091C 81377844
858A46D8: 81377BB8 800509BC 80050A34 80050AAC 800333EC 800331B0 8139B864 800333A0
858A46F8: 8139B864 8139D160 8139D220 80050884 80050838 8003326C 80033CE4 800508D0
858A4718: 8139B864 8139B864 8139B864 80033D20 8139B864 8139B86C 85631EBC 858A3968
858A4738: 85631A8C 85631CDC        0        0        0        0        0        0
858A4758:        0        0        0        0     45EC     154C        0        0
858A4778:        0        0        0        0  18E9493        0        0        0
---- block70  ptr=85A44F48  is_malloc=0  length=0x100 ----
85A44F08:        0        0        0      1F4      1F4        1        1        0
85A44F28:        0        0        0        0        0        0        0        0
85A44F48:        0        0        0        0        0        0     4200        0
85A44F68:        0        0        0        0        0        0        0        0
85A44F88:        0        0        0        0        0        0        0        0
85A44FA8:        0        0        0        0        0        0        0        0
85A44FC8:        0        0        0        0        0        0        0        0
85A44FE8:        0        0        0        0        0        0        0        0
85A45008:        0        0        0        0        0        0        0        0
85A45028:        0        0        0        0        0        0        0        0
---- block71  ptr=86036BB8  is_malloc=0  length=0x100 ----
86036B78: 8603500C 86036B70 86C08368 8603500C 86036B7C 884929D4 8603500C 86036B88
86036B98: 8A049C08 8603500C        0 8738FE10 8603500C        0 8A049E58 8603500C
86036BB8: 860346A8 85E02CD0 8603500C        0 8731509C 8603500C 86036BC4 86E75CA0
86036BD8: 8603500C        0 876CDDA4 8603500C 86036BDC 876CDD44 8603500C        0
86036BF8: 876CDD8C 8603500C 86036BF4 876CDD5C 8603500C        0 876CDCCC 8603500C
86036C18: 86036C0C 876CDC84 8603500C        0 876CE38C 8603500C 86036C24 876CDCE4
86036C38: 8603500C        0 876CE374 8603500C        0 876CE32C 8603500C 86036C48
86036C58: 876CE344 8603500C        0 876CE35C 8603500C 86036C60 876CE2FC 8603500C
86036C78: 86036C6C 876CE314 8603500C 86036C78 876CE2E4 8603500C 86036C84 876CDCE4
86036C98: 8603500C 86036C3C 876CE2CC 8603500C        0 876CE2B4 8603500C 86036CA8
---- block72  ptr=85B0A0E0  is_malloc=0  length=0x100 ----
85B0A0A0:        0        0        0        0        0        0        0        0
85B0A0C0:        0        0        0        0        0        0        0        0
85B0A0E0:        0        0        0        0        0        0        0        0
85B0A100:        0        0        0        0        0        0        0        0
85B0A120:        0        0        0        0        0        0        0        0
85B0A140:        0        0        0        0        0        0        0        0
85B0A160:        0        0        0        0        0        0        0        0
85B0A180:        0        0        0        0        0        0        0        0
85B0A1A0:        0        0        0        0        0        0        0        0
85B0A1C0:        0        0        0        0        0        0        0        0
---- block73  ptr=881F0248  is_malloc=1  length=0x83C ----
881F0208:        0        0        0        0        0        0        0        0
881F0228:        0        0        0        0        0        0        0 FD0110DF
881F0248: AB1234CD FFFE0000        0 839C1F98 807F84DC 881F0A84 881EFA20 80000406
881F0268:        1        0        1 85FB07EC        0        0        0        0
881F0288:        0        0        0        0        0        0        0        0
881F02A8:        0        0        0        0        0        0        0        0
881F02C8:        0        0        0        0        0        0        0        0
881F02E8:        0        0        0        0        0        0        0        0
881F0308:        0        0        0        0        0        0        0        0
881F0328:        0        0        0        0        0        0        0        0
881F0348:        0        0        0        0        0        0        0        0
881F0368:        0        0        0        0        0        0        0        0
881F0388:        0        0        0        0        0        0        0        0
881F03A8:        0        0        0        0        0        0        0        0
881F03C8:        0        0        0        0        0        0        0        0
881F03E8:        0        0        0        0        0        0        0        0
881F0408:        0        0        0        0        0        0        0        0
881F0428:        0        0        0        0        0        0        0        0
881F0448:        0        0        0        0        0        0        0        0
881F0468:        0        0        0        0        0        0        0        0
881F0488:        0        0        0        0        0        0        0        0
881F04A8:        0        0        0        0        0        0        0        0
881F04C8:        0        0        0        0        0        0        0        0
881F04E8:        0        0        0        0        0        0        0        0
881F0508:        0        0        0        0        0        0        0        0
881F0528:        0        0        0        0        0        0        0        0
881F0548:        0        0        0        0        0        0        0        0
881F0568:        0        0        0        0        0        0        0        0
881F0588:        0        0        0        0        0        0        0        0
881F05A8:        0        0        0        0        0        0        0        0
881F05C8:        0        0        0        0        0        0        0        0
881F05E8:        0        0        0        0        0        0        0        0
881F0608:        0        0        0        0        0        0        0        0
881F0628:        0        0        0        0        0        0        0        0
881F0648:        0        0        0        0        0        0        0        0
881F0668:        0        0        0        0        0        0        0        0
881F0688:        0        0        0        0        0        0        0        0
881F06A8:        0        0        0        0        0        0        0        0
881F06C8:        0        0        0        0        0        0        0        0
881F06E8:        0        0        0        0        0        0        0        0
881F0708:        0        0        0        0        0        0        0        0
881F0728:        0        0        0        0        0        0        0        0
881F0748:        0        0        0        0        0        0        0        0
881F0768:        0        0        0        0        0        0        0        0
881F0788:        0        0        0        0        0        0        0        0
881F07A8:        0        0        0        0        0        0        0        0
881F07C8:        0        0        0        0        0        0        0        0
881F07E8:        0        0        0        0        0        0        0        0
881F0808:        0        0        0        0        0        0        0        0
881F0828:        0        0        0        0        0        0        0        0
881F0848:        0        0        0        0        0        0        0        0
881F0868:        0        0        0        0        0        0        0        0
881F0888:        0        0        0        0        0        0        0        0
881F08A8:        0        0        0        0        0        0        0        0
881F08C8:        0        0        0        0        0        0        0        0
881F08E8:        0        0        0        0        0        0        0        0
881F0908:        0        0        0        0        0        0        0        0
881F0928:        0        0        0        0        0        0        0        0
881F0948:        0        0        0        0        0        0        0        0
881F0968:        0        0        0        0        0        0        0        0
881F0988:        0        0        0        0        0        0        0        0
881F09A8:        0        0        0        0        0        0        0        0
881F09C8:        0        0        0        0        0        0        0        0
881F09E8:        0        0        0        0        0        0        0        0
881F0A08:        0        0        0        0        0        0        0        0
881F0A28:        0        0        0        0        0        0        0        0
881F0A48:        0        0        0        0        0        0        0        0
881F0A68:        0        0        0        0        0        0 FD0110DF
---- block74  ptr=881EF1D0  is_malloc=1  length=0x83C ----
881EF190:        0        0        0        0        0        0        0        0
881EF1B0:        0        0        0        0        0        0        0 FD0110DF
881EF1D0: AB1234CD FFFE0000        0 839C1F98 807F84DC 881EFA0C 881EE9A8 80000406
881EF1F0:        1        0        1 85FB07EC        0        0        0        0
881EF210:        0        0        0        0        0        0        0        0
881EF230:        0        0        0        0        0        0        0        0
881EF250:        0        0        0        0        0        0        0        0
881EF270:        0        0        0        0        0        0        0        0
881EF290:        0        0        0        0        0        0        0        0
881EF2B0:        0        0        0        0        0        0        0        0
881EF2D0:        0        0        0        0        0        0        0        0
881EF2F0:        0        0        0        0        0        0        0        0
881EF310:        0        0        0        0        0        0        0        0
881EF330:        0        0        0        0        0        0        0        0
881EF350:        0        0        0        0        0        0        0        0
881EF370:        0        0        0        0        0        0        0        0
881EF390:        0        0        0        0        0        0        0        0
881EF3B0:        0        0        0        0        0        0        0        0
881EF3D0:        0        0        0        0        0        0        0        0
881EF3F0:        0        0        0        0        0        0        0        0
881EF410:        0        0        0        0        0        0        0        0
881EF430:        0        0        0        0        0        0        0        0
881EF450:        0        0        0        0        0        0        0        0
881EF470:        0        0        0        0        0        0        0        0
881EF490:        0        0        0        0        0        0        0        0
881EF4B0:        0        0        0        0        0        0        0        0
881EF4D0:        0        0        0        0        0        0        0        0
881EF4F0:        0        0        0        0        0        0        0        0
881EF510:        0        0        0        0        0        0        0        0
881EF530:        0        0        0        0        0        0        0        0
881EF550:        0        0        0        0        0        0        0        0
881EF570:        0        0        0        0        0        0        0        0
881EF590:        0        0        0        0        0        0        0        0
881EF5B0:        0        0        0        0        0        0        0        0
881EF5D0:        0        0        0        0        0        0        0        0
881EF5F0:        0        0        0        0        0        0        0        0
881EF610:        0        0        0        0        0        0        0        0
881EF630:        0        0        0        0        0        0        0        0
881EF650:        0        0        0        0        0        0        0        0
881EF670:        0        0        0        0        0        0        0        0
881EF690:        0        0        0        0        0        0        0        0
881EF6B0:        0        0        0        0        0        0        0        0
881EF6D0:        0        0        0        0        0        0        0        0
881EF6F0:        0        0        0        0        0        0        0        0
881EF710:        0        0        0        0        0        0        0        0
881EF730:        0        0        0        0        0        0        0        0
881EF750:        0        0        0        0        0        0        0        0
881EF770:        0        0        0        0        0        0        0        0
881EF790:        0        0        0        0        0        0        0        0
881EF7B0:        0        0        0        0        0        0        0        0
881EF7D0:        0        0        0        0        0        0        0        0
881EF7F0:        0        0        0        0        0        0        0        0
881EF810:        0        0        0        0        0        0        0        0
881EF830:        0        0        0        0        0        0        0        0
881EF850:        0        0        0        0        0        0        0        0
881EF870:        0        0        0        0        0        0        0        0
881EF890:        0        0        0        0        0        0        0        0
881EF8B0:        0        0        0        0        0        0        0        0
881EF8D0:        0        0        0        0        0        0        0        0
881EF8F0:        0        0        0        0        0        0        0        0
881EF910:        0        0        0        0        0        0        0        0
881EF930:        0        0        0        0        0        0        0        0
881EF950:        0        0        0        0        0        0        0        0
881EF970:        0        0        0        0        0        0        0        0
881EF990:        0        0        0        0        0        0        0        0
881EF9B0:        0        0        0        0        0        0        0        0
881EF9D0:        0        0        0        0        0        0        0        0
881EF9F0:        0        0        0        0        0        0 FD0110DF
---- block75  ptr=8600AC7C  is_malloc=1  length=0x100 ----
8600AC3C:        0     1C14     1C15       56        0    10000 85647630 52656720
8600AC5C: 46756E63 74696F6E 20310000 8600AC78 8600AC78        0        0 FD0110DF
8600AC7C: AB1234CD FFFE0000        0 849D5850 82AA91D0 8600AD0C 8600AC00 80000030
8600AC9C:        1 82A47588        1 85FB07EC 8600AD3C 888DD198        0        0
8600ACBC: 8600BCC0       64        0    C000C        0      6A2      6A2       59
8600ACDC:        0    10000 85647630 52656720 46756E63 74696F6E 204C0000 8600AD08
8600ACFC: 8600AD08        0        0 FD0110DF AB1234CD FFFE0000        0 849D5868
8600AD1C: 82AA91F8 8600AD9C 8600AC90 80000030        1 82A47588        1 85FB07EC
8600AD3C: 8600ADCC 8602E57C        0        0 8602E57C       5A        0   100010
8600AD5C:        0       41       41       1E        0    10000 85647630 52656720
---- block76  ptr=86B27F50  is_malloc=1  length=0x190 ----
86B27F50: AB1234CD FFFE0000        0 839C1F98 82AA9A90 86B280E0 86B27760 800000B0
