webex - change hardware during upgrade
m.cucchi
Hello Guys,
I need to perform an upgrade of webex starting from  2.8.1.1034.B-AE  (what version is ? 2.8.1 MR1 patch1 ?) version to 4.0.
i have seen in the documentation that i need to make un update to 2.8MR3 patch3 and then make to upgrade to 4.0, creating and adding a multi data center architecture.
But the hardware in this moment used is two server C220 M3 with few disk space and i need an hardware with at least 2.5 TB.
I though to buy other 4 server MC220 M5 to install a webex VM but how i can upgrade with hardware change ?
i though this procedure:
1) upgrade to 2.8M3 patch3 in production hardware
2) move the VM to new hardware
3) upgrade to 4.0 in new hardware.
4) create another data center with version 4.0 in other hardware
5) update both to 4.0 MR1
6) install license feature (for multi data center) on primary data center
6) create a Multi data center
What do you think ?
there are some tips to do that ?
Any suggestion is appreciate.
Max
0 Replies 0
