Strange issue with Anyconnect on 9.0.3 with Radius based authentication.
manish arora
Level 6
Level 6
Hi everyone
Just saw a very strange issue with Anyconnect on 9.0.3 with radius authentication with Class 25 Attribute. I have webvpn|Anyconnect  configured on 5510 running 9.0.3, the authentication is done using a FreeRadius server with class 25 attributes being passed on for group assignment.
The user is able to authenticate & group-policy is being assigned as per the Class attribute but for some reason only members of one Group have access to the resources ones connected using anyconnect  rest of the users are authenticated, group-policy assigned but have no access at all and whats strange is that all users have access according to group-policy for webvpn.
I have not cleared the tunnel-group or rebooted the device since it's been moved to Freeradius with Class Attributes from the static group assignment. Here's the configuration :
webvpn
 enable outside
 enable backup
 enable inside
 anyconnect image disk0:/anyconnect-win-3.1.05170-k9.pkg 1
 anyconnect image disk0:/anyconnect-macosx-i386-3.1.05170-k9.pkg 2
 anyconnect image disk0:/anyconnect-linux-64-3.1.05170-k9.pkg 3
 anyconnect enable
 tunnel-group-list enable
group-policy SSL_1 internal
group-policy SSL_1 attributes
 dns-server value 10.100.100.100
 vpn-filter value SSL_1-FILTER
 vpn-tunnel-protocol ssl-client ssl-clientless
 split-tunnel-policy tunnelall
 address-pools value SSL_1
 webvpn
  anyconnect keep-installer installed
group-policy SSL_2 internal
group-policy SSL_2 attributes
 vpn-filter value SSL_2-FILTER
 address-pools value SSL_2
 webvpn
tunnel-group VPN-SSL type remote-access
tunnel-group VPN-SSL general-attributes
 authentication-server-group 2FA_GRP_LDAP LOCAL
 authorization-server-group 2FA_GRP_LDAP
 default-group-policy SSL_2
tunnel-group VPN-SSL webvpn-attributes
 radius-reject-message
 group-alias VPN-SSL enable
Please let me know if you have seen this before.
Manish
manish arora
Level 6
Level 6
anyone ?
Fixed - Thanks to TAC ( Mr. Luis) :-)
"sh vpn-sessiondb detail anyconnect" is your friend.
If you have multiple policies and your assigned policy is missing some parameters, the firewall will pull them from default policy and use them.
Hi Manish ,
I am trying to get a similar thing working. Can you explain how you configured free radius class25 , where is it etc ?
Craig
are you looking for the ASA side or FR side ?
Manish
