Hotspot Issue
lea.s
i am trying to connect to webex using Hotspot and i am not being able to login or connect to my meetings.
i live in a country with bad Wifi connection and usually i used to connect through Hotspot without any complications.
please advise
GavinW
Are you able to connect via ethernet instead?
or maybe get closer to the access point?
Kathy N.
Open a browser and try this SPEED TEST when you're connected to the MiFi.  It will help you check your connection to the internet from the MiFi which might help you identify the problem.  Speeds with MiFi's can change with configuration changes by the provider so good service in the past doesn't always guarantee good service in the future.  If you notice a degradation of service, contact your provider for help.
Response Signature
mgrabek
DO you know what speeds on the Mifi you have ?
