How can i get mediatest result on terminal ?
abner.magalhaes
Hello everyone, in advance I appreciate any help.
 I would like to monitor the results obtained at https://mediatest.ciscospark.com/#/main and integrate them with my zabbix platform that I have in the company.
 Is there an api, any query via get that I can receive the information that https://mediatest.ciscospark.com/#/main brings?
Stoyan Stoitsev
Level 8
Level 8
There is a similar functionality coming to Webex Control Hub that will display network quality to Webex. It will require you to install an agent on a Windows server or a PC in your network. I am not aware if there will be APIs to poll this data initially.
Stoyan Stoitsev
Level 8
Level 8
Thanks for your help. If it had an api it would be better because all monitoring would be integrated in one place, but unfortunately it does not. Thank you very much anyway :)
