Problem in ISDN
ajaykumar2k1
I'm using WIC-1B-U-V2 on 1841 router configured for ISDN .Although ISDN line is o.k we are not able to connect through ISDN we are getting following error when doing debug .
Can u help me what may be the issue
g the remaining 1 calls
*Sep 4 08:28:30.406: ISDN BR0/1/0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x8003
*Sep 4 08:28:31.174: ISDN BR0/1/0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x8004
*Sep 4 08:28:52.402: ISDN BR0/1/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8003, event 0x5 ces 1
*Sep 4 08:28:53.174: ISDN BR0/1/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8004, event 0x5 ces 1
regards
Ajay Kumar
14 Replies 14
rajinikanth
Level 3
Level 3
Can you provide ur isdn config
Ajay
In my experience the kind of error messages that you post are sometimes related to physical layer issues. Can you post the output of show isdn status, and of show interface?
Rick
Rick
Dear Rick
Below is output of sh isdn sta & Sh bri0/1/0
Although Layer is deactivated but as service Provider is checking on ISDN Phone its working fine.
RouterA#sh int bri0/1/0
BRI0/1/0 is up, line protocol is up (spoofing)
Hardware is GT96K BRI (3086)
Description: = = = = ISDN Backup Dialout to Delhi Prirouter = = = =
Internet address is 172.16.0.86/30
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 13:14:45
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 carrier transitions
RouterA#sh isdn sta
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Configuration For BRI
interface BRI0/1/0
description = = = = ISDN Backup Dialout
ip address 172.16.0.86 255.255.255.252
ip pim dense-mode
encapsulation ppp
dialer string XXXXXXXXXX
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
ppp authentication chap
ppp multilink
end
Ajay
I do not understand your statement:
The output of show isdn status does seem to confirm that at least at this point that there is a problem with the ISDN that keeps it from working. When that problem is resolved let us know how things are working.
Rick
Rick
Dear Rick
I mean to say ISDN service provider is telling his isdn line is o.k he proves this by calling through ISDN phone which works perfectly.
Ajay Kumar
Hi AJAY
I had faced the similar problem ....were on ISP side switch we gave layer 3 hold command .
At the 1st exchange from the branch office ,they changed the card of the dlc .
Before that they proved with isdn phone that line was fine.....in turn we proved by replacing the router....
After this two changes we didn't had any problem.so try with this..before this ensure ur equipments are fine.
S.Mahesvaran
interface BRI0/1/0
ip pim dense-mode
encapsulation ppp
dialer-group 1
ppp multilink
end
Please try to capture the "debug isdn q921" & "debug isdn q931" then post it here for more info. Thx.
Given the results of show isdn status:
RouterA#sh isdn sta
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
debug isdn q921 or debug isdn q931 are predictable and will show that there is no activity.
The provider may say that the ISDN line is fine and may prove it by using an ISDN phone, but something is seriously not working for the router connection. Can Ajay check the physical connection and verify that the interface of the router is connected properly to the correct place for the ISDN line?
Rick
Rick
Did you carry a very simple step .... to swap the phone cable ? And checked the pin assignment of the cable is correct ?
The way for the provider to prove it work, I suggest to ask the provider to bring a router to your office and plug to ISDN.
Or do you have another router for the test ?
Dear ajaykumar,
Even I am facing same problem on my network setup. When we expect ISDN will come to help us out as a backup to serial line, ISDN refuses to work by giving this error on console.
Please let me also know if you could resolve the problem
Subodh Bapat
you might want to try and add the following to both your dialer strings, there is a possibility that the ISDN switch only supports 56K speeds...
dialer string XXXXXXXX class Speed56
map-class dialer Speed56
dialer isdn speed 56
GNT
Dear Ajay,
which IOS you are using for 1841.
Rgds,
Hardik..
