Control Hub Agent Wrap time
Neil B
When using Control Hub (NOT Contact Center) to manage Queues & Agents:
  1. What is the default Wrap-up Time for Agents?
  2. How/where can the Wrap-up Time be edited or changed?
5 Replies 5
Answer still relevant, not Contact Center, just Webex Call Queue wrapuptime settings guideline.
maxmeisel
Level 4
Level 4
I'm also looking for settings in the Calling & Customer Experience setting to set the wrap-up time for the agents, but there is nothing to find in configuration or in documentation as of now. I assume it is not feasible, also didn't see anything on the roadmap to get this setting implemented.
I have the same question. Was this ever answered?
MicahP
Log in to the customer organization at https://admin.webex.com/.
Navigate to Services > Contact Center > Settings > Desktop.
In the Agent Experience section, enter the automatic wrap-up value in milliseconds in the Auto Wrapup Interval field. After you set the Auto Wrapup Interval, the Agent Desktop wraps up automatically after an agent ends a conversation. Consider this setting only if the Auto Wrap Up With Time Out Of <value> is not defined in an agent profile in the Management Portal (Provisioning > Agent Profiles > Auxiliary Codes).
The following table shows the default value and the allowed range for the automatic wrap-up interval:
Default Value (milliseconds) Minimum Value (milliseconds) Maximum Value (milliseconds)
60000 (1 minute)
600000 (10 minutes)
By default, the automatic wrap-up value is 0 milliseconds, indicating that the wrap-up time is not configured. The administrator must define the automatic wrap-up value.
In my original post I was clear that I am not looking for a Contact Center solution....we use Control Hub Auto Attendants & Queues.
Does your solution also apply to Control Hub, or is it limited just to Contact Center?
