Showing results forĀ
Search instead forĀ
Did you mean:Ā
LetsEncrypt ACME timeout problem
falke
Frequent Visitor
Frequent Visitor
system is a FPR-1010 with ASA-SW 9.23(1)13.
When enrolling LetsEncrypt certificates with ACME I noticed a strange timeout problem.
Without "alt-fqdn" entries, everything works fine!
crypto ca trustpoint LetsEncrypt_Trustpoint
 enrollment interface outside
 enrollment protocol acme authentication http01 outside
 enrollment protocol acme url https://acme-v02.api.letsencrypt.org:443/directory
 fqdn asa.domain1
 subject-name CN=asa.domain1
 keypair ecdsa elliptic-curve 384
 auto-enroll regenerate
 no ca-check
 crl configure
With "alt-fqdn" entries, there is always a timeout, because it takes longer than 20 seconds to get a response for all "alt-fqdn"s.
 fqdn asa.domain1
 alt-fqdn asa.domain1
 alt-fqdn asa.domain2
 alt-fqdn asa.domain3
 no ca-check
 crl configure
The ACME-log as attachment shows the timeout. 20 seconds are obviously too short for three domains.
Any recommendations besides using separate certificates for each domain?
11 Replies 11
fqdn asa.domain1
But as I know fqdn is main domain
Alt-fqdn is sub-domain' I see you use sub-domain and domain is same ?
MHM
Thank you for your reply. Sub-domain is always "asa.", the domain name is different.
This should be a common task as RFC 5280 defines "Subject Alternative Names" (=alt-fqdn) to be expressed in the same manner as any other subject distinguished name.
So DNS can resolve asa.domain2?
Show logging
Did you see any log about dns can not resolve name?
MHM
Yes, all three real host-names can be resolved.
ciscoasa(config)# ping asa.domain1
Sending 5, 100-byte ICMP Echos to x.x.x.x, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
ciscoasa(config)# ping asa.domain2
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ciscoasa(config)# ping asa.domain3
The log attached to the first post shows, that the exit code is 124:
ACME client exit code: 124
Which means according to Cisco documentation:
124
ACME processing timeout
Every time exactly after 20 seconds (=timeout, see log attached to first post) enrollment is canceled.
debug crypto ca messages
debug crypto ca transactions
Run these two debug when you use only primary fqdn and when you use alt-fqdn
Let check in which step the enrollment is stop
MHM
ciscoasa(config)# debug crypto ca messages
ERROR: % Invalid input detected at '^' marker.
ciscoasa(config)# debug crypto ca transactions
ciscoasa(config)# debug crypto ca ?
exec mode commands/options:
  <1-14>                   Specify an optional debug level (default is 1)
  acme                     debug the ACME transactions
  cluster                  debug PKI cluster
  cmp                      debug the CMP transactions
  periodic-authentication  debug PKI peroidic authentication
  scep-proxy               debug the SCEP proxy
  trustpool                debug the trustpool
  <cr>
Log of "debug crypto ca acme 255" is the log attached to the first post.
Ok'
Asa domain1 is resolve to public IP which is reachable via CA
Other asa domain2/domain3 is resolve to private IP
Can you check if I am right
MHM
All three domains are resolved to a public IP.
 fqdn asa.domain1
 no ca-check
 crl configure
just asa.domain1 works
 fqdn asa.domain2
 subject-name CN=asa.domain2
 no ca-check
 crl configure
just asa.domain2 works
 fqdn asa.domain3
 subject-name CN=asa.domain3
 no ca-check
 crl configure
just asa.domain3 works
Every enrollment for a single domain is successful and has a debug log that looks like this:
Begin ACME PKCS#10 enrollment log
using BIND_ADDR4: 169.254.1.3
using BIND_ADDR6: fd00:0:0:1::3
debug level:      3
DEBUG:            --debug 1
timeout:          20
[Wed Aug 27 14:18:06 CEST 2025] Lets find script dir.