86B27F70:        1        0        1 85FB07EC        0        0        0        0
86B27F90:        0        0        0        0        0        0        0        0
86B27FB0:        0        0        0        0        0        0        0        0
86B27FD0:        0        0        0        0        0        0        0        0
86B27FF0:        0        0        0        0        0 80F3B9A8        0        0
86B28010:        0        0        0        0        0        0        0        0
86B28030:        0        0        0        0        0        0        0        0
86B28050:        0        0        0        0        0        0        0        0
86B28070:        0        0        0        0        0        0        0        0
86B28090:        0        0        0        0        0        0        0        0
86B280B0:        0        0        0        0        0        0        0        0
86B280D0:        0        0        0 FD0110DF
---- block77  ptr=86A5963C  is_malloc=1  length=0x804 ----
86A595FC: 839C1F98 82AA9A90 86A5963C 86A59474 8000000E        1        0        1
86A5961C: 85FB07EC        0        0        0 82AE88B4        0        0 FD0110DF
86A5963C: AB1234CD FFFE0000        0 8600ACE8 82AA9390 86A59E40 86A59604 800003EA
86A5965C:        1 82A47550        1 85FB07EC        0 869E58BC 86B2777C        0
86A5967C: 8600ACAC       64       77    C000C        0        0        0        0
86A5969C:        4    30000 85647630 52656720 46756E63 74696F6E 204C0000 86A598A4
86A596BC: 86A59E38        0        0 86A598A4 86A598B0 86A598BC 86A598C8 86A598D4
86A596DC: 86A598E0 86A598EC 86A598F8 86A59904 86A59910 86A5991C 86A59928 86A59934
86A596FC: 86A59940 86A5994C 86A59958 86A59964 86A59970 86A5997C 86A59988 86A59994
86A5971C: 86A599A0 86A599AC 86A599B8 86A599C4 86A599D0 86A599DC 86A599E8 86A599F4
86A5973C: 86A59A00 86A59A0C 86A59A18 86A59A24 86A59A30 86A59A3C 86A59A48 86A59A54
86A5975C: 86A59A60 86A59A6C 86A59A78 86A59A84 86A59A90 86A59A9C 86A59AA8 86A59AB4
86A5977C: 86A59AC0 86A59ACC 86A59AD8 86A59AE4 86A59AF0 86A59AFC 86A59B08 86A59B14
86A5979C: 86A59B20 86A59B2C 86A59B38 86A59B44 86A59B50 86A59B5C 86A59B68 86A59B74
86A597BC: 86A59B80 86A59B8C 86A59B98 86A59BA4 86A59BB0 86A59BBC 86A59BC8 86A59BD4
86A597DC: 86A59BE0 86A59BEC 86A59BF8 86A59C04 86A59C10 86A59C1C 86A59C28 86A59C34
86A597FC: 86A59C40 86A59C4C 86A59C58 86A59C64 86A59C70 86A59C7C 86A59C88 86A59C94
86A5981C: 86A59CA0 86A59CAC 86A59CB8 86A59CC4 86A59CD0 86A59CDC 86A59CE8 86A59CF4
86A5983C: 86A59D00 86A59D0C 86A59D18 86A59D24 86A59D30 86A59D3C 86A59D48 86A59D54
86A5985C: 86A59D60 86A59D6C 86A59D78 86A59D84 86A59D90 86A59D9C 86A59DA8 86A59DB4
86A5987C: 86A59DC0 86A59DCC 86A59DD8 86A59DE4 86A59DF0 86A59DFC 86A59E08 86A59E14
86A5989C: 86A59E20 86A59E2C 86B26D30        0        0 86B26D60        0        0
86A598BC: 86B26DD8        0        0 86B26DE4        0        0 86B26DFC        0
86A598DC:        0 86B26E74        0        0 86B26E8C        0        0 86B00358
86A598FC:        0        0 86B00364        0        0 86B00370        0        0
86A5991C: 86B0037C        0        0 86B00388        0        0 86B00394        0
86A5993C:        0 86B003A0        0        0 86B003B8        0        0 86B00400
86A5995C:        0        0 86B0040C        0        0 86B00418        0        0
86A5997C: 86B00484        0        0 86B00490        0        0 86B004B4        0
86A5999C:        0 86B004C0        0        0 86B004CC        0        0 86B004D8
86A599BC:        0        0 86B00508        0        0 86B00514        0        0
86A599DC: 86B00568        0        0 86B005B0        0        0 86B005BC        0
86A599FC:        0 86B005E0        0        0 86B0064C        0        0 86B00658
86A59A1C:        0        0 86B00688        0        0 86B00694        0        0
86A59A3C: 86B006A0        0        0 86B006AC        0        0 86B006F4        0
86A59A5C:        0 86B00700        0        0 86B0070C        0        0 86B00724
86A59A7C:        0        0 86B00748        0        0 86B00754        0        0
86A59A9C: 86B00784        0        0 86B00790        0        0 86B0079C        0
86A59ABC:        0 86B007A8        0        0 86B007D8        0        0 86B007E4
86A59ADC:        0        0 86B00808        0        0 86B00814        0        0
86A59AFC: 86B00880        0        0 86B0088C        0        0 86B00898        0
86A59B1C:        0 86B008A4        0        0 86AC7320        0        0 86AC732C
86A59B3C:        0        0 86AC7338        0        0 86AC7344        0        0
86A59B5C: 86AC7350        0        0 86AC73BC        0        0 86AC73C8        0
86A59B7C:        0 86AC73EC        0        0 86AC7404        0        0 86AC75E4
86A59B9C:        0        0 86AC75F0        0        0 86AC7638        0        0
86A59BBC: 86AC7644        0        0 86AC765C        0        0 86AC768C        0
86A59BDC:        0 86AC7698        0        0 86AC76E0        0        0 86AC76EC
86A59BFC:        0        0 86AC76F8        0        0 86AC7704        0        0
86A59C1C: 86AC7740        0        0 86AC7758        0        0 86AC7788        0
86A59C3C:        0 86AC77AC        0        0 86AC77B8        0        0 86AC77D0
86A59C5C:        0        0 86AC77DC        0        0 86AC77E8        0        0
86A59C7C: 86AC77F4        0        0 86AC780C        0        0 86AC7818        0
86A59C9C:        0 86AC7824        0        0 86AC7830        0        0 86AC7848
86A59CBC:        0        0 86A703B0        0        0 86A703BC        0        0
86A59CDC: 86A703C8        0        0 86A703D4        0        0 86A703F8        0
86A59CFC:        0 86A70404        0        0 86A70440        0        0 86A70458
86A59D1C:        0        0 86A704C4        0        0 86A704D0        0        0
86A59D3C: 86A704DC        0        0 86A704E8        0        0 86A70560        0
86A59D5C:        0 86A70584        0        0 86A70590        0        0 86A7059C
86A59D7C:        0        0 86A705CC        0        0 86A705D8        0        0
86A59D9C: 86A705FC        0        0 86A70608        0        0 86A70614        0
86A59DBC:        0 86A70620        0        0 86A70644        0        0 86A1EE6C
86A59DDC:        0        0 86A1EE84        0        0 86A1EEA8        0        0
86A59DFC: 86A1EEC0        0        0 86A1EECC        0        0 86A1EED8        0
86A59E1C:        0 86A1EF08        0        0 86A1EF14        0        0        0
86A59E3C: FD0110DF
---- block78  ptr=8735DD74  is_malloc=1  length=0x804 ----
8735DD34:        0        0 48545450 20626173 65642049 4F532046 696C6520 53657276
8735DD54: 65720000        0        0        0        0        1        1 FD0110DF
8735DD74: AB1234CD FFFE0000        0 8600ACE8 82AA9390 8735E578 8735DD00 800003EA
8735DD94:        1 82A47550        1 85FB07EC        0 86B2777C 86F20878        0
8735DDB4: 8600ACAC       64       77    C000C        0        0        0        0
8735DDD4:        4    30000 85647630 52656720 46756E63 74696F6E 204C0000 8735DFDC
8735DDF4: 8735E570        0        0 8735DFDC 8735DFE8 8735DFF4 8735E000 8735E00C
8735DE14: 8735E018 8735E024 8735E030 8735E03C 8735E048 8735E054 8735E060 8735E06C
8735DE34: 8735E078 8735E084 8735E090 8735E09C 8735E0A8 8735E0B4 8735E0C0 8735E0CC
8735DE54: 8735E0D8 8735E0E4 8735E0F0 8735E0FC 8735E108 8735E114 8735E120 8735E12C
8735DE74: 8735E138 8735E144 8735E150 8735E15C 8735E168 8735E174 8735E180 8735E18C
8735DE94: 8735E198 8735E1A4 8735E1B0 8735E1BC 8735E1C8 8735E1D4 8735E1E0 8735E1EC
8735DEB4: 8735E1F8 8735E204 8735E210 8735E21C 8735E228 8735E234 8735E240 8735E24C
8735DED4: 8735E258 8735E264 8735E270 8735E27C 8735E288 8735E294 8735E2A0 8735E2AC
8735DEF4: 8735E2B8 8735E2C4 8735E2D0 8735E2DC 8735E2E8 8735E2F4 8735E300 8735E30C
8735DF14: 8735E318 8735E324 8735E330 8735E33C 8735E348 8735E354 8735E360 8735E36C
8735DF34: 8735E378 8735E384 8735E390 8735E39C 8735E3A8 8735E3B4 8735E3C0 8735E3CC
8735DF54: 8735E3D8 8735E3E4 8735E3F0 8735E3FC 8735E408 8735E414 8735E420 8735E42C
8735DF74: 8735E438 8735E444 8735E450 8735E45C 8735E468 8735E474 8735E480 8735E48C
8735DF94: 8735E498 8735E4A4 8735E4B0 8735E4BC 8735E4C8 8735E4D4 8735E4E0 8735E4EC
8735DFB4: 8735E4F8 8735E504 8735E510 8735E51C 8735E528 8735E534 8735E540 8735E54C
8735DFD4: 8735E558 8735E564 86F1C8D8        0        0 86F1C8E4        0        0
8735DFF4: 86F1C8F0        0        0 86F1C8FC        0        0 86F1C920        0
8735E014:        0 86F1C974        0        0 86F1C980        0        0 86F1C9A4
8735E034:        0        0 86F1C9BC        0        0 86F1CA04        0        0
8735E054: 86F1CA64        0        0 86F1CA70        0        0 86F1CAA0        0
8735E074:        0 86F1CB00        0        0 86F1CB24        0        0 86F1CB30
8735E094:        0        0 86F1CB48        0        0 87390A80        0        0
8735E0B4: 87390A8C        0        0 87390A98        0        0 87390AA4        0
8735E0D4:        0 87390AB0        0        0 87390ABC        0        0 87390AC8
8735E0F4:        0        0 87390AD4        0        0 87390AE0        0        0
8735E114: 87390AEC        0        0 87390AF8        0        0 87390B04        0
8735E134:        0 87390B10        0        0 87390B28        0        0 87390B40
8735E154:        0        0 87390B4C        0        0 87390B58        0        0
8735E174: 87390B64        0        0 87390B7C        0        0 87390B94        0
8735E194:        0 87390BC4        0        0 87390BDC        0        0 87390BE8
8735E1B4:        0        0 87390BF4        0        0 87390C00        0        0
8735E1D4: 87390C18        0        0 87390C24        0        0 87390C30        0
8735E1F4:        0 87390CA8        0        0 87390CE4        0        0 87390D20
8735E214:        0        0 87390D44        0        0 87390D50        0        0
8735E234: 87390DC8        0        0 87390DD4        0        0 87390DE0        0
8735E254:        0 87390E10        0        0 87390E40        0        0 87390E58
8735E274:        0        0 87390E7C        0        0 87390E88        0        0
8735E294: 87390E94        0        0 87390EA0        0        0 87390EAC        0
8735E2B4:        0 87390EB8        0        0 87390F48        0        0 87390F78
8735E2D4:        0        0 87390F84        0        0 87390FA8        0        0
8735E2F4: 87390FE4        0        0 87390FF0        0        0 871811C8        0
8735E314:        0 871811D4        0        0 871811E0        0        0 871812AC
8735E334:        0        0 871812C4        0        0 871812D0        0        0
8735E354: 87181330        0        0 8718133C        0        0 87181348        0
8735E374:        0 871813F0        0        0 8718148C        0        0 87181498
8735E394:        0        0 871814A4        0        0 871814E0        0        0
8735E3B4: 87181510        0        0 87181528        0        0 87181534        0
8735E3D4:        0 8718154C        0        0 87181570        0        0 871815AC
8735E3F4:        0        0 871815B8        0        0 871815D0        0        0
8735E414: 871815E8        0        0 871815F4        0        0 87181618        0
8735E434:        0 87181624        0        0 87181630        0        0 87181678
8735E454:        0        0 8718169C        0        0 871816A8        0        0
8735E474: 871816B4        0        0 87181720        0        0 873C3EDC        0
8735E494:        0 873C3F24        0        0 873C3F6C        0        0 873C3F9C
8735E4B4:        0        0 873C3FA8        0        0 873C3FB4        0        0
8735E4D4: 873C3FC0        0        0 873C3FCC        0        0 873C3FD8        0
8735E4F4:        0 873C4008        0        0 873C402C        0        0 873C4038
8735E514:        0        0 873C40C8        0        0 873C4128        0        0
8735E534: 873C4134        0        0 873C4140        0        0 873C414C        0
8735E554:        0 873C4158        0        0 873C4164        0        0        0
8735E574: FD0110DF
---- block79  ptr=85647630  is_malloc=0  length=0x100 ----
856475F0: 8139B864 8139B864 8139B864 8139B864 8139B864 8139B864 8139B864 8139B864
85647610: 8139B864 8139B864 8139B864 8139B864 8139B864 8139B864 8139B864 8139B86C
85647630: 83995ED0        1 856497F8 856497F8 856495F4 85648600 85647638 857FCF0C
85647650:        4    10000        1        0 83995ED0 82A9865C 8549413C        0
85647670:  24920C2   300000  23FD450  97EFD5C  97EFD8C        0    68678   700A35
85647690:        0        0 85C10274        0        0    18000     8000        0
856476B0:        0        0        0        0        0        0        0 85647A5C
856476D0: 85647DA4       1E        E        0        E        0       25 8A2B62E4
856476F0:        0        0        0        0        0 8A115A7C        0        0
85647710:        0       26        F       26       26       33 8A778824        0
---- block80  ptr=8600C494  is_malloc=1  length=0x14C ----
8600C454:        0        0 8600BC28        0        0 8600BC34        0        0
8600C474: 8600BC58        0        0 8600BC70        0        0        0 FD0110DF
8600C494: AB1234CD FFFE0000        0 84524B38 82AA9A90 8600C5E0 8600BCA4 8000008E
8600C4B4:        1        0        1 85FB07EC        0 823D6B88 823D6C4C        0
8600C4D4:        0        0        0        0        0        0        0        0
8600C4F4:        0        0        0        0        0        0        0        0
8600C514:        0        0        0        0 823D68B0        0 823D6C4C        0
8600C534:        0        0        0        0        0        0        0        0
8600C554:        0        0        0        0        0        0        0        0
8600C574:        0        0 8302AD84        0        0 8244A15C 8244A15C 8244A15C
8600C594:        0        0        0        0        0        0        0        0
8600C5B4:        0        0        0        0        0        0        0        0
8600C5D4:        0        0 FD0110DF
---- block81  ptr=8600B48C  is_malloc=1  length=0x804 ----
8600B44C:        1 85FB07EC        0        0 823CE3F8 823CE458        0        0
8600B46C:        0        0        0        0        0        0        0 FD0110DF
8600B48C: AB1234CD FFFE0000        0 8600AC58 82AA9DD4 8600BC90 8600B438 800003EA
8600B4AC:        1 82A47550        1 85FB07EC        0        0 86064470        0
8600B4CC: 8600AC1C       64       77    C000C        0        0        0        0
8600B4EC:        4    30000 85647630 52656720 46756E63 74696F6E 20310000 8600B6F4
8600B50C: 8600BC88        0        0 8600B6F4 8600B700 8600B70C 8600B718 8600B724
8600B52C: 8600B730 8600B73C 8600B748 8600B754 8600B760 8600B76C 8600B778 8600B784
8600B54C: 8600B790 8600B79C 8600B7A8 8600B7B4 8600B7C0 8600B7CC 8600B7D8 8600B7E4
8600B56C: 8600B7F0 8600B7FC 8600B808 8600B814 8600B820 8600B82C 8600B838 8600B844
8600B58C: 8600B850 8600B85C 8600B868 8600B874 8600B880 8600B88C 8600B898 8600B8A4
8600B5AC: 8600B8B0 8600B8BC 8600B8C8 8600B8D4 8600B8E0 8600B8EC 8600B8F8 8600B904
8600B5CC: 8600B910 8600B91C 8600B928 8600B934 8600B940 8600B94C 8600B958 8600B964
8600B5EC: 8600B970 8600B97C 8600B988 8600B994 8600B9A0 8600B9AC 8600B9B8 8600B9C4
8600B60C: 8600B9D0 8600B9DC 8600B9E8 8600B9F4 8600BA00 8600BA0C 8600BA18 8600BA24
8600B62C: 8600BA30 8600BA3C 8600BA48 8600BA54 8600BA60 8600BA6C 8600BA78 8600BA84
8600B64C: 8600BA90 8600BA9C 8600BAA8 8600BAB4 8600BAC0 8600BACC 8600BAD8 8600BAE4
8600B66C: 8600BAF0 8600BAFC 8600BB08 8600BB14 8600BB20 8600BB2C 8600BB38 8600BB44
