WSA, ISE, with HTTPS
irissen
Visitor
I have an WSA S170 (Async 9), ISE (v2.0), Active Directory, WCCP router, no CDA server
With HTTP traffic, I believe it is doable for transparent authentication (WSA > ISE)
However for HTTPS traffic, whereby the WSA should have a browser prompt for user login after enabling HTTPS Proxy, does the WSA also contact the ISE to authenticate users? Or does it need to have integration with AD by itself, directly?
I am trying to avoid the case of WSA contacting AD as it uses SMBv1
Thanks in advance
11 Replies 11
balaji.bandi
WSA S170
This is the end of life last year, I do not believe anything broken cisco can support
(Async 9),
stable release and TAC support were 13. X or 14. is the latest, so you need to look at some features that may be not work as expected.
WSA can use ISE for user authentication - but there is some minimum requirements to be in place :
for reference check the below guide :
https://www.cisco.com/c/en/us/products/collateral/security/web-security-appliance/guide-c07-741637.html
BB
thanks, sorry the versions are quite old and out of support.
when you say some features may not work as expected, is there an experience or issue that was known?
also concerned that with the old versions, is it feasible at all?
its been Long time worked on WSA aysnc 9.
Please check the configuration guide : (its possible for radius authentication)
https://www.cisco.com/c/dam/en/us/td/docs/security/wsa/wsa9-0/WSA_9-0-0_UserGuide.pdf
BB
okay thanks
@irissen if WSA and ISE are integrated using pxGrid, then the WSA has the user information (user/ip binding) to authenticate the users without prompting.
thanks, does this mean WSA can run solely off the integration with ISE, without the need to create any realms for AD?
@irissen as per the guide below, WSA obtains ISE (user/IP mappings) and AD group information for authenticated users from ISE using ERS.
https://www.cisco.com/c/en/us/products/collateral/security/web-security-appliance/guide-c07-741637.pdf
Hi @irissen
I am referring form userguide 14.0 but that could be the same
Kindly notice that
User Guide for AsyncOS 14.0 for Cisco Web Security Appliances - GD (General Deployment)
page 88
under section : Identifying Users Transparently
[1] When you configure an Identification Profile to transparently identify users, the authentication surrogate must be IP address. You cannot select a different surrogate type.
[2] From identification profile on the policies which are sets to authenticate users please select “Transparently identify users with authentication realms”
this is the latest version of ISE and WSA compatibility Matrix, maybe it help you to decide clearly regarding the upgrade plan
ISE Compatibility Matrix for Secure Web Appliance - Cisco
++++   If you find this answer helpful, please rate it as such  ++++
Amirhossein Mojarrad
hi amojarra,
i think my version does not have this option.. for authentication realms are given as Kerberos and LDAP only. ISE is a separate section by itself. Asked my question specifically for Async 9.0, as I am in a situation with no possible means to upgrade 😞
thanks Rob
if directly reading from the diagram, WSA should purely rely on ISE for identifying user-IP mappings.
I guess the next question would be.. does the ISE also use SMBv1 to connect with AD?
Hi @irissen
Thanks for the reply
It is so sad that you can not upgrade at this moment, hope things gets well soon 🙂
According to the user guide : User Guide for AsyncOS 9.0 for Cisco Web Security Appliances - LD (Limited Deployment)
page 132 E-Book, there is an option :  Fallback to Authentication Realm or Guest Privileges
If you have another Realm with AD and this option is configured to use that realm, then WSA will try connect to AD if Auth failed with ISE.
For ISE V2.0, what I can see in Active Directory Integration with Cisco ISE 2.x - Cisco under section "Network Ports That Must Be Open for Communication" ISE is using MSRPC instead of SMB.
from release note : Cisco Identity Services Engine Administrator Guide, Release 2.0 page 225 E-book :
Cisco ISE 1.3 and above support SMB 2.0.