[Wed Aug 27 14:18:06 CEST 2025] _SCRIPT_='/asa/scripts/acme.sh'
[Wed Aug 27 14:18:06 CEST 2025] _script='/opt/cisco/csp/applications/cisco-asa.9.23.1.13__asa_001_............/app_bin/asa/scripts/acme.sh'
[Wed Aug 27 14:18:06 CEST 2025] _script_home='/opt/cisco/csp/applications/cisco-asa.9.23.1.13__asa_001_............/app_bin/asa/scripts'
[Wed Aug 27 14:18:06 CEST 2025] Using default home://.acme.sh
[Wed Aug 27 14:18:06 CEST 2025] Using config home:/var/acmesh/LetsEncrypt_Trustpoint/data
https://github.com/acmesh-official/acme.sh
v3.0.8
[Wed Aug 27 14:18:06 CEST 2025] Using server: https://acme-v02.api.letsencrypt.org:443/directory
[Wed Aug 27 14:18:07 CEST 2025] Running cmd: signcsr
[Wed Aug 27 14:18:07 CEST 2025] _csrsubj='asa.domain'
[Wed Aug 27 14:18:07 CEST 2025] _dnsAltnames='DNS:asa.domain'
[Wed Aug 27 14:18:07 CEST 2025] AltNames contains subject
[Wed Aug 27 14:18:07 CEST 2025] _excapedAlgnames='DNS:asa.domain'
[Wed Aug 27 14:18:07 CEST 2025] _escapedSubject='asa.domain'
[Wed Aug 27 14:18:07 CEST 2025] _csrdomainlist
[Wed Aug 27 14:18:07 CEST 2025] ECC CSR
[Wed Aug 27 14:18:07 CEST 2025] Using config home:/var/acmesh/LetsEncrypt_Trustpoint/data
[Wed Aug 27 14:18:07 CEST 2025] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org:443/directory'
[Wed Aug 27 14:18:07 CEST 2025] DOMAIN_PATH='/var/acmesh/LetsEncrypt_Trustpoint/certs/asa.domain_ecc'
[Wed Aug 27 14:18:07 CEST 2025] Copy csr to: /var/acmesh/LetsEncrypt_Trustpoint/certs/asa.domain_ecc/asa.domain.csr
[Wed Aug 27 14:18:07 CEST 2025] _main_domain='asa.domain'
[Wed Aug 27 14:18:07 CEST 2025] _alt_domains
[Wed Aug 27 14:18:07 CEST 2025] Using ACME_DIRECTORY: https://acme-v02.api.letsencrypt.org:443/directory
[Wed Aug 27 14:18:07 CEST 2025] _init api for server: https://acme-v02.api.letsencrypt.org:443/directory
[Wed Aug 27 14:18:07 CEST 2025] GET
[Wed Aug 27 14:18:07 CEST 2025] url='https://acme-v02.api.letsencrypt.org:443/directory'
[Wed Aug 27 14:18:07 CEST 2025] timeout=
[Wed Aug 27 14:18:07 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:08 CEST 2025] ret='0'
[Wed Aug 27 14:18:08 CEST 2025] ACME_KEY_CHANGE='https://acme-v02.api.letsencrypt.org/acme/key-change'
[Wed Aug 27 14:18:08 CEST 2025] ACME_NEW_AUTHZ
[Wed Aug 27 14:18:08 CEST 2025] ACME_NEW_ORDER='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Wed Aug 27 14:18:08 CEST 2025] ACME_NEW_ACCOUNT='https://acme-v02.api.letsencrypt.org/acme/new-acct'
[Wed Aug 27 14:18:08 CEST 2025] ACME_REVOKE_CERT='https://acme-v02.api.letsencrypt.org/acme/revoke-cert'
[Wed Aug 27 14:18:08 CEST 2025] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.5-February-24-2025.pdf'
[Wed Aug 27 14:18:08 CEST 2025] ACME_NEW_NONCE='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Wed Aug 27 14:18:08 CEST 2025] Using CA: https://acme-v02.api.letsencrypt.org:443/directory
[Wed Aug 27 14:18:08 CEST 2025] _on_before_issue
[Wed Aug 27 14:18:08 CEST 2025] _chk_main_domain='asa.domain'
[Wed Aug 27 14:18:08 CEST 2025] _chk_alt_domains
[Wed Aug 27 14:18:08 CEST 2025] Le_LocalAddress
[Wed Aug 27 14:18:08 CEST 2025] d='asa.domain'
[Wed Aug 27 14:18:08 CEST 2025] Check for domain='asa.domain'
[Wed Aug 27 14:18:08 CEST 2025] _currentRoot='/var/acmesh/acme_challenge'
[Wed Aug 27 14:18:08 CEST 2025] config file is empty, can not read CA_KEY_HASH
[Wed Aug 27 14:18:08 CEST 2025] Using config home:/var/acmesh/LetsEncrypt_Trustpoint/data
[Wed Aug 27 14:18:08 CEST 2025] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org:443/directory'
[Wed Aug 27 14:18:08 CEST 2025] _init api for server: https://acme-v02.api.letsencrypt.org:443/directory
[Wed Aug 27 14:18:08 CEST 2025] length='ec-256'
[Wed Aug 27 14:18:08 CEST 2025] Use length 256
[Wed Aug 27 14:18:08 CEST 2025] Using ec name: prime256v1
[Wed Aug 27 14:18:08 CEST 2025] Create account key ok.
