Kernel Panic when installing vWSA in Hyper-V
fw_mon
Level 4
Level 4
Windows 11 with Hyper-V Manager v 10
my steps:
  • download coeus-15-2-0-164-S100V.vhdx.tgz Hypervisor Image from Virtuelle Cisco Secure Web Appliance - Cisco
  • extract a vhdx image from the tgz archive
  • hyper-v manager > New virtual machine
  • 3 CPU cores, 8 GB Ram according to the documentation
  • short after start I get a kernel panic message and the VM restarts.
does anybody else have this issue?
amojarra
Hello @fw_mon
Sorry for the late Reply
I was able to install and launch WSA 15.2.0-164 on Hyper-V in Windows 11
Generation 2
coeus-15-2-0-164-S100V-disk-0.vhdx
The Secure Boot should be Off
if I turn on the Secure Boot I get this Error:
Here is my Windows version:
I tried with Windows 10 - 2019 and 2022 and they were all OK with the same WSA Image.
Amirhossein Mojarrad
++++     If you find this answer helpful, please rate it as such    ++++
13 Replies 13
balaji.bandi
the reqs are met, Win 11 with Hyper-V v 10, vWSA 15.2
amojarra
@fw_mon
can you please confirm the secure boot is disabled + you are using Gen 2 ?
@amojarra I use generation 1
fw_mon
Level 4
Level 4
Can someone with Hyper-V available try to start a Hyper-V image here Software Download - Cisco Systems ? You don’t even need a license - the kernel panic appears within the first few seconds of the initial attempt to start an image.
thank you
amojarra
Thank you @fw_mon
I've tried with Hyper-V server 2019 and 2022 versions 14.5.1-008 and 14.5.1-016 last week with Gen2 VM they were OK, I will try to check 15.2 as well if my LAB is still up.
meanwhile may I ask to please share the Kernel panic Error ?
Hi @amojarra
screenshots are attached. The VM starts only when configured as a Generation 1 VM. With Generation 2 I got another error (also attached).
I got this when configured Generation 2 (just wanted to test after you mentioned that Gen2 works for you):
the order of screenshot reversed (read them from the bottom up).
hyperv_vwsa_6.pnghyperv_vwsa_5.pnghyperv_vwsa_4.pnghyperv_vwsa_3.pnghyperv_vwsa_2.pnghyperv_vwsa_1.png
fw_mon
Level 4
Level 4
any feedback?
would opening a support ticket be a better option? I open a case if somebody confirms that it doesn't work.
Cristian Matei
   I've done this in the past without any issue; please carefully follow guidelines and understand requirements for installation; also, starting AsyncOS 15.x, only generation 2 is supported: https://www.cisco.com/c/dam/en/us/td/docs/security/content_security/virtual_appliances/Cisco_Content_Security_Virtual_Appliance_Install_Guide.pdf
Best,
Cristian.
thanks Cristian, I got an error "no operation system was loaded" (see screenshot above in the thread) if I used generation 2.
  I understand that; message means you may have not correctly followed installation instructions and requirements; provide link, can you first read document E2E and start over?
Best,
Cristian.
amojarra
Hello @fw_mon
Generation 2
fw_mon
Level 4
Level 4
many thanks @Cristian Matei and especially @amojarra !
following Amirhossein's screenshot I was able to get it running on hyper-v.
