Webex Calling Local Gateway DNS & Import DigiCert
joseivan_11
Hi Community,
I have a question about the DNS configured in the local gateway.
I want to know if it is mandatory to configure google DNS (8.8.8.8) or can it be the company's own DNS?
The question arises because I could not import the Digicert certificate in the local gateway (http://www.cisco.com/security/pki/trs/ios_core.p7b), and I do not know if it is due to a DNS or permissions issue in the network.
VGW-B(config)#crypto pki trustpool import clean url http://www.cisco.com/security/pki/trs/ios_core.p7b
% Error: failed to open file.
% No certificates imported from http://www.cisco.com/security/pki/trs/ios_core.p7b.
The company's DNS solves the domain of cisco.com without any problem, and they tell me that they have already validated the information regarding the permissions or port requirements for correct operation (https://help.webex.com/en-us/b2exve/Port-Reference-Information-for-Cisco-Webex-Calling).
VGW-B#ping cisco.com
Sending 5, 100-byte ICMP Echos to 72.163.4.185, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 41/41/42 ms
VGW-B#sh ip dns servers
IP VRF TTL(s) RTT(ms) RTO(ms) EDNS DNSSEC RECURSION
10.210.160.4 125 1698 1698 No Yes Yes
10.210.160.6 126 1667 1667 No Yes Yes
8.8.8.8 expired rto 120000
VGW-B#
Best Regards
You should be able to use any DNS service as long as it can resolve the external records needed.
Response Signature
Response Signature
jsuarez_
You must have configured IP domain-lookup.
inderdeeps
Level 4
Level 4
@joseivan_11 : no it’s not mandatory to configure google DNS. I would say go with Cisco Umbrella DNS.