8600B68C: 8600BB50 8600BB5C 8600BB68 8600BB74 8600BB80 8600BB8C 8600BB98 8600BBA4
8600B6AC: 8600BBB0 8600BBBC 8600BBC8 8600BBD4 8600BBE0 8600BBEC 8600BBF8 8600BC04
8600B6CC: 8600BC10 8600BC1C 8600BC28 8600BC34 8600BC40 8600BC4C 8600BC58 8600BC64
8600B6EC: 8600BC70 8600BC7C        0        B 80031C48        0        B 80031C0C
8600B70C:        0        B 80031BF4        0        B 80031B9C 86064C30        1
8600B72C: 800311B8 8600B6F4        1 80031188 8600B700        1 80031138 8600B70C
8600B74C:        1 80031120 8600B718        1 800310C8 8600B724        0 800310BC
8600B76C: 8600B730        0 8003108C 8600B73C        0 8003103C 8600B748        0
8600B78C: 80031024 8600B754        0 80030FCC 8643FD7C        0 81A472AC 86126B90
8600B7AC:        0 81A46F14 869C21F4        0 81A4EA4C 86064B40        0 82ADE780
8600B7CC: 86064B4C        0 82ADE754        0        0 8135F110 8600B7A8        0
8600B7EC: 81418A34 86064AD4        0 813D24D0 8643FDF4        0 813D9A6C 8600B79C
8600B80C:        0 813D9A6C 86064BE8        0 813DB170 87503464        0 813DB020
8600B82C:        0        0 813DB020 8600B7B4        0 813D23BC        0        0
8600B84C: 813CB340        0        0 813C7B88 867A9D0C        0 813D5A3C 8600B85C
8600B86C:        0 813C4050        0        0 813C3EE8        0        0 813D591C
8600B88C: 8600B814        0 813D6044 8600B7E4        0 8140CCB0        0        0
8600B8AC: 8140C0B0 8747EBC4        0 813DE938 8747EBD0        0 813CDCE8 8600B898
8600B8CC:        0 813F7D00 869C20BC       54 813952AC 86B26CF4        0 8384DA04
8600B8EC: 869C1FC0        0 8133BEB0 8600B7C0        0 813FF058 8600B7CC        0
8600B90C: 813FF02C 877DAED0        0 81376810 8600B910        0 81437074 8600B91C
8600B92C:        0 81436044 8600B928        0 81436EB0 8600B934        0 81436AB0
8600B94C: 8600B940        0 814366B0 8600B94C        0 814362F4 86126884        0
8600B96C: 81376774 8600B964        0 8143702C 8600B970        0 81435FDC 8600B97C
8600B98C:        0 81436D40 8600B988        0 8143682C 8600B994        0 81436540
8600B9AC: 8600B9A0        0 814360B8        0        0 8136AA88 877DAEE8        0
8600B9CC: 8136CEF4 8600B9C4        0 813735A8 8600B9D0        0 8136CBFC 877DAEF4
8600B9EC:        0 8136CEF4 8600B9E8        0 813735A8 8600B9F4        0 8136C90C
8600BA0C:        0        0 813733E0 8600B8F8        0 803172A8 8600BA18        0
8600BA2C: 813DD3B0 8600B904        0 813DD37C 8600BA24        0 8137B04C 8600BA30
8600BA4C:        0 8137B020 8600BA3C        0 81384710 8600BA48        0 813846E4
8600BA6C: 8600B8EC        0 81365198        0        0 802C17C8 86126B84        0
8600BA8C: 803560A0        0        0 82A91AD4        0        0 82A919F8        0
8600BAAC:        0 82AAD868 8643FED8        0 82CE6A44 8643FEE4        0 82CE69E4
8600BACC: 8643FECC        0 82CE6994 8600BA54        0 82CE288C 8600BA60        0
8600BAEC: 82CE2550 8600BAD8        0 82B2BBC4 8600BAE4        0 82B2BBA0        0
8600BB0C:        0 82B272CC 878560B8        0 82B26654        0        0 8144C64C
8600BB2C: 8600BA84        0 8144DEA8 8640D124        0 80F0531C        0        0
8600BB4C: 803585A8 869F9280        0 8034FA94        0        0 80347554 8600BB50
8600BB6C:        0 8034F010 86126B48        0 8034CD3C 86126B3C        0 8034CC14
8600BB8C: 86126B54        0 8034A5FC 86F1C9C8        0 8034A350        0        0
8600BBAC: 813AA4D4 86D862CC        0 8396F4D4 8643FCEC        0 80FE32CC        0
8600BBCC:        0 8368272C        0        0 8368247C        0        0 836823B0
8600BBEC:        0        0 8368231C        0        0 8368222C        0        0
8600BC0C: 83681FDC        0        0 83681F00        0        0 83681E6C        0
8600BC2C:        0 83681C28        0        0 836819DC        0        3 8352ED14
8600BC4C:        0        2        1        0        0 823D3534        0        0
8600BC6C: 823D352C        0        0 823D3524        0        0 823D3520        0
8600BC8C: FD0110DF
---- block82  ptr=86127488  is_malloc=1  length=0x804 ----
86127448: 839C1F98 82AA9A90 86127488 86127404 8000000E        1        0        1
86127468: 85FB07EC        0 812C7CEC 812C8884        0        0        0 FD0110DF
86127488: AB1234CD FFFE0000        0 8600ACE8 82AA9390 86127C8C 86127450 800003EA
861274A8:        1 82A47550        1 85FB07EC        0 8600BCC0 85FA4BD8        0
861274C8: 8600ACAC       64       77    C000C        0        0        0        0
861274E8:        4    30000 85647630 52656720 46756E63 74696F6E 204C0000 861276F0
86127508: 86127C84        0        0 861276F0 861276FC 86127708 86127714 86127720
86127528: 8612772C 86127738 86127744 86127750 8612775C 86127768 86127774 86127780
86127548: 8612778C 86127798 861277A4 861277B0 861277BC 861277C8 861277D4 861277E0
86127568: 861277EC 861277F8 86127804 86127810 8612781C 86127828 86127834 86127840
86127588: 8612784C 86127858 86127864 86127870 8612787C 86127888 86127894 861278A0
861275A8: 861278AC 861278B8 861278C4 861278D0 861278DC 861278E8 861278F4 86127900
861275C8: 8612790C 86127918 86127924 86127930 8612793C 86127948 86127954 86127960
861275E8: 8612796C 86127978 86127984 86127990 8612799C 861279A8 861279B4 861279C0
86127608: 861279CC 861279D8 861279E4 861279F0 861279FC 86127A08 86127A14 86127A20
86127628: 86127A2C 86127A38 86127A44 86127A50 86127A5C 86127A68 86127A74 86127A80
86127648: 86127A8C 86127A98 86127AA4 86127AB0 86127ABC 86127AC8 86127AD4 86127AE0
86127668: 86127AEC 86127AF8 86127B04 86127B10 86127B1C 86127B28 86127B34 86127B40
86127688: 86127B4C 86127B58 86127B64 86127B70 86127B7C 86127B88 86127B94 86127BA0
861276A8: 86127BAC 86127BB8 86127BC4 86127BD0 86127BDC 86127BE8 86127BF4 86127C00
861276C8: 86127C0C 86127C18 86127C24 86127C30 86127C3C 86127C48 86127C54 86127C60
861276E8: 86127C6C 86127C78 85FA25AC        0        0 85FA25B8        0        0
86127708: 85FA25C4        0        0 85FA25D0        0        0 85FA25DC        0
86127728:        0 85FA25E8        0        0 861C4D3C        0        0 861C4D54
86127748:        0        0 861C4D6C        0        0 861C4D90        0        0
86127768: 861C4DB4        0        0 861C4DD8        0        0 861C4DE4        0
86127788:        0 861C4DF0        0        0 861C4DFC        0        0 861C4E20
861277A8:        0        0 861C4E2C        0        0 861C4E38        0        0
861277C8: 861C4E44        0        0 861C4E80        0        0 861C4E98        0
861277E8:        0 861C4EA4        0        0 861C4EB0        0        0 861C4ED4
86127808:        0        0 861C4EE0        0        0 861C4F34        0        0
86127828: 861C4F40        0        0 861C4F64        0        0 861C4FD0        0
86127848:        0 861C4FDC        0        0 861C4FE8        0        0 861C4FF4
86127868:        0        0 861C5000        0        0 861C500C        0        0
86127888: 861C5030        0        0 861C503C        0        0 861C5048        0
861278A8:        0 861C5054        0        0 861C5060        0        0 861C506C
861278C8:        0        0 861C5078        0        0 861C5084        0        0
861278E8: 861C5090        0        0 861C509C        0        0 861C50A8        0
86127908:        0 861C50B4        0        0 861C50C0        0        0 861C50CC
86127928:        0        0 861C50D8        0        0 861C50E4        0        0
86127948: 861C50F0        0        0 861C5114        0        0 861C5120        0
86127968:        0 861C512C        0        0 861C5138        0        0 861C5144
86127988:        0        0 861C5150        0        0 861C515C        0        0
861279A8: 861C5168        0        0 861C5174        0        0 861C5180        0
861279C8:        0 861C518C        0        0 861C5198        0        0 861C51A4
861279E8:        0        0 861C51B0        0        0 861C51BC        0        0
86127A08: 861C51C8        0        0 861C51D4        0        0 861C51E0        0
86127A28:        0 861C51EC        0        0 861C51F8        0        0 861C5204
86127A48:        0        0 861C5210        0        0 8612680C        0        0
86127A68: 86126830        0        0 86126848        0        0 86126854        0
86127A88:        0 86126890        0        0 8612689C        0        0 861268C0
86127AA8:        0        0 861268CC        0        0 861268E4        0        0
86127AC8: 861268F0        0        0 8612692C        0        0 86126938        0
86127AE8:        0 86126944        0        0 86126968        0        0 86126974
86127B08:        0        0 86126980        0        0 86126998        0        0
86127B28: 861269BC        0        0 861269C8        0        0 861269D4        0
86127B48:        0 861269E0        0        0 861269EC        0        0 861269F8
86127B68:        0        0 86126A10        0        0 86126A1C        0        0
86127B88: 86126A28        0        0 86126A34        0        0 86126A40        0
86127BA8:        0 86126A4C        0        0 86126A58        0        0 86126A64
86127BC8:        0        0 86126A70        0        0 86126A88        0        0
86127BE8: 86126AA0        0        0 86126AAC        0        0 86126AB8        0
86127C08:        0 86126AC4        0        0 86126ADC        0        0 86126AE8
86127C28:        0        0 86126AF4        0        0 86126B00        0        0
86127C48: 86126B0C        0        0 86126B18        0        0 86126B30        0
86127C68:        0 86126B60        0        0 86126BB4        0        0        0
86127C88: FD0110DF
---- block83  ptr=8612649C  is_malloc=1  length=0x804 ----
8612645C:        0        0        0        0        0        0        0        0
8612647C:        0        0        0        0        0        0        0 FD0110DF
8612649C: AB1234CD FFFE0000        0 8600AC58 82AA92C8 86126CA0 86126320 800003EA
861264BC:        1 82A47550        1 85FB07EC        0 86064470 861C4AF8        0
861264DC: 8600AC1C       64       77    C000C        0        0        0        0
861264FC:        4    30000 85647630 52656720 46756E63 74696F6E 20310000 86126704
8612651C: 86126C98        0        0 86126704 86126710 8612671C 86126728 86126734
8612653C: 86126740 8612674C 86126758 86126764 86126770 8612677C 86126788 86126794
8612655C: 861267A0 861267AC 861267B8 861267C4 861267D0 861267DC 861267E8 861267F4
8612657C: 86126800 8612680C 86126818 86126824 86126830 8612683C 86126848 86126854
8612659C: 86126860 8612686C 86126878 86126884 86126890 8612689C 861268A8 861268B4
861265BC: 861268C0 861268CC 861268D8 861268E4 861268F0 861268FC 86126908 86126914
861265DC: 86126920 8612692C 86126938 86126944 86126950 8612695C 86126968 86126974
861265FC: 86126980 8612698C 86126998 861269A4 861269B0 861269BC 861269C8 861269D4
8612661C: 861269E0 861269EC 861269F8 86126A04 86126A10 86126A1C 86126A28 86126A34
8612663C: 86126A40 86126A4C 86126A58 86126A64 86126A70 86126A7C 86126A88 86126A94
8612665C: 86126AA0 86126AAC 86126AB8 86126AC4 86126AD0 86126ADC 86126AE8 86126AF4
8612667C: 86126B00 86126B0C 86126B18 86126B24 86126B30 86126B3C 86126B48 86126B54
8612669C: 86126B60 86126B6C 86126B78 86126B84 86126B90 86126B9C 86126BA8 86126BB4
861266BC: 86126BC0 86126BCC 86126BD8 86126BE4 86126BF0 86126BFC 86126C08 86126C14
861266DC: 86126C20 86126C2C 86126C38 86126C44 86126C50 86126C5C 86126C68 86126C74
861266FC: 86126C80 86126C8C        0        0 82F772F0        0        0 82F77724
8612671C:        0        0 82F77498        0        0 82F7720C        0        4
8612673C: 82F70260 861C4F1C        0 82F710D4 861C4F28        0 82F710A8        0
8612675C:        0 82F6AF60        0        0 82F6AEE0 87F260B8       10 82F71058
8612677C: 87F260AC       10 82F70EE8 86126770        F 82F70EE0 8612677C        F
8612679C: 82F70E58 86126788        E 82F70E50 86126794        E 82F70D78 861C5018
861267BC:        0 8142D750 8612674C        0 82AADB74 86126740        0 82AAD960
861267DC: 85FA20F0        0 82A1A044 864120C0        0 82A1B074        0      200
861267FC: 82A18F74        0      200 82A168D4 869C2098        0 82A19BCC 861267D0
8612681C:        0 82A1B1AC 861267C4        0 82A1B180 86F21368        0 82A1C440
8612683C:        0        0 82A1B320 869F9478        0 82883DF0 861C4E8C        0
8612685C: 827A070C 86126BCC        5 827A2DCC 869F9454        5 827A0EC0 869F93D0
8612687C:        5 827A0404 877DAEDC        0 8279EE00        0        0 822EA468
8612689C: 877BC0F0        0 822EA374 86126818        0 822E702C 86126824        0
861268BC: 822E7670 861C4D9C        0 822E5CF8 867A9A18        0 822E5CF0 861268B4
861268DC:        0 820B7388        0        0 820B737C        0        0 820B7370
861268FC: 861268A8        0 818FC2EC 861268D8        0 818FC2C0 861268FC        0
8612691C: 817A0CC0 86126908        0 817A0C84        0        0 815EAC1C        0
8612693C:        0 815EAB68        0        0 815E7318 86064714        1 815E7D84
8612695C:        0        1 815E7D30        0        0 815EA0CC        0        0
8612697C: 815E9FE8 861267E8        0 815E974C 86126800       40 815E91B0        0
8612699C:        0 815E71A4 86126914        0 815EB054 86126920        0 815EB028
861269BC: 871815DC        0 814B4FA0 86EFC140        0 814B4F70        0        0
861269DC: 814C5414 86939C10        0 814B15C4 8747EA80        0 814B4898        0
861269FC:        0 814B47F4 869F4AA8        0 814B44DC 86B5D720        0 814AD95C
86126A1C: 86B26D84        0 814B45FC        0        0 814BD9EC        0        0
86126A3C: 814A4F30        0        0 814A4AE0        0        0 814A4840 869F934C
86126A5C:        0 814A6568        0        0 814B4360        0        0 814B42C4
86126A7C: 86439B48        0 814B4178        0        0 814B3F4C        0        0
86126A9C: 814A365C        0        0 814C3044 869C2008        0 814C2E18        0
86126ABC:        0 814ACC60 86F214D0        0 814ACD48 86C00FF4       62 814B9C7C
86126ADC:        0        0 814AFBFC 864121BC        0 814AB398 861C4F10        0
86126AFC: 814B9950 86439B6C        0 814C29F4 861267DC        0 814C287C 86AC7668
86126B1C:        0 814C293C 861C50FC        0 814C28C8 86EFBEA0        0 814B0934
86126B3C: 85FA20D8        0 814A4304 8640D010        0 814AA2E0 867A99B8        0
86126B5C: 814B8D4C 86C010CC        0 814C8BB4 861269A4        0 814C8B84 861269B0
86126B7C:        0 814C8B58        0        0 81398BB8 861C5024        0 81398B90
86126B9C: 86126A04        0 81332788 86126A7C        0 812C8FD4        0        0
86126BBC: 812C999C        0       14 812CD10C        0       14 812C9D68        0
86126BDC:       10 812C7318 86126BD8        5 812C8CA4 861C4FB8        0 812C5A18
86126BFC: 86126BF0        0 812C5920 86126B6C        0 812C9490 86126B78        0
86126C1C: 812C9464 86126C08        0 80F080AC 86126C14        0 80F08080 86126B24
86126C3C:        0 80F07FE4 86A1F0D0        0 80F073FC 86F5D694        3 80E27520
86126C5C:        0        0 80E274EC 87390CB4        0 80E20644 87390CC0        0
86126C7C: 80E20458 867A99D0        0 80DE3E24 86EFC11C        0 80DE3E24        0
86126C9C: FD0110DF
---- block84  ptr=86064440  is_malloc=1  length=0x804 ----
86064400:        0        5        5       2C        0   410000 85647630 4C696365
86064420: 6E736520 52656769 73740000 8606443C 8606443C        0        0 FD0110DF
86064440: AB1234CD FFFE0000        0 8600AC58 82AA9A10 86064C44 860643C4 800003EA
86064460:        1 82A47550        1 85FB07EC        0 8600B4BC 861264CC        0
86064480: 8600AC1C       64       77    C000C        0        0        0        0
