PRI to BRI connection between h.o and remote branch
Dear all,
in my H.O i have a 2801 with VWIC2-1MFT E1/T1 and i have an E1 leased connection which is 2.048Mb, and at the branch side
i have 1841 and ISDN BRI card and my ISDN BRI connection is ready at remote branch
i need to connect between these 2 offices, can anybody give a sample configuration, i will be connecting 10 remote offices in future.
i will rate all the posts.
regards
BInoy
JamesLuther
Level 3
Level 3
Please find an attached example config for a central site where
10.0.0.0/24 is the central site
10.0.1.0/24 is site 1
10.0.2.0/24 is site 2
The transits between the sites are 10.99.99.x/30
The ISDN config is for a UK E1 PRI.
Not sure if this exactly what you need but I hope it helps
hi james,
thank you for your reply.
i have couple of doubts.as i have explained in my first post, i have a leased line which is E1 and for sure i can channelize it. suppose site 1 using BRI so the site 1 router need to dial into my H.Q correct me if i'm wrong?
as it is a leased line at H.Q i will not be getting seperate no's for PRI channels. i'm really confused it will be great if you can provie your views.