[Wed Aug 27 14:18:08 CEST 2025] EC key
[Wed Aug 27 14:18:09 CEST 2025] config file is empty, can not read CA_EAB_KEY_ID
[Wed Aug 27 14:18:09 CEST 2025] config file is empty, can not read CA_EAB_HMAC_KEY
[Wed Aug 27 14:18:09 CEST 2025] config file is empty, can not read CA_EMAIL
[Wed Aug 27 14:18:09 CEST 2025] Registering account: https://acme-v02.api.letsencrypt.org:443/directory
[Wed Aug 27 14:18:09 CEST 2025] =======Begin Send Signed Request=======
[Wed Aug 27 14:18:09 CEST 2025] url='https://acme-v02.api.letsencrypt.org/acme/new-acct'
[Wed Aug 27 14:18:09 CEST 2025] payload='{"termsOfServiceAgreed": true}'
[Wed Aug 27 14:18:09 CEST 2025] HEAD
[Wed Aug 27 14:18:09 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Wed Aug 27 14:18:09 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g  -I  '
[Wed Aug 27 14:18:09 CEST 2025] _ret='0'
[Wed Aug 27 14:18:09 CEST 2025] POST
[Wed Aug 27 14:18:09 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-acct'
[Wed Aug 27 14:18:09 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:10 CEST 2025] _ret='0'
[Wed Aug 27 14:18:10 CEST 2025] code='201'
[Wed Aug 27 14:18:10 CEST 2025] Registered
[Wed Aug 27 14:18:10 CEST 2025] _accUri='https://acme-v02.api.letsencrypt.org/acme/acct/............'
[Wed Aug 27 14:18:10 CEST 2025] Calc CA_KEY_HASH='............'
[Wed Aug 27 14:18:10 CEST 2025] ACCOUNT_THUMBPRINT='............'
[Wed Aug 27 14:18:10 CEST 2025] Signing from existing CSR.
[Wed Aug 27 14:18:10 CEST 2025] Getting domain auth token for each domain
[Wed Aug 27 14:18:10 CEST 2025] d
[Wed Aug 27 14:18:10 CEST 2025] STEP 1, Ordering a Certificate
[Wed Aug 27 14:18:10 CEST 2025] =======Begin Send Signed Request=======
[Wed Aug 27 14:18:10 CEST 2025] url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Wed Aug 27 14:18:10 CEST 2025] payload='{"identifiers": [{"type":"dns","value":"asa.domain"}]}'
[Wed Aug 27 14:18:11 CEST 2025] POST
[Wed Aug 27 14:18:11 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Wed Aug 27 14:18:11 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:11 CEST 2025] _ret='0'
[Wed Aug 27 14:18:11 CEST 2025] code='201'
[Wed Aug 27 14:18:12 CEST 2025] Le_LinkOrder='https://acme-v02.api.letsencrypt.org/acme/order/............/............'
[Wed Aug 27 14:18:12 CEST 2025] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/............/............'
[Wed Aug 27 14:18:12 CEST 2025] STEP 2, Get the authorizations of each domain
[Wed Aug 27 14:18:12 CEST 2025] =======Begin Send Signed Request=======
[Wed Aug 27 14:18:12 CEST 2025] url='https://acme-v02.api.letsencrypt.org/acme/authz/............/............'
[Wed Aug 27 14:18:12 CEST 2025] payload
[Wed Aug 27 14:18:12 CEST 2025] POST
[Wed Aug 27 14:18:12 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/authz/............/............'
[Wed Aug 27 14:18:12 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:12 CEST 2025] _ret='0'
[Wed Aug 27 14:18:13 CEST 2025] code='200'
[Wed Aug 27 14:18:13 CEST 2025] d='asa.domain'
[Wed Aug 27 14:18:13 CEST 2025] Getting webroot for domain='asa.domain'
[Wed Aug 27 14:18:13 CEST 2025] _w='/var/acmesh/acme_challenge'
[Wed Aug 27 14:18:13 CEST 2025] _currentRoot='/var/acmesh/acme_challenge'
[Wed Aug 27 14:18:13 CEST 2025] _authz_url='https://acme-v02.api.letsencrypt.org/acme/authz/............/............'
[Wed Aug 27 14:18:13 CEST 2025] entry='"type":"http-01","url":"https://acme-v02.api.letsencrypt.org/acme/chall/............/............/............","status":"pending","token":"............"'