860644A0:        4    30000 85647630 52656720 46756E63 74696F6E 20310000 860646A8
860644C0: 86064C3C        0        0 860646A8 860646B4 860646C0 860646CC 860646D8
860644E0: 860646E4 860646F0 860646FC 86064708 86064714 86064720 8606472C 86064738
86064500: 86064744 86064750 8606475C 86064768 86064774 86064780 8606478C 86064798
86064520: 860647A4 860647B0 860647BC 860647C8 860647D4 860647E0 860647EC 860647F8
86064540: 86064804 86064810 8606481C 86064828 86064834 86064840 8606484C 86064858
86064560: 86064864 86064870 8606487C 86064888 86064894 860648A0 860648AC 860648B8
86064580: 860648C4 860648D0 860648DC 860648E8 860648F4 86064900 8606490C 86064918
860645A0: 86064924 86064930 8606493C 86064948 86064954 86064960 8606496C 86064978
860645C0: 86064984 86064990 8606499C 860649A8 860649B4 860649C0 860649CC 860649D8
860645E0: 860649E4 860649F0 860649FC 86064A08 86064A14 86064A20 86064A2C 86064A38
86064600: 86064A44 86064A50 86064A5C 86064A68 86064A74 86064A80 86064A8C 86064A98
86064620: 86064AA4 86064AB0 86064ABC 86064AC8 86064AD4 86064AE0 86064AEC 86064AF8
86064640: 86064B04 86064B10 86064B1C 86064B28 86064B34 86064B40 86064B4C 86064B58
86064660: 86064B64 86064B70 86064B7C 86064B88 86064B94 86064BA0 86064BAC 86064BB8
86064680: 86064BC4 86064BD0 86064BDC 86064BE8 86064BF4 86064C00 86064C0C 86064C18
860646A0: 86064C24 86064C30        0        0 80DEE684        0        0 80DF34DC
860646C0:        0        0 80E2B9E8        0        0 80E082B8        0        0
860646E0: 80E18A5C        0        0 80E18788        0        0 80E1836C 86126A94
86064700:        0 80DD6E3C 86126BA8        0 80DD6CF0        0        9 80DE3AF0
86064720: 86AC75D8        9 80DD6CE8        0        0 80DE3540 86126C38        0
86064740: 80DE06A0        0        0 80DD31BC        0        0 80DD2F10        0
86064760:        0 80DD2A98        0        0 80DD0944 869F9400        0 80DD10E0
86064780:        0        0 80DE01A8 861C4E50        0 80DE01A8 86126C20        0
860647A0: 80E470DC 86126C2C        0 80E470B0 86412090        0 80DA01A4 8643FDAC
860647C0:        0 80DA00D8 8643FDB8        0 80DA006C 861C5108        0 80DA0028
860647E0: 87390C90        0 80DA0144        0        0 80D9FF4C 87390C9C        0
86064800: 80D9FF4C        0        8 80DB2D84 86064A98        5 80DB2C48        0
86064820:        0 80DB2B60        0        0 80DB2B24 869C1EE8        0 80DB252C
86064840:        0        0 80DB24C8        0        0 80DB24C4 869C1F00        0
86064860: 80DB2404 87856280        0 80DB2C34 8785628C        0 80DB29B4 87856298
86064880:        0 80DB28C4 878562A4        0 80DB2840 860648F4        3 80DA2F3C
860648A0: 86064834        0 80DA2A5C 8606484C        0 80DA2A58 86064858        0
860648C0: 80DA2998 86064864        0 80DA2F28 86064870        0 80DA2D58 8606487C
860648E0:        0 80DA2C68 86064888        0 80DA2BE4 86064810        4 80DA14BC
86064900: 860648A0        0 80DA1130 860648AC        0 80DA112C 860648B8        0
86064920: 80DA1014 860648D0        0 80DA1378 86126B9C        0 80DA7594 86064900
86064940:        0 80DA71E4 8606490C        0 80DA71E0 86064918        0 80DA709C
86064960: 86064894        2 80DA7484 86064A08        0 80DA578C 8606493C        0
86064980: 80DA51B0 86064948        0 80DA51AC 86064954        0 80DA50EC 86064924
860649A0:        0 80DA541C 860648DC        0 80DA5628 860648E8        0 80DA550C
860649C0: 86064828        0 80DB1030 87856268        0 80DB1380 8606499C        0
860649E0: 80DB123C        0        2 80DA4004 860649FC        1 80DA3FFC 86064804
86064A00:        2 80DA3FFC 86064960        1 80DA3EBC 86064978        0 80DA37A0
86064A20: 86064840        0 80DA3670 86064984        0 80DA379C 86064990        0
86064A40: 80DA36D4 860648C4        0 80DA3D98 860649A8        0 80DA3B54 86064A2C
86064A60:        0 80DA9EC0 86064A38        0 80DA9E30 86064798        0 80DA0D18
86064A80: 860647A4        0 80DA0CEC 86939694       C8 80DB0020 869C22F0       C8
86064AA0: 80DB0654 86064A14        0 80DA9A98 86064A5C        0 80DA9910 86064A68
86064AC0:        0 80DA9788 860647D4        0 80DB1B9C 861C521C        0 8066A860
86064AE0: 86439C80        0 8050646C 86439C8C        0 80506EF8 86439CA4        0
86064B00: 8050063C 86064A74        0 803CC4F0 86064A80        0 803CC464 875FA8C8
86064B20:        C 803CCB68        0        0 803D57D4 8612683C        0 803C6E54
86064B40: 86064B04        0 803744E4 86064B10        0 80374460 869F91B4        0
86064B60: 80324EC4        0        0 80159118        0        0 80159358        0
86064B80:        0 80158F50        0        0 80158D38        0        0 80158C44
86064BA0:        0        0 80158B50        0        0 80158910        0        0
86064BC0: 80158724        0        0 80158618        0        0 8007192C        0
86064BE0:        0 80071A48 861267B8        0 80070E04        0        0 80037428
86064C00:        0        1 85631C58        0        0 80036110        0        0
86064C20: 80036438 86439E18        0 80035BA0        0        B 80031C84        0
86064C40: FD0110DF
---- block85  ptr=8589D1C0  is_malloc=0  length=0x100 ----
8589D180: 82AA9134 82AA9134 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130 82AA9130
8589D1A0: 82AA9130 82AA9130 82AA9130 80282E4C 80282ECC 82AA9130 82AA9130 82AA9130
8589D1C0: 8589D160 84D00404        0 80273DCC 82AA9130 82AA9130 82AA9130 8589D258
8589D1E0: 84D0044C        0 82D935F0 82D9367C 82D94534 82D945A8 82D936F0 82D93CB0
8589D200: 82D93914 82D93CB8 82D93EE8 82D93DDC 82D941F0 82D93EF0 82D9428C 82D943E0
8589D220: 82D941F8 82D94244 82D958F0 82D95E34 82D95BE4 82D95EA0 82D95F74 82DA0FC8
8589D240: 82D9F5A4 82AA9134 82D9C238 82D9C258 82D9C278 82D9C760 85805D14 84D00480
8589D260:        0        0        0        0        0        3        0 82AA9130
8589D280: 86B12AAC        3        0 82AA9130 86B12B90        3        0 82AA9134
8589D2A0:        0        3        0 82AA9134        0        3        0 82AA9134
---- block86  ptr=84A779D4  is_malloc=0  length=0x100 ----
84A77994:        1        9        A       18        0        3        A 84A77980
84A779B4:        B 84A7794C        B 84A77920        E 84A769F8        E 84A76800
84A779D4: 84A79ECC    20020 84A779E8        0        0        1 8562F86C        1
84A779F4: 8562F824 7670646E 6D696200 7265713A 2076706E        0 63697363 6F567064
84A77A14: 6E4D676D 744D4942        0 312E332E 362E312E 342E312E 392E3130 2E323400
84A77A34: 63697363 6F567064 6E4D676D 744D4942 4F626A65 63747300 312E332E 362E312E
84A77A54: 342E312E 392E3130 2E32342E 31000000 63767064 6E537973 74656D49 6E666F00
84A77A74: 312E332E 362E312E 342E312E 392E3130 2E32342E 312E3100 63767064 6E54756E
84A77A94: 6E656C54 6F74616C        0 312E332E 362E312E 342E312E 392E3130 2E32342E
84A77AB4: 312E312E 31000000 63767064 6E536573 73696F6E 546F7461 6C000000 312E332E
---- block87  ptr=877D74C8  is_malloc=1  length=0x100 ----
877D7488: 839C1F98 82AA9A90 877D74C8 877D73D4 8000000E        1        0        1
877D74A8: 85FB07EC 82CBA744        0        0        0        0        0 FD0110DF
877D74C8: AB1234CD FFFE0000        0 839C1F98 82AA9A90 877D7514 877D7490 8000000E
877D74E8:        1        0        1 85FB07EC 82CC87E4 82CC877C        0        0
877D7508:        0        0 FD0110DF AB1234CD FFFE0000        0 848324C4 827E7718
877D7528: 877D7560 877D74DC 8000000E        1        0        1 85FB07EC 877D7590
877D7548: 854EB54C       68        0        0        0 FD0110DF AB1234CD FFFE0000
877D7568:        0 848324C4 827E7718 877D75AC 877D7528 8000000E        1        0
877D7588:        1 85FB07EC 877D75DC 854EB54C       67        0        0        0
877D75A8: FD0110DF AB1234CD FFFE0000        0 848324C4 827E7718 877D75F8 877D7574
---- block88  ptr=87107008  is_malloc=1  length=0x100 ----
87106FC8:        0        0        0        0        0   410000 85647630 6C327475
87106FE8: 6E206170 7020736F 636B0000 87107004 87107004        0        0 FD0110DF
87107008: AB1234CD FFFE0000        0 839C1F98 8385EAB0 8710709C 87106F8C 80000032
87107028:        1        0        1 85FB07EC        0        0        0        0
87107048:        0        0        0        0        0        0        0        0
87107068:        0        0        0        0        0        0        0        0
87107088:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
871070A8: 8483209C 8234FDEC 87107110 8710701C 80000022        1 8234E508        1
871070C8: 85FB07EC       28   170000        0        0 54656C6E 65740000        0
871070E8:        0        0        0        0        0        0        0        0
---- block89  ptr=86F6DC94  is_malloc=1  length=0x100 ----
86F6DC54:        0        0        0        0        0        0        0        0
86F6DC74:        0        0        0        0        0        0        0 FD0110DF
86F6DC94: AB1234CD FFFE0000        0 839C1F98 8385EAC8 86F6DD24 86F6DC18 80000030
86F6DCB4:        1        0        1 85FB07EC 82CCA77C        0        0        0
86F6DCD4:        0        0        0        0        0        0        0        0
86F6DCF4:        0        0        0        0        0        0        0        0
86F6DD14:        0        0        0 FD0110DF AB1234CD FFFE0000        0 839C1F98
86F6DD34: 82AA9A90 86F6DDD0 86F6DCA8 8000003E        1        0        1 85FB07EC
86F6DD54:        0        0        0        0        0        0 82CAA68C        0
86F6DD74:        0        0        0        0        0        0        0        0
---- block90  ptr=8451675C  is_malloc=0  length=0x100 ----
8451671C: 75742066 696C7465 72206D6F 64650000 636F6E66 69672D76 69657700 42616E6E
8451673C: 65722049 6E707574 206D6F64 65000000 62616E6E 65725F65 6E747279        0
8451675C: 50617273 6572204D 6F646500 50617273 6572204D 6F646520 51310000 50617273
8451677C: 6572204D 6F646520 51320000  A416464 696E6720 70617273 6572206D 6F64653A
8451679C: 20272573 27202030 78257800 25323073 20253230 73203078 25387820 25387320
845167BC: 2538730A        0  A506172 73657220 6D6F6465 733A0000  A4E616D 65202020
845167DC: 20202020 20202020 20202020 20205072 6F6D7074 20202020 20202020 20202020
845167FC: 20202054 6F702020 20202020 2020416C 69617320 20202050 72697669 6C656765
8451681C:  A000000  A4E6F20 70617273 6572206D 6F646573        0  A4C6F6F 6B207570
8451683C: 206F6620 70617273 6572206D 6F646520 27257327 20257300  A252520 556E6162
---- block91  ptr=868F9D94  is_malloc=1  length=0x100 ----
868F9D54: 84516778 813E41E0 868F9D94 868F9D10 8000000E        1        0        1
868F9D74: 85FB07EC        0        0        0        0        0        0 FD0110DF
868F9D94: AB1234CD FFFE0000        0 8451675C 813E4150 868F9E04 868F9D5C 80000020
868F9DB4:        1        0        1 85FB07EC 868F9ECC 8646B904 83E07918 83E078E0
868F9DD4: 83E078F4 84C50310 80492B70 80492B88        0        7 85020E20 868F9E34
868F9DF4: 868F9E80        0        0 FD0110DF AB1234CD FFFE0000        0 84516768
868F9E14: 813E41BC 868F9E50 868F9DA8 8000000E        1        0        1 85FB07EC
868F9E34:        0        0        0        0        0        0 FD0110DF AB1234CD
868F9E54: FFFE0000        0 84516778 813E41E0 868F9E9C 868F9E18 8000000E        1
868F9E74:        0        1 85FB07EC        0        0        0        0        0
---- block92  ptr=847E1544  is_malloc=0  length=0x100 ----
847E1504:        0 676C6F62 616C2070 6172616D 65746572 73000000 6475706C 69636174
847E1524: 65204650 49730000 46504973 20776974 68207361 6D652074 79706520 616E6420
847E1544: 76726600 72657175 65737420 6D736720 61626F72 74000000 4C464420 72657772
847E1564: 69746520 6C6F6F6B 75700000 4C464420 72657772 69746520 64657175 65756500
847E1584: 4C464420 67657420 6F757470 75742063 6861696E        0 4C464420 73617665
847E15A4: 20726577 72697465        0 4C464420 46504920 64657374 726F7900 4C464420
847E15C4: 64656C65 74652072 65777269 7465202D 206E6F74 20666F75 6E640000 4C464420
847E15E4: 75706461 74652074 79706500 6E6F2053 4E4D5020 41707000 62616420 61706920
847E1604: 76657273 696F6E00 47656E65 72616C20 636D6420 6572726F 72000000 4C424C00
847E1624: 49563400 49563600 4652414D 45000000 54455475 6E496E74        0 54454C73
---- block93  ptr=84A7F438  is_malloc=0  length=0x100 ----
84A7F3F8: 696E7465 72666163 65206973 20707265 73656E74 20696E20 61205652 46206F72
84A7F418: 206E6F74        0 496C6C65 67616C20 56524620 43434120 636F6D6D 616E6400
84A7F438: 636F6E66 69672D76 72660000 436F6E66 69677572 65205652 46207061 72616D65
84A7F458: 74657273        0 636F6E66 69672D76 72662D61 66000000 436F6E66 69677572
84A7F478: 65204950 20565246 20706172 616D6574 65727300 69702D69 6E742D76 72662D66
84A7F498: 6F727761 7264696E 67000000 44657065 6E64656E 63696573 20666F72 20697020
84A7F4B8: 76726620 666F7277 61726469 6E670000 44657065 6E64656E 63696573 20666F72
84A7F4D8: 20697020 76726600 4F55493A 56504E2D 496E6465 78000000 43444220 6C697374
84A7F4F8:        0 646F776E 73747265 616D2076 72660000 20646F77 6E737472 65616D20
84A7F518: 25730000  A252520 416C7265 61647920 636F6E66 69677572 65642027 69702076
---- block94  ptr=84C50310  is_malloc=0  length=0x100 ----
84C502D0: 55706461 74696E67 20746865 20766572 73696F6E 206E756D 6265723A 20256400
84C502F0:  A457A56 504E2825 73293A20 4E6F2055 524C2061 7661696C 61626C65 20746F20
84C50310: 636F6E66 69677572 65000000  A457A56 504E2825 73293A20 636F6E66 69677572
84C50330: 6174696F 6E20736B 69707065 642C2061 6C726561 64792061 70706C69 65642100
84C50350:  A457A56 504E2825 73293A20 636F6E66 69677572 6174696F 6E206665 74636820
84C50370: 736B6970 7065642C 20616C72 65616479 20686176 65207361 6D652028 25642920
84C50390: 76657273 696F6E00  A457A56 504E2825 73293A20 726F6C6C 696E6720 6261636B
84C503B0: 20746865 20636F6E 66696720 746F2062 61736500  A457A56 504E2825 73293A20
84C503D0: 5741524E 494E473A 20726F6C 6C206261 636B2077 61732075 6E737563 63657373
84C503F0: 66756C00  A457A56 504E2825 73293A20 74686572 65206973 206E6F20 636F6E66
---- block95  ptr=873F969C  is_malloc=1  length=0x100 ----
873F965C: 839C1F98 8385EAF4 873F969C 873F9618 8000000E        1        0        1
873F967C: 85FB07EC        0        0        0        0        0        0 FD0110DF
873F969C: AB1234CD FFFE0000        0 8451675C 813E4150 873F970C 873F9664 80000020
873F96BC:        1        0        1 85FB07EC 873F97D4 86B25DF4 847C37F8 845431C0
873F96DC: 845431CC 84C50310 81491DBC 81491E94 8149B928        7 851CAFE4 873F973C
873F96FC: 873F9788        0        0 FD0110DF AB1234CD FFFE0000        0 84516768
873F971C: 813E41BC 873F9758 873F96B0 8000000E        1        0        1 85FB07EC
873F973C:        0        0        0        0        0        0 FD0110DF AB1234CD
873F975C: FFFE0000        0 84516778 813E41E0 873F97A4 873F9720 8000000E        1
873F977C:        0        1 85FB07EC        0        0        0        0        0
---- block96  ptr=8614F338  is_malloc=1  length=0x100 ----
8614F2F8: 84516778 813E41E0 8614F338 8614F2B4 8000000E        1        0        1
8614F318: 85FB07EC        0        0        0        0        0        0 FD0110DF
8614F338: AB1234CD FFFE0000        0 8451675C 813E4150 8614F3A8 8614F300 80000020
8614F358:        1        0        1 85FB07EC 8614F470        0 84523EC0 84524AD4
8614F378: 84524AE4 84C50310 8141DB70 8141DBD8 8141DCC8        7 851B9104 8614F3D8
8614F398: 8614F424        0        0 FD0110DF AB1234CD FFFE0000        0 84516768
8614F3B8: 813E41BC 8614F3F4 8614F34C 8000000E        1        0        1 85FB07EC
8614F3D8:        0        0        0        0        0        0 FD0110DF AB1234CD
