3745 with E1 connection problem
raju
We have 3745 Router with E1 interface, configured for dial-in service with Toll free Number . What happens, user gets connected when dials through Tollfree Number and works fine. As per Telco ,the connection gets locked even after user disconnects the dial-in connection. In this case, after 30th connection, all the channels in E1 line gets locked and 31st user can't dial-in and he/she gets busy tone when dials .In this case , either I have to restart the E1 controller or call the Telco to unlock all the channels in E1 . Telco claims that this is something to do with Router configuration only as it does not release the connection after user disconnects the connection. I'm posting the configuration of RAS server which shows E1 controller configuration and Async configuration.
sh run
Building configuration...
Current configuration : 2458 bytes
version 12.3
service password-encryption
hostname RAS-SERVER
boot-start-marker
boot-end-marker
card type e1 1
enable secret xxxx
modem country mica e1-default
aaa new-model
aaa authentication login default group tacacs+ local enable
aaa authentication login notac enable
aaa authentication ppp default group tacacs+
aaa authorization exec default none
aaa authorization network default group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
ip subnet-zero
ip domain name xxxxxx
no ftp-server write-enable
isdn voice-call-failure 0
chat-script offhook "" "ATH1" OK
controller E1 1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
unused-abcd 0 0 0 1
country saudiarabia
debounce-time 20
release-guard-time 250
dnis-complete
answer-guard-time 300
ani-define 8003031111
interface FastEthernet0/0
ip address x.x.x.x
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Group-Async0
ip unnumbered FastEthernet0/0
encapsulation ppp
ip tcp header-compression
no ip mroute-cache
async mode interactive
peer default ip address pool dial-in
ppp authentication pap
group-range 129 158
line 129 158
session-timeout 500
absolute-timeout 500
modem Dialin
transport input all
autoselect ppp
line aux 0
line vty 0 4
exec-timeout 200 0
password xxx
end
tepatel
We need to see the following debugs for a incoming call starting from receipt of the call at 3745 till user disconnect the call.
debug modem csm
debug modem
debug cas
Make sure to disconnect the call after 1 mins of normal operation after connection.