[Wed Aug 27 14:18:13 CEST 2025] token='............'
[Wed Aug 27 14:18:13 CEST 2025] uri='https://acme-v02.api.letsencrypt.org/acme/chall/............/............/............'
[Wed Aug 27 14:18:13 CEST 2025] keyauthorization='.........................'
[Wed Aug 27 14:18:13 CEST 2025] dvlist='asa.domain#.........................#https://acme-v02.api.letsencrypt.org/acme/chall/............/............/............#http-01#/var/acmesh/acme_challenge#https://acme-v02.api.letsencrypt.org/acme/authz/............/............'
[Wed Aug 27 14:18:13 CEST 2025] vlist='asa.domain#.........................#https://acme-v02.api.letsencrypt.org/acme/chall/............/............/............#http-01#/var/acmesh/acme_challenge#https://acme-v02.api.letsencrypt.org/acme/authz/............/............,'
[Wed Aug 27 14:18:13 CEST 2025] ok, let's start to verify
[Wed Aug 27 14:18:13 CEST 2025] Verifying: asa.domain
[Wed Aug 27 14:18:13 CEST 2025] wellknown_path='/var/acmesh/acme_challenge/.well-known/acme-challenge'
[Wed Aug 27 14:18:13 CEST 2025] writing token:............ to /var/acmesh/acme_challenge/.well-known/acme-challenge/............
[Wed Aug 27 14:18:13 CEST 2025] =======Begin Send Signed Request=======
[Wed Aug 27 14:18:13 CEST 2025] url='https://acme-v02.api.letsencrypt.org/acme/chall/............/............/............'
[Wed Aug 27 14:18:13 CEST 2025] payload='{}'
[Wed Aug 27 14:18:13 CEST 2025] POST
[Wed Aug 27 14:18:13 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall/............/............/............'
[Wed Aug 27 14:18:13 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:14 CEST 2025] _ret='0'
[Wed Aug 27 14:18:14 CEST 2025] code='200'
[Wed Aug 27 14:18:14 CEST 2025] trigger validation code: 200
[Wed Aug 27 14:18:14 CEST 2025] Lets check the status of the authz
[Wed Aug 27 14:18:14 CEST 2025] Pending, The CA is processing your order, please just wait. (1/30)
[Wed Aug 27 14:18:14 CEST 2025] sleep 2 secs to verify again
[Wed Aug 27 14:18:16 CEST 2025] checking
[Wed Aug 27 14:18:16 CEST 2025] =======Begin Send Signed Request=======
[Wed Aug 27 14:18:16 CEST 2025] url='https://acme-v02.api.letsencrypt.org/acme/authz/............/............'
[Wed Aug 27 14:18:16 CEST 2025] payload
[Wed Aug 27 14:18:17 CEST 2025] POST
[Wed Aug 27 14:18:17 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/authz/............/............'
[Wed Aug 27 14:18:17 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:17 CEST 2025] _ret='0'
[Wed Aug 27 14:18:17 CEST 2025] code='200'
[Wed Aug 27 14:18:17 CEST 2025] Success
[Wed Aug 27 14:18:17 CEST 2025] pid
[Wed Aug 27 14:18:17 CEST 2025] Debugging, skip removing: /var/acmesh/acme_challenge/.well-known
[Wed Aug 27 14:18:17 CEST 2025] No need to restore nginx, skip.
[Wed Aug 27 14:18:17 CEST 2025] _clearupdns
[Wed Aug 27 14:18:17 CEST 2025] dns_entries
[Wed Aug 27 14:18:17 CEST 2025] skip dns.
[Wed Aug 27 14:18:17 CEST 2025] Verify finished, start to sign.
[Wed Aug 27 14:18:17 CEST 2025] i='2'
[Wed Aug 27 14:18:17 CEST 2025] j='9'
[Wed Aug 27 14:18:17 CEST 2025] Lets finalize the order.
[Wed Aug 27 14:18:17 CEST 2025] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/............/............'
[Wed Aug 27 14:18:17 CEST 2025] =======Begin Send Signed Request=======
[Wed Aug 27 14:18:17 CEST 2025] url='https://acme-v02.api.letsencrypt.org/acme/finalize/............/............'
[Wed Aug 27 14:18:17 CEST 2025] payload='{"csr": "............"}'
[Wed Aug 27 14:18:18 CEST 2025] POST
[Wed Aug 27 14:18:18 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/finalize/............/............'
