12-18-2012 11:28 AM - edited 02-21-2020 06:34 PM
I have been configureating AnyConnect (SSL VPN) on my cisco 1841 router running Version 12.4(13r)T.
It is working great on windows pc, but when i try to connect from a Mac then I get a bug, I have read on the internet that it is because I need to install a package on my router for osx.
Okay so far so good, then if i try to install a osx package via cli then i get this error:
R1(config)#webvpn install svc flash:/anyconnect-macosx-i386-2.5.0217-k9.pkg sequence 2
SSLVPN Package SSL-VPN-Client (seq:2): installed Error: Invalid Archive
and after that the file is deleted from the flash !?
I don´t know if I am using the right .pkg fil or ?
any one who have an idea to what to do ?
Best Regards
Benjamin
12-18-2012 12:36 PM
I think I found out why, my router is only having 119808 kb of memory and when it is running, then there is only 8 mb back
I think that is the problem, because when I try to install a new packaged the router is loading it in to the ram and also saving it on the flash, and I think it is that there is the problem.
pls correct me if I am wrong
11-26-2018 12:20 AM
I know this is an old post but thanks for the information provided I was able to fix the same issue on my router that was running out of memory while installing the SSL VPN Package.
Thank you.