8614F3F8: FFFE0000        0 84516778 813E41E0 8614F440 8614F3BC 8000000E        1
8614F418:        0        1 85FB07EC        0        0        0        0        0
---- block97  ptr=843985F4  is_malloc=0  length=0x100 ----
843985B4: 706F6F6C        0 4C6F6361 6C206970 20706F6F 6C206164 64726573 73000000
843985D4: 69702D75 6E6E756D 62657265 64000000 49502075 6E6E756D 62657265 64000000
843985F4: 69702D76 72660000 56524620 496E666F        0 7070702D 61636374 2D6C6973
84398614: 74000000 50505020 6163636F 756E7469 6E67206D 6574686F 642D6C69 73740000
84398634: 7070702D 61757468 6F722D6C 69737400 50505020 61757468 6F72697A 6174696F
84398654: 6E206D65 74686F64 2D6C6973 74000000 7070702D 61757468 656E2D74 79706500
84398674: 50505020 61757468 656E7469 63617469 6F6E2070 726F746F 636F6C73        0
84398694: 7070702D 61757468 656E2D6C 69737400 50505020 61757468 656E7469 63617469
843986B4: 6F6E206D 6574686F 642D6C69 73740000 7261642D 73657276 2D66696C 74657200
843986D4: 52616469 75732066 696C7465 72206C69 7374206E 616D6520 666F7220 73657276
---- block98  ptr=854EB804  is_malloc=0  length=0x100 ----
854EB7C4:        0        0       19 854EB7D8        0 82CDADA8        0 80000000
854EB7E4:        0        0       19 854EB7F8        0 82CDD490        0 80000000
854EB804:        0 854EB818       2B 84A7A2D0        0 854EBD10 854EB844       45
854EB824: 854EB82C        0 8562CED0 844E8BD8 854EB838   400000        0        0
854EB844: 854EBD10 854EB878       47 854EB858        0 8562CED4 844E8C00 854EB86C
854EB864:  B740004        1   400000        0        0 854EBC84 851A547C       8D
854EB884: 84A7A2D8        0 854EBB18 851A547C       8D 84A7A2E4        0 854EBA00
854EB8A4: 851A547C       8D 84A7A2F0        0 854EB938 851A547C       8D 84A7A2FC
854EB8C4:        0 854EB8DC 851A547C       8D 84A7A308        0 854EB8F0 851A547C
854EB8E4:       8D 84A7A314        0 854EB91C 854EC0E0       45 854EB904        0
---- block99  ptr=873F8370  is_malloc=1  length=0x100 ----
873F8330: 84516778 813E41E0 873F8370 873F82EC 8000000E        1        0        1
873F8350: 85FB07EC        0        0        0        0        0        0 FD0110DF
873F8370: AB1234CD FFFE0000        0 839C1F98 813EAA50 873F83BC 873F8338 8000000E
873F8390:        1        0        1 85FB07EC        0 854EB7E4 84A7F48C 84A7F4A4
873F83B0: 8715C720        0 FD0110DF AB1234CD FFFE0000        0 839C1F98 813EAA50
873F83D0: 873F8408 873F8384 8000000E        1        0        1 85FB07EC        1
873F83F0: 854EB7C4 843985F4 84A7F4C8 873F83A0        0 FD0110DF AB1234CD FFFE0000
873F8410:        0 839C1F98 813EA808 873F845C 873F83D0 80000012        1        0
873F8430:        1 85FB07EC 854EB734 84A7D090 84939C1C        0 84939C1C 8432C1EC
873F8450:        0        0 FD0110DF AB1234CD FFFE0000        0 839C1F98 8385EAB0
---- block100  ptr=84A9EF30  is_malloc=0  length=0x100 ----
84A9EEF0: 65000000 4D61726B 75704261 73655552 4C206E6F 7420696E 69746961 6C697A65
84A9EF10: 64000000  A466169 6C656420 746F2075 6E6C6F63 6B205549 44202564        0
84A9EF30: 56786D6C 4D6F6475 6C650000 6275696C 74696E3A 56786D6C 4D6F6475 6C652E43
84A9EF50:        0  A496E69 7469616C 697A696E 672E2E2E  A000000 4275696C 7420696E
84A9EF70: 20432050 61636B61 67652069 6D706C65 6D656E74 696E6720 74686520 56786D6C
84A9EF90: 20536572 76696365        0 535F4449 414C4F47        0 535F5452 414E5346
84A9EFB0: 45525F54 45524D49 4E415449 4E470000 76786D6C 73657276 69636500 61637469
84A9EFD0: 76656C65 67000000 414E492F 52444E49 53202825 7329206D 75737420 73746172
84A9EFF0: 74207769 74682027 70686F6E 653A2F2F 27000000 414E492F 52444E49 53202825
84A9F010: 7329206E 6F742069 6E20452E 31363420 666F726D 61740000 696E7661 6C696420
---- block101  ptr=85B22820  is_malloc=0  length=0x100 ----
85B227E0:        1 829A4CE0 829A4D2C 8733CBEC        0        0        0        0
85B22800:       40       67       C0       18       3F        0 829A48F4 829A4B74
85B22820: 84992500 85B20228 87334400        1       16        0        1        0
85B22840:        0        0        0 81E76A10 81E76A44 81E76B0C 81E7906C 81E79108
85B22860: 81E7A064 81E79E88 81E7A150 81E76994 81E77584 81E7768C 81E79828 81E79238
85B22880: 81E77BFC 81E79330 81E791E4 81E792BC 81E799EC 81E79B28        0 81E7A1F4
85B228A0: 81E7A330        0        0        0        0        0        0        0
85B228C0:        0        0        0        0        0        0        0        0
85B228E0:        0        0        0        0        0        0        0        0
85B22900:        0        0        0        0        0        0        0        0
---- block102  ptr=86C6976C  is_malloc=1  length=0x100 ----
86C6972C:        0        0        0        0        0        0        0        0
86C6974C:        0        0        0        0        0        0        0 FD0110DF
86C6976C: AB1234CD FFFE0000        0 839C1F98 81E76FAC 86C697B8 86C696AC 8000000E
86C6978C:        1        0        1 85FB07EC 6976723A 2056786D 6C4D6F64 756C6500
86C697AC:        0        0 FD0110DF AB1234CD FFFE0000        0 84756994 81E99DAC
86C697CC: 86C69804 86C69780 8000000E        1        0        1 85FB07EC 76786D6C
86C697EC: 6D6F6475 6C650000        0        0        0 FD0110DF AB1234CD FFFE0000
86C6980C:        0 847569A8 81E99DC8 86C69850 86C697CC 8000000E        1        0
86C6982C:        1 85FB07EC 6275696C 74696E3A 56786D6C 4D6F6475 6C652E43        0
86C6984C: FD0110DF AB1234CD FFFE0000        0 847569C0 81E99DEC 86C6989C 86C69818
---- block103  ptr=8647CCD8  is_malloc=0  length=0x100 ----
8647CC98:   8C0BDE  23538AB        0      85B     69B7    235BA   F7FBB6  3A5D2D1
8647CCB8:        0      DB1    70078    768E3 18A5F9C8  A3F93AE        0     81C7
8647CCD8:       24     F586        0        0        0      35F    B2126        5
8647CCF8:     9CA4      A86        0        0        0        0        0        0
8647CD18:      450        0       5B       1C        0        0        0        0
8647CD38:        0        0        0        0        0        0        0        0
8647CD58:        0        0        0        0        0        0        0        0
8647CD78:        0        0        0        0        0        0        0        0
8647CD98:        0        0        0        0        0        0        0        0
8647CDB8:        0        0        0        0        0        0        0        0
---- block104  ptr=8647CDDC  is_malloc=0  length=0x18C ----
8647CD9C:        0        0        0        0        0        0        0        0
8647CDBC:        0        0        0        0        0        0        0        0
8647CDDC:        0        0        0        0        0        0        0        0
8647CDFC:        0        0        0        0        0        0        0        0
8647CE1C:        0        0        0        0        0        0        0        0
8647CE3C:        0        0        0        0        0        0        0        0
8647CE5C:        0        0        0        0        0        0        0        0
8647CE7C:     21A8      24F        0     23F7     7A12        0        0        0
8647CE9C:        A  96C0000   110002        0 8AA85378        0        0        0
8647CEBC:        0        0        0        0        0        0        0        0
8647CEDC:        0        0        0        0        0        0        0        0
8647CEFC:        0        0        0        0        0        0        0        0
8647CF1C:        0        0        0        0        0        0        0        0
8647CF3C:        0        0        0        0        0        0        0        0
8647CF5C:        0        0        0
---- block105  ptr=85FF8EA8  is_malloc=0  length=0x100 ----
85FF8E68: 857FCF0C      2AE    90000        1        0 84BE547C 82A9F8A0 8549413C
85FF8E88:        0        0        0 84BE547C        4        0        0 85FF7174
85FF8EA8: 85FF8E44 85FF8F0C 85FF8EA8 85BAE4E4        0        0 863E48D0 862F5814
85FF8EC8: 85FF8EB8 857FCF0C      298    90000        0        0 8432F35C 82A9F8A0
85FF8EE8: 8549413C        0        0        0 8432F35C        4 864731C8        1
85FF8F08: 85FF7174 85FF8EA8 85FF8F70 85FF8F0C 85BAE4E4 8678E4D0 8678E4D0 86472F34
85FF8F28: 862F59AC 85FF8F1C 857FCF0C      291    90000        1        0 843316A8
85FF8F48: 82A9F8A0 8549413C        0        0        0 843316A8        4        4
85FF8F68:        0 85FF7174 85FF8F0C 85FF8FD4 85FF8F70 85BAE4E4 8678F670 8678F670
85FF8F88: 86470BD4 85A37AC4 85FF8F80 857FCF0C      28A    90000        1        0
---- block106  ptr=863E45DC  is_malloc=1  length=0x610 ----
863E459C:        0        0        0        0        0        0        0        0
863E45BC:        0        0        0        0        0        0        0 FD0110DF
863E45DC: AB1234CD FFFE0000        0 85F9A4A4 82AA0C40 863E4BEC 863E3A04 800002F0
863E45FC:        1 82A47550        1 85FB07EC        0 8601336C 866FF814        0
863E461C: 85F9A468        A        C   68006C        0        0        0        0
863E463C:       40   430000 85647630 57617463 68656420 53656D61 70680000 863E4698
863E465C: 863E4BA8        0        0 863E469C 863E4708 863E4774 863E47E0 863E484C
863E467C: 863E48B8 863E4924 863E4990 863E49FC 863E4A68 863E4AD4 863E4B40 863E460C
863E469C: 866FFD48 863E4708 863E469C 85BBD418        0        0 863E3DA0 863E3E94
863E46BC: 863E46AC 857FCF0C      33E    90000        0        0 849D57CC 82A9F8A0
863E46DC: 8549413C        0        1        0 849D57CC        8        0        0
863E46FC: FFFFFFFF        0 863E460C 863E469C 863E4774 863E4708 85BBD418        0
863E471C:        0 866F94A4 863E3F88 863E4718 857FCF0C      322    90000        0
863E473C:        0 849D57CC 82A9F8A0 8549413C        0        0        0 849D57CC
863E475C:        8        0        0 FFFFFFFF        0 863E460C 863E4708 863E47E0
863E477C: 863E4774 85BBD418        0        0 866F4740 863E407C 863E4784 857FCF0C
863E479C:      303    90000        0        0 849D57CC 82A9F8A0 8549413C        0
863E47BC:        0        0 849D57CC        8        0        0 FFFFFFFF        0
863E47DC: 863E460C 863E4774 863E484C 863E47E0 85BBD418        0        0 866DC5DC
863E47FC: 863E4170 863E47F0 857FCF0C      2E4    90000        0        0 849D57CC
863E481C: 82A9F8A0 8549413C        0        0        0 849D57CC        8        0
863E483C:        0 FFFFFFFF        0 863E460C 863E47E0 863E48B8 863E484C 85BBD418
863E485C:        0        0 8669E8E0 863E4264 863E485C 857FCF0C      2CC    90000
863E487C:        0        0 849D57CC 82A9F8A0 8549413C        0        0        0
863E489C: 849D57CC        8        0        0 FFFFFFFF        0 863E460C 863E484C
863E48BC: 863E4924 863E48B8 85BBD418        0        0 8647A6B0 85FF8EC0 863E48C8
863E48DC: 857FCF0C      299    90000        0        0 8432F36C 82A9F8A0 8549413C
863E48FC:        0        0        0 8432F36C        8 864731C8        0 FFFFFFFF
863E491C:        0 863E460C 863E48B8 863E4990 863E4924 85BBD418        0        0
863E493C: 85FF8FEC 863E4358 863E4934 857FCF0C      27B    90000        0        0
863E495C: 849D57CC 82A9F8A0 8549413C        0        0        0 849D57CC        8
863E497C:        0        0 FFFFFFFF        0 863E460C 863E4924 863E49FC 863E4990
863E499C: 85BBD418        0        0 863F8640 863E4A14 863E49A0 857FCF0C      200
863E49BC:    90000        0        0 85B1F8E4 82A9F8A0 8549413C        0        0
863E49DC:        0 85B1F8E4        8        0        0 FFFFFFFF        0 863E460C
863E49FC: 863E4990 863E4A68 863E49FC 85BBD418        0        0 863E49A8 863E4A80
863E4A1C: 863E4A0C 857FCF0C      1FF    90000        0        0 85B1D8C4 82A9F8A0
863E4A3C: 8549413C        0        0        0 85B1D8C4        8        0        0
863E4A5C: FFFFFFFF        0 863E460C 863E49FC 863E4AD4 863E4A68 85BBD418        0
863E4A7C:        0 863E4A14 863E4AEC 863E4A78 857FCF0C      1FE    90000        0
863E4A9C:        0 85B1B8A4 82A9F8A0 8549413C        0        0        0 85B1B8A4
863E4ABC:        8        0        0 FFFFFFFF        0 863E460C 863E4A68 863E4B40
863E4ADC: 863E4AD4 85BBD418        0        0 863E4A80 862F77F4 863E4AE4 857FCF0C
863E4AFC:      1FD    90000        0        0 85B19884 82A9F8A0 8549413C        0
863E4B1C:        0        0 85B19884        8        0        0 FFFFFFFF        0
863E4B3C: 863E460C 863E4AD4 860133FC 863E4B40 85BBD418        0        0 863F01F8
863E4B5C: 863E444C 863E4B50 857FCF0C      1E1    90000        0        0 849D57CC
863E4B7C: 82A9F8A0 8549413C        0        1        0 849D57CC        8        0
863E4B9C:        0 FFFFFFFF        0        0        0        0        0        0
863E4BBC:        0        0        0        0        0        0        0        0
863E4BDC:        0        0        0 FD0110DF
---- block107  ptr=8432B480  is_malloc=0  length=0x100 ----
8432B440: 696C6500 75736572 2070726F 66696C65 20746167        0 636F6E66 69672D75
8432B460: 7365722D 70726F66 696C6500 75736572 2070726F 66696C65 206D6F64 65000000
8432B480: 85635060        0 813A524C 80C14D00 8432BEF4        0 83998C50 850D5D98
8432B4A0: 80C07518        4 83DA1F0C        0        0        0 8562CEA8        0
8432B4C0:        0 8432BF78 850D5EBC 80C07484 8432BF90 850D5ED0 80C073F0      A18
8432B4E0: 80C0EBDC      A14 80C0ED5C      A10 80C0EAE0 813E0E38        4 8432B4A4
8432B500: 85637CE8 850D7250 856386B0 850D6544 856395D4 850D6254 85638824        0
8432B520: 83998C50 850D656C 80C073E0        4 83DA1F0C        0        0        0
8432B540: 8562CEA8        0        0      83C 8477CD9C     F001 813E0E38        4
8432B560: 8432B52C 83998C50 850D749C 80C17630        4 83DA1F0C        0        0
---- block108  ptr=85FAAD28  is_malloc=0  length=0x100 ----
85FAACE8:        0 85FF949C 85FAACB4 85FAACE4 857FCF0C       F8    D0000        0
85FAAD08:        0 849D7268 82A9865C 8549413C        0   5C0000 85F9DA1C 85FA9ACC
85FAAD28:        0        1        1 82AA7348 85F920E4 85F920D0 85FAAD78 85F9ED40
85FAAD48: 85FAAD38 857FCF0C       32    D0000        3        0 849D7230 82A9865C
85FAAD68: 8549413C        0 85FB0828 877FF03C 85FAADB0 85FAAD40 85FAAD70 857FCF0C
85FAAD88:       33    90000      153        0 849D724C 82A9865C 8549413C        0
85FAADA8:        0        0 85FB0840 85FAAD78 85FAADA8 857FCF0C       34    D0000
85FAADC8:        0        0 849D7268 82A9865C 8549413C        0   4D0000 85F9DBC0
85FAADE8:        0        0        0        0        0        0        0        0
85FAAE08:        0        0        0        0        0        0        0        0
---- block109  ptr=85F9D614  is_malloc=1  length=0x610 ----
85F9D5D4:        0 FFFFFFFF        0        0        0        0        0 85F9BE44
85F9D5F4:        0        0        0        0        0        0        0 FD0110DF
85F9D614: AB1234CD FFFE0000        0 85F9B790 81392F6C 85F9DC24 85F9C26C 800002F0
85F9D634:        1 82A47550        1 85FB07EC        0 871B5098 87ABEFC8        0
85F9D654: 85F9B754       20       3A   140014        0        0        0        0
85F9D674:       10    30000 85647630 53747269 6E672D44 42206F77 6E650000 85F9D788
85F9D694: 85F9DC10        0        0 85F9D788 85F9D79C 85F9D7B0 85F9D7C4 85F9D7D8
85F9D6B4: 85F9D7EC 85F9D800 85F9D814 85F9D828 85F9D83C 85F9D850 85F9D864 85F9D878
85F9D6D4: 85F9D88C 85F9D8A0 85F9D8B4 85F9D8C8 85F9D8DC 85F9D8F0 85F9D904 85F9D918
85F9D6F4: 85F9D92C 85F9D940 85F9D954 85F9D968 85F9D97C 85F9D990 85F9D9A4 85F9D9B8
85F9D714: 85F9D9CC 85F9D9E0 85F9D9F4 85F9DA08 85F9DA1C 85F9DA30 85F9DA44 85F9DA58
85F9D734: 85F9DA6C 85F9DA80 85F9DA94 85F9DAA8 85F9DABC 85F9DAD0 85F9DAE4 85F9DAF8
