After migrating to Webex Control Hub I can not manage basic templates
mmaiug
As the title say, I can add and remove general templates for the specific groups, I can also create specific templates to be used when creating the meeting by a user, but I cannot remove old templates from the standard meeting templates pool that appears when a user creates a meeting. The online solutions point to site administration webpage but once migrated to control hub this feature is not there. Anybody else has solve these issues?
Kathy N.
@mmaiug, the navigation @rikardkrvaric shared will get you to the correct place.  Here's a screenshot showing where message template management is located once you're on that site in Control Hub.
Response Signature
rikardkrvaric
In Control Hub, Under Services > Meetings > Select your Meeting Org, then...
You have access to lots of Settings here, specifically to your Meetings Platform.
Can you take a look here?
