Verify Custom Branding image on Webex boards
Does cisco have a way to verify if a custom background has been loaded on to a cisco Webex board? 55s and 70
The only option I have is to ask end users to "check" and see if the image is correct about 50 end users. I went through and did the upload under the branding section in settings for all devices.
My thoughts are there is a way to remote into the boards Admin page and see if the file is stored somewhere on there.
Thanks in advance
Mike_Brezicky
In the Web Admin, if you go to Maintenance > User Interface Screenshots. Take a screenshot of the OSD in half awake state and you can see the branding images.
cpeebles_hms
I'm late to the party on this one, but another way you can approach this (when you want to do one-off changes) is:
Within Control Hub > Devices > Device Web Portal
Under Personalization, you can see what's currently visible on your displays/touch pads for that particular device.
Mike_Brezicky
Thank you that is exactly what I was looking for Mike!