85F9D754: 85F9DB0C 85F9DB20 85F9DB34 85F9DB48 85F9DB5C 85F9DB70 85F9DB84 85F9DB98
85F9D774: 85F9DBAC 85F9DBC0 85F9DBD4 85F9DBE8 85F9DBFC        0 85F9DD98 861514C4
85F9D794:    20000        0        0 85F9DDAC 861514CC    20000        0        0
85F9D7B4: 85F9DDC0 861514D4    20000        0        0 85F9DDD4 861514DC    20000
85F9D7D4:        0        0 85F9DDE8 861514E4    20000        0        0 85F9DDFC
85F9D7F4: 861514EC    20000        0        0 85F9DE10 861514F4    20000        0
85F9D814:        0 85F9DE24 861514FC    20000        0        0 85F9DE38 86151504
85F9D834:    20000        0        0 85F9DE4C 8615150C    20000        0        0
85F9D854: 85F9DE60 86151514    20000        0        0 85F9DE74 8615151C    20000
85F9D874:        0        0 85F9DE88 86151524    20000        0        0 85F9DE9C
85F9D894: 8615152C    20000        0        0 85F9DEB0 86151534    20000        0
85F9D8B4:        0 85F9DEC4 8615153C    20000        0        0 85F9DED8 86151544
85F9D8D4:    20000        0        0 85F9DEEC 8615154C    20000        0        0
85F9D8F4: 85F9DF00 86151554    20000        0        0 85F9DF14 8615155C    20000
85F9D914:        0        0 85F9DF28 85FB0A20    20000        0        0 85F9DF3C
85F9D934: 85FB0A28    20000        0        0 85F9DF50 85FB0A30    20000        0
85F9D954:        0 85F9DF64 85FB0A38    20000        0        0 85F9DF78 85FB0A40
85F9D974:    20000        0        0 85F9DF8C 85FB0A48    20000        0        0
85F9D994: 85F9DFA0 85FB0A50    20000        0        0 85F9DFB4 85FB0A58    20000
85F9D9B4:        0        0 85F9DFC8 85FB0A60    20000        0        0 85F9DFDC
85F9D9D4: 85FB0A68    20000        0        0 85F9DFF0 85FB0A70    20000        0
85F9D9F4:        0 85F9E004 85FAABA0    10000        0        0 85F9E018 85FB0A78
85F9DA14:    20000        0        0 85F9E02C 85FAAC64    10000        0        0
85F9DA34: 85F9E040 85F9CE68        0        0        0 85F9E054 85FB0A80    20000
85F9DA54:        0        0 85F9E068 85FB0A88    20000        0        0 85F9E07C
85F9DA74: 85FB0A90    20000        0        0 85F9E090 85FB0A98    20000        0
85F9DA94:        0 85F9E0A4 85FB0AA0    20000        0        0 85F9E0B8 85FB0AA8
85F9DAB4:    20000        0        0 85F9E0CC 85FB0AB0    20000        0        0
85F9DAD4: 85F9E0E0 85FB0AB8    20000        0        0 85F9E0F4 85FB0AC0    20000
85F9DAF4:        0        0 85F9E108 85FB0AC8    20000        0        0 85F9E11C
85F9DB14: 85FB0AD0    20000        0        0 85F9E130 85FB0AE0    20000        0
85F9DB34:        0 85F9E144 85FB0AE8    20000        0        0 85F9E158 85FB0AF0
85F9DB54:    20000        0        0 85F9E16C 85FB0AF8    20000        0        0
85F9DB74: 85F9E180 85FB0B00    20000        0        0 85F9E194 85FB0B08    20000
85F9DB94:        0        0 85F9E1A8 85FB0B10    20000        0        0 85F9E1BC
85F9DBB4: 85FB0B18    20000        0        0 85F9E1D0 85FAAD28    10000        0
85F9DBD4:        0 85F9E1E4 85F9D04C        0        0        0 85F9E1F8 85F9D230
85F9DBF4:        0        0        0 85F9E20C 85F9D414        0        0        0
85F9DC14:        0        0        0 FD0110DF
---- block110  ptr=85FB6938  is_malloc=0  length=0x140 ----
85FB68F8: 85FB6884 85FB0838        0 85FD6A94 85FB1B8C 85FB07EC 85F9D414        0
85FB6918:        0        0        0       FF        0 85FC6A1C        0        0
85FB6938: 85FB68B0 85FB0840 85FB6930 857FCF0C       36    D0000        0        0
85FB6958: 849D6AD0 82A9865C 8549413C        0 85FB67D0 85FB23D0 85FB690C 85F9D460
85FB6978: 85FB68F0        0 85FB690C 85FB0838        0 85FB69E0        0        0
85FB6998:        0        0        0        0        0 FD0110DF AB1234CD FFFE0000
85FB69B8:        0 84524B38 82AB41A0 85FB69FC 85FB1B70 8000000E        1        0
85FB69D8:        1 85FB07EC        0        0        0        0        0        0
85FB69F8: FD0110DF AB1234CD FFFE0000        0 85F9E40C 82A90ED0 85FC6A30 85FB69C4
85FB6A18: 80008002        1 82A47550        1 85FB07EC        0        0 85F9E3D0
85FB6A38:        0 85F9E3D0      400      7FD    C001C      6A9        0        0
85FB6A58:        0        4   230000 85647630 4D656D6F 72792052 4F205255 20490000
---- block111  ptr=85FB6868  is_malloc=0  length=0x100 ----
85FB6828: 85FB07AC 85FB68B0 85FB6820 857FCF0C       38    D0000        0        0
85FB6848: 849D6AD0 82A9865C 8549413C        0 85FB66C0 85FB22C0 85FB67FC 85F9D098
85FB6868:        0 85FB68F0 85FB67FC 85FB0838        0        0 85FB1B8C 85FB07EC
85FB6888: 85F9D230        0        0        0        0       FF        0 85FE69AC
85FB68A8:        0        0 85FB6828 85FB6938 85FB68A8 857FCF0C       37    D0000
85FB68C8:        0        0 849D6AD0 82A9865C 8549413C        0 85FB6748 85FB2348
85FB68E8: 85FB6884 85F9D27C 85FB6868 85FB6978 85FB6884 85FB0838        0 85FD6A94
85FB6908: 85FB1B8C 85FB07EC 85F9D414        0        0        0        0       FF
85FB6928:        0 85FC6A1C        0        0 85FB68B0 85FB0840 85FB6930 857FCF0C
85FB6948:       36    D0000        0        0 849D6AD0 82A9865C 8549413C        0
---- block112  ptr=857FCF0C  is_malloc=0  length=0x100 ----
857FCECC:        0        0        0        0        0        0        0        0
857FCEEC:        0        0        0        0        0        0        0        0
857FCF0C: 85BBD870 86AC2654        0        0        0        0        0    90000
857FCF2C:     6A0C        0 844DB808 82A9865C 8549413C        0 43697363 6F20494F
857FCF4C: 5320536F 66747761 72652C20 55433530 3020536F 66747761 72652028 55433530
857FCF6C: 302D4144 56495053 45525649 4345534B 392D4D29 2C205665 7273696F 6E203135
857FCF8C: 2E302831 29584133 612C2053 42544720 53706563 69616C0A 536D616C 6C204275
857FCFAC: 73696E65 73732053 7570706F 72743A20 68747470 3A2F2F77 77772E63 6973636F
857FCFCC: 2E636F6D 2F676F2F 736D616C 6C62697A 68656C70  A436F70 79726967 68742028
857FCFEC: 63292031 3938362D 32303130 20627920 43697363 6F205379 7374656D 732C2049
---- block113  ptr=84587D58  is_malloc=0  length=0x100 ----
84587D18: 29000000  A657374 696D6174 6F725F74 696D6572 735F7065 725F7469 636B5F62
84587D38: 6F6F6B6B 65657069 6E673A20 68697761 74657220 256C7520 3D3E2025 6C750A00
84587D58: 8563A4E8 8563A4E0 8034672C 815E7EB4 844C4B60        0 FD05DC1C FD05DC24
84587D78: FD05DC2C FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14
84587D98: FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC34 FD05DC3C
84587DB8: FD05DC44 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14
84587DD8: FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC4C FD05DC54
84587DF8: FD05DC5C FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14
84587E18: FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC14 FD05DC64 FD05DC6C
84587E38: FD05DC74 FD05DBD4 FD05DBEC FD05DBF8 FD05DC04 FD05DC10 FD05DC1C FD05DC28
---- block114  ptr=878785DC  is_malloc=1  length=0x13C ----
8787859C:        0        0        0        0        0        0        0        0
878785BC:        0        0        0        0        0        0        0 FD0110DF
878785DC: AB1234CD FFFE0000        0 839C1F98 8010EF4C 87878718 87878338 80000086
878785FC:        1        0        1 85FB07EC        0 878573E0 84587D58 8889B4B8
8787861C: 8647A800        0        0        0        0        0        0        0
8787863C:        0        0        0        0        0        0        0        0
8787865C:        0        0        0        0        0        0        0        0
8787867C:        0        0        0        0        0        0        0        0
8787869C:        0        0        0        0        0        0        0        0
878786BC:        0        0        0        0        0        0        0        0
878786DC:        0        0        0        0        0        0        0        0
878786FC:        0        0        0        0        0        0 FD0110DF
---- block115  ptr=8645403C  is_malloc=1  length=0x13C ----
86453FFC:        0        1        1        1        1        1        1        1
8645401C:        1        0        1        0 2E865BA0        0        0 FD0110DF
8645403C: AB1234CD FFFE0000        0 839C1F98 815E6FAC 86454178 86453DBC 80000086
8645405C:        1        0        1 85FB07EC        0 86452C60 84587D58 8647A800
8645407C: 86452ABC        0        0        0        0        0        0        0
8645409C:        0        0        0        0        0        0        0        0
864540BC:        0        0        0        0        0        0        0        0
864540DC:        0        0        0        0        0        0        0 813A524C
864540FC:        0 81368440        0        0        0        0        0        0
8645411C:        0        0        0 86455DBC 86452B78 86454120 857FCF0C      25A
8645413C:    50000        0        0 84588DE8 82A9865C 8549413C        0 813A524C
8645415C:        0        0        0        0        0        0 FD0110DF
---- block116  ptr=856350C8  is_malloc=0  length=0x100 ----
85635088: 80C59A88 80C478D4 80C584F4 80C59C40        5 80C59D44 80C59908 80C3B104
856350A8: 87F3EFD4 80C583FC 80C598C8 80C599CC        0        3        1        0
856350C8:        3        0        0        0        0        0        0        0
856350E8:        6        0        0        0        0        0        0        0
85635108:        0        0        0        0        0        0        0        0
85635128:        0        0        0 80C5892C 80C58FBC 80C58E84        0        0
85635148:        0        0 80CA6058 80C58D70 80C58688        0 80C58420 80C1191C
85635168:        0 80C583D0        0 80C59434        0 80C58D3C        0 80C59740
85635188: 80C583D0 80C590A4        0        0        0 80CE20D8 88BA8188        0
856351A8:        0        0        0        0        0        0        0        0
---- block117  ptr=8434A5B0  is_malloc=0  length=0x100 ----
8434A570:  9A309A8  9A809B4  9B408FC  9671324 14281432 143C1446 1482148C 14B414BE
8434A590: 14C8157C 1644165D 16C10000 69665F64 6F743131 5F68616C 5F617468        0
8434A5B0: 444F5431 31204841 4C205375 62626C6F 636B0000 2E2E2F64 6F743131 742F745F
8434A5D0: 69665F64 6F743131 5F68616C 5F617468 2E630000  A20496E 74657266 61636520
8434A5F0: 25733A20 63686970 73657420 6E6F7420 696E2072 756E6E69 6E672073 74617465
8434A610:        0  A20496E 74657266 61636520 25733A20 4E6F2066 72656520 64657363
8434A630: 72697074 6F720000  A20496E 74657266 61636520 25733A20 4E6F2076 6C616E20
8434A650: 656E7472 7920666F 7220636C 69656E74 27732076 6C616E00  A20496E 74657266
8434A670: 61636520 25733A20 4E6F2066 72656520 6B657920 63616368 65000000  A20496E
8434A690: 74657266 61636520 25733A20 4E6F2066 72656520 64657363 72697074 6F722066
---- block118  ptr=8646B048  is_malloc=1  length=0x100 ----
8646B008: 839C1F98 82AB41A0 8646B048 8646AFB0 8000000E        1        0        1
8646B028: 85FB07EC        0        0        0        0        0        0 FD0110DF
8646B048: AB1234CD FFFE0000        0 839C1F98 83989988 8646B11C 8646B010 80000052
8646B068:        1        0        1 85FB07EC 8645F280        0        0        0
8646B088:        0        0        0        0        0        0        0        0
8646B0A8:        0        0        0        0        0        0        0        0
8646B0C8:        0        0        0        0        0        0        0        0
8646B0E8:        0        0        0        0        0        0        0        0
8646B108:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
8646B128: 839C1F98 82AA9A90 8646B1A0 8646B05C 8000002A        1        0        1
---- block119  ptr=8647128C  is_malloc=1  length=0x100 ----
8647124C:        0        0        0        0        0        0        0        0
8647126C:        0        0        0        0        0        0        0 FD0110DF
8647128C: AB1234CD FFFE0000        0 84330B38 80C27638 8647131C 86470E4C 80000030
864712AC:        1 82A47588        1 85FB07EC 8647134C 8AA7A9A0        0        0
864712CC: 8AA7A9A0        6        0 12D012D0        0        2        4        9
864712EC:        0    10000 85647630 646F7431 31647276 7220636C 69650000 86471318
8647130C: 86471318        0        0 FD0110DF AB1234CD FFFE0000        0 84330B4C
8647132C: 80C27660 864713AC 864712A0 80000030        1 82A47588        1 85FB07EC
8647134C: 864713DC        0        0        0        0        6        0   140014
8647136C:        0        0        0        0        0    10000 85647630 646F7431
---- block120  ptr=8785804C  is_malloc=1  length=0x464 ----
8785800C:        0        0        0        0        0        0 8787AD30        0
8785802C:        0        0        0        0        0        0        0 FD0110DF
8785804C: AB1234CD FFFE0000        0 845E13D8 81730D64 878584B0 878573C4 8000021A
8785806C:        1        0        1 85FB07EC 880ECB44 86D83B10 8787B72C 8787B9D0
8785808C:        1       93      101  1000000        0        0       11       11
878580AC:        0        0        0        0        0        0        0        0
878580CC:        0        0        0        0        0        0        0        0
878580EC:        0        0        0        0        0        0        0        0
8785810C:        0        0        0        0        0        0        0        0
8785812C:        0        0        0        0        0        0        0        0
8785814C:        0        0        0        0        0        0        0        0
8785816C:        0        0        0        0        0        0        0        0
8785818C:        0        0        0        0        0        0        0        0
878581AC:        0        0        0        0        0        0        0        0
878581CC:        0        0        0        0        0        0        0        0
878581EC:        0        0        0        0        0        0        0        0
8785820C:        0        0        0        0        0        0        0        0
8785822C:        0        0        0        0        0        0        0        0
8785824C:        0        0        0        0        0        0        0        0
8785826C:        0        0        0        0        0        0        0        0
8785828C:        0        0        0        0        0        0        0        0
878582AC:        0        0        0        0        0        0        0        0
878582CC:        0        0        0        0        0        0        0        0
878582EC:        0        0        0        0        0        0        0        0
8785830C:        0        0        0        0        0        0        0        0
8785832C:        0        0        0        0        0        0        0        0
8785834C:        0        0        0        0        0        0        0        0
8785836C:        0        0        0        0        0        0        0        0
8785838C:        0        0        0        0        0        0        0        0
878583AC:        0        0        0        0        0        0        0        0
878583CC:        0        0        0        0        0        0        0        0
878583EC:        0        0        0        0        0        0        0        0
8785840C:        0        0        0        0        0        0 878573E0 8787BA1C
8785842C: 8787BA1C    186A0        9        1   210048   200011        0        0
8785844C: FFFFFFFF 817300D4        0        1        0        0        0        F
8785846C:        0  1000000        E        0        0        0        0        0