[Wed Aug 27 14:18:18 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:21 CEST 2025] _ret='0'
[Wed Aug 27 14:18:21 CEST 2025] code='200'
[Wed Aug 27 14:18:21 CEST 2025] Order status is valid.
[Wed Aug 27 14:18:21 CEST 2025] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/066f234b0fb37120b9bf3fb103fa4558160c'
[Wed Aug 27 14:18:21 CEST 2025] Downloading cert.
[Wed Aug 27 14:18:21 CEST 2025] =======Begin Send Signed Request=======
[Wed Aug 27 14:18:21 CEST 2025] url='https://acme-v02.api.letsencrypt.org/acme/cert/066f234b0fb37120b9bf3fb103fa4558160c'
[Wed Aug 27 14:18:21 CEST 2025] payload
[Wed Aug 27 14:18:22 CEST 2025] POST
[Wed Aug 27 14:18:22 CEST 2025] _post_url='https://acme-v02.api.letsencrypt.org/acme/cert/066f234b0fb37120b9bf3fb103fa4558160c'
[Wed Aug 27 14:18:22 CEST 2025] _CURL='curl --silent --dump-header /var/acmesh/LetsEncrypt_Trustpoint/data/http.header  -L  --cacert /etc/lina_roots/lina_roots.0.pem  -g '
[Wed Aug 27 14:18:22 CEST 2025] _ret='0'
[Wed Aug 27 14:18:22 CEST 2025] code='200'
[Wed Aug 27 14:18:22 CEST 2025] Found cert chain
[Wed Aug 27 14:18:22 CEST 2025] _end_n='22'
[Wed Aug 27 14:18:22 CEST 2025] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/066f234b0fb37120b9bf3fb103fa4558160c'
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
        Signature Algorithm: ecdsa-with-SHA384
        Issuer: C = US, O = Let's Encrypt, CN = E7
        Validity
            Not Before: Aug 27 11:19:48 2025 GMT
            Not After : Nov 25 11:19:47 2025 GMT
        Subject: CN = asa.domain
        Subject Public Key Info:
            Public Key Algorithm: id-ecPublicKey
                Public-Key: (384 bit)
                pub:
                ASN1 OID: secp384r1
                NIST CURVE: P-384
        X509v3 extensions:
            X509v3 Key Usage: critical
                Digital Signature
            X509v3 Extended Key Usage:
                TLS Web Server Authentication, TLS Web Client Authentication
            X509v3 Basic Constraints: critical
                CA:FALSE
[Wed Aug 27 14:18:22 CEST 2025] Cert success.
-----BEGIN CERTIFICATE-----
MII............
-----END CERTIFICATE-----
[Wed Aug 27 14:18:22 CEST 2025] Your cert is in: /var/acmesh/LetsEncrypt_Trustpoint/certs/asa.domain_ecc/asa.domain.cer
[Wed Aug 27 14:18:22 CEST 2025] The intermediate CA cert is in: /var/acmesh/LetsEncrypt_Trustpoint/certs/asa.domain_ecc/ca.cer
[Wed Aug 27 14:18:22 CEST 2025] And the full chain certs is there: /var/acmesh/LetsEncrypt_Trustpoint/certs/asa.domain_ecc/fullchain.cer
[Wed Aug 27 14:18:23 CEST 2025] _on_issue_success
ACME client exit code: 0
End ACME PKCS#10 enrollment log
PKI ACME[7]: END LOG BUF:
PKI ACME[8]: BEGIN OUTPUT BUF
{"ERROR_CODE":0,"CERT_CHAIN_PEM_TXT":"-----BEGIN CERTIFICATE-----\nMII............\n-----END CERTIFICATE-----"}
PKI ACME[8]: END OUTPUT BUF:
PKI ACME[7]: ERROR_CODE 0. Success
PKI ACME[7]: Certificate chain:
MII............
MII............
PKI ACME[7]: ACME_Enroll() returns 0
PKI ACME[7]: Verifying ACME certificate path.
PKI ACME[7]: Verifying ACME cert chain
PKI ACME[7]: Certificate path verified
PKI ACME[7]: trust_point->router_cert_issued = TRUE
PKI ACME[7]: ACME enrollment certificate has been granted by CA
So it is definitly an error with multiple domains and/or 20 seconds timeout.
balaji.bandi
check this document and see any limitation of multidomain.
https://www.cisco.com/c/en/us/support/docs/security/secure-firewall-asa/222809-configure-certificate-enrollment-with-ac.html
check if you can do multi trust point different trust point with different domain (never tested my self just an idea)
the document provides troubleshooting tips.
BB
=====ļ•‰ļø Preenayamo Vasudevam ļ•‰ļø=====
