01-17-2022 11:03 AM
Why does Webex activate the desktop microphone when not in use? It does this many times throughout the day. I simply can not allow this to occur given the nature of my employment.
01-17-2022 11:09 AM
It is because it listens for ultrasound from video devices. You can disable this from settings in the Webex application, “Use Ultrasound”.
01-17-2022 11:13 AM
just keep in mind, if you disable this setting it will no longer be able to auto-detect you are in the room and pair to the room device and you may want to try using Wifi based detection instead. Administration - Manage Wi-Fi Discovery of Cisco Webex Devices
01-17-2022 11:25 AM
For sure. I’m well aware, just giving the OP an explanation on why this happens on a regular basis. Another option would be to enable Use Ultrasound when needed, ie when you have a need to connect with a video device.
01-17-2022 02:43 PM