8785848C:        0        0        0        0        0        0        0        0
878584AC: FD0110DF
---- block121  ptr=8889A21C  is_malloc=1  length=0xA00 ----
8889A1DC:        0        0        0        0        0        0        0        0
8889A1FC:        0        0        0        0   1D45B7 EB000000        0 FD0110DF
8889A21C: AB1234CD FFFE0000        0 83D97C78 813696CC 8889AEB8 8889A16C 80000636
8889A23C:        1        0        1 85FB07EC 88C58964      101        0        0
8889A25C:        0        0 8889AEE8       93        2 8010E980        3        0
8889A27C:        0  1000000        0        0        0 81AAA3D8 818422A4       18
8889A29C:        0        0        0        1      5EA        E        0        0
8889A2BC:      5EA        0        0        0       64       16       1F        E
8889A2DC:        0 FFFFFFFF FFFFFFFF FFFFFFFF        0        0        0        0
8889A2FC:        0        0        9        0        0        0 83E07538 839C71BC
8889A31C: 888AD344 888AD390        0        0        0        0        0        0
8889A33C:        0        0  5DC05DC        1      5F4      5F0 FFFFFFFF        0
8889A35C:        0   210048   200011        0        0 10000200        4        5
8889A37C:        0        5        0        0        0 2E82086C        0        0
8889A39C:        0        0        0     BDA4        0        0 858CF038 8889A24C
8889A3BC:        0        0    14242        0      7D0      7D0        0 84309E38
8889A3DC: 89F8D7C0        0        1        1        1        0        0        0
8889A3FC: 81368440  1010101 FF000009        0        0        0        0       10
8889A41C:        0        0        0        0        0        0        0        0
8889A43C:        0        0        0        0        0        0        0        0
8889A45C:        0        0        0        0        0        0        0        0
8889A47C:        0        0       28       28       28       28       28       28
8889A49C:       28       28       28       28       28       28       28       28
8889A4BC:       28       28       28        0        0        0       28        0
8889A4DC:        0        0       28        0        0        0       28        0
8889A4FC:        0        0       28        0        0        0       28        0
8889A51C:        0        0       28        0        0        0       28        0
8889A53C:        0        0       28        0        0        0       28        0
8889A55C:        0        0       28        0        0        0       28        0
8889A57C:        0        0       28        0        0        0       28        0
8889A59C:        0        0       28        0        0        0       28        0
8889A5BC:        0        0       28        0        0        0       28        0
8889A5DC: 8889A24C        0        0        0       4B        0       4B        0
8889A5FC:        0        0 8010EB0C 8010EC54        0        0 815E7F34 815E7628
8889A61C:        0 813A522C        0        0        0 8010EA14        0        0
8889A63C: 80341D0C 8031DEA8 8031E5DC        0        0 815E6780 8010E724 8010E8FC
8889A65C: 815EAE80 803393B8 815E6270        0 815E66B8        0        0        0
8889A67C:        0 8010E978        0        0 8010ED38 813A524C        0        0
8889A69C:        0 801E9F10        0        0 815E656C        0        0        0
8889A6BC:        0        0        0        0        0        0        0        0
8889A6DC:        0        0        0        0 FD5A1687       72        0        0
8889A6FC:  ACE79A2       1D        0        0      58D        0        1        0
8889A71C:    14D0C      5B4        0        0        0        0        0        0
8889A73C:        0        0        0        0        0        0        0    A6AA2
8889A75C:        0        0        0        0        0        0        0        0
8889A77C:        0        0        0        0        0        0        0        0
8889A79C:        0        0        0        0        0        0        0        0
8889A7BC:        0    A6AA2        0        0        0        0        0        0
8889A7DC:        0        0        0        0        0        0        0        0
8889A7FC:        0        1        0        0        0        2        0  320068B
8889A81C:  27347EF       64   1C9B15       32        0        0        0        0
8889A83C:        0        0        0        0        0        0        0 2E865124
8889A85C: 8889A91C 8889A968        0        0        0        0        0        0
8889A87C:        0        0 86144FA4        0        0        0        0        0
8889A89C:        0 88B7EA70        0        0        0        0        0        0
8889A8BC:        0        0        0        0        0        0        0        0
8889A8DC:        0        0        0        0        0        0        0        0
8889A8FC:        0        0        0        0        0        0        0        0
8889A91C:        0        0        0        0        0        0        0        0
8889A93C:        0        0        0        0        0        0        0        0
8889A95C:        0        0        0        0        0        0        0        0
8889A97C:        0        0        0        0        0    A64D4  31E78B1        0
8889A99C:        0        0        0        0        0        0        0        0
8889A9BC:        0        0        0 2E865124        0        0        0        0
8889A9DC:        0        0        0        0        0 8889B4B8 8889B5F4        0
8889A9FC:        0        0        0        0        0        0        0        0
8889AA1C:        0        0        0        0        0        0        0        0
8889AA3C:        0        0        0        0        0        0        0        0
8889AA5C:        0        0        0        0        0        0        0        0
8889AA7C:        0        0        0        0 8889B5F4        0        0 FFFFFFFF
8889AA9C:        0        0        0        0        0        0        0        0
8889AABC:        0        0        0        0        0        0        0        0
8889AADC:        0        0        0        0        0        0        0        0
8889AAFC:        0        0        0        0        0        0        0        0
8889AB1C: 858C7320 8889A24C        0        0    44246        0        0        0
8889AB3C:        0        0        0        0        0        0        0        0
8889AB5C:        0        0        0        0        0        0        0        0
8889AB7C:        0        0        0        0        0        0        0        0
8889AB9C:        0        0        0        0        0        0        0        0
8889ABBC:        0        0        0        0        0        0        0        0
8889ABDC:        0        0        0        0        0        0        0        0
8889ABFC:        0        0        0        0        0        0        0        0
---- block122  ptr=8787AD00  is_malloc=1  length=0x4DC ----
8787ACC0:        0        0        0        0        0        0        0        0
8787ACE0:        0        0        0        0        0        0        0 FD0110DF
8787AD00: AB1234CD FFFE0000        0 83D97C68 813696EC 8787B1DC 8787AA5C 80000256
8787AD20:        1        0        1 85FB07EC 8889AEE8 882DF644      5DC        0
8787AD40:  5DC0000        0        0 88899B7C 887BB560 40000001        0        0
8787AD60:        0        0        1        0        0        0        0        0
8787AD80:        0        0        0        0        0 878573E0        0        0
8787ADA0:       11        0        0        1        2        1 87878748 8787B678
8787ADC0:        0 89FABBEC        F 8787AD30        0        0        2    20000
8787ADE0:        0        0        0        0        0        0        0        A
8787AE00:        A    186A0    186A0        0        0        0        0 863FE12C
8787AE20:        0 8787BCA8 87858748        0        0        0        0        0
8787AE40:        0        0        0        0        0        0        0 88735700
8787AE60: 887357E4        0        0        0        0        0        0        0
8787AE80:        0        0        0        0        0        0 887357E4        0
8787AEA0:        0        0        0        0        0        6        0        0
8787AEC0:        0        0   DBBA00        0  1000000    10000        0        0
8787AEE0:        0        0        0        0        0        0 FFFFFFFF        0
8787AF00:        0        0        0        0        0        0        0        0
8787AF20:        0        0        0    10100        0        0 8787B798        0
8787AF40:        0        0        0        0        0        0        0        0
8787AF60:        0        0        0        0        0     72A4        0        0
8787AF80:        0        0        0        0        0        0        0        0
8787AFA0:        0      100  1000000        0      202  2808080        0        0
8787AFC0:        0        0        0        0        0        0        0        1
8787AFE0:        0        0        0        0        0        0        0        0
8787B000:        0        0        0        0 8787BC28     FFFF 42000000        0
8787B020:        0        0        0        0        0        0        0        0
8787B040:        0        0        0        0        0        0        0        0
8787B060:        0        0        0        0        0        0        0        0
8787B080:        0        0        0        0        0        0        0        0
8787B0A0:        0        0        0        0        0        0        0        0
8787B0C0:        0        0        0        0        0  2000000        0        0
8787B0E0:        0        0        0        0        0 85B0EFB0 85B0E460        0
8787B100:        0        0        0        0        4        0        0        0
8787B120:        0        0 89F645A0 8787B964        0        0        0        0
8787B140:        0        0        0        0        0        0        0        0
8787B160:        0        0        0        0        0        0        0        0
8787B180:        0        0        0        0        0        0        0        0
8787B1A0: 8787AD30        0        0        0        0    10000        0       4B
8787B1C0:    124F8        0        0        0        0        0 FD0110DF
---- block123  ptr=83E07538  is_malloc=0  length=0x100 ----
83E074F8: 45746865 726E6574 2043464D 20657272 6F72732C 20657665 6E74732C 20706163
83E07518: 6B657473 20000000 45746865 726E6574 2043464D 20686100 53657276 69636520
83E07538: 566C616E        0 45746865 726E6574 2043464D 20646961 676E6F73 74696320
83E07558: 6576656E 7420696E 666F726D 6174696F 6E000000 45746865 726E6574 2043464D
83E07578: 20646961 676E6F73 74696320 7061636B 65742069 6E666F72 6D617469 6F6E0000
83E07598: 6D69702D 6175746F 63726561 74650000 45746865 726E6574 2043464D 20646961
83E075B8: 676E6F73 74696320 4D495020 6175746F 20637265 61746520 696E666F 726D6174
83E075D8: 696F6E00 45746865 726E6574 2043464D 20646961 676E6F73 74696320 61697320
83E075F8: 696E666F 726D6174 696F6E00 45746865 726E6574 2043464D 20646961 676E6F73
83E07618: 74696320 6C636B20 696E666F 726D6174 696F6E00 45746865 726E6574 2043464D
---- block124  ptr=839C71BC  is_malloc=0  length=0x100 ----
839C717C:        0  A436F75 6C64206E 6F742067 6574206D 61737465 72206361 72640A00
839C719C:  A436172 64207479 7065203C 30782578 3E206973 206D6173 7465720A        0
839C71BC: 45746865 72535649        0 25632563 25640000 53564920 49444273        0
839C71DC: 45535749 4C505F4F 49444200 7376695F 65737769 6C705F72 65676973 74727900
839C71FC: 5356495F 45535749 4C500000 25733A20 4572726F 7220696E 73657274 696E6720
839C721C: 6D6F6475 6C650A00 66726564 646F5F65 73775F6D 72766C5F 726D6F6E 5F616464
839C723C: 5F646174 61736F75 72636500 66726564 646F5F65 73775F6D 72766C5F 726D6F6E
839C725C: 5F657468 65725F73 75627379 735F696E 69740000 839C73A0    1001C 839C7284
839C727C:        0        0        1 8562F864 66726564 646F5F65 73775F6D 72766C5F
839C729C: 726D6F6E 5F657468 65720000  A257328 293A2062 61642073 74617475 73206672
---- block125  ptr=86474404  is_malloc=1  length=0x100 ----
864743C4: 80000016        1        0        1 85FB07EC 86474434 8527DAF4       22
864743E4:    80000        0        0        0        0        0        0 FD0110DF
86474404: AB1234CD FFFE0000        0 839C1F98 81A459C0 86474464 864743BC 80000018
86474424:        1        0        1 85FB07EC        0        6 7379736C 6F670000
86474444:        0        0        0        0        0        0        0 FD0110DF
86474464: AB1234CD FFFE0000        0 839C1F98 816F6DB4 864744C4 86474418 80000018
86474484:        1        0        1 85FB07EC 864746B0 864D5DE4 8527C358        9
864744A4:  4000000        0     1760 FFFFFFFF FFFFFFFF FFFFFFFF        0 FD0110DF
864744C4: AB1234CD FFFE0000        0 839C1F98 816F6DB4 86474524 86474478 80000018
864744E4:        1        0        1 85FB07EC 86474604 864D4ABC 852727A8        A
---- block126  ptr=8527DAF4  is_malloc=0  length=0x100 ----
8527DAB4: 7D0A7D0A        0        7 C15C0515 C15C0515        1        0        0
8527DAD4: 845D127C        1        0        1 816F6CC8    30001      2C9 84170D98
8527DAF4:        0 816F692C 816F6A44 816F6C30        0        0        0        0
8527DB14:        0        0        0        0        0        0        0        0
8527DB34:        0        0        0        0 84B15C64        1 845CE2A4        2
8527DB54: 847EBEE8        7 845CE29C        0 845A3B38        3 84519524        6
8527DB74: 84009FA0        5 84587610        4        0 FFFFFFFF C15C0515 C15C0515
8527DB94:        1        0        0 845D12D0        1        0        1 816F6F80
8527DBB4:    30001      2CA 84170D98 864748B4 845BCFD8        0        8 46000000
8527DBD4:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF 8527DBEC 8527DBFC        0
---- block127  ptr=882580D8  is_malloc=1  length=0x100 ----
88258098:        0 88257C2C        0        0        0        0        0        0
882580B8:        0        0        0        0        0        0        0 FD0110DF
882580D8: AB1234CD FFFE0000        0 839C1F98 8031FF48 88258124 88257C10 8000000E
882580F8:        1        0        1 85FB07EC 446F302F 352F302E 31000000        0
88258118:        0        0 FD0110DF AB1234CD FFFE0000        0 839C1F98 8031FF98
88258138: 88258170 882580EC 8000000E        1        0        1 85FB07EC 446F7431
88258158: 31526164 696F302F 352F302E 31000000        0 FD0110DF AB1234CD FFFE0000
88258178:        0 8470C1FC 81D56CDC 882581DC 88258138 8000001E        1        0
88258198:        1 85FB07EC        0        2        0        0        0        0
882581B8:        0        0        0        0     FFFF        0        0        0
---- block128  ptr=882DF614  is_malloc=1  length=0x4DC ----
882DF5D4: 8440AA6C 80F4745C 882DF614 882DF564 8000000E        1        0        1
882DF5F4: 85FB07EC        0  1000CCC CCCD0000       41        4        0 FD0110DF
882DF614: AB1234CD FFFE0000       9D 83D97C68 813696EC 882DFAF0 882DF5DC 80000256
882DF634:        1        0        1 85FB07EC 8787AD30 88257C2C      5DC        0
882DF654:  5DC0000        0        0        0 888AD408        1        0        0
882DF674:        0        0        1        0        0        0        0        0
882DF694:        0        0        0        0        0 864731C8        0 88257C94
