09-24-2019 12:29 PM
Hi - a user recently came to me with the following (we're on Webex locked down version 33.6.7.8):
Any recommendations, or will this be built into a future Webex version? All I've been able to find on the Cisco Collab Help site so far is this: https://help.webex.com/en-us/WBX57619/What-is-the-Recommended-Screen-Resolution-for-Optimal-Viewing-in-a-Webex-Meeting
07-15-2022 07:33 AM
07-05-2022 03:55 AM - edited 07-05-2022 04:01 AM
I am using a 42 inch 4K monitor, and need to turn it down to FullHD to be able to share anything with anyone. It's going on since years and no improvement. Please what is this?
I just read Cisco's KB article about the optimal sharing resolution and they suggest changing it before sharing. Is it supposed to be a joke? No other vendor of similar software requires its users to do such things. Unbelievable.
12-11-2021 07:50 AM
Here's a solution until WebEx can support this natively: https://github.com/tom-englert/RegionToShare
10-07-2021 09:03 AM
I've seen this issue before, also.
10-05-2021 12:00 AM
Yup same issue, has anyone got a good workaround for the moment? I have a 34" ultrawide on a MacBook pro. I normally have Google Chrome opened on the right side of the screen and meeting notepad opened on the left half of the screen. I only want to share just the google chrome app, but when I do this with WebEx, the viewer sees whitespace on the left side of the screen. Any help here would be great!
08-23-2021 01:01 AM
Have the same issue..
06-08-2021 07:24 AM
Thanks, have voted !
01-29-2021 10:00 AM
Submit your ideas and feature requests here:
https://ciscocollabcustomer.ideas.aha.io/
Cisco is unlikely to read/respond to all discussions in this community forum.
02-03-2021 10:29 AM - edited 02-03-2021 10:59 AM
Thanks good idea. I've posted it now, please help vote it up!
Allow screen scaling for super | User Community Feedback (aha.io)
01-28-2021 06:08 AM
Please Cisco. Fix this issue. Ultrawide monitors are becoming common. Find a way to effectively share a screen with an ultrawide.
06-15-2020 06:56 AM
I have the Dell U4919DW and it outputs a 5140x1440 resolution.
I have been having the same issue. The only workaround I have found is to switch the resolution of the monitor to 1920x1080 when I am sharing my screen. I use the DisplayFusion software to have a different monitor profile saved and assigned to a hot-key to switch the resolution. Not great, I know, but at least I can switch instantly instead of going through the windows display manager.
Dear Cisco: If you are reading this, can you add an option for sharing where; WebEx asks what Application you want to share, asks if you want to lock the resolution of it, that brings up a drop list of common sizes (like 1920x1080), then it resizes the window on your screen and locks it at that resolution, and you share only that application/window without all the extra black space around it?
@jlunser, Good Luck!
Monitor Link: https://www.dell.com/en-us/work/shop/dell-ultrasharp-49-curved-monitor-u4919dw/apd/210-arnw/monitors-monitor-accessories
DisplayFusion Link: https://www.displayfusion.com/
01-20-2021 02:42 PM - edited 01-20-2021 02:46 PM
Re:
Yes, this needs to be an option in WebEx when sharing applications!
11-03-2020 05:51 AM
Thank you!
@cisco: Please fix this asap. It is a huge pain for presentations and all competitors offer this; MS Teams, Zoom, etc ....
11-21-2020 01:17 AM
Yes, please fix. This is actually ridiculous. Even if I understand the design behind it, please give at least a possibility to choose what we want.
06-09-2020 03:59 AM
I use a large screen as well. While it is obviously not possible to share just a part of it, the problem appears also when I share a window (of small size). The participants complain that it appears really small (too small to read). I don't understand why the overall screen size influences the scaling of the actually shared window... No problems with Teams, Skype for Business.
01-08-2020 04:53 PM
I just got the Dell 49” curved monitor and this is how I work around this issue. On the monitor, I enabled the mode to split the screen so my laptop HDMI input was on one side. I connected the USB-C input from the monitor to my laptop (same laptop) so it uses the other side of the monitor. Webex sees two screens for the purpose of sharing, so I can share just the one side and it looks fine to the audience. The cool part is that Windows sees both inputs together as essentially one seamless screen. So I can move apps from one side to the other or just use the whole monitor. Best of both worlds.
04-07-2020 10:36 AM
@Cynthia F
as I read "Dell" in your posting... that reminds me of the "Dell Display Manager" - a utility to manage the space of large Screens.
https://www.dell.com/support/article/en-us/qna44541/what-is-dell-display-manager?lang=en
This software helps to auto-resize and auto-arrange application-windows.
In case this software does this trick by creating "fake" / virtual screens, this might work.
But: this software requires a DELL-Screen:
Q. Does Dell Display Manager work on all brands of Monitors?
A. DDM works only with Dell monitors developed from 2013 and beyond, except Dell D-series and Nvidia G-SYNC based models.
Fritz
12-06-2019 12:10 AM - edited 12-06-2019 12:10 AM
have you find a "workaround"?
12-11-2021 07:57 AM
09-27-2019 09:17 AM
It is not possible to crop window for screen sharing. I have used Webex sharing on 1920x1080 resolution and no one complained so far.
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
