VPN connection
j.rounkles
Community Member
At home I have a Pix 501. At work we use a VPN 3000. Everyone else can connect and work from home except the users who have a Pix (such as myself). The VPN client connects (or atleasts says it does) however I cannot use any terminal service (ie Remote Desktop Connection). We use this on several servers at work. I obtain all the Network settings from our DHCP server at work (IP, Gateway, DNS, etc.). What am I missing in the Pix that is keeping my from browsing the network? TIA for any help.
12 Replies 12
aacole
Level 9
Level 9
When you connect into your network from home are you using a PC with a VPN client or are you using a pix to concentrator VPN?
Using the Cisco VPN Client (ver. 4.6.03.0021).
johnd2310
Level 11
Level 11
what is your config?
I have the following config and remote desktop works fine:
-Internet-827(NAT overload)-PIX(NAT0)-PC(vpn client)
**Please rate posts you find helpful**
Here is a copy of my config...if you see something I should have that is missing please advise...
I apologize for my ignorance but please be specific on what I am missing and what I should add.
try this command:
isakmp nat-traversal
added lines and still not able to connect through RDP connection. (Trying to connect using IP address and not machine name.)
quick question on your config. what is the ipsec config for? Are you using it to connect to another vpn device or is it to allow vpn into your home network?
try the following:
disable the ipsec stuff on the pix.
set your vpn client to connect using ipsec over tcp
port is usually 10000. check that the office vpn
concentrator is configured to support ipsec over tcp
port 10000
Still no go...it doesn't seem that I am decrypting any packets on my end at home nor am I establishing any routes...see attachment screen capture
try capture command on the pix to see what traffic is going through.
used any prsonal firewall on the pc?
is there any device between pix and internet? have you tried connecting pc directly, bypassing pix?
I have the Win XP firewall disabled, Internet comes through my wireless antenna which has Pix's MAC address tied to it. If I want to test by going around Pix then I have to call ISP and have them enter another MAC address. All other users that are not using a Cisco PIX are able to access the Terminal Servers via VPN connection. We are all using the same VPN Client version.
having a look at the posted config.
the crypto map is matching acl 101, but acl 101 is missing. would you plesse re-post the config?
: Written by enable_15 at 12:23:45.258 CDT Tue Jul 12 2005
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname jakepix
domain-name cmuonline.net
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 172.30.5.5 Server
access-list 101 permit ip 172.30.5.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list outside-in permit tcp any interface outside eq ftp
pager lines 24
logging on
logging host inside Server
mtu outside 1500
mtu inside 1500
ip address outside xx.xx.xxx.xx 255.255.255.192
ip address inside 172.30.5.x 255.255.255.0
ip verify reverse-path interface outside
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 10.1.1.1-10.1.1.254
pdm location 172.30.5.0 255.255.255.255 inside
pdm location Server 255.255.255.255 inside
pdm location 172.30.6.0 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface ftp Server ftp netmask 255.255.255.255 0 0
access-group outside-in in interface outside
route outside 0.0.0.0 0.0.0.0 xx.xx.xxx.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 172.30.5.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 172.30.5.xx c:
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set aptset esp-3des esp-md5-hmac
crypto map aptmap 10 ipsec-isakmp
crypto map aptmap 10 match address 101
crypto map aptmap 10 set peer (work's ip address)
crypto map aptmap 10 set transform-set aptset
crypto map aptmap interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
telnet 172.30.5.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 3
terminal width 80
Cryptochecksum:xxxx