882DF6B4:       15       64        0        1        2        1 882DF580 882DF534
882DF6D4:        0        0        0 882DF644        0        0       20    20000
882DF6F4:        0        0        0        0        0        0        0       64
882DF714:       64     D2F0     D2F0        0        0        0        0        0
882DF734:        0 88400A4C 8A467658        0        0        0        0        0
882DF754:        0        0        0        0        0        0        0        0
882DF774:        0        0        0        0        0        0        0 87489268
882DF794:        0        0        0        0        0        0 8A467658        0
882DF7B4:        0        0        0        0        0        0        0        0
882DF7D4:        0        0   DBBA00        0  1000000    10000        0        0
882DF7F4:        0        0        0        0        0        0 FFFFFFFF        0
882DF814:        0        0        0        0        0        0        0        0
882DF834:        0        0        0    10100        0        0 882DEBBC        0
882DF854:        0        0        0        0        0        0        0        0
882DF874:        0        0        0        0        0     94D8        0        0
882DF894:        0        0        0        0        0        0        0        0
882DF8B4:        0      100  1000000        0      202  2808080        0        0
882DF8D4:        0        0        0        0        0        0        0        1
882DF8F4:        0        0        0        0        0        0        0        0
882DF914:        0        0        0        0 882DFB6C     FFFF 42000000        0
882DF934:        0        0        0        0        0        0        0        0
882DF954:        0        0        0        0        0        0        0        0
882DF974:        0        0        0        0        0        0        0        0
882DF994:        0        0        0        0        0        0        0        0
882DF9B4:        0        0        0        0        0        0        0        0
882DF9D4:        0        0        0        0        0  2000000        0        0
882DF9F4:        0        0        0        0        0 85B0EFB0 85B0E460 89F8B998
882DFA14: 89F8B998        1        0        0        0        0        0        0
882DFA34:        0        0 89F64554 888AD4FC        0        0        0        0
882DFA54:        0        0        0        0        0        0        0        0
882DFA74:        0        0        0        0        0        0        0        0
882DFA94:        0        0        0        0        0        0        0        0
882DFAB4: 882DF644        0        0        0        0        0        0        0
882DFAD4:        0        0        0        0        0        0 FD0110DF
---- block129  ptr=882317A4  is_malloc=1  length=0x434 ----
88231764: 8440BDAC 80F4F690 882317A4 882315E8 8000000E        1        0        1
88231784: 85FB07EC 888ADB60 88257C2C 8440BBBC 88231604    18014        0 FD0110DF
882317A4: AB1234CD FFFE0000        0 8440AA60 80F47230 88231BD8 8823176C 80000202
882317C4:        1        0        1 85FB07EC 882DF4E8        0        0        0
882317E4:        0        0        0        0        0        0        0        0
88231804:        0        0        0        0        0        0        0        0
88231824:        0        0        0        0        0        0        0        0
88231844:        0        0        0        0        0        0        0        0
88231864:        0        0        0        0        0        0 88231C08        0
88231884:        0        0        0        0        0        0        0        0
882318A4:        0        0        0        0        0        0        0        0
882318C4:        0        0        0        0        0        0        0        0
882318E4:        0 8855B66C        0        0        0        0        0        0
88231904:        0        0        0 89E8A438        0        0        0        0
88231924:        0        0        0        0        0        0        0        0
88231944:        0        0        0        0        0        0        0        0
88231964:        0        0        0        0        0 887B9C4C        0        0
88231984:        0        0        0        0        0        0        0        0
882319A4:        0        0 887A5284        0        0        0        0        0
882319C4:        0        0        0        0        0        0        0        0
882319E4:        0        0        0        0        0        0        0        0
88231A04:        0        0        0        0        0        0        0        0
88231A24:        0        0 86A1AC68        0        0        0        0        0
88231A44:        0        0        0        0        0        0        0        0
88231A64:        0        0        0        0        0        0        0        0
88231A84:        0        0        0        0        0        0        0        0
88231AA4:        0        0        0        0        0        0        0        0
88231AC4:        0        0        0        0 87A79EF4 882DF5F8 88231C54        0
88231AE4:        0        0        0        0        0        0        0        0
88231B04:        0        0        0        0        0        0        0        0
88231B24:        0        0        0        0        0        0        0        0
88231B44:        0        0        0        0        0        0        0        0
88231B64:        0        0        0        0        0        0        0        0
88231B84:        0        0        0        0        0        0        0        0
88231BA4:        0        0        0        0        0        0        0        0
88231BC4:        0        0        0        0 FD0110DF
---- block130  ptr=88849BA0  is_malloc=1  length=0x100 ----
88849B60: 80C49034 88849BA0 88849A40 80000010        1        0        1 85FB07EC
88849B80: DD180050 F2010100   50F204  1000050 F2040100   50F202 28000000 FD0110DF
88849BA0: AB1234CD FFFE0000        0 83D97CBC 8032006C 88849C94 88849B64 80000062
88849BC0:        1        0        1 85FB07EC        1        0        0        0
88849BE0:    10000        0        0        0        1        0        0        0
88849C00:        0        0        0        1        0    10000        0        0
88849C20:        0        0        0        0        0        0        0        0
88849C40:        0        0        0        0        0        0        0        0
88849C60:        0        0        0        0        0        0        0        0
88849C80:        0        0        0        0 FD0110DF AB1234CD FFFE0000        0
---- block131  ptr=888A8624  is_malloc=1  length=0x100 ----
888A85E4:        0        0        0        0        0   210000 85647630 2E31515B
888A8604: 41727261 79204865 61640000 888A8620 888A8620        0        0 FD0110DF
888A8624: AB1234CD FFFE0000        0 839C1F98 82AF2D04 888A86C0 888A85A8 80000036
888A8644:        1        0        1 85FB07EC    10000        1        0        0
888A8664:        0        0        0        0     9209        0        0        0
888A8684:        0        0        0     32D3       80        0        0    A5EB8
888A86A4:        0        0        0        0        0        0 FD0110DF AB1234CD
888A86C4: FFFE0000        0 839C1F98 82AFCB68 888A8740 888A8638 80000028        1
888A86E4:        0        1 85FB07EC 88736258        1        C       1C        0
888A8704:        0        0        0        0        0        0        0        0
========= Scheduler History Dump ======================
PID Exectime(ms) Caller PC Process Name
  67         396 0x0        Dot11 driver
253     3266440 0x80861EB4 Skinny MOH Server
163        6012 0x82475784 HQF Shaper Background
106        8956 0x81A78054 IPAM Manager
  86       27536 0x8047C2A4 Ethernet Msec Timer CFM
  67       16360 0x80C15FC8 Dot11 driver
  86       13768 0x8047C2A4 Ethernet Msec Timer CFM
171       17336 0x82ADF3DC PPP Events
  65       16000 0x82257570 PPP manager
  61      293872 0x8009BB6C COLLECT STAT COUNTERS
119      454264 0x807FC6B0 Skinny Msg Server
  48        1044 0x80CDF7C8 Radio LED Process
  57        1020 0x80672208 Netclock Background Proccess
123         996 0x8287D594 SSS Feature Timer
280         136 0x80FE3290 TRP_PSEUDOTIMER
  99       69480 0x81258AEC CDP Protocol
  60     5394928 0x800A7DE8 ILPM
Dumping Managed Timer Operation history [Next Entry(4)]
Index IPL Caller_pc   Timer      Operation
0     0   0x81EA5288  0x86C9F748 Managed Timer Initialized
1     0   0x81EA52A0  0x86C9F768 Managed Timer Initialized
2     0   0x81EA52B8  0x86C9F788 Managed Timer Initialized
3     0   0x81EA52D0  0x86C9F7A8 Managed Timer Initialized
4     0   0x0  0x0 Empty Buffer
5     0   0x0  0x0 Empty Buffer
6     0   0x0  0x0 Empty Buffer
7     0   0x0  0x0 Empty Buffer
8     0   0x0  0x0 Empty Buffer
9     0   0x0  0x0 Empty Buffer
10    0   0x0  0x0 Empty Buffer
11    0   0x0  0x0 Empty Buffer
12    0   0x0  0x0 Empty Buffer
13    0   0x0  0x0 Empty Buffer
14    0   0x0  0x0 Empty Buffer
15    0   0x0  0x0 Empty Buffer
16    0   0x0  0x0 Empty Buffer
17    0   0x0  0x0 Empty Buffer
18    0   0x0  0x0 Empty Buffer
19    0   0x0  0x0 Empty Buffer
20    0   0x0  0x0 Empty Buffer
21    0   0x0  0x0 Empty Buffer
22    0   0x0  0x0 Empty Buffer
23    0   0x0  0x0 Empty Buffer
24    0   0x0  0x0 Empty Buffer
========= Data Inconsistency Errors =========
No data inconsistency errors have been recorded.
========= End of Crashinfo Collection ================
------------------ show chunk failures ------------------
Hi Paul,
Please open a TAC case and provide them the crashinfo files.  This may be related to CSCtt94391.
Brandon
thomas wing
im having the same issues with a 877W running advipservicesk9-mz.151-4.M3 the router will hang and restart.
the crashinfo file also has the same telltale line: " ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1818 " righte before software forced reload.
iv tried another 877W with the same IOS and have the same outcome, so its not a hardware fault.
iv noticed this problem though with earlier IOS's of the 15.1M Chain and not just with the later 4.M3
the reference from brandon CSCtt94391 i cannot find anywhere, could you provide a link please?
Tom
I wasn't able to dig up that bug either.
However, it looks like that that error that the problem is with the WIFI.
Without the details of the bug its hard to say what the fix is -- but if I were you I would try turning off the WIFI and see if that fixes your problem as a temporary solution.
Hi Thomas,
You should be able to see CSCtt94391 in the Bug Toolkit.  Is it not showing up for you?  Hmm, I don't see anything that would indicate it wouldn't be publically viewable.
Currently, that bug is still Open and root cause is being investigated, which is why I have suggested to open a case.  It is related to the wireless, as you suspected.  Please open a case if you are seeing this.
Brandon
thomas wing
Hi Daniel
iv tried with the wireless off for the last couple of months on one 877W and its been stable, but wireless is really required in my deployment.
i know the error is related to the atheros wireless module, but id like to know if cisco have a bug or TAC incident is already open for this fault, as it would appear to affect ISR's of the same era with the same atheros card running 15.1M*
and if this will be fixed soon in a later 15.1M release.
Tom
iv also done some trials with 15.0-1M7 on the 877w and this is still flaky, im now reverting back to 12.4-24T2 to see if this resolves the issue
Hi Paul, Daniel, and Thomas,
It defintely looks like you are hitting CSCtt94391. If the details on this bug weren't able to be found here they are. You should be able to access them now, however.
CSCtt94391 - "../dot11t/t_if_dot11_hal_ath.c" "HAL_Ath_receive_packet" crash
Symptom:
Unit crash/reboot with error message "../dot11t/t_if_dot11_hal_ath.c"
Conditions:
This has been seen on a Cisco Router with a 802.11 radio installed. The crash is triggered by the use of Apple iphone/ipad iOS 5 connecting to the router's radio.
Workaround:
None at this time.
1st Found-in:
12.4(22)T3, 12.4(24)T5, 15.1(2)T4
Installing an earlier release of code is something to consider, and probably a good idea if this bug is causing your router to reload.
I suggest also saving the bug on the from your cisco cco bug search, and requesting email alerts so you can be notified of any new releases of code or workarounds.
************** Tristan Manduley Cisco TAC
kyle woodhouse
Hi Guys,
I ran into this bug last night too.  Seems like it's pretty wide spread as my software is different than others listed here.  Might have something to do with the iPhone iOS and the wifi drivers because i was taking quite a few interface errors on the dot11radio0 interface (this might just be me).  I was able to replicate the issues every time I did a facetime session with someone.
It definantly looks like bug CSCtt94391 but if anyone finds a software version that fixes the issue or has a workaround (other then not using wifi) please update.  Thanks all!
Issue:
Apple iPhone 4S, IOS 5, connected to CISCO871W on 2.4Ghz radio.  Creating a facetime session with someone works fine for intermitant amount of time, but eventually the router will lock up display the "
ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1818" error and then reload the router.
Software:
CISCO871W#show ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
CISCO871W uptime is 36 minutes
System image file is "flash:c870-advipservicesk9-mz.151-4.M.bin"
Last reload reason: Unknown reason
Errors on console:
*Mar  1 02:53:05.173: ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1818
*Mar  1 02:53:05.177: ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1818
*Mar  1 02:53:05.241: ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 2582
*Mar  1 02:53:05.241: ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1818
*Mar  1 02:53:05.241: ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1817
%Software-forced reload
*Mar  1 02:53:05.289: ASSERTION FAILED: file "../dot11t/t_if_dot11_hal_ath.c", line 1817
20:53:05 PCTime Thu Feb 28 2002: Unexpected exception to CPU: vector 700, PC = 0x80391C18, LR = 0x80391BB0
-Traceback= 0x80391C18z 0x80391BB0z 0x8041B90Cz 0x8040FA40z 0x80393DF8z 0x8037A04Cz
CPU Register Context:
MSR = 0x00029032  CR  = 0x24248082  CTR = 0x00000000  XER   = 0x00000000
R0  = 0x80391BB0  R1  = 0x84F36280  R2  = 0xFFF4FFF4  R3    = 0x83EFE5B8
R4  = 0x00000000  R5  = 0x00000000  R6  = 0x00000000  R7    = 0x00000001
R8  = 0x00000000  R9  = 0x83E50000  R10 = 0x83E50000  R11   = 0x00000000
R12 = 0x28248028  R13 = 0x8FFFFF30  R14 = 0x00000000  R15   = 0x84F9BFDE
R16 = 0x83E60000  R17 = 0x84FA9864  R18 = 0x0E8D0B26  R19   = 0x00000000
R20 = 0x84F36310  R21 = 0x84FB0B6C  R22 = 0x84FB0A28  R23   = 0x84F363A0
R24 = 0x84FB0B6C  R25 = 0x84F36310  R26 = 0x84F39090  R27   = 0x00000000
R28 = 0x00000000  R29 = 0x0E8D0B42  R30 = 0x83900000  R31   = 0x00000000
TEXT_START : 0x8002007C
DATA_START : 0x82D92A44
=== Start of Crashinfo Collection (20:53:05 PCTime Thu Feb 28 2002) ===
For image:
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 24-Mar-11 20:29 by prod_rel_team
Show int dot11radio 0 counters:
  Last clearing of "show interface" counters 00:09:34
     293 input errors, 884 CRC, 0 frame, 0 overrun, 0 ignored
     44620 packets output, 9905916 bytes, 0 underruns
