adding user to webex control hub
Tesfaye41175
We wanted to add users to webex control hub but there is a error that says the domain of the user doesnt match any of your claimed or verified domains, but we have been using that domain to create account for users until now. Below attached screenshot is error
Follow  below  process when adding users.
For verifying the domains Refer link shared by @Shalid Kurunnan Chalil .
Response Signature
7 Replies 7
Check if the user has free webex account created with [email protected].
If yes, refer below link.
https://help.webex.com/en-us/ndta402/Add-a-User-with-Existing-Free-Webex-Account
Response Signature
They said they dont have free account and also domain ienetworksolutions,com says pending it doesnt say claimed could that be the problem. this is the screenshot.
Response Signature
Yes, this is definitely a reason. you cannot add a domain user until you claim and verify that domain from your control hub.
you can refer the following link to complete the verification / claiming.
https://help.webex.com/en-us/cd6d84/Manage-Your-Domains#Cisco_Task.dita_01123578-ddcb-41d5-9bce-df3af6045e8b
check if the user created any free account or not. you can try deleting the user and try adding the user again.
are you using directory sync or configuring manually?
No I am configuring manually, how do i check if the user created any free account and also one thing i didnt mention the domain says pending it doesnt say claimed.
you can try the link provided by @Nithin Eluvathingal
or you browse the URL:: https://help.webex.com/en-us/yjrmmp/Webex-Delete-Your-Free-Account
