ā08-02-2021 11:13 PM
We wanted to add users to webex control hub but there is a error that says the domain of the user doesnt match any of your claimed or verified domains, but we have been using that domain to create account for users until now. Below attached screenshot is error
Solved! Go to Solution.
ā08-03-2021 01:55 AM
Follow below process when adding users.
For verifying the domains Refer link shared by @Shalid Kurunnan Chalil .
ā08-03-2021 12:04 AM
Check if the user has free webex account created with [email protected].
If yes, refer below link.
https://help.webex.com/en-us/ndta402/Add-a-User-with-Existing-Free-Webex-Account
ā08-03-2021 12:20 AM
ā08-03-2021 12:54 AM
Yes, this is definitely a reason. you cannot add a domain user until you claim and verify that domain from your control hub.
you can refer the following link to complete the verification / claiming.
ā08-02-2021 11:57 PM
check if the user created any free account or not. you can try deleting the user and try adding the user again.
are you using directory sync or configuring manually?
ā08-03-2021 12:13 AM
ā08-03-2021 12:51 AM
you can try the link provided by @Nithin Eluvathingal
or you browse the URL:: https://help.webex.com/en-us/yjrmmp/Webex-Delete-Your-Free-Account
