01-28-2020 11:56 PM
On a WebEx Meetings site that has SSO enabled, can we hide the option to login with a WebEx-ID and just only have the Office 365 login visible? (this site is managed in control hub)
Erik
Solved! Go to Solution.
01-29-2020 07:55 PM
Yes, for the button to disappear please uncheck "Sign In" under third party integration for 365. Please follow the article where you can find that setting in admin portal.
01-29-2020 03:06 AM
Please verify if 365 sign in is enabled for user for your site, in the admin portal. This is under common site setting>third party integration.
https://help.webex.com/en-us/k6j1db/Configure-Third-Party-Integrations-on-a-Webex-Site
01-29-2020 03:10 AM
As you can see from the screenshot, 365 login IS working fine, no problem with that.
We want to HIDE/DISABLE the WebEx login and only have the 365 login available. Possible?
Erik
02-07-2020 08:02 AM
Hi. I have the same question but do not see the solution. If I uncheck the box then the O365 login goes away. Were you able to figure this out?
01-29-2020 07:55 PM
